[PATCH 4/4] bsp/beagle: Ported Beagle pinmux driver to RTEMS
Christian Mauderer
oss at c-mauderer.de
Sun Mar 21 12:54:09 UTC 2021
Hello Niteesh,
thanks for the patches. I tested them (together with the libbsd one)
with BBB and a littlevgl demo and they work fine. I pushed them.
Best regards
Christian
PS: Sorry for the double mail. I used the wrong sender for the list (again).
On 13/03/2021 12:19, Niteesh G. S. wrote:
> Hello,
> I tested this patch by removing the pinmux initialization code from the
> Beagle I2C
> driver and letting this driver do the initialization. I then used the
> I2C driver to read
> the EEPROM in the pocket beagle using the I2C driver. The initialization
> of the
> pinmux settings was also confirmed using JTAG.
> To confirm that the driver also works in libBSD I used the media01
> example to
> write a test file to the SD card. Though I couldn't write to it due to
> some pre-existing
> issue which I also faced during GSoC I was able to get the SD card
> details like the size
> and make which gives some hope that the driver works in libBSD too.
> I kindly request people owning beagle hardware to test the driver.
> I also apologies for the long inactivity, I was consumed with other
> activities which left
> me no free time to work on this post-GSoC.
> Thanks,
> Niteesh.
> On Sat, Mar 13, 2021 at 4:32 PM G S Niteesh Babu <niteesh.gs at gmail.com
> <mailto:niteesh.gs at gmail.com>> wrote:
> The following files have been ported
> 1) ti_pinmux.c
> 2) ti_pinmux.h
> 3) am335x_scm_padconf.c
> 4) am335x_scm_padconf.h
> Update #3784
> bsps/arm/beagle/start/bspstart.c | 31 +++++
> bsps/include/arm/ti/ti_pinmux.h | 9 +-
> .../sys/arm/ti/am335x/am335x_scm_padconf.c | 4 +
> bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c | 115 +++++++++++++++++-
> spec/build/bsps/obj.yml | 6 +
> 5 files changed, 163 insertions(+), 2 deletions(-)
> diff --git a/bsps/arm/beagle/start/bspstart.c
> b/bsps/arm/beagle/start/bspstart.c
> index 0a6f1b4a64..a0736294c9 100644
> --- a/bsps/arm/beagle/start/bspstart.c
> +++ b/bsps/arm/beagle/start/bspstart.c
> @@ -20,6 +20,8 @@
> #include <bsp/i2c.h>
> #include <rtems/sysinit.h>
> #include "bsp-soc-detect.h"
> +#include <arm/ti/ti_pinmux.h>
> +#include <ofw/ofw.h>
> #include "bspdebug.h"
> @@ -55,6 +57,29 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr,
> size_t icells)
> return intr[0];
> +static void traverse_fdt_nodes( phandle_t node )
> + for (node = rtems_ofw_child(node); node != 0; node =
> rtems_ofw_peer(node)) {
> + traverse_fdt_nodes(node);
> + if (!rtems_ofw_node_status(node))
> + continue;
> + * Put all driver initialization functions here
> + beagle_pinmux_init(node);
> +static void bbb_drivers_initialize(void)
> + phandle_t node = rtems_ofw_peer(0);
> static void bbb_i2c_0_initialize(void)
> int err;
> @@ -73,3 +98,9 @@ RTEMS_SYSINIT_ITEM(
> RTEMS_SYSINIT_LAST,
> RTEMS_SYSINIT_ORDER_LAST_BUT_5
> +RTEMS_SYSINIT_ITEM(
> + bbb_drivers_initialize,
> + RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> + RTEMS_SYSINIT_ORDER_LAST
> diff --git a/bsps/include/arm/ti/ti_pinmux.h
> b/bsps/include/arm/ti/ti_pinmux.h
> index 52409df61d..208e327c2b 100644
> --- a/bsps/include/arm/ti/ti_pinmux.h
> +++ b/bsps/include/arm/ti/ti_pinmux.h
> @@ -42,6 +42,9 @@
> #ifndef _TI_PINMUX_H_
> #define _TI_PINMUX_H_
> +#ifdef __rtems__
> +#endif /* __rtems__ */
> struct ti_pinmux_padconf {
> uint16_t reg_off;
> @@ -63,12 +66,16 @@ struct ti_pinmux_device {
> const struct ti_pinmux_padconf *padconf;
> +#ifndef __rtems__
> struct ti_pinmux_softc {
> device_t sc_dev;
> struct resource * sc_res[4];
> bus_space_tag_t sc_bst;
> bus_space_handle_t sc_bsh;
> +#else /* __rtems__ */
