[PATCH 2/3] tester: Remove target from BSP coverage configs
Alex White
alex.white at oarcorp.com
Wed Mar 10 18:56:11 UTC 2021
tester/rt/coverage.py | 3 ++-
tester/rtems/testing/bsps/griscv-sis-cov.ini | 1 -
tester/rtems/testing/bsps/leon3-qemu-cov.ini | 1 -
tester/rtems/testing/bsps/leon3-sis-cov.ini | 1 -
4 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index 0f225a9..e2a5161 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -380,11 +380,12 @@ class coverage_run(object):
self.no_clean = int(self.macros['_no_clean'])
self.report_format = self.macros['cov_report_format']
self.symbol_set = symbol_set
- self.target = self.macros['target']
+ self.target = self.macros['arch']
self.bsp_name = self.macros['bsp'].split('-')[0]
self.prefix = prefix
self.macros.define('coverage')
self.covoar_cmd = self.macros.expand(self.macros['bsp_covoar_cmd'])
+ self.covoar_cmd += ' -T ' + self.macros['arch'] + '-rtems' + str(version.version())
def run(self):
try:
diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
index 7249af6..9ab37a8 100644
--- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
+++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
@@ -35,7 +35,6 @@
bsp = griscv-sis
arch = riscv
tester = %{_rtscripts}/run.cfg
-target = riscv-rtems5
bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
index 3b183e6..2d319f0 100644
--- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
+++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
@@ -34,7 +34,6 @@
[leon3-qemu-cov]
bsp = leon3-qemu
arch = sparc
-target = sparc-rtems5
tester = %{_rtscripts}/qemu.cfg
bsp_qemu_opts = %{qemu_opts_base} %{qemu_opts_serial} -M leon3_generic
bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini b/tester/rtems/testing/bsps/leon3-sis-cov.ini
index 626d314..d8ffe28 100644
--- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
+++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
@@ -35,7 +35,6 @@
bsp = leon3-sis
arch = sparc
bsp_run_opts = -leon3 -nouartrx -r -tlim 200 s -cov
2.27.0
