[PATCH] shell.c: Dereference after null check (CID #26083)
Ryan Long
ryan.long at oarcorp.com
Wed Mar 10 19:10:07 UTC 2021
CID 26083: Dereference after null check in rtems_shell_login().
Closes #4327
cpukit/libmisc/shell/shell.c | 196 ++++++++++++++++++++++---------------------
1 file changed, 99 insertions(+), 97 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 1e5962b..b724b1d 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -683,109 +683,111 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
int c;
time_t t;
- if (out) {
- if ((env->devname[5]!='p')||
- (env->devname[6]!='t')||
- (env->devname[7]!='y')) {
- fd = fopen("/etc/issue","r");
- if (fd) {
- while ((c = fgetc(fd)) != EOF) {
- if (c=='@') {
- switch (c = fgetc(fd)) {
- case 'L':
- fprintf(out,"%s", env->devname);
- break;
- case 'B':
- fprintf(out,"0");
- break;
- case 'T':
- case 'D':
- time(&t);
- fprintf(out,"%s",ctime(&t));
- break;
- case 'S':
- fprintf(out,"RTEMS");
- break;
- case 'V':
- fprintf(
- out,
- "%s\n%s",
- rtems_get_version_string(),
- rtems_get_copyright_notice()
- break;
- case '@':
- fprintf(out,"@");
- break;
- default :
- fprintf(out,"@%c",c);
- break;
- } else if (c=='\\') {
- switch(c=fgetc(fd)) {
- case '\\': fprintf(out,"\\"); break;
- case 'b': fprintf(out,"\b"); break;
- case 'f': fprintf(out,"\f"); break;
- case 'n': fprintf(out,"\n"); break;
- case 'r': fprintf(out,"\r"); break;
- case 's': fprintf(out," "); break;
- case 't': fprintf(out,"\t"); break;
- case '@': fprintf(out,"@"); break;
- } else {
- fputc(c,out);
+ if (out == NULL) {
+ return false;
+ if ((env->devname[5]!='p')||
+ (env->devname[6]!='t')||
+ (env->devname[7]!='y')) {
+ fd = fopen("/etc/issue","r");
+ if (fd) {
+ while ((c = fgetc(fd)) != EOF) {
+ if (c=='@') {
+ switch (c = fgetc(fd)) {
+ case 'L':
+ fprintf(out,"%s", env->devname);
+ break;
+ case 'B':
+ fprintf(out,"0");
+ break;
+ case 'T':
+ case 'D':
+ time(&t);
+ fprintf(out,"%s",ctime(&t));
+ break;
+ case 'S':
+ fprintf(out,"RTEMS");
+ break;
+ case 'V':
+ fprintf(
+ out,
+ "%s\n%s",
+ rtems_get_version_string(),
+ rtems_get_copyright_notice()
+ break;
+ case '@':
+ fprintf(out,"@");
+ break;
+ default :
+ fprintf(out,"@%c",c);
+ break;
+ } else if (c=='\\') {
+ switch(c=fgetc(fd)) {
+ case '\\': fprintf(out,"\\"); break;
+ case 'b': fprintf(out,"\b"); break;
+ case 'f': fprintf(out,"\f"); break;
+ case 'n': fprintf(out,"\n"); break;
+ case 'r': fprintf(out,"\r"); break;
+ case 's': fprintf(out," "); break;
+ case 't': fprintf(out,"\t"); break;
+ case '@': fprintf(out,"@"); break;
+ } else {
+ fputc(c,out);
- fclose(fd);
- } else {
- fd = fopen("/etc/issue.net","r");
- if (fd) {
- while ((c=fgetc(fd))!=EOF) {
- if (c=='%') {
- case 't':
- break;
- case 'h':
- fprintf(out,"0");
- break;
- case 'D':
- fprintf(out," ");
- break;
- case 'd':
- time(&t);
- break;
- case 's':
- break;
- case 'm':
- fprintf(out,"(" CPU_NAME "/" CPU_MODEL_NAME ")");
- break;
- case 'r':
- fprintf(out,rtems_get_version_string());
- break;
- case 'v':
- fprintf(
- out,
- "%s\n%s",
- break;
- case '%':fprintf(out,"%%");
- break;
- default:
- fprintf(out,"%%%c",c);
- break;
- } else {
- fputc(c,out);
+ fclose(fd);
+ } else {
+ fd = fopen("/etc/issue.net","r");
+ if (fd) {
+ while ((c=fgetc(fd))!=EOF) {
+ if (c=='%') {
+ case 't':
+ break;
+ case 'h':
+ fprintf(out,"0");
+ break;
+ case 'D':
+ fprintf(out," ");
+ break;
+ case 'd':
+ time(&t);
+ break;
+ case 's':
+ break;
+ case 'm':
+ fprintf(out,"(" CPU_NAME "/" CPU_MODEL_NAME ")");
+ break;
+ case 'r':
+ fprintf(out,rtems_get_version_string());
+ break;
+ case 'v':
+ fprintf(
+ out,
+ "%s\n%s",
+ break;
+ case '%':fprintf(out,"%%");
+ break;
+ default:
+ fprintf(out,"%%%c",c);
+ break;
+ } else {
+ fputc(c,out);
- fclose(fd);
+ fclose(fd);
1.8.3.1
