[PATCH] score: Add Thread_Configuration::cpu_time_budget
Fri Mar 12 07:34:28 UTC 2021
Move the CPU time budget to the thread configuration.  This simplifies
_Thread_Initialize().
 cpukit/include/rtems/posix/pthreadimpl.h | 26 +++++++-------
 cpukit/include/rtems/score/threadimpl.h  |  5 +++
 cpukit/posix/src/psxtransschedparam.c    | 23 +++++++------
 cpukit/posix/src/pthreadcreate.c         |  3 +-
 cpukit/posix/src/pthreadsetschedparam.c  | 44 +++++++++---------------
 cpukit/score/src/threadinitialize.c      | 18 +---------
 6 files changed, 49 insertions(+), 70 deletions(-)
diff --git a/cpukit/include/rtems/posix/pthreadimpl.h b/cpukit/include/rtems/posix/pthreadimpl.h
index 52d462ab6f..723b20e8d2 100644
--- a/cpukit/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/include/rtems/posix/pthreadimpl.h
@@ -77,24 +77,24 @@ int _POSIX_Thread_Translate_to_sched_policy(
- * @brief Translate sched_param into SuperCore terms.
+ * @brief Translates the POSIX scheduling policy and parameters to parts of the
+ *   thread configuration.
- * This method translates the POSIX API sched_param into the corresponding
- * SuperCore settings.
+ * @param policy is the POSIX scheduling policy.
- * @param[in] policy is the POSIX scheduling policy
- * @param[in] param points to the scheduling parameter structure
- * @param[in] budget_algorithm points to the output CPU Budget algorithm
- * @param[in] budget_callout points to the output CPU Callout
+ * @param param is the pointer to the POSIX scheduling parameters.
- * @retval 0 Indicates success.
- * @retval error_code POSIX error code indicating failure.
+ * @param[out] config is the pointer to a thread configuration to set the
+ *   budget algorithm, callout, and CPU time budget.
+ * @retval 0 The operation was successful.
+ * @retval EINVAL The POSIX scheduling policy or parameters were invalid.
 int _POSIX_Thread_Translate_sched_param(
-  int                                  policy,
-  const struct sched_param            *param,
-  Thread_CPU_budget_algorithms        *budget_algorithm,
-  Thread_CPU_budget_algorithm_callout *budget_callout
+  int                       policy,
+  const struct sched_param *param,
+  Thread_Configuration     *config
 RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate(void)
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 1e7d58609f..d9c0779b08 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -163,6 +163,11 @@ typedef struct {
   Thread_CPU_budget_algorithm_callout budget_callout;
+   * @brief The thread's initial CPU time budget.
+  uint32_t cpu_time_budget;
    * @brief 32-bit unsigned integer name of the object for the thread.
diff --git a/cpukit/posix/src/psxtransschedparam.c b/cpukit/posix/src/psxtransschedparam.c
index 6fa7a43886..eba26d4932 100644
--- a/cpukit/posix/src/psxtransschedparam.c
+++ b/cpukit/posix/src/psxtransschedparam.c
@@ -42,27 +42,28 @@ int _POSIX_Thread_Translate_to_sched_policy(
-  int                                  policy,
+  int                       policy,
-  *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE;
-  *budget_callout = NULL;
+  config->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE;
+  config->budget_callout = NULL;
+  config->cpu_time_budget = 0;
   if ( policy == SCHED_OTHER ) {
-    *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE;
+    config->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE;
     return 0;
   if ( policy == SCHED_FIFO ) {
     return 0;
   if ( policy == SCHED_RR ) {
-    *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE;
+    config->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE;
+    config->cpu_time_budget = rtems_configuration_get_ticks_per_timeslice();
     return 0;
@@ -80,8 +81,8 @@ int _POSIX_Thread_Translate_sched_param(
 	 _Timespec_To_ticks( &param->sched_ss_init_budget ) )
       return EINVAL;
-    *budget_algorithm  = THREAD_CPU_BUDGET_ALGORITHM_CALLOUT;
-    *budget_callout = _POSIX_Threads_Sporadic_budget_callout;
+    config->budget_algorithm  = THREAD_CPU_BUDGET_ALGORITHM_CALLOUT;
+    config->budget_callout = _POSIX_Threads_Sporadic_budget_callout;
     return 0;
 #endif
