Fwd: New Defects reported by Coverity Scan for RTEMS
Daniel Hellstrom
daniel at gaisler.com
Fri Mar 12 13:22:16 UTC 2021
yes, it must have, so I will look into that.
/Daniel
On 2021-03-12 14:07, Joel Sherrill wrote:
> Without looking, I would assume this was introduced by Daniel's recent
> patches.
> ---------- Forwarded message ---------
> From: <scan-admin at coverity.com <mailto:scan-admin at coverity.com>>
> Date: Fri, Mar 12, 2021, 12:55 AM
> Subject: New Defects reported by Coverity Scan for RTEMS
> To: <build at rtems.org <mailto:build at rtems.org>>
> Hi,
> Please find the latest report on new defect(s) introduced to RTEMS
> found with Coverity Scan.
> 1 new defect(s) introduced to RTEMS found with Coverity Scan.
> New defect(s) Reported-by: Coverity Scan
> Showing 1 of 1 defect(s)
> ** CID 1473629: Control flow issues (NO_EFFECT)
> /bsps/shared/grlib/can/grcanfd.c: 323 in grcan_hw_write_try_fd()
> ________________________________________________________________________________________________________
> *** CID 1473629: Control flow issues (NO_EFFECT)
> 317 bds = 1;
> 318 if (space_left < bds)
> 319 break;
> 320
> 321 /* Convert and write CAN message to DMA buffer */
> 322 dlc = grcan_len2dlc(source->len);
> >>> This less-than-zero comparison of an unsigned value is never
> true. "dlc < 0".
> 323 if (dlc < 0) {
> 324 /* Bad user input. Report the number
> of written messages
> 325 * or an error when non sent.
> 326 */
> 327 if (ret <= 0)
> 328 return GRCAN_RET_INVARG;
> To view the defects in Coverity Scan visit,
> https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DVX3j_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMppdCoTOdWUHKtQLrEQ1MfSyaNP2M1HWoDjjoKTjy-2FIq1HdvVcL1npIuQDJWa-2FDWEQ-2FAOQo8VzAxUCWwGfT9lbXVNqnU0jQl-2FWSYNQAJPY2Tylmw5hG5KcV6hC39VfLDFtSor5xgUxBh-2BcdibW34mNQFj7qSSTl6hW9DF4ywtf1oYStmZyjbwIV0D1AeB2dPto-3D
> <https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DVX3j_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMppdCoTOdWUHKtQLrEQ1MfSyaNP2M1HWoDjjoKTjy-2FIq1HdvVcL1npIuQDJWa-2FDWEQ-2FAOQo8VzAxUCWwGfT9lbXVNqnU0jQl-2FWSYNQAJPY2Tylmw5hG5KcV6hC39VfLDFtSor5xgUxBh-2BcdibW34mNQFj7qSSTl6hW9DF4ywtf1oYStmZyjbwIV0D1AeB2dPto-3D>
> build mailing list
> http://lists.rtems.org/mailman/listinfo/build
> <http://lists.rtems.org/mailman/listinfo/build>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210312/43c993e3/attachment.html>
