[PATCH 4/4] bsp/beagle: Ported Beagle pinmux driver to RTEMS
Niteesh G. S. niteesh.gs at gmail.com
Sat Mar 13 11:19:04 UTC 2021
Hello,
I tested this patch by removing the pinmux initialization code from the
Beagle I2C
driver and letting this driver do the initialization. I then used the I2C
driver to read
the EEPROM in the pocket beagle using the I2C driver. The initialization of
the
pinmux settings was also confirmed using JTAG.
To confirm that the driver also works in libBSD I used the media01 example
to
write a test file to the SD card. Though I couldn't write to it due to some
pre-existing
issue which I also faced during GSoC I was able to get the SD card details
like the size
and make which gives some hope that the driver works in libBSD too.
I kindly request people owning beagle hardware to test the driver.
I also apologies for the long inactivity, I was consumed with other
activities which left
me no free time to work on this post-GSoC.
Thanks,
Niteesh.
On Sat, Mar 13, 2021 at 4:32 PM G S Niteesh Babu <niteesh.gs at gmail.com>
wrote:
> The following files have been ported
> 1) ti_pinmux.c
> 2) ti_pinmux.h
> 3) am335x_scm_padconf.c
> 4) am335x_scm_padconf.h
> Update #3784
>  bsps/arm/beagle/start/bspstart.c              |  31 +++++
>  bsps/include/arm/ti/ti_pinmux.h               |   9 +-
>  .../sys/arm/ti/am335x/am335x_scm_padconf.c    |   4 +
>  bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c    | 115 +++++++++++++++++-
>  spec/build/bsps/obj.yml                       |   6 +
>  5 files changed, 163 insertions(+), 2 deletions(-)
> diff --git a/bsps/arm/beagle/start/bspstart.c
> b/bsps/arm/beagle/start/bspstart.c
> index 0a6f1b4a64..a0736294c9 100644
> --- a/bsps/arm/beagle/start/bspstart.c
> +++ b/bsps/arm/beagle/start/bspstart.c
> @@ -20,6 +20,8 @@
>  #include <bsp/i2c.h>
>  #include <rtems/sysinit.h>
>  #include "bsp-soc-detect.h"
> +#include <arm/ti/ti_pinmux.h>
> +#include <ofw/ofw.h>
>  #include "bspdebug.h"
> @@ -55,6 +57,29 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t
> icells)
>    return intr[0];
> +static void traverse_fdt_nodes( phandle_t node )
> +  for (node = rtems_ofw_child(node); node != 0; node =
> rtems_ofw_peer(node)) {
> +    traverse_fdt_nodes(node);
> +    if (!rtems_ofw_node_status(node))
> +      continue;
> +     * Put all driver initialization functions here
> +    beagle_pinmux_init(node);
> +static void bbb_drivers_initialize(void)
> +  phandle_t node = rtems_ofw_peer(0);
>  static void bbb_i2c_0_initialize(void)
>    int err;
> @@ -73,3 +98,9 @@ RTEMS_SYSINIT_ITEM(
>    RTEMS_SYSINIT_LAST,
>    RTEMS_SYSINIT_ORDER_LAST_BUT_5
> +RTEMS_SYSINIT_ITEM(
> +       bbb_drivers_initialize,
> +       RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> +       RTEMS_SYSINIT_ORDER_LAST
> diff --git a/bsps/include/arm/ti/ti_pinmux.h
> b/bsps/include/arm/ti/ti_pinmux.h
> index 52409df61d..208e327c2b 100644
> --- a/bsps/include/arm/ti/ti_pinmux.h
> +++ b/bsps/include/arm/ti/ti_pinmux.h
> @@ -42,6 +42,9 @@
>  #ifndef _TI_PINMUX_H_
>  #define _TI_PINMUX_H_
> +#ifdef __rtems__
> +#endif /* __rtems__ */
>  struct ti_pinmux_padconf {
>         uint16_t    reg_off;
> @@ -63,12 +66,16 @@ struct ti_pinmux_device {
>         const struct ti_pinmux_padconf  *padconf;
> +#ifndef __rtems__
>  struct ti_pinmux_softc {
>         device_t                sc_dev;
>         struct resource *       sc_res[4];
>         bus_space_tag_t         sc_bst;
>         bus_space_handle_t      sc_bsh;
> +#else /* __rtems__ */
> +void beagle_pinmux_init(phandle_t node);
>  int ti_pinmux_padconf_set(const char *padname, const char *muxmode,
>      unsigned int state);
> @@ -77,4 +84,4 @@ int ti_pinmux_padconf_get(const char *padname, const
> char **muxmode,
>  int ti_pinmux_padconf_set_gpiomode(uint32_t gpio, unsigned int state);
>  int ti_pinmux_padconf_get_gpiomode(uint32_t gpio, unsigned int *state);
> -#endif /* _TI_SCM_H_ */
> \ No newline at end of file
> +#endif /* _TI_SCM_H_ */
