[PATCH 2/4] bsp/beagle: Import Beagle pinmux from FreeBSD
G S Niteesh Babu niteesh.gs at gmail.com
Sat Mar 13 11:02:01 UTC 2021
This patch imports the beagle pinmux driver from FreeBSD into
RTEMS. Previously this driver was placed in RTEMS-libBSD but
this caused double initialization of few pins once during RTEMS
initialization and second time during libBSD initialization.
The following patches port the driver from FreeBSD to RTEMS and
will remove the driver from RTEMS-libBSD.
RTEMS Ticket Update: #3784
FreeBSD head: ca12b7e9534b10af022fed60c043984dbaf4003d
The following files have been imported from FreeBSD:
1) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
2) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
3) freebsd/sys/arm/ti/ti_pinmux.h
4) freebsd/sys/arm/ti/ti_pinmux.c
 .../arm/ti/am335x/am335x_scm_padconf.h        |  47 ++
 bsps/include/arm/ti/ti_pinmux.h               |  80 +++
 .../sys/arm/ti/am335x/am335x_scm_padconf.c    | 303 ++++++++++++
 bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c    | 461 ++++++++++++++++++
 4 files changed, 891 insertions(+)
 create mode 100644 bsps/include/arm/ti/am335x/am335x_scm_padconf.h
 create mode 100644 bsps/include/arm/ti/ti_pinmux.h
 create mode 100644 bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
 create mode 100644 bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
diff --git a/bsps/include/arm/ti/am335x/am335x_scm_padconf.h b/bsps/include/arm/ti/am335x/am335x_scm_padconf.h
new file mode 100644
index 0000000000..afbb15381f
--- /dev/null
+++ b/bsps/include/arm/ti/am335x/am335x_scm_padconf.h
@@ -0,0 +1,47 @@
+ * Copyright (c) 2012 Damjan Marion <dmarion at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef AM335X_SCM_PADCONF_H
+#define AM335X_SCM_PADCONF_H
+#define SLEWCTRL	(0x01 << 6) /* faster(0) or slower(1) slew rate. */
+#define RXACTIVE	(0x01 << 5) /* Input enable value for the Pad */
+#define PULLTYPESEL	(0x01 << 4) /* Pad pullup/pulldown type selection */
+#define PULLUDEN	(0x01 << 3) /* Pullup/pulldown disabled */
+#define PADCONF_OUTPUT			(PULLUDEN)
+#define PADCONF_OUTPUT_PULLUP		(PULLTYPESEL)
+#define PADCONF_OUTPUT_PULLDOWN		(0)
+#define PADCONF_INPUT			(RXACTIVE | PULLUDEN)
+#define PADCONF_INPUT_PULLUP		(RXACTIVE | PULLTYPESEL)
+#define PADCONF_INPUT_PULLDOWN		(RXACTIVE)
+#define PADCONF_INPUT_PULLUP_SLOW	(PADCONF_INPUT_PULLUP | SLEWCTRL)
+extern const struct ti_pinmux_device ti_am335x_pinmux_dev;
+#endif /* AM335X_SCM_PADCONF_H */
\ No newline at end of file
diff --git a/bsps/include/arm/ti/ti_pinmux.h b/bsps/include/arm/ti/ti_pinmux.h
index 0000000000..52409df61d
--- /dev/null
+++ b/bsps/include/arm/ti/ti_pinmux.h
@@ -0,0 +1,80 @@
+ * Copyright (c) 2010
+ *	Ben Gray <ben.r.gray at gmail.com>.
+ * are met:
+ * 3. All advertising materials mentioning features or use of this software
+ *    must display the following acknowledgement:
+ *	This product includes software developed by Ben Gray.
+ * 4. The name of the company nor the name of the author may be used to
+ *    endorse or promote products derived from this software without specific
+ *    prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY BEN GRAY ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL BEN GRAY BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD$
+ *	Functions to configure the PIN multiplexing on the chip.
+ *	This is different from the GPIO module in that it is used to configure the
+ *	pins between modules not just GPIO input output.
+#ifndef _TI_PINMUX_H_
+#define _TI_PINMUX_H_
+struct ti_pinmux_padconf {
+	uint16_t    reg_off;
+	uint16_t    gpio_pin;
+	uint16_t    gpio_mode;
+	const char  *ballname;
+	const char  *muxmodes[8];
+struct ti_pinmux_padstate {
+	const char  *state;
+	uint16_t    reg;
+struct ti_pinmux_device {
+	uint16_t		padconf_muxmode_mask;
+	uint16_t		padconf_sate_mask;
+	const struct ti_pinmux_padstate	*padstate;
+	const struct ti_pinmux_padconf	*padconf;
+struct ti_pinmux_softc {
+	device_t		sc_dev;
+	struct resource *	sc_res[4];
+	bus_space_tag_t		sc_bst;
+	bus_space_handle_t	sc_bsh;
+int ti_pinmux_padconf_set(const char *padname, const char *muxmode,
+    unsigned int state);
+int ti_pinmux_padconf_get(const char *padname, const char **muxmode,
+    unsigned int *state);
+int ti_pinmux_padconf_set_gpiomode(uint32_t gpio, unsigned int state);
+int ti_pinmux_padconf_get_gpiomode(uint32_t gpio, unsigned int *state);
+#endif /* _TI_SCM_H_ */
diff --git a/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c b/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
index 0000000000..44a36a754b
--- /dev/null
+++ b/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
