[PATCH] score: Add Thread_Configuration::cpu_time_budget
Gedare Bloom
gedare at rtems.org
Mon Mar 15 20:24:53 UTC 2021
looks good
On Fri, Mar 12, 2021 at 12:34 AM Sebastian Huber
> Move the CPU time budget to the thread configuration. This simplifies
> _Thread_Initialize().
> cpukit/include/rtems/posix/pthreadimpl.h | 26 +++++++-------
> cpukit/include/rtems/score/threadimpl.h | 5 +++
> cpukit/posix/src/psxtransschedparam.c | 23 +++++++------
> cpukit/posix/src/pthreadcreate.c | 3 +-
> cpukit/posix/src/pthreadsetschedparam.c | 44 +++++++++---------------
> cpukit/score/src/threadinitialize.c | 18 +---------
> 6 files changed, 49 insertions(+), 70 deletions(-)
> diff --git a/cpukit/include/rtems/posix/pthreadimpl.h b/cpukit/include/rtems/posix/pthreadimpl.h
> index 52d462ab6f..723b20e8d2 100644
> --- a/cpukit/include/rtems/posix/pthreadimpl.h
> +++ b/cpukit/include/rtems/posix/pthreadimpl.h
> @@ -77,24 +77,24 @@ int _POSIX_Thread_Translate_to_sched_policy(
> - * @brief Translate sched_param into SuperCore terms.
> + * @brief Translates the POSIX scheduling policy and parameters to parts of the
> + * thread configuration.
> - * This method translates the POSIX API sched_param into the corresponding
> - * SuperCore settings.
> + * @param policy is the POSIX scheduling policy.
> - * @param[in] policy is the POSIX scheduling policy
> - * @param[in] param points to the scheduling parameter structure
> - * @param[in] budget_algorithm points to the output CPU Budget algorithm
> - * @param[in] budget_callout points to the output CPU Callout
> + * @param param is the pointer to the POSIX scheduling parameters.
> - * @retval 0 Indicates success.
> - * @retval error_code POSIX error code indicating failure.
> + * @param[out] config is the pointer to a thread configuration to set the
> + * budget algorithm, callout, and CPU time budget.
> + * @retval 0 The operation was successful.
> + * @retval EINVAL The POSIX scheduling policy or parameters were invalid.
> int _POSIX_Thread_Translate_sched_param(
> - int policy,
> - const struct sched_param *param,
> - Thread_CPU_budget_algorithms *budget_algorithm,
> - Thread_CPU_budget_algorithm_callout *budget_callout
> + int policy,
> + const struct sched_param *param,
> + Thread_Configuration *config
> RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate(void)
> diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
> index 1e7d58609f..d9c0779b08 100644
> --- a/cpukit/include/rtems/score/threadimpl.h
> +++ b/cpukit/include/rtems/score/threadimpl.h
> @@ -163,6 +163,11 @@ typedef struct {
> Thread_CPU_budget_algorithm_callout budget_callout;
> + * @brief The thread's initial CPU time budget.
> + uint32_t cpu_time_budget;
> * @brief 32-bit unsigned integer name of the object for the thread.
> diff --git a/cpukit/posix/src/psxtransschedparam.c b/cpukit/posix/src/psxtransschedparam.c
> index 6fa7a43886..eba26d4932 100644
> --- a/cpukit/posix/src/psxtransschedparam.c
> +++ b/cpukit/posix/src/psxtransschedparam.c
> @@ -42,27 +42,28 @@ int _POSIX_Thread_Translate_to_sched_policy(
> - int policy,
> + int policy,
> - *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE;
> - *budget_callout = NULL;
> + config->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE;
> + config->budget_callout = NULL;
> + config->cpu_time_budget = 0;
> if ( policy == SCHED_OTHER ) {
> - *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE;
> + config->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE;
> return 0;
> if ( policy == SCHED_FIFO ) {
> return 0;
> if ( policy == SCHED_RR ) {
> - *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE;
> + config->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE;
> + config->cpu_time_budget = rtems_configuration_get_ticks_per_timeslice();
> return 0;
> @@ -80,8 +81,8 @@ int _POSIX_Thread_Translate_sched_param(
> _Timespec_To_ticks( ¶m->sched_ss_init_budget ) )
> return EINVAL;
> - *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_CALLOUT;
> - *budget_callout = _POSIX_Threads_Sporadic_budget_callout;
> + config->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_CALLOUT;
> + config->budget_callout = _POSIX_Threads_Sporadic_budget_callout;
> return 0;
> #endif
> diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
