[PATCH 1/1] Hello World - Ida's proof to work on rtems
Ida Delphine idadelm at gmail.com
Sat Mar 13 04:13:16 UTC 2021
Modified rtems/testsuites/samples/hello/init.c to prove I can work on the RTEMS project for GSoC.
 testsuites/samples/hello/init.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index 34ded37c55..fa581fd447 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -22,7 +22,7 @@ static rtems_task Init(
   rtems_print_printer_fprintf_putc(&rtems_test_printer);
   TEST_BEGIN();
-  printf( "Hello World\n" );
+  printf( "Hello World, I'm Ida Deslphine and this is th main proof I can officially work on the RTEMS Project for GSoC. I'm so excited. Thank you all for the help you rendered when I ran into several errors!\n" );
   TEST_END();
   rtems_test_exit( 0 );
2.25.1