@@ -0,0 +1,303 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/bus.h>
+#include <sys/resource.h>
+#include <sys/rman.h>
+#include <sys/lock.h>
+#include <sys/malloc.h>
+#include <machine/bus.h>
+#include <machine/resource.h>
+#include <machine/intr.h>
+#include <sys/gpio.h>
+#include <arm/ti/tivar.h>
+#include <arm/ti/ti_pinmux.h>
+#include <arm/ti/am335x/am335x_scm_padconf.h>
+#define _PIN(r, b, gp, gm, m0, m1, m2, m3, m4, m5, m6, m7) \
+	{	.reg_off = r, \
+		.gpio_pin = gp, \
+		.gpio_mode = gm, \
+		.ballname = b, \
+		.muxmodes[0] = m0, \
+		.muxmodes[1] = m1, \
+		.muxmodes[2] = m2, \
+		.muxmodes[3] = m3, \
+		.muxmodes[4] = m4, \
+		.muxmodes[5] = m5, \
+		.muxmodes[6] = m6, \
+		.muxmodes[7] = m7, \
+const static struct ti_pinmux_padstate ti_padstate_devmap[] = {
+	{"output",		PADCONF_OUTPUT },
+	{"output_pullup",	PADCONF_OUTPUT_PULLUP },
+	{"input",		PADCONF_INPUT },
+	{"input_pulldown",	PADCONF_INPUT_PULLDOWN },
+	{"input_pullup",	PADCONF_INPUT_PULLUP },
+	{"i2c",			PADCONF_INPUT_PULLUP_SLOW },
+	{ .state = NULL }
+const static struct ti_pinmux_padconf ti_padconf_devmap[] = {
+	_PIN(0x000, "GPMC_AD0",		32, 7,"gpmc_ad0", "mmc1_dat0", NULL, NULL, NULL, NULL, NULL, "gpio1_0"),
+	_PIN(0x004, "GPMC_AD1",		33, 7,"gpmc_ad1", "mmc1_dat1", NULL, NULL, NULL, NULL, NULL, "gpio1_1"),
+	_PIN(0x008, "GPMC_AD2",		34, 7,"gpmc_ad2", "mmc1_dat2", NULL, NULL, NULL, NULL, NULL, "gpio1_2"),
+	_PIN(0x00C, "GPMC_AD3",		35, 7,"gpmc_ad3", "mmc1_dat3", NULL, NULL, NULL, NULL, NULL, "gpio1_3"),
+	_PIN(0x010, "GPMC_AD4",		36, 7,"gpmc_ad4", "mmc1_dat4", NULL, NULL, NULL, NULL, NULL, "gpio1_4"),
+	_PIN(0x014, "GPMC_AD5",		37, 7,"gpmc_ad5", "mmc1_dat5", NULL, NULL, NULL, NULL, NULL, "gpio1_5"),
+	_PIN(0x018, "GPMC_AD6",		38, 7,"gpmc_ad6", "mmc1_dat6", NULL, NULL, NULL, NULL, NULL, "gpio1_6"),
+	_PIN(0x01C, "GPMC_AD7",		39, 7,"gpmc_ad7", "mmc1_dat7", NULL, NULL, NULL, NULL, NULL, "gpio1_7"),
+	_PIN(0x020, "GPMC_AD8",		22, 7, "gpmc_ad8", "lcd_data23", "mmc1_dat0", "mmc2_dat4", "ehrpwm2A", NULL, NULL, "gpio0_22"),
+	_PIN(0x024, "GPMC_AD9",		23, 7, "gpmc_ad9", "lcd_data22", "mmc1_dat1", "mmc2_dat5", "ehrpwm2B", NULL, NULL, "gpio0_23"),
+	_PIN(0x028, "GPMC_AD10",	26, 7, "gpmc_ad10", "lcd_data21", "mmc1_dat2", "mmc2_dat6", "ehrpwm2_tripzone_in", NULL, NULL, "gpio0_26"),
+	_PIN(0x02C, "GPMC_AD11",	27, 7, "gpmc_ad11", "lcd_data20", "mmc1_dat3", "mmc2_dat7", "ehrpwm0_synco", NULL, NULL, "gpio0_27"),
+	_PIN(0x030, "GPMC_AD12",	44, 7, "gpmc_ad12", "lcd_data19", "mmc1_dat4", "mmc2_dat0", "eQEP2A_in", "pr1_mii0_txd2", "pr1_pru0_pru_r30_14", "gpio1_12"),
+	_PIN(0x034, "GPMC_AD13",	45, 7, "gpmc_ad13", "lcd_data18", "mmc1_dat5", "mmc2_dat1", "eQEP2B_in", "pr1_mii0_txd1", "pr1_pru0_pru_r30_15", "gpio1_13"),
+	_PIN(0x038, "GPMC_AD14",	46, 7, "gpmc_ad14", "lcd_data17", "mmc1_dat6", "mmc2_dat2", "eQEP2_index", "pr1_mii0_txd0", "pr1_pru0_pru_r31_14", "gpio1_14"),
+	_PIN(0x03C, "GPMC_AD15",	47, 7, "gpmc_ad15", "lcd_data16", "mmc1_dat7", "mmc2_dat3", "eQEP2_strobe", "pr1_ecap0_ecap_capin_apwm_o", "pr1_pru0_pru_r31_15", "gpio1_15"),
+	_PIN(0x040, "GPMC_A0",		48, 7, "gpmc_a0", "gmii2_txen", "rgmii2_tctl", "rmii2_txen", "gpmc_a16", "pr1_mii_mt1_clk", "ehrpwm1_tripzone_input", "gpio1_16"),
+	_PIN(0x044, "GPMC_A1",		49, 7, "gpmc_a1", "gmii2_rxdv", "rgmii2_rctl", "mmc2_dat0", "gpmc_a17", "pr1_mii1_txd3", "ehrpwm0_synco", "gpio1_17"),
+	_PIN(0x048, "GPMC_A2",		50, 7, "gpmc_a2", "gmii2_txd3", "rgmii2_td3", "mmc2_dat1", "gpmc_a18", "pr1_mii1_txd2", "ehrpwm1A", "gpio1_18"),
+	_PIN(0x04C, "GPMC_A3",		51, 7, "gpmc_a3", "gmii2_txd2", "rgmii2_td2", "mmc2_dat2", "gpmc_a19", "pr1_mii1_txd1", "ehrpwm1B", "gpio1_19"),
+	_PIN(0x050, "GPMC_A4",		52, 7, "gpmc_a4", "gmii2_txd1", "rgmii2_td1", "rmii2_tdx1", "gpmc_a20", "pr1_mii1_txd0", "eQEP1A_in", "gpio1_20"),
+	_PIN(0x054, "GPMC_A5",		53, 7, "gpmc_a5", "gmii2_txd0", "rgmii2_td0", "rmii2_txd0", "gpmc_a21", "pr1_mii1_rxd3", "eQEP1B_in", "gpio1_21"),
+	_PIN(0x058, "GPMC_A6",		54, 7, "gpmc_a6", "gmii2_txclk", "rgmii2_tclk", "mmc2_dat4", "gpmc_a22", "pr1_mii1_rxd2", "eQEP1_index", "gpio1_22"),
+	_PIN(0x05C, "GPMC_A7",		55, 7, "gpmc_a7", "gmii2_rxclk", "rgmii2_rclk", "mmc2_dat5", "gpmc_a23", "pr1_mii1_rxd1", "eQEP1_strobe", "gpio1_23"),
+	_PIN(0x060, "GPMC_A8",		56, 7, "gpmc_a8", "gmii2_rxd3", "rgmii2_rd3", "mmc2_dat6", "gpmc_a24", "pr1_mii1_rxd0", "mcasp0_aclkx", "gpio1_24"),
+	_PIN(0x064, "GPMC_A9",		57, 7, "gmpc_a9", "gmii2_rxd2", "rgmii2_rd2", "mmc2_dat7 / rmii2_crs_dv", "gpmc_a25", "pr1_mii_mr1_clk", "mcasp0_fsx", "gpio1_25"),
+	_PIN(0x068, "GPMC_A10",		58, 7, "gmpc_a10", "gmii2_rxd1", "rgmii2_rd1", "rmii2_rxd1", "gpmc_a26", "pr1_mii1_rxdv", "mcasp0_arx0", "gpio1_26"),
