[PATCH 4/5] flashdisk.c: Fix Resource leak (CID #1439298)
Joel Sherrill
joel at rtems.org
Mon Mar 15 03:21:28 UTC 2021
On Sun, Mar 14, 2021, 9:27 PM Chris Johns <chrisj at rtems.org> wrote:
> On 13/3/21 2:18 am, Ryan Long wrote:
> > CID 1439298: Resource leak in rtems_fdisk_initialize().
> > Closes #4299
> > cpukit/libblock/src/flashdisk.c | 42
> > 1 file changed, 31 insertions(+), 11 deletions(-)
> > diff --git a/cpukit/libblock/src/flashdisk.c
> b/cpukit/libblock/src/flashdisk.c
> > index 91f99e0..c4bac82 100644
> > --- a/cpukit/libblock/src/flashdisk.c
> > +++ b/cpukit/libblock/src/flashdisk.c
> > @@ -2463,6 +2463,7 @@ rtems_fdisk_initialize (rtems_device_major_number
> major,
> > char name[] = RTEMS_FLASHDISK_DEVICE_BASE_NAME "a";
> > uint32_t device;
> > + uint32_t device_to_free;
> > uint32_t blocks = 0;
> > int ret;
> > @@ -2485,18 +2486,27 @@ rtems_fdisk_initialize
> (rtems_device_major_number major,
> > * One copy buffer of a page size.
> > fd->copy_buffer = malloc (c->block_size);
> > - if (!fd->copy_buffer)
> > + if (!fd->copy_buffer) {
> > + free(fd);
> > return RTEMS_NO_MEMORY;
> > fd->blocks = calloc (blocks, sizeof (rtems_fdisk_block_ctl));
> > - if (!fd->blocks)
> > + if (!fd->blocks) {
> > + free(fd->copy_buffer);
> > + free(fd);
> > fd->block_count = blocks;
> > fd->devices = calloc (c->device_count, sizeof
> (rtems_fdisk_device_ctl));
> > - if (!fd->devices)
> > + if (!fd->devices) {
> > + free (fd->blocks);
> > + free (fd->copy_buffer);
> > + free (fd);
> > rtems_mutex_init (&fd->lock, "Flash Disk");
> > @@ -2505,9 +2515,10 @@ rtems_fdisk_initialize (rtems_device_major_number
> major,
> > if (sc != RTEMS_SUCCESSFUL)
> > rtems_mutex_destroy (&fd->lock);
> > - free (fd->copy_buffer);
> > - free (fd->blocks);
> > free (fd->devices);
> Why the order change?
Does the change make it exactly the opposite order of creation or do you
see it not being in inverse order?
This was a hard one. It was missing a LOT of cleanup.
> > + free (fd);
> What happens to the created blkdev the fd is passed into? Does that need
> to be
> destroyed before this is released?
I didn't recognise that as an allocation. What's the destroy call for that?
> Same for the other cases below?
> Chris
> > rtems_fdisk_error ("disk create phy failed");
> > return sc;
> > @@ -2524,11 +2535,14 @@ rtems_fdisk_initialize
> > sizeof
> (rtems_fdisk_segment_ctl));
> > if (!fd->devices[device].segments)
> > + for (device_to_free = device - 1; device_to_free >= 0;
> device_to_free--)
> > + free(fd->devices[device_to_free].segments);
> > unlink (name);
> > free (fd->devices);
> > + free (fd);
> > @@ -2559,11 +2573,14 @@ rtems_fdisk_initialize
> > ret = rtems_fdisk_recover_block_mappings (fd);
> > if (ret)
> device_to_free--)
> > unlink (name);
> > free (fd->devices);
> > + free (fd);
> > rtems_fdisk_error ("recovery of disk failed: %s (%d)",
> > strerror (ret), ret);
> > return ret;
> > @@ -2572,11 +2589,14 @@ rtems_fdisk_initialize
> > ret = rtems_fdisk_compact (fd);
> > if (ret)
> device_to_free--)
> > unlink (name);
> > free (fd->devices);
> > + free (fd);
> > rtems_fdisk_error ("compacting of disk failed: %s (%d)",
> > return ret;
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210314/af97146e/attachment-0001.html>
