[PATCH 0/3] tester: Update coverage configs
Gedare Bloom
gedare at rtems.org
Wed Mar 10 22:51:01 UTC 2021
This series looks fine to me. Thanks for figuring out how to drop the
'target' variable.
On Wed, Mar 10, 2021 at 11:56 AM Alex White <alex.white at oarcorp.com> wrote:
> This patch set updates symbol-sets.ini to work with the paths used by
> the new build system, removes the need for "target" in the BSP
> configurations that include coverage, and adds a few new
> coverage-enabled BSP configurations.
> Alex White (3):
> tester: Update to support new build system
> tester: Remove target from BSP coverage configs
> tester: Add coverage variants for a few BSPs
> tester/rt/coverage.py | 3 +-
> .../rtems/testing/bsps/a53_lp64_qemu-cov.ini | 40 ++++++++
> tester/rtems/testing/bsps/griscv-sis-cov.ini | 1 -
> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 1 -
> tester/rtems/testing/bsps/leon3-sis-cov.ini | 1 -
> tester/rtems/testing/bsps/pc-qemu-cov.ini | 41 +++++++++
> .../testing/bsps/xilinx_zynq_a9_qemu-cov.ini | 40 ++++++++
> .../bsps/xilinx_zynqmp_lp64_qemu-cov.ini | 40 ++++++++
> tester/rtems/testing/coverage/symbol-sets.ini | 91 ++++++++++---------
> 9 files changed, 209 insertions(+), 49 deletions(-)
> create mode 100644 tester/rtems/testing/bsps/a53_lp64_qemu-cov.ini
> create mode 100644 tester/rtems/testing/bsps/pc-qemu-cov.ini
> create mode 100644 tester/rtems/testing/bsps/xilinx_zynq_a9_qemu-cov.ini
> create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_lp64_qemu-cov.ini
> 2.27.0
> devel mailing list
> devel at rtems.org