+	_PIN(0x06C, "GPMC_A11",		59, 7, "gmpc_a11", "gmii2_rxd0", "rgmii2_rd0", "rmii2_rxd0", "gpmc_a27", "pr1_mii1_rxer", "mcasp0_axr1", "gpio1_27"),
+	_PIN(0x070, "GPMC_WAIT0",	30, 7, "gpmc_wait0", "gmii2_crs", "gpmc_csn4", "rmii2_crs_dv", "mmc1_sdcd", "pr1_mii1_col", "uart4_rxd", "gpio0_30"),
+	_PIN(0x074, "GPMC_WPn",		31, 7, "gpmc_wpn", "gmii2_rxerr", "gpmc_csn5", "rmii2_rxerr", "mmc2_sdcd", "pr1_mii1_txen", "uart4_txd", "gpio0_31"),
+	_PIN(0x078, "GPMC_BEn1",	60, 7, "gpmc_be1n", "gmii2_col", "gmpc_csn6","mmc2_dat3", "gpmc_dir", "pr1_mii1_rxlink", "mcasp0_aclkr", "gpio1_28"),
+	_PIN(0x07c, "GPMC_CSn0",	61, 7, "gpmc_csn0", NULL, NULL, NULL, NULL, NULL, NULL, "gpio1_29"),
+	_PIN(0x080, "GPMC_CSn1",	62, 7, "gpmc_csn1", "gpmc_clk", "mmc1_clk", "pr1_edio_data_in6", "pr1_edio_data_out6", "pr1_pru1_pru_r30_12", "pr1_pru1_pru_r31_12", "gpio1_30"),
+	_PIN(0x084, "GPMC_CSn2",	63, 7, "gpmc_csn2", "gpmc_be1n", "mmc1_cmd", "pr1_edio_data_in7", "pr1_edio_data_out7", "pr1_pru1_pru_r30_13", "pr1_pru1_pru_r31_13", "gpio1_31"),
+	_PIN(0x088, "GPMC_CSn3",	64, 7, "gpmc_csn3", "gpmc_a3", "rmii2_crs_dv", "mmc2_cmd", "pr1_mii0_crs", "pr1_mdio_data", "EMU4", "gpio2_0"),
+	_PIN(0x08c, "GPMC_CLK",		65, 7, "gpmc_clk", "lcd_memory_clk", "gpmc_wait1", "mmc2_clk", "pr1_mii1_crs", "pr1_mdio_mdclk", "mcasp0_fsr", "gpio2_1"),
+	_PIN(0x090, "GPMC_ADVn_ALE",	66, 7, "gpmc_advn_ale", NULL, "timer4", NULL, NULL, NULL, NULL, "gpio2_2"),
+	_PIN(0x094, "GPMC_OEn_REn",	67, 7, "gpmc_oen_ren", NULL, "timer7", NULL, NULL, NULL, NULL, "gpio2_3"),
+	_PIN(0x098, "GPMC_WEn",		68, 7, "gpmc_wen", NULL, "timer6", NULL, NULL, NULL, NULL, "gpio2_4"),
+	_PIN(0x09c, "GPMC_BEn0_CLE",	67, 7, "gpmc_ben0_cle", NULL, "timer5", NULL, NULL, NULL, NULL, "gpio2_5"),
+	_PIN(0x0a0, "LCD_DATA0",	68, 7, "lcd_data0", "gpmc_a0", "pr1_mii_mt0_clk", "ehrpwm2A", NULL, "pr1_pru1_pru_r30_0", "pr1_pru1_pru_r31_0", "gpio2_6"),
+	_PIN(0x0a4, "LCD_DATA1",	69, 7, "lcd_data1", "gpmc_a1", "pr1_mii0_txen", "ehrpwm2B", NULL, "pr1_pru1_pru_r30_1", "pr1_pru1_pru_r31_1", "gpio2_7"),
+	_PIN(0x0a8, "LCD_DATA2",	70, 7, "lcd_data2", "gpmc_a2", "pr1_mii0_txd3", "ehrpwm2_tripzone_input", NULL, "pr1_pru1_pru_r30_2", "pr1_pru1_pru_r31_2", "gpio2_8"),
+	_PIN(0x0ac, "LCD_DATA3",	71, 7, "lcd_data3", "gpmc_a3", "pr1_mii0_txd2", "ehrpwm0_synco", NULL, "pr1_pru1_pru_r30_3", "pr1_pru1_pru_r31_3", "gpio2_9"),
+	_PIN(0x0b0, "LCD_DATA4",	72, 7, "lcd_data4", "gpmc_a4", "pr1_mii0_txd1", "eQEP2A_in", NULL, "pr1_pru1_pru_r30_4", "pr1_pru1_pru_r31_4", "gpio2_10"),
+	_PIN(0x0b4, "LCD_DATA5",	73, 7, "lcd_data5", "gpmc_a5", "pr1_mii0_txd0", "eQEP2B_in", NULL, "pr1_pru1_pru_r30_5", "pr1_pru1_pru_r31_5", "gpio2_11"),
+	_PIN(0x0b8, "LCD_DATA6",	74, 7, "lcd_data6", "gpmc_a6", "pr1_edio_data_in6", "eQEP2_index", "pr1_edio_data_out6", "pr1_pru1_pru_r30_6", "pr1_pru1_pru_r31_6", "gpio2_12"),
+	_PIN(0x0bc, "LCD_DATA7",	75, 7, "lcd_data7", "gpmc_a7", "pr1_edio_data_in7", "eQEP2_strobe", "pr1_edio_data_out7", "pr1_pru1_pru_r30_7", "pr1_pru1_pru_r31_7", "gpio2_13"),
+	_PIN(0x0c0, "LCD_DATA8",	76, 7, "lcd_data8", "gpmc_a12", "ehrpwm1_tripzone_input", "mcasp0_aclkx", "uart5_txd", "pr1_mii0_rxd3", "uart2_ctsn", "gpio2_14"),
+	_PIN(0x0c4, "LCD_DATA9",	76, 7, "lcd_data9", "gpmc_a13", "ehrpwm0_synco", "mcasp0_fsx", "uart5_rxd", "pr1_mii0_rxd2", "uart2_rtsn", "gpio2_15"),
+	_PIN(0x0c8, "LCD_DATA10",	77, 7, "lcd_data10", "gpmc_a14", "ehrpwm1A", "mcasp0_axr0", NULL, "pr1_mii0_rxd1", "uart3_ctsn", "gpio2_16"),
+	_PIN(0x0cc, "LCD_DATA11",	78, 7, "lcd_data11", "gpmc_a15", "ehrpwm1B", "mcasp0_ahclkr", "mcasp0_axr2", "pr1_mii0_rxd0", "uart3_rtsn", "gpio2_17"),
+	_PIN(0x0d0, "LCD_DATA12",	8, 7, "lcd_data12", "gpmc_a16", "eQEP1A_in", "mcasp0_aclkr", "mcasp0_axr2", "pr1_mii0_rxlink", "uart4_ctsn", "gpio0_8"),
+	_PIN(0x0d4, "LCD_DATA13",	9, 7, "lcd_data13", "gpmc_a17", "eQEP1B_in", "mcasp0_fsr", "mcasp0_axr3", "pr1_mii0_rxer", "uart4_rtsn", "gpio0_9"),
+	_PIN(0x0d8, "LCD_DATA14",	10, 7, "lcd_data14", "gpmc_a18", "eQEP1_index", "mcasp0_axr1", "uart5_rxd", "pr1_mii_mr0_clk", "uart5_ctsn", "gpio0_10"),
+	_PIN(0x0dc, "LCD_DATA15",	11, 7, "lcd_data15", "gpmc_a19", "eQEP1_strobe", "mcasp0_ahclkx", "mcasp0_axr3", "pr1_mii0_rxdv", "uart5_rtsn", "gpio0_11"),
+	_PIN(0x0e0, "LCD_VSYNC",	86, 7, "lcd_vsync", "gpmc_a8", "gpmc_a1", "pr1_edio_data_in2", "pr1_edio_data_out2", "pr1_pru1_pru_r30_8", "pr1_pru1_pru_r31_8", "gpio2_22"),
+	_PIN(0x0e4, "LCD_HSYNC",	87, 7, "lcd_hsync", "gmpc_a9", "gpmc_a2", "pr1_edio_data_in3", "pr1_edio_data_out3", "pr1_pru1_pru_r30_9", "pr1_pru1_pru_r31_9", "gpio2_23"),
+	_PIN(0x0e8, "LCD_PCLK",		88, 7, "lcd_pclk", "gpmc_a10", "pr1_mii0_crs", "pr1_edio_data_in4", "pr1_edio_data_out4", "pr1_pru1_pru_r30_10", "pr1_pru1_pru_r31_10", "gpio2_24"),
+	_PIN(0x0ec, "LCD_AC_BIAS_EN",	89, 7, "lcd_ac_bias_en", "gpmc_a11", "pr1_mii1_crs", "pr1_edio_data_in5", "pr1_edio_data_out5", "pr1_pru1_pru_r30_11", "pr1_pru1_pru_r31_11", "gpio2_25"),
+	_PIN(0x0f0, "MMC0_DAT3",	90, 7, "mmc0_dat3", "gpmc_a20", "uart4_ctsn", "timer5", "uart1_dcdn", "pr1_pru0_pru_r30_8", "pr1_pru0_pru_r31_8", "gpio2_26"),
+	_PIN(0x0f4, "MMC0_DAT2",	91, 7, "mmc0_dat2", "gpmc_a21", "uart4_rtsn", "timer6", "uart1_dsrn", "pr1_pru0_pru_r30_9", "pr1_pru0_pru_r31_9", "gpio2_27"),
+	_PIN(0x0f8, "MMC0_DAT1",	92, 7, "mmc0_dat1", "gpmc_a22", "uart5_ctsn", "uart3_rxd", "uart1_dtrn", "pr1_pru0_pru_r30_10", "pr1_pru0_pru_r31_10", "gpio2_28"),
+	_PIN(0x0fc, "MMC0_DAT0",	93, 7, "mmc0_dat0", "gpmc_a23", "uart5_rtsn", "uart3_txd", "uart1_rin", "pr1_pru0_pru_r30_11", "pr1_pru0_pru_r31_11", "gpio2_29"),
+	_PIN(0x100, "MMC0_CLK",		94, 7, "mmc0_clk", "gpmc_a24", "uart3_ctsn", "uart2_rxd", "dcan1_tx", "pr1_pru0_pru_r30_12", "pr1_pru0_pru_r31_12", "gpio2_30"),
+	_PIN(0x104, "MMC0_CMD",		95, 7, "mmc0_cmd", "gpmc_a25", "uart3_rtsn", "uart2_txd", "dcan1_rx", "pr1_pru0_pru_r30_13", "pr1_pru0_pru_r31_13", "gpio2_31"),
+	_PIN(0x108, "MII1_COL",		96, 7, "gmii1_col", "rmii2_refclk", "spi1_sclk", "uart5_rxd", "mcasp1_axr2", "mmc2_dat3", "mcasp0_axr2", "gpio3_0"),
+	_PIN(0x10c, "MII1_CRS",		97, 7, "gmii1_crs", "rmii1_crs_dv", "spi1_d0", "I2C1_SDA", "mcasp1_aclkx", "uart5_ctsn", "uart2_rxd", "gpio3_1"),
+	_PIN(0x110, "MII1_RX_ER",	98, 7, "gmii1_rxerr", "rmii1_rxerr", "spi1_d1", "I2C1_SCL", "mcasp1_fsx", "uart5_rtsn", "uart2_txd", "gpio3_2"),
+	_PIN(0x114, "MII1_TX_EN",	99, 7, "gmii1_txen", "rmii1_txen", "rgmii1_tctl", "timer4", "mcasp1_axr0", "eQEP0_index", "mmc2_cmd", "gpio3_3"),
+	_PIN(0x118, "MII1_RX_DV",	100, 7, "gmii1_rxdv", "cd_memory_clk", "rgmii1_rctl", "uart5_txd", "mcasp1_aclkx", "mmc2_dat0", "mcasp0_aclkr", "gpio3_4"),
+	_PIN(0x11c, "MII1_TXD3",	16, 7, "gmii1_txd3", "dcan0_tx", "rgmii1_td3", "uart4_rxd", "mcasp1_fsx", "mmc2_dat1", "mcasp0_fsr", "gpio0_16"),
+	_PIN(0x120, "MII1_TXD2",	17, 7, "gmii1_txd2", "dcan0_rx", "rgmii1_td2", "uart4_txd", "mcasp1_axr0", "mmc2_dat2", "mcasp0_ahclkx", "gpio0_17"),
+	_PIN(0x124, "MII1_TXD1",	21, 7, "gmii1_txd1", "rmii1_txd1", "rgmii1_td1", "mcasp1_fsr", "mcasp1_axr1", "eQEP0A_in", "mmc1_cmd", "gpio0_21"),
+	_PIN(0x128, "MII1_TXD0",	28, 7, "gmii1_txd0", "rmii1_txd0", "rgmii1_td0", "mcasp1_axr2", "mcasp1_aclkr", "eQEP0B_in", "mmc1_clk", "gpio0_28"),
+	_PIN(0x12c, "MII1_TX_CLK",	105, 7, "gmii1_txclk", "uart2_rxd", "rgmii1_tclk", "mmc0_dat7", "mmc1_dat0", "uart1_dcdn", "mcasp0_aclkx", "gpio3_9"),
+	_PIN(0x130, "MII1_RX_CLK",	106, 7, "gmii1_rxclk", "uart2_txd", "rgmii1_rclk", "mmc0_dat6", "mmc1_dat1", "uart1_dsrn", "mcasp0_fsx", "gpio3_10"),
+	_PIN(0x134, "MII1_RXD3",	82, 7, "gmii1_rxd3", "uart3_rxd", "rgmii1_rd3", "mmc0_dat5", "mmc1_dat2", "uart1_dtrn", "mcasp0_axr0", "gpio2_18"),
+	_PIN(0x138, "MII1_RXD2",	83, 7, "gmii1_rxd2", "uart3_txd", "rgmii1_rd2", "mmc0_dat4", "mmc1_dat3", "uart1_rin", "mcasp0_axr1", "gpio2_19"),
+	_PIN(0x13c, "MII1_RXD1",	84, 7, "gmii1_rxd1", "rmii1_rxd1", "rgmii1_rd1", "mcasp1_axr3", "mcasp1_fsr", "eQEP0_strobe", "mmc2_clk", "gpio2_20"),
+	_PIN(0x140, "MII1_RXD0",	85, 7, "gmii1_rxd0", "rmii1_rxd0", "rgmii1_rd0", "mcasp1_ahclkx", "mcasp1_ahclkr", "mcasp1_aclkr", "mcasp0_axr3", "gpio2_21"),
+	_PIN(0x144, "RMII1_REF_CLK",	29, 7, "rmii1_refclk", "xdma_event_intr2", "spi1_cs0", "uart5_txd", "mcasp1_axr3", "mmc0_pow", "mcasp1_ahclkx", "gpio0_29"),
+	_PIN(0x148, "MDIO",		0, 7, "mdio_data", "timer6", "uart5_rxd", "uart3_ctsn", "mmc0_sdcd","mmc1_cmd", "mmc2_cmd","gpio0_0"),
+	_PIN(0x14c, "MDC",		1, 7, "mdio_clk", "timer5", "uart5_txd", "uart3_rtsn", "mmc0_sdwp", "mmc1_clk", "mmc2_clk", "gpio0_1"),
+	_PIN(0x150, "SPI0_SCLK",	2, 7, "spi0_sclk", "uart2_rxd", "I2C2_SDA", "ehrpwm0A", "pr1_uart0_cts_n", "pr1_edio_sof", "EMU2", "gpio0_2"),
+	_PIN(0x154, "SPI0_D0",		3, 7, "spi0_d0", "uart2_txd", "I2C2_SCL", "ehrpwm0B", "pr1_uart0_rts_n", "pr1_edio_latch_in", "EMU3", "gpio0_3"),
+	_PIN(0x158, "SPI0_D1",		4, 7, "spi0_d1", "mmc1_sdwp", "I2C1_SDA", "ehrpwm0_tripzone_input", "pr1_uart0_rxd", "pr1_edio_data_in0", "pr1_edio_data_out0", "gpio0_4"),
+	_PIN(0x15c, "SPI0_CS0",		5, 7, "spi0_cs0", "mmc2_sdwp", "I2C1_SCL", "ehrpwm0_synci", "pr1_uart0_txd", "pr1_edio_data_in1", "pr1_edio_data_out1", "gpio0_5"),
+	_PIN(0x160, "SPI0_CS1",		6, 7, "spi0_cs1", "uart3_rxd", "eCAP1_in_PWM1_out", "mcc0_pow", "xdm_event_intr2", "mmc0_sdcd", "EMU4", "gpio0_6"),
+	_PIN(0x164, "ECAP0_IN_PWM0_OUT",7, 7, "eCAP0_in_PWM0_out", "uart3_txd", "spi1_cs1", "pr1_ecap0_ecap_capin_apwm_o", "spi1_sclk", "mmc0_sdwp", "xdma_event_intr2", "gpio0_7"),
+	_PIN(0x168, "UART0_CTSn",	40, 7, "uart0_ctsn", "uart4_rxd", "dcan1_tx", "I2C1_SDA", "spi1_d0", "timer7", "pr1_edc_sync0_out", "gpio1_8"),
+	_PIN(0x16c, "UART0_RTSn",	41, 7, "uart0_rtsn", "uart4_txd", "dcan1_rx", "I2C1_SCL", "spi1_d1", "spi1_cs0", "pr1_edc_sync1_out", "gpio1_9"),
+	_PIN(0x170, "UART0_rxd",	42, 7, "uart0_rxd", "spi1_cs0", "dcan0_tx", "I2C2_SDA", "eCAP2_in_PWM2_out", "pr1_pru1_pru_r30_14", "pr1_pru1_pru_r31_14", "gpio1_10"),
+	_PIN(0x174, "UART0_txd",	43, 7, "uart0_txd", "spi1_cs1", "dcan0_rx", "I2C2_SCL", "eCAP1_in_PWM1_out", "pr1_pru1_pru_r30_15", "pr1_pru1_pru_r31_15", "gpio1_11"),
+	_PIN(0x178, "UART1_CTSn",	12, 7, "uart1_ctsn", "timer6_mux1", "dcan0_tx", "I2C2_SDA", "spi1_cs0", "pr1_uart0_cts_n", "pr1_edc_latch0_in", "gpio0_12"),
+	_PIN(0x17c, "UART1_RTSn",	13, 7, "uart1_rtsn", "timer5_mux1", "dcan0_rx", "I2C2_SCL", "spi1_cs1", "pr1_uart0_rts_n", "pr1_edc_latch1_in", "gpio0_13"),
+	_PIN(0x180, "UART1_RXD",	14, 7, "uart1_rxd", "mmc1_sdwp", "dcan1_tx", "I2C1_SDA", NULL, "pr1_uart0_rxd", "pr1_pru1_pru_r31_16", "gpio0_14"),
+	_PIN(0x184, "UART1_TXD",	15, 7, "uart1_txd", "mmc2_sdwp", "dcan1_rx", "I2C1_SCL", NULL, "pr1_uart0_txd", "pr1_pru0_pru_r31_16", "gpio0_15"),
+	_PIN(0x188, "I2C0_SDA",		101, 7, "I2C0_SDA", "timer4", "uart2_ctsn", "eCAP2_in_PWM2_out", NULL, NULL, NULL, "gpio3_5"),
+	_PIN(0x18c, "I2C0_SCL",		102, 7, "I2C0_SCL", "timer7", "uart2_rtsn", "eCAP1_in_PWM1_out", NULL, NULL, NULL, "gpio3_6"),
+	_PIN(0x190, "MCASP0_ACLKX",	110, 7, "mcasp0_aclkx", "ehrpwm0A", NULL, "spi1_sclk", "mmc0_sdcd", "pr1_pru0_pru_r30_0", "pr1_pru0_pru_r31_0", "gpio3_14"),
+	_PIN(0x194, "MCASP0_FSX",	111, 7, "mcasp0_fsx", "ehrpwm0B", NULL, "spi1_d0", "mmc1_sdcd", "pr1_pru0_pru_r30_1", "pr1_pru0_pru_r31_1", "gpio3_15"),
+	_PIN(0x198, "MCASP0_AXR0",	112, 7, "mcasp0_axr0", "ehrpwm0_tripzone_input", NULL, "spi1_d1", "mmc2_sdcd", "pr1_pru0_pru_r30_2", "pr1_pru0_pru_r31_2", "gpio3_16"),
+	_PIN(0x19c, "MCASP0_AHCLKR",	113, 7, "mcasp0_ahclkr", "ehrpwm0_synci", "mcasp0_axr2", "spi1_cs0", "eCAP2_in_PWM2_out", "pr1_pru0_pru_r30_3", "pr1_pru0_pru_r31_3", "gpio3_17"),
+	_PIN(0x1a0, "MCASP0_ACLKR",	114, 7, "mcasp0_aclkr", "eQEP0A_in", "mcasp0_axr2", "mcasp1_aclkx", "mmc0_sdwp", "pr1_pru0_pru_r30_4", "pr1_pru0_pru_r31_4", "gpio3_18"),
+	_PIN(0x1a4, "MCASP0_FSR",	115, 7, "mcasp0_fsr", "eQEP0B_in", "mcasp0_axr3", "mcasp1_fsx", "EMU2", "pr1_pru0_pru_r30_5", "pr1_pru0_pru_r31_5", "gpio3_19"),
+	_PIN(0x1a8, "MCASP0_AXR1",	116, 7, "mcasp0_axr1", "eQEP0_index", NULL, "mcasp1_axr0", "EMU3", "pr1_pru0_pru_r30_6", "pr1_pru0_pru_r31_6", "gpio3_20"),
+	_PIN(0x1ac, "MCASP0_AHCLKX",	117, 7, "mcasp0_ahclkx", "eQEP0_strobe", "mcasp0_axr3", "mcasp1_axr1", "EMU4", "pr1_pru0_pru_r30_7", "pr1_pru0_pru_r31_7", "gpio3_21"),
+	_PIN(0x1b0, "XDMA_EVENT_INTR0",	19, 7, "xdma_event_intr0", NULL, "timer4", "clkout1", "spi1_cs1", "pr1_pru1_pru_r31_16", "EMU2", "gpio0_19"),
+	_PIN(0x1b4, "XDMA_EVENT_INTR1",	20, 7, "xdma_event_intr1", NULL, "tclkin", "clkout2", "timer7", "pr1_pru0_pru_r31_16", "EMU3", "gpio0_20"),
+#if 0
+	_PIN(0x1b8, "nresetin_out",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1bc, "porz",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1c0, "nnmi",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1c4, "osc0_in",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1c8, "osc0_out",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1cc, "osc0_vss",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1d0, "tms",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1d4, "tdi",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1d8, "tdo",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1dc, "tck",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1e0, "ntrst",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+#endif
+	_PIN(0x1e4, "EMU0",		103, 7, "EMU0", NULL, NULL, NULL, NULL, NULL, NULL, "gpio3_7"),
+	_PIN(0x1e8, "EMU1",		104, 0, "EMU1", NULL, NULL, NULL, NULL, NULL, NULL, "gpio3_8"),
+#if 0
+	_PIN(0x1ec, "osc1_in",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1f0, "osc1_out",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1f4, "osc1_vss",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1f8, "rtc_porz",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x1fc, "pmic_power_en",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x200, "ext_wakeup",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x204, "enz_kaldo_1p8v",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+#endif
+	_PIN(0x208, "USB0_DM",		0, 0, "USB0_DM", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x20c, "USB0_DP",		0, 0, "USB0_DP", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x210, "USB0_CE",		0, 0, "USB0_CE", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x214, "USB0_ID",		0, 0, "USB0_ID", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x218, "USB0_VBUS",	0, 0, "USB0_VBUS", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x21c, "USB0_DRVVBUS",	18, 7, "USB0_DRVVBUS", NULL, NULL, NULL, NULL, NULL, NULL, "gpio0_18"),
+	_PIN(0x220, "USB1_DM",		0, 0, "USB1_DM", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x224, "USB1_DP",		0, 0, "USB1_DP", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x228, "USB1_CE",		0, 0, "USB1_CE", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x22c, "USB1_ID",		0, 0, "USB1_ID", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x230, "USB1_VBUS",	0, 0, "USB1_VBUS", NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x234, "USB1_DRVVBUS",	109, 7, "USB1_DRVVBUS", NULL, NULL, NULL, NULL, NULL, NULL, "gpio3_13"),
+#if 0
+	_PIN(0x238, "ddr_resetn",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x23c, "ddr_csn0",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x240, "ddr_cke",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x244, "ddr_ck",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x248, "ddr_nck",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x24c, "ddr_casn",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x250, "ddr_rasn",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x254, "ddr_wen",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x258, "ddr_ba0",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x25c, "ddr_ba1",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x260, "ddr_ba2",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x264, "ddr_a0",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x268, "ddr_a1",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x26c, "ddr_a2",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x270, "ddr_a3",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x274, "ddr_a4",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x278, "ddr_a5",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x27c, "ddr_a6",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x280, "ddr_a7",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x284, "ddr_a8",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x288, "ddr_a9",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x28c, "ddr_a10",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x290, "ddr_a11",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x294, "ddr_a12",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x298, "ddr_a13",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x29c, "ddr_a14",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2a0, "ddr_a15",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2a4, "ddr_odt",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2a8, "ddr_d0",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2ac, "ddr_d1",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2b0, "ddr_d2",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2b4, "ddr_d3",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2b8, "ddr_d4",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2bc, "ddr_d5",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2c0, "ddr_d6",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2c4, "ddr_d7",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2c8, "ddr_d8",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2cc, "ddr_d9",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2d0, "ddr_d10",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2d4, "ddr_d11",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2d8, "ddr_d12",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2dc, "ddr_d13",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2e0, "ddr_d14",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2e4, "ddr_d15",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2e8, "ddr_dqm0",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2ec, "ddr_dqm1",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2f0, "ddr_dqs0",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2f4, "ddr_dqsn0",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2f8, "ddr_dqs1",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x2fc, "ddr_dqsn1",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x300, "ddr_vref",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x304, "ddr_vtp",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x308, "ddr_strben0",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x30c, "ddr_strben1",	