RSB build breaks
Chris Johns
chrisj at rtems.org
Thu Mar 11 05:56:51 UTC 2021
On 11/3/21 4:38 pm, Vijay Kumar Banerjee wrote:
> Hello,
> After fixing the logical error in the parser, it exposed another issue that's
> causing RSB to break. Strange that it was hidden for so long.
> I have filed a ticket with details: http://deveone linel.rtems.org/ticket/4335
> <http://devel.rtems.org/ticket/4335>
> The fix is on the way and will be posted soon by Ricardo from Gemini software.
> This is going to be another one-line fix with the if checkers. The build breaks
> at rtems-gdb-10.cfg.
> Sorry for not checking the build before. Since this patch was posted to branch 5
> as well, the fix needs to be posted there as well.
All ok and thank you for following this up.