> +void beagle_pinmux_init(phandle_t node);
> int ti_pinmux_padconf_set(const char *padname, const char *muxmode,
> unsigned int state);
> @@ -77,4 +84,4 @@ int ti_pinmux_padconf_get(const char *padname,
> const char **muxmode,
> int ti_pinmux_padconf_set_gpiomode(uint32_t gpio, unsigned int state);
> int ti_pinmux_padconf_get_gpiomode(uint32_t gpio, unsigned int
> *state);
> -#endif /* _TI_SCM_H_ */
> \ No newline at end of file
> +#endif /* _TI_SCM_H_ */
> diff --git
> a/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> b/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> index 44a36a754b..e5cb1801e1 100644
> --- a/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> +++ b/bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> @@ -27,9 +27,12 @@
> #include <sys/cdefs.h>
> +#ifndef __rtems__
> __FBSDID("$FreeBSD$");
> #include <sys/param.h>
> +#ifndef __rtems__
> #include <sys/systm.h>
> #include <sys/kernel.h>
> #include <sys/module.h>
> @@ -45,6 +48,7 @@ __FBSDID("$FreeBSD$");
> #include <sys/gpio.h>
> #include <arm/ti/tivar.h>
> #include <arm/ti/am335x/am335x_scm_padconf.h>
> diff --git a/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> b/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> index 7adbcbb365..cec30d2cc5 100644
> --- a/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> +++ b/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> @@ -34,9 +34,12 @@
> * Exposes pinmux module to pinctrl-compatible interface
> +#ifndef __rtems__
> +#ifndef __rtems__
> @@ -55,22 +58,52 @@ __FBSDID("$FreeBSD$");
> #include <dev/fdt/fdt_pinctrl.h>
> #include <arm/ti/omap4/omap4_scm_padconf.h>
> +#include <ofw/ofw_compat.h>
> #include <arm/ti/ti_cpuid.h>
> +#ifndef __rtems__
> #include "ti_pinmux.h"
> +#include <stdio.h>
> +#include <string.h>
> +#include <errno.h>
> +#include <libfdt.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/sysinit.h>
> struct pincfg {
> uint32_t reg;
> uint32_t conf;
> +#ifndef __rtems__
> static struct resource_spec ti_pinmux_res_spec[] = {
> { SYS_RES_MEMORY, 0, RF_ACTIVE }, /* Control
> memory window */
> { -1, 0 }
> +#ifdef __rtems__
> +struct ti_pinmux_softc {
> +#ifndef __rtems__
> + device_t sc_dev;
> + struct resource * sc_res[4];
> + bus_space_tag_t sc_bst;
> + bus_space_handle_t sc_bsh;
> + int sc_bst;
> + uintptr_t sc_bsh;
> static struct ti_pinmux_softc *ti_pinmux_sc;
> +#ifndef __rtems__
> #define ti_pinmux_read_2(sc, reg) \
> bus_space_read_2((sc)->sc_bst, (sc)->sc_bsh, (reg))
> #define ti_pinmux_write_2(sc, reg, val) \
> @@ -79,6 +112,19 @@ static struct ti_pinmux_softc *ti_pinmux_sc;
> bus_space_read_4((sc)->sc_bst, (sc)->sc_bsh, (reg))
> #define ti_pinmux_write_4(sc, reg, val) \
> bus_space_write_4((sc)->sc_bst, (sc)->sc_bsh, (reg), (val))
> +static uint16_t
> +ti_pinmux_read_2(struct ti_pinmux_softc *sc, uintptr_t ofs) {
> + uintptr_t bsh = sc->sc_bsh;
> + return *(uint16_t volatile *)(bsh + ofs);
> +static void
> +ti_pinmux_write_2(struct ti_pinmux_softc *sc, uintptr_t ofs,
> uint16_t val) {
> + uint16_t volatile *bsp = (uint16_t volatile *)(bsh + ofs);
> + *bsp = val;
> @@ -149,16 +195,22 @@ ti_pinmux_padconf_set_internal(struct
> /* couldn't find the mux mode */
> if (mode >= 8) {
> +#ifndef __rtems__
> printf("Invalid mode \"%s\"\n", muxmode);
> + printk("Invalid mode \"%s\"\n", muxmode);
> return (EINVAL);
> /* set the mux mode */
> reg_val |= (uint16_t)(mode &
> ti_pinmux_dev->padconf_muxmode_mask);
> +#ifndef __rtems__
> if (bootverbose)
> device_printf(sc->sc_dev, "setting internal %x for
> %s\n",
> reg_val, muxmode);
> /* write the register value (16-bit writes) */
> ti_pinmux_write_2(sc, padconf->reg_off, reg_val);
> @@ -331,14 +383,20 @@ ti_pinmux_padconf_get_gpiomode(uint32_t gpio,
