[PATCH 4/5] flