[PATCH] rtems-examples: Add CoreMark Benchmark
Gedare Bloom
gedare at rtems.org
Sun Mar 14 16:46:43 UTC 2021
Hi Hesham,
Nice work getting this integrated in the upstream. I guess that the
git submodule instructions for building with waf will work for this,
but not Make. How hard would it be for you to integrate the submodule
with Make?
This is fine with me as-is, I just want to know if we can keep it
supporting both build systems.
On Sat, Mar 13, 2021 at 12:50 AM Hesham Almatary
<hesham.almatary at cl.cam.ac.uk> wrote:
> CoreMark's primary goals are simplicity and providing a method for
> testing only a processor's core features. It is used primarily here as
> a performance benchmark.
> Built and tested for RISC-V rv64imafdc_medany on QEMU and HW
> .gitmodules | 3 +++
> benchmarks/coremark/coremark | 1 +
> benchmarks/coremark/wscript | 50 ++++++++++++++++++++++++++++++++++++
> benchmarks/wscript | 2 +-
> 4 files changed, 55 insertions(+), 1 deletion(-)
> create mode 160000 benchmarks/coremark/coremark
> create mode 100644 benchmarks/coremark/wscript
> diff --git a/.gitmodules b/.gitmodules
> index ae86e49..d7e52b9 100644
> --- a/.gitmodules
> +++ b/.gitmodules
> @@ -1,3 +1,6 @@
> [submodule "rtems_waf"]
> path = rtems_waf
> url = git://git.rtems.org/rtems_waf.git
> +[submodule "benchmarks/coremark/coremark"]
> + path = benchmarks/coremark/coremark
> + url = git at github.com:eembc/coremark.git
> diff --git a/benchmarks/coremark/coremark b/benchmarks/coremark/coremark
> new file mode 160000
> index 0000000..1541482
> --- /dev/null
> +++ b/benchmarks/coremark/coremark
> @@ -0,0 +1 @@
> +Subproject commit 1541482bf3e6ef7f5c69f5be76b14537b60833d0
> diff --git a/benchmarks/coremark/wscript b/benchmarks/coremark/wscript
> new file mode 100644
> index 0000000..2ec5f1e
> --- /dev/null
> +++ b/benchmarks/coremark/wscript
> @@ -0,0 +1,50 @@
> +# SPDX-License-Identifier: BSD-2-Clause
> +# Copyright (c) 2021 Hesham Almatary
> +# This software was developed by SRI International and the University of
> +# Cambridge Computer Laboratory (Department of Computer Science and
> +# Technology) under DARPA contract HR0011-18-C-0016 ("ECATS"), as part of the
> +# DARPA SSITH research programme.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions
> +# are met:
> +# 1. Redistributions of source code must retain the above copyright
> +# notice, this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> +# notice, this list of conditions and the following disclaimer in the
> +# documentation and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> +# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> +# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> +# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> +# OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> +# HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> +# LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> +# OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> +# SUCH DAMAGE.
> +import rtems_waf.rtems as rtems
> +def build(bld):
> + rtems.build(bld)
> + bld(features = 'c cprogram',
> + target = 'coremark.bin',
> + includes = ['coremark/', 'coremark/posix/'],
> + source = ['coremark/rtems/init.c', 'coremark/posix/core_portme.c',
> + 'coremark/core_list_join.c', 'coremark/core_main.c',
> + 'coremark/core_matrix.c', 'coremark/core_state.c',
> + 'coremark/core_util.c'],
> + defines = [
> + # FLAGS_STR is used within CoreMark to print the compiler flags used
> + 'FLAGS_STR="'+' '.join([str(flag) for flag in bld.env.CFLAGS])+'"'
> diff --git a/benchmarks/wscript b/benchmarks/wscript
> index 12741e7..0947060 100644
> --- a/benchmarks/wscript
> +++ b/benchmarks/wscript
> @@ -7,4 +7,4 @@ import rtems_waf.rtems as rtems
> def build(bld):
> bld.recurse('nbench')
> + bld.recurse('coremark')
I think we usually keep the blank line at the end of the wscript file.
Not a hard rule.
> 2.25.1
> devel mailing list
> devel at rtems.org
