[PATCH 3/4] bsps/beagle: Added SOC detection using FDT
G S Niteesh Babu niteesh.gs at gmail.com
Sat Mar 13 11:02:02 UTC 2021
Detects the SOC type using FDT and also replaces the ti_cpuid.h
header in FreeBSD with custom one.
 bsps/arm/beagle/start/bsp-soc-detect.c | 55 ++++++++++++++++++++++++++
 bsps/arm/beagle/start/bsp-soc-detect.h | 38 ++++++++++++++++++
 bsps/arm/beagle/start/bspstart.c       | 23 ++++++++---
 bsps/include/arm/ti/ti_cpuid.h         | 48 ++++++++++++++++++++++
 spec/build/bsps/arm/beagle/obj.yml     |  1 +
 5 files changed, 159 insertions(+), 6 deletions(-)
 create mode 100644 bsps/arm/beagle/start/bsp-soc-detect.c
 create mode 100644 bsps/arm/beagle/start/bsp-soc-detect.h
 create mode 100644 bsps/include/arm/ti/ti_cpuid.h
diff --git a/bsps/arm/beagle/start/bsp-soc-detect.c b/bsps/arm/beagle/start/bsp-soc-detect.c
new file mode 100644
index 0000000000..445c8881ff
--- /dev/null
+++ b/bsps/arm/beagle/start/bsp-soc-detect.c
@@ -0,0 +1,55 @@
+ * @file
+ * @ingroup arm_Beagle
+ * @brief
+ * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
+ * are met:
+#include <rtems/bspIo.h>
+#include <libfdt.h>
+#include <bsp/fdt.h>
+#include "bsp-soc-detect.h"
+int _ti_chip;
+void bsp_soc_detect( void )
+  const void *fdt = bsp_fdt_get();
+  if (fdt_node_offset_by_compatible(fdt, -1, "ti_am33xx") != FDT_ERR_NOTFOUND) {
+    _ti_chip = CHIP_AM335X;
+  } else if (fdt_node_offset_by_compatible(fdt, -1, "ti_omap3") != FDT_ERR_NOTFOUND) {
+    _ti_chip = CHIP_OMAP_3;
+  } else {
+    printk("Unknown platform");
+    _ti_chip = -1;
diff --git a/bsps/arm/beagle/start/bsp-soc-detect.h b/bsps/arm/beagle/start/bsp-soc-detect.h
index 0000000000..545bba3eaf
--- /dev/null
+++ b/bsps/arm/beagle/start/bsp-soc-detect.h
@@ -0,0 +1,38 @@
+ * @file
+ * @brief
+ * are met:
+#include <arm/ti/ti_cpuid.h>
+void bsp_soc_detect( void );
diff --git a/bsps/arm/beagle/start/bspstart.c b/bsps/arm/beagle/start/bspstart.c
index 3c05f2a9cd..0a6f1b4a64 100644
--- a/bsps/arm/beagle/start/bspstart.c
+++ b/bsps/arm/beagle/start/bspstart.c
@@ -19,17 +19,28 @@
 #include <bsp/linker-symbols.h>
 #include <bsp/i2c.h>
 #include <rtems/sysinit.h>
 #include "bspdebug.h"
 void bsp_start(void)
-#if IS_DM3730
-  const char* type = "dm3730-based";
-#endif
-#if IS_AM335X
-  const char* type = "am335x-based";
-#endif
+  const char *type;
+  bsp_soc_detect();
+  switch (ti_chip()) {
+    case CHIP_AM335X:
+      type = "am335x-based";
+      break;
+    case CHIP_OMAP_3:
+      type = "dm3730-based";
+      break;
+    default:
+      type = "Unknown SOC";
+      break;
   bsp_interrupt_initialize();
   printk("\nRTEMS Beagleboard: %s\n", type);
   printk("        ARM Debug: 0x%08x\n", (intptr_t) bbb_arm_debug_registers());
diff --git a/bsps/include/arm/ti/ti_cpuid.h b/bsps/include/arm/ti/ti_cpuid.h
index 0000000000..9d533db5d3
--- /dev/null
+++ b/bsps/include/arm/ti/ti_cpuid.h
@@ -0,0 +1,48 @@
+ * @file
+ * @ingroup LIBFREEBSD
+ * @brief
+ * are met:
+#include <assert.h>
+#define SOC_TI_AM335X
+#define CHIP_OMAP_4  0
+#define CHIP_AM335X  1
+#define CHIP_OMAP_3  2
+extern int _ti_chip;
+static __inline int ti_chip(void)
+  assert(_ti_chip != -1);
+  return _ti_chip;
diff --git a/spec/build/bsps/arm/beagle/obj.yml b/spec/build/bsps/arm/beagle/obj.yml
index 908c188547..5ad859ad8d 100644
--- a/spec/build/bsps/arm/beagle/obj.yml
+++ b/spec/build/bsps/arm/beagle/obj.yml
@@ -39,6 +39,7 @@ source:
 - bsps/arm/beagle/start/bspdebug.c
 - bsps/arm/beagle/start/bspreset.c
 - bsps/arm/beagle/start/bspstart.c
+- bsps/arm/beagle/start/bsp-soc-detect.c
 - bsps/arm/beagle/start/bspstarthooks.c
 - bsps/arm/beagle/start/bspstartmmu.c
 - bsps/arm/shared/cache/cache-cp15.c
2.17.1