> index 55ba73c8b4..75d3c64676 100644
> --- a/cpukit/posix/src/pthreadcreate.c
> +++ b/cpukit/posix/src/pthreadcreate.c
> @@ -171,8 +171,7 @@ int pthread_create(
> error = _POSIX_Thread_Translate_sched_param(
> schedpolicy,
> &schedparam,
> - &config.budget_algorithm,
> - &config.budget_callout
> + &config
> if ( error != 0 ) {
> return error;
> diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
> index 9ab543cd31..e9be24b417 100644
> --- a/cpukit/posix/src/pthreadsetschedparam.c
> +++ b/cpukit/posix/src/pthreadsetschedparam.c
> @@ -24,6 +24,7 @@
> #endif
> #include <pthread.h>
> +#include <string.h>
> #include <errno.h>
> #include <rtems/posix/pthreadimpl.h>
> @@ -32,12 +33,11 @@
> #include <rtems/score/schedulerimpl.h>
> static int _POSIX_Set_sched_param(
> - Thread_Control *the_thread,
> - int policy,
> - Thread_CPU_budget_algorithms budget_algorithm,
> - Thread_CPU_budget_algorithm_callout budget_callout,
> - Thread_queue_Context *queue_context
> + Thread_Control *the_thread,
> + int policy,
> + const Thread_Configuration *config,
> + Thread_queue_Context *queue_context
> const Scheduler_Control *scheduler;
> @@ -103,8 +103,9 @@ static int _POSIX_Set_sched_param(
> #endif
> - the_thread->budget_algorithm = budget_algorithm;
> - the_thread->budget_callout = budget_callout;
> + the_thread->cpu_time_budget = config->cpu_time_budget;
> + the_thread->budget_algorithm = config->budget_algorithm;
> + the_thread->budget_callout = config->budget_callout;
> #if defined(RTEMS_POSIX_API)
> _Priority_Node_set_priority( &api->Sporadic.Low_priority, core_low_prio );
> @@ -114,11 +115,6 @@ static int _POSIX_Set_sched_param(
> if ( policy == SCHED_SPORADIC ) {
> _POSIX_Threads_Sporadic_timer_insert( the_thread, api );
> - } else {
> -#endif
> - the_thread->cpu_time_budget =
> - rtems_configuration_get_ticks_per_timeslice();
> -#if defined(RTEMS_POSIX_API)
> #endif
> @@ -135,23 +131,18 @@ int pthread_setschedparam(
> #endif
> - Thread_CPU_budget_algorithms budget_algorithm;
> - Thread_CPU_budget_algorithm_callout budget_callout;
> - Thread_Control *the_thread;
> - Per_CPU_Control *cpu_self;
> - Thread_queue_Context queue_context;
> - int error;
> + Thread_Configuration config;
> + Thread_Control *the_thread;
> + Per_CPU_Control *cpu_self;
> + Thread_queue_Context queue_context;
> + int error;
> if ( param == NULL ) {
> return EINVAL;
> - error = _POSIX_Thread_Translate_sched_param(
> - policy,
> - param,
> - &budget_algorithm,
> - &budget_callout
> + memset( &config, 0, sizeof( config ) );
> + error = _POSIX_Thread_Translate_sched_param( policy, param, &config );
> if ( error != 0 ) {
> return error;
> @@ -169,8 +160,7 @@ int pthread_setschedparam(
> the_thread,
> policy,
> param,
> - budget_algorithm,
> - budget_callout,
> + &config,
> &queue_context
> cpu_self = _Thread_queue_Dispatch_disable( &queue_context );
> diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
> index f11e35dcf3..18c98c6995 100644
> --- a/cpukit/score/src/threadinitialize.c
> +++ b/cpukit/score/src/threadinitialize.c
> @@ -27,7 +27,6 @@
> #include <rtems/score/tls.h>
> #include <rtems/score/userextimpl.h>
> #include <rtems/score/watchdogimpl.h>
> -#include <rtems/config.h>
> void _Thread_Free(
> Thread_Information *information,
> @@ -176,6 +175,7 @@ static bool _Thread_Try_initialize(
> the_thread->is_fp = config->is_fp;
> the_thread->Start.isr_level = config->isr_level;
> the_thread->Start.is_preemptible = config->is_preemptible;
> the_thread->Start.budget_algorithm = config->budget_algorithm;
> @@ -184,22 +184,6 @@ static bool _Thread_Try_initialize(
> _Thread_Timer_initialize( &the_thread->Timer, cpu );
> - switch ( config->budget_algorithm ) {
> - case THREAD_CPU_BUDGET_ALGORITHM_NONE:
> - case THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE:
> - break;
> - #if defined(RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE)
> - case THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE:
> - break;
> - #endif
> - #if defined(RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT)
> - case THREAD_CPU_BUDGET_ALGORITHM_CALLOUT:
> - break;
> - #endif
> #if defined(RTEMS_SMP)
> scheduler_node = NULL;
> scheduler_node_for_index = the_thread->Scheduler.nodes;
> 2.26.2
> devel mailing list
> devel at rtems.org