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 55ba73c8b4..75d3c64676 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -171,8 +171,7 @@ int pthread_create(
   error = _POSIX_Thread_Translate_sched_param(
     schedpolicy,
     &schedparam,
-    &config.budget_algorithm,
-    &config.budget_callout
+    &config
   if ( error != 0 ) {
     return error;
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index 9ab543cd31..e9be24b417 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -24,6 +24,7 @@
 #endif
 #include <pthread.h>
+#include <string.h>
@@ -32,12 +33,11 @@
 static int _POSIX_Set_sched_param(
-  Thread_Control                       *the_thread,
-  int                                   policy,
-  Thread_CPU_budget_algorithms          budget_algorithm,
-  Thread_CPU_budget_algorithm_callout   budget_callout,
-  Thread_queue_Context                 *queue_context
+  Thread_Control             *the_thread,
+  int                         policy,
+  const Thread_Configuration *config,
+  Thread_queue_Context       *queue_context
   const Scheduler_Control *scheduler;
@@ -103,8 +103,9 @@ static int _POSIX_Set_sched_param(
 #endif
-  the_thread->budget_algorithm = budget_algorithm;
-  the_thread->budget_callout   = budget_callout;
+  the_thread->cpu_time_budget  = config->cpu_time_budget;
+  the_thread->budget_algorithm = config->budget_algorithm;
+  the_thread->budget_callout   = config->budget_callout;
 #if defined(RTEMS_POSIX_API)
   _Priority_Node_set_priority( &api->Sporadic.Low_priority, core_low_prio );
@@ -114,11 +115,6 @@ static int _POSIX_Set_sched_param(
   if ( policy == SCHED_SPORADIC ) {
     _POSIX_Threads_Sporadic_timer_insert( the_thread, api );
-  } else {
-#endif
-    the_thread->cpu_time_budget =
-      rtems_configuration_get_ticks_per_timeslice();
-#if defined(RTEMS_POSIX_API)
 #endif
@@ -135,23 +131,18 @@ int pthread_setschedparam(
 #endif
-  Thread_CPU_budget_algorithms         budget_algorithm;
-  Thread_CPU_budget_algorithm_callout  budget_callout;
-  Thread_Control                      *the_thread;
-  Per_CPU_Control                     *cpu_self;
-  Thread_queue_Context                 queue_context;
-  int                                  error;
+  Thread_Configuration config;
+  Thread_Control      *the_thread;
+  Per_CPU_Control     *cpu_self;
+  Thread_queue_Context queue_context;
+  int                  error;
   if ( param == NULL ) {
     return EINVAL;
-  error = _POSIX_Thread_Translate_sched_param(
-    policy,
-    param,
-    &budget_algorithm,
-    &budget_callout
+  memset( &config, 0, sizeof( config ) );
+  error = _POSIX_Thread_Translate_sched_param( policy, param, &config );
   if ( error != 0 ) {
     return error;
@@ -169,8 +160,7 @@ int pthread_setschedparam(
     the_thread,
     policy,
     param,
-    budget_algorithm,
-    budget_callout,
+    &config,
     &queue_context
   cpu_self = _Thread_queue_Dispatch_disable( &queue_context );
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index f11e35dcf3..18c98c6995 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -27,7 +27,6 @@
 #include <rtems/score/tls.h>
 #include <rtems/score/userextimpl.h>
-#include <rtems/config.h>
 void _Thread_Free(
   Thread_Information *information,
@@ -176,6 +175,7 @@ static bool _Thread_Try_initialize(
   the_thread->is_fp                  = config->is_fp;
   the_thread->Start.isr_level        = config->isr_level;
   the_thread->Start.is_preemptible   = config->is_preemptible;
   the_thread->Start.budget_algorithm = config->budget_algorithm;
@@ -184,22 +184,6 @@ static bool _Thread_Try_initialize(
   _Thread_Timer_initialize( &the_thread->Timer, cpu );
-  switch ( config->budget_algorithm ) {
-    case THREAD_CPU_BUDGET_ALGORITHM_NONE:
-    case THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE:
-      break;
-    #if defined(RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE)
-      case THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE:
-        break;
-    #endif
-    #if defined(RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT)
-      case THREAD_CPU_BUDGET_ALGORITHM_CALLOUT:
-	break;
-    #endif
 #if defined(RTEMS_SMP)
   scheduler_node = NULL;
   scheduler_node_for_index = the_thread->Scheduler.nodes;
2.26.2