> diff --git a/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> b/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> index 44a36a754b..e5cb1801e1 100644
> --- a/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> +++ b/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> @@ -27,9 +27,12 @@
>  #include <sys/cdefs.h>
> +#ifndef __rtems__
>  __FBSDID("$FreeBSD$");
>  #include <sys/param.h>
> +#ifndef __rtems__
>  #include <sys/systm.h>
>  #include <sys/kernel.h>
>  #include <sys/module.h>
> @@ -45,6 +48,7 @@ __FBSDID("$FreeBSD$");
>  #include <sys/gpio.h>
>  #include <arm/ti/tivar.h>
>  #include <arm/ti/am335x/am335x_scm_padconf.h>
> diff --git a/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> b/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> index 7adbcbb365..cec30d2cc5 100644
> --- a/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> +++ b/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> @@ -34,9 +34,12 @@
>   * Exposes pinmux module to pinctrl-compatible interface
> +#ifndef __rtems__
> +#ifndef __rtems__
> @@ -55,22 +58,52 @@ __FBSDID("$FreeBSD$");
>  #include <dev/fdt/fdt_pinctrl.h>
>  #include <arm/ti/omap4/omap4_scm_padconf.h>
> +#include <ofw/ofw_compat.h>
>  #include <arm/ti/ti_cpuid.h>
> +#ifndef __rtems__
>  #include "ti_pinmux.h"
> +#include <stdio.h>
> +#include <string.h>
> +#include <errno.h>
> +#include <libfdt.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/sysinit.h>
>  struct pincfg {
>         uint32_t reg;
>         uint32_t conf;
> +#ifndef __rtems__
>  static struct resource_spec ti_pinmux_res_spec[] = {
>         { SYS_RES_MEMORY,       0,      RF_ACTIVE },    /* Control memory
> window */
>         { -1, 0 }
> +#ifdef __rtems__
> +struct ti_pinmux_softc {
> +#ifndef __rtems__
> +       device_t                sc_dev;
> +       struct resource *       sc_res[4];
> +       bus_space_tag_t         sc_bst;
> +       bus_space_handle_t      sc_bsh;
> +       int                     sc_bst;
> +       uintptr_t               sc_bsh;
>  static struct ti_pinmux_softc *ti_pinmux_sc;
> +#ifndef __rtems__
>  #define        ti_pinmux_read_2(sc, reg)               \
>      bus_space_read_2((sc)->sc_bst, (sc)->sc_bsh, (reg))
>  #define        ti_pinmux_write_2(sc, reg, val)         \
> @@ -79,6 +112,19 @@ static struct ti_pinmux_softc *ti_pinmux_sc;
>      bus_space_read_4((sc)->sc_bst, (sc)->sc_bsh, (reg))
>  #define        ti_pinmux_write_4(sc, reg, val)         \
>      bus_space_write_4((sc)->sc_bst, (sc)->sc_bsh, (reg), (val))
> +static uint16_t
> +ti_pinmux_read_2(struct ti_pinmux_softc *sc, uintptr_t ofs) {
> +       uintptr_t bsh = sc->sc_bsh;
> +       return *(uint16_t volatile *)(bsh + ofs);
> +static void
> +ti_pinmux_write_2(struct ti_pinmux_softc *sc, uintptr_t ofs, uint16_t
> val) {
> +       uint16_t volatile *bsp = (uint16_t volatile *)(bsh + ofs);
> +       *bsp = val;
> @@ -149,16 +195,22 @@ ti_pinmux_padconf_set_internal(struct
>         /* couldn't find the mux mode */
>         if (mode >= 8) {
> +#ifndef __rtems__
>                 printf("Invalid mode \"%s\"\n", muxmode);
> +               printk("Invalid mode \"%s\"\n", muxmode);
>                 return (EINVAL);
>         /* set the mux mode */
>         reg_val |= (uint16_t)(mode & ti_pinmux_dev->padconf_muxmode_mask);
> +#ifndef __rtems__
>         if (bootverbose)
>                 device_printf(sc->sc_dev, "setting internal %x for %s\n",
>                     reg_val, muxmode);
>         /* write the register value (16-bit writes) */
>         ti_pinmux_write_2(sc, padconf->reg_off, reg_val);
> @@ -331,14 +383,20 @@ ti_pinmux_padconf_get_gpiomode(uint32_t gpio,
>  static int
> +#ifndef __rtems__
>  ti_pinmux_configure_pins(device_t dev, phandle_t cfgxref)
> +ti_pinmux_configure_pins(struct ti_pinmux_softc *sc, phandle_t cfgxref)
>         struct pincfg *cfgtuples, *cfg;
>         phandle_t cfgnode;
>         int i, ntuples;
> +#ifndef __rtems__
>         static struct ti_pinmux_softc *sc;