0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x32c, "ain0",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x328, "ain1",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x324, "ain2",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x320, "ain3",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x31c, "ain4",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x318, "ain5",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x314, "ain6",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x310, "ain7",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x330, "vrefp",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x334, "vrefn",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x338, "avdd",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x33c, "avss",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x340, "iforce",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x344, "vsense",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+	_PIN(0x348, "testout",		0, 0, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL),
+#endif
+	{  .ballname = NULL  },
+const struct ti_pinmux_device ti_am335x_pinmux_dev = {
+	.padconf_muxmode_mask	= 0x7,
+	.padconf_sate_mask	= 0x78,
+	.padstate		= ti_padstate_devmap,
+	.padconf		= ti_padconf_devmap,
diff --git a/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c b/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
index 0000000000..7adbcbb365
--- /dev/null
+++ b/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
@@ -0,0 +1,461 @@
+ * are met:
+ * Exposes pinmux module to pinctrl-compatible interface
+#include <sys/mutex.h>
+#include <dev/ofw/openfirm.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <dev/fdt/fdt_pinctrl.h>
+#include <arm/ti/omap4/omap4_scm_padconf.h>
+#include <arm/ti/ti_cpuid.h>
+#include "ti_pinmux.h"
+struct pincfg {
+	uint32_t reg;
+	uint32_t conf;
+static struct resource_spec ti_pinmux_res_spec[] = {
+	{ SYS_RES_MEMORY,	0,	RF_ACTIVE },	/* Control memory window */
+	{ -1, 0 }
+static struct ti_pinmux_softc *ti_pinmux_sc;
+#define	ti_pinmux_read_2(sc, reg)		\
+    bus_space_read_2((sc)->sc_bst, (sc)->sc_bsh, (reg))
+#define	ti_pinmux_write_2(sc, reg, val)		\
+    bus_space_write_2((sc)->sc_bst, (sc)->sc_bsh, (reg), (val))
+#define	ti_pinmux_read_4(sc, reg)		\
+    bus_space_read_4((sc)->sc_bst, (sc)->sc_bsh, (reg))
+#define	ti_pinmux_write_4(sc, reg, val)		\
+    bus_space_write_4((sc)->sc_bst, (sc)->sc_bsh, (reg), (val))
+ *	ti_padconf_devmap - Array of pins, should be defined one per SoC
+ *	This array is typically defined in one of the targeted *_scm_pinumx.c
+ *	files and is specific to the given SoC platform. Each entry in the array
+ *	corresponds to an individual pin.
+static const struct ti_pinmux_device *ti_pinmux_dev;
+ *	ti_pinmux_padconf_from_name - searches the list of pads and returns entry
+ *	                             with matching ball name.
+ *	@ballname: the name of the ball
+ *	RETURNS:
+ *	A pointer to the matching padconf or NULL if the ball wasn't found.
+static const struct ti_pinmux_padconf*
+ti_pinmux_padconf_from_name(const char *ballname)
+	padconf = ti_pinmux_dev->padconf;
+	while (padconf->ballname != NULL) {
+		if (strcmp(ballname, padconf->ballname) == 0)
+			return(padconf);
+		padconf++;
+	return (NULL);
+ *	ti_pinmux_padconf_set_internal - sets the muxmode and state for a pad/pin
+ *	@padconf: pointer to the pad structure
+ *	@muxmode: the name of the mode to use for the pin, i.e. "uart1_rx"
+ *	@state: the state to put the pad/pin in, i.e. PADCONF_PIN_???
+ *	LOCKING:
+ *	Internally locks it's own context.
+ *	RETURNS:
+ *	0 on success.
+ *	EINVAL if pin requested is outside valid range or already in use.
+static int
+ti_pinmux_padconf_set_internal(struct ti_pinmux_softc *sc,
+    const struct ti_pinmux_padconf *padconf,
+    const char *muxmode, unsigned int state)
+	unsigned int mode;
+	uint16_t reg_val;
+	/* populate the new value for the PADCONF register */
+	reg_val = (uint16_t)(state & ti_pinmux_dev->padconf_sate_mask);
+	/* find the new mode requested */
+	for (mode = 0; mode < 8; mode++) {
+		if ((padconf->muxmodes[mode] != NULL) &&
+		    (strcmp(padconf->muxmodes[mode], muxmode) == 0)) {
+			break;
+	/* couldn't find the mux mode */
+	if (mode >= 8) {
+		printf("Invalid mode \"%s\"\n", muxmode);
+		return (EINVAL);
+	/* set the mux mode */
+	reg_val |= (uint16_t)(mode & ti_pinmux_dev->padconf_muxmode_mask);
+	if (bootverbose)
+		device_printf(sc->sc_dev, "setting internal %x for %s\n",
+		    reg_val, muxmode);
+	/* write the register value (16-bit writes) */
+	ti_pinmux_write_2(sc, padconf->reg_off, reg_val);
+	return (0);
+ *	ti_pinmux_padconf_set - sets the muxmode and state for a pad/pin
+ *	@padname: the name of the pad, i.e. "c12"
+ *	LOCKING:
+ *	RETURNS:
+ *	0 on success.