> unsigned int *state)
> static int
> +#ifndef __rtems__
> ti_pinmux_configure_pins(device_t dev, phandle_t cfgxref)
> +ti_pinmux_configure_pins(struct ti_pinmux_softc *sc, phandle_t cfgxref)
> struct pincfg *cfgtuples, *cfg;
> phandle_t cfgnode;
> int i, ntuples;
> +#ifndef __rtems__
> static struct ti_pinmux_softc *sc;
> sc = device_get_softc(dev);
> cfgnode = OF_node_from_xref(cfgxref);
> ntuples = OF_getencprop_alloc_multi(cfgnode,
> "pinctrl-single,pins",
> sizeof(*cfgtuples), (void **)&cfgtuples);
> @@ -350,12 +408,14 @@ ti_pinmux_configure_pins(device_t dev,
> phandle_t cfgxref)
> return (0); /* Empty property is not an error. */
> for (i = 0, cfg = cfgtuples; i < ntuples; i++, cfg++) {
> +#ifndef __rtems__
> if (bootverbose) {
> char name[32];
> OF_getprop(cfgnode, "name", &name,
> sizeof(name));
> printf("%16s: muxreg 0x%04x muxval 0x%02x\n",
> name, cfg->reg, cfg->conf);
> ti_pinmux_write_2(sc, cfg->reg, cfg->conf);
> @@ -370,6 +430,7 @@ ti_pinmux_configure_pins(device_t dev, phandle_t
> cfgxref)
> * Device part of OMAP SCM driver
> +#ifndef __rtems__
> static int
> ti_pinmux_probe(device_t dev)
> @@ -404,7 +465,27 @@ ti_pinmux_probe(device_t dev)
> device_set_desc(dev, "TI Pinmux Module");
> return (BUS_PROBE_DEFAULT);
> +static void
> +beagle_pinctrl_configure_children(struct ti_pinmux_softc *sc,
> phandle_t parent)
> + phandle_t node;
> + int len;
> + uint32_t phandle;
> + for (node = OF_child(parent); node != 0; node = OF_peer(node)) {
> + if (rtems_ofw_node_status(node)) {
> + beagle_pinctrl_configure_children(sc, node);
> + len = OF_getencprop(node, "pinctrl-0",
> &phandle, sizeof(phandle));
> + if (len == sizeof(phandle)) {
> + ti_pinmux_configure_pins(sc, phandle);
> +#ifndef __rtems__
> * ti_pinmux_attach - attaches the pinmux to the simplebus
> * @dev: new device
> @@ -440,7 +521,38 @@ ti_pinmux_attach(device_t dev)
> return (0);
> +#endif
> +void
> +beagle_pinmux_init(phandle_t node)
> + static struct ti_pinmux_softc pinmux_softc;
> + rtems_ofw_memory_area reg;
> + int rv;
> + if (!rtems_ofw_is_node_compatible(node, "pinctrl-single"))
> + return ;
> + switch (ti_chip()) {
> + case CHIP_AM335X:
> + ti_pinmux_dev = &ti_am335x_pinmux_dev;
> + break;
> + default:
> + printk("Unknown CPU in pinmux\n");
> + return ;
> + rv = rtems_ofw_get_reg(node, ®, sizeof(reg));
> + if (rv == -1) {
> + printk("pinmux_init: rtems_ofw_get_reg failed %d\n",
> rv);
> + return ;
> + pinmux_softc.sc_bsh = reg.start;
> + beagle_pinctrl_configure_children(&pinmux_softc, OF_peer(0));
> +#ifndef __rtems__
> static device_method_t ti_pinmux_methods[] = {
> DEVMETHOD(device_probe, ti_pinmux_probe),
> DEVMETHOD(device_attach, ti_pinmux_attach),
> @@ -458,4 +570,5 @@ static driver_t ti_pinmux_driver = {
> static devclass_t ti_pinmux_devclass;
> -DRIVER_MODULE(ti_pinmux, simplebus, ti_pinmux_driver,
> ti_pinmux_devclass, 0, 0);
> +DRIVER_MODULE(ti_pinmux, simplebus, ti_pinmux_driver,
> diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> index 6d2bef84d8..906d9aadc0 100644
> --- a/spec/build/bsps/obj.yml
> +++ b/spec/build/bsps/obj.yml
> @@ -60,6 +60,10 @@ install:
> source:
> - bsps/include/rtems/zilog/z8036.h
> - bsps/include/rtems/zilog/z8530.h
> +- destination: ${BSP_INCLUDEDIR}/arm/ti
> + source:
> + - bsps/include/arm/ti/ti_pinmux.h
> + - bsps/include/arm/ti/ti_cpuid.h
> links:
> - role: build-dependency
> uid: objmpci
> @@ -101,4 +105,6 @@ source:
> - bsps/shared/ofw/ofw.c
> - bsps/shared/rtems-version.c
> - bsps/shared/start/bootcard.c
> +- bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> +- bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> type: build
> 2.17.1
> devel mailing list
> devel at rtems.org