>         sc = device_get_softc(dev);
>         cfgnode = OF_node_from_xref(cfgxref);
>         ntuples = OF_getencprop_alloc_multi(cfgnode, "pinctrl-single,pins",
>             sizeof(*cfgtuples), (void **)&cfgtuples);
> @@ -350,12 +408,14 @@ ti_pinmux_configure_pins(device_t dev, phandle_t
> cfgxref)
>                 return (0); /* Empty property is not an error. */
>         for (i = 0, cfg = cfgtuples; i < ntuples; i++, cfg++) {
> +#ifndef __rtems__
>                 if (bootverbose) {
>                         char name[32];
>                         OF_getprop(cfgnode, "name", &name, sizeof(name));
>                         printf("%16s: muxreg 0x%04x muxval 0x%02x\n",
>                             name, cfg->reg, cfg->conf);
>                 ti_pinmux_write_2(sc, cfg->reg, cfg->conf);
> @@ -370,6 +430,7 @@ ti_pinmux_configure_pins(device_t dev, phandle_t
> cfgxref)
>   * Device part of OMAP SCM driver
> +#ifndef __rtems__
>  static int
>  ti_pinmux_probe(device_t dev)
> @@ -404,7 +465,27 @@ ti_pinmux_probe(device_t dev)
>         device_set_desc(dev, "TI Pinmux Module");
>         return (BUS_PROBE_DEFAULT);
> +static void
> +beagle_pinctrl_configure_children(struct ti_pinmux_softc *sc, phandle_t
> parent)
> +       phandle_t node;
> +       int len;
> +       uint32_t phandle;
> +       for (node = OF_child(parent); node != 0; node = OF_peer(node)) {
> +               if (rtems_ofw_node_status(node)) {
> +                       beagle_pinctrl_configure_children(sc, node);
> +                       len = OF_getencprop(node, "pinctrl-0", &phandle,
> sizeof(phandle));
> +                       if (len == sizeof(phandle)) {
> +                               ti_pinmux_configure_pins(sc, phandle);
> +#ifndef __rtems__
>   *     ti_pinmux_attach - attaches the pinmux to the simplebus
>   *     @dev: new device
> @@ -440,7 +521,38 @@ ti_pinmux_attach(device_t dev)
>         return (0);
> +#endif
> +void
> +beagle_pinmux_init(phandle_t node)
> +       static struct ti_pinmux_softc pinmux_softc;
> +       rtems_ofw_memory_area reg;
> +       int rv;
> +       if (!rtems_ofw_is_node_compatible(node, "pinctrl-single"))
> +               return ;
> +       switch (ti_chip()) {
> +       case CHIP_AM335X:
> +               ti_pinmux_dev = &ti_am335x_pinmux_dev;
> +               break;
> +       default:
> +               printk("Unknown CPU in pinmux\n");
> +               return ;
> +       rv = rtems_ofw_get_reg(node, &reg, sizeof(reg));
> +       if (rv == -1) {
> +               printk("pinmux_init: rtems_ofw_get_reg failed %d\n", rv);
> +               return ;
> +       pinmux_softc.sc_bsh = reg.start;
> +       beagle_pinctrl_configure_children(&pinmux_softc, OF_peer(0));
> +#ifndef __rtems__
>  static device_method_t ti_pinmux_methods[] = {
>         DEVMETHOD(device_probe,         ti_pinmux_probe),
>         DEVMETHOD(device_attach,        ti_pinmux_attach),
> @@ -458,4 +570,5 @@ static driver_t ti_pinmux_driver = {
>  static devclass_t ti_pinmux_devclass;
> -DRIVER_MODULE(ti_pinmux, simplebus, ti_pinmux_driver, ti_pinmux_devclass,
> 0, 0);
> +DRIVER_MODULE(ti_pinmux, simplebus, ti_pinmux_driver, ti_pinmux_devclass,
> 0, 0);
> diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> index 6d2bef84d8..906d9aadc0 100644
> --- a/spec/build/bsps/obj.yml
> +++ b/spec/build/bsps/obj.yml
> @@ -60,6 +60,10 @@ install:
>    source:
>    - bsps/include/rtems/zilog/z8036.h
>    - bsps/include/rtems/zilog/z8530.h
> +- destination: ${BSP_INCLUDEDIR}/arm/ti
> +  source:
> +  - bsps/include/arm/ti/ti_pinmux.h
> +  - bsps/include/arm/ti/ti_cpuid.h
>  links:
>  - role: build-dependency
>    uid: objmpci
> @@ -101,4 +105,6 @@ source:
>  - bsps/shared/ofw/ofw.c
>  - bsps/shared/rtems-version.c
>  - bsps/shared/start/bootcard.c
> +- bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> +- bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
>  type: build
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210313/185e1e7b/attachment-0001.html>
