[PATCH 1/1] Hello World - Ida's proof to work on rtems
Ida Delphine idadelm at gmail.com
Sat Mar 13 04:15:04 UTC 2021
Here's a screenshot as requested on the guide.
Thanks,
Ida.
On Sat, Mar 13, 2021 at 5:13 AM Ida Delphine <idadelm at gmail.com> wrote:
> From: Meh Mbeh Ida Delphine <idadelm at gmail.com>
> Modified rtems/testsuites/samples/hello/init.c to prove I can work on the
> RTEMS project for GSoC.
>  testsuites/samples/hello/init.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/testsuites/samples/hello/init.c
> b/testsuites/samples/hello/init.c
> index 34ded37c55..fa581fd447 100644
> --- a/testsuites/samples/hello/init.c
> +++ b/testsuites/samples/hello/init.c
> @@ -22,7 +22,7 @@ static rtems_task Init(
>    rtems_print_printer_fprintf_putc(&rtems_test_printer);
>    TEST_BEGIN();
> -  printf( "Hello World\n" );
> +  printf( "Hello World, I'm Ida Deslphine and this is th main proof I can
> officially work on the RTEMS Project for GSoC. I'm so excited. Thank you
> all for the help you rendered when I ran into several errors!\n" );
>    TEST_END();
>    rtems_test_exit( 0 );
> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210313/c5687d6b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210313/c5687d6b/attachment-0001.png>