+int
+ti_pinmux_padconf_set(const char *padname, const char *muxmode, unsigned int state)
+	if (!ti_pinmux_sc)
+		return (ENXIO);
+	/* find the pin in the devmap */
+	padconf = ti_pinmux_padconf_from_name(padname);
+	if (padconf == NULL)
+		return (EINVAL);
+	return (ti_pinmux_padconf_set_internal(ti_pinmux_sc, padconf, muxmode, state));
+ *	ti_pinmux_padconf_get - gets the muxmode and state for a pad/pin
+ *	@muxmode: upon return will contain the name of the muxmode of the pin
+ *	@state: upon return will contain the state of the pad/pin
+ *	LOCKING:
+ *	RETURNS:
+ *	0 on success.
+int
+ti_pinmux_padconf_get(const char *padname, const char **muxmode,
+	uint16_t reg_val;
+		return (ENXIO);
+		return (EINVAL);
+	/* read the register value (16-bit reads) */
+	reg_val = ti_pinmux_read_2(ti_pinmux_sc, padconf->reg_off);
+	/* save the state */
+	if (state)
+		*state = (reg_val & ti_pinmux_dev->padconf_sate_mask);
+	/* save the mode */
+	if (muxmode)
+		*muxmode = padconf->muxmodes[(reg_val & ti_pinmux_dev->padconf_muxmode_mask)];
+	return (0);
+ *	ti_pinmux_padconf_set_gpiomode - converts a pad to GPIO mode.
+ *	@gpio: the GPIO pin number (0-195)
+ *	LOCKING:
+ *	RETURNS:
+ *	0 on success.
+int
+ti_pinmux_padconf_set_gpiomode(uint32_t gpio, unsigned int state)
+	uint16_t reg_val;
+		return (ENXIO);
+	/* find the gpio pin in the padconf array */
+		if (padconf->gpio_pin == gpio)
+			break;
+		padconf++;
+	if (padconf->ballname == NULL)
+		return (EINVAL);
+	reg_val |= (uint16_t)(padconf->gpio_mode & ti_pinmux_dev->padconf_muxmode_mask);
+	ti_pinmux_write_2(ti_pinmux_sc, padconf->reg_off, reg_val);
+	return (0);
+ *	ti_pinmux_padconf_get_gpiomode - gets the current GPIO mode of the pin
+ *	LOCKING:
+ *	RETURNS:
+ *	0 on success.
+ *	EINVAL if pin requested is outside valid range or not configured as GPIO.
+int
+ti_pinmux_padconf_get_gpiomode(uint32_t gpio, unsigned int *state)
+	uint16_t reg_val;
+		return (ENXIO);
+			break;
+		padconf++;
+		return (EINVAL);
+	/* read the current register settings */
+	/* check to make sure the pins is configured as GPIO in the first state */
+	if ((reg_val & ti_pinmux_dev->padconf_muxmode_mask) != padconf->gpio_mode)
+		return (EINVAL);
+	/* read and store the reset of the state, i.e. pull-up, pull-down, etc */
+	if (state)
+	return (0);
+static int
+ti_pinmux_configure_pins(device_t dev, phandle_t cfgxref)
+	struct pincfg *cfgtuples, *cfg;
+	phandle_t cfgnode;
+	int i, ntuples;
+	static struct ti_pinmux_softc *sc;
+	sc = device_get_softc(dev);
+	cfgnode = OF_node_from_xref(cfgxref);
+	ntuples = OF_getencprop_alloc_multi(cfgnode, "pinctrl-single,pins",
+	    sizeof(*cfgtuples), (void **)&cfgtuples);
+	if (ntuples < 0)
+		return (ENOENT);
+	if (ntuples == 0)
+		return (0); /* Empty property is not an error. */
+	for (i = 0, cfg = cfgtuples; i < ntuples; i++, cfg++) {
+		if (bootverbose) {
+			char name[32];
+			OF_getprop(cfgnode, "name", &name, sizeof(name));
+			printf("%16s: muxreg 0x%04x muxval 0x%02x\n",
+			    name, cfg->reg, cfg->conf);
+		ti_pinmux_write_2(sc, cfg->reg, cfg->conf);
+	OF_prop_free(cfgtuples);
+	return (0);
+ * Device part of OMAP SCM driver
+static int
+ti_pinmux_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "pinctrl-single"))
+		return (ENXIO);
+	if (ti_pinmux_sc) {
+		printf("%s: multiple pinctrl modules in device tree data, ignoring\n",
+		    __func__);
+		return (EEXIST);
+	switch (ti_chip()) {
+#ifdef SOC_OMAP4
+	case CHIP_OMAP_4:
+		ti_pinmux_dev = &omap4_pinmux_dev;
+		break;
+#endif
+#ifdef SOC_TI_AM335X
+	case CHIP_AM335X:
+		ti_pinmux_dev = &ti_am335x_pinmux_dev;
+		break;
+#endif
+	default:
+		printf("Unknown CPU in pinmux\n");
+		return (ENXIO);
+	device_set_desc(dev, "TI Pinmux Module");
+	return (BUS_PROBE_DEFAULT);
+ *	ti_pinmux_attach - attaches the pinmux to the simplebus
+ *	@dev: new device
+ *	RETURNS
+ *	Zero on success or ENXIO if an error occuried.
+static int
+ti_pinmux_attach(device_t dev)
+	struct ti_pinmux_softc *sc = device_get_softc(dev);
+#if 0
+	if (ti_pinmux_sc)
+		return (ENXIO);
+#endif
+	sc->sc_dev = dev;
+	if (bus_alloc_resources(dev, ti_pinmux_res_spec, sc->sc_res)) {
+		device_printf(dev, "could not allocate resources\n");
+		return (ENXIO);
+	sc->sc_bst = rman_get_bustag(sc->sc_res[0]);
+	sc->sc_bsh = rman_get_bushandle(sc->sc_res[0]);
+	if (ti_pinmux_sc == NULL)
+		ti_pinmux_sc = sc;
+	fdt_pinctrl_register(dev, "pinctrl-single,pins");
+	fdt_pinctrl_configure_tree(dev);
+	return (0);
+static device_method_t ti_pinmux_methods[] = {
+	DEVMETHOD(device_probe,		ti_pinmux_probe),
+	DEVMETHOD(device_attach,	ti_pinmux_attach),
+        /* fdt_pinctrl interface */
+	DEVMETHOD(fdt_pinctrl_configure, ti_pinmux_configure_pins),
+	{ 0, 0 }
+static driver_t ti_pinmux_driver = {
+	"ti_pinmux",
+	ti_pinmux_methods,
+	sizeof(struct ti_pinmux_softc),
+static devclass_t ti_pinmux_devclass;
+DRIVER_MODULE(ti_pinmux, simplebus, ti_pinmux_driver, ti_pinmux_devclass, 0, 0);
2.17.1
