[PATCH] rtems-examples: Add CoreMark Benchmark
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Mon Mar 15 10:53:14 UTC 2021
Hello Gedare,
Yeah adding Make support should be straightforward. I just assumed
Make will be deprecated soon based on [1] and haven't bothered
supporting it.
[1] https://github.com/RTEMS/rtems-examples/blob/983926a7e519be85f630c620430e7e1ac3e0f4ea/README.Makefile#L32
On Sun, 14 Mar 2021 at 18:47, Gedare Bloom <gedare at rtems.org> wrote:
> Hi Hesham,
> Nice work getting this integrated in the upstream. I guess that the
> git submodule instructions for building with waf will work for this,
> but not Make. How hard would it be for you to integrate the submodule
> with Make?
> This is fine with me as-is, I just want to know if we can keep it
> supporting both build systems.
> On Sat, Mar 13, 2021 at 12:50 AM Hesham Almatary
> <hesham.almatary at cl.cam.ac.uk> wrote:
> > CoreMark's primary goals are simplicity and providing a method for
> > testing only a processor's core features. It is used primarily here as
> > a performance benchmark.
> > Built and tested for RISC-V rv64imafdc_medany on QEMU and HW
> > .gitmodules | 3 +++
> > benchmarks/coremark/coremark | 1 +
> > benchmarks/coremark/wscript | 50 ++++++++++++++++++++++++++++++++++++
> > benchmarks/wscript | 2 +-
> > 4 files changed, 55 insertions(+), 1 deletion(-)
> > create mode 160000 benchmarks/coremark/coremark
> > create mode 100644 benchmarks/coremark/wscript
> > diff --git a/.gitmodules b/.gitmodules
> > index ae86e49..d7e52b9 100644
> > --- a/.gitmodules
> > +++ b/.gitmodules
> > @@ -1,3 +1,6 @@
> > [submodule "rtems_waf"]
> > path = rtems_waf
> > url = git://git.rtems.org/rtems_waf.git
> > +[submodule "benchmarks/coremark/coremark"]
> > + path = benchmarks/coremark/coremark
> > + url = git at github.com:eembc/coremark.git
> > diff --git a/benchmarks/coremark/coremark b/benchmarks/coremark/coremark
> > new file mode 160000
> > index 0000000..1541482
> > --- /dev/null
> > +++ b/benchmarks/coremark/coremark
> > @@ -0,0 +1 @@
> > +Subproject commit 1541482bf3e6ef7f5c69f5be76b14537b60833d0
> > diff --git a/benchmarks/coremark/wscript b/benchmarks/coremark/wscript
> > new file mode 100644
> > index 0000000..2ec5f1e
> > --- /dev/null
> > +++ b/benchmarks/coremark/wscript
> > @@ -0,0 +1,50 @@
> > +# SPDX-License-Identifier: BSD-2-Clause
> > +# Copyright (c) 2021 Hesham Almatary
> > +# This software was developed by SRI International and the University of
> > +# Cambridge Computer Laboratory (Department of Computer Science and
> > +# Technology) under DARPA contract HR0011-18-C-0016 ("ECATS"), as part of the
> > +# DARPA SSITH research programme.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> > +# are met:
> > +# 1. Redistributions of source code must retain the above copyright
> > +# notice, this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> > +# notice, this list of conditions and the following disclaimer in the
> > +# documentation and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> > +# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> > +# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> > +# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> > +# OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> > +# HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> > +# LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> > +# OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> > +# SUCH DAMAGE.
> > +import rtems_waf.rtems as rtems
> > +def build(bld):
> > + rtems.build(bld)
> > + bld(features = 'c cprogram',
> > + target = 'coremark.bin',
> > + includes = ['coremark/', 'coremark/posix/'],
> > + source = ['coremark/rtems/init.c', 'coremark/posix/core_portme.c',
> > + 'coremark/core_list_join.c', 'coremark/core_main.c',
> > + 'coremark/core_matrix.c', 'coremark/core_state.c',
> > + 'coremark/core_util.c'],
> > + defines = [
> > + # FLAGS_STR is used within CoreMark to print the compiler flags used
> > + 'FLAGS_STR="'+' '.join([str(flag) for flag in bld.env.CFLAGS])+'"'
> > diff --git a/benchmarks/wscript b/benchmarks/wscript
> > index 12741e7..0947060 100644
> > --- a/benchmarks/wscript
> > +++ b/benchmarks/wscript
> > @@ -7,4 +7,4 @@ import rtems_waf.rtems as rtems
> > def build(bld):
> > bld.recurse('nbench')
> > + bld.recurse('coremark')
> I think we usually keep the blank line at the end of the wscript file.
> Not a hard rule.
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
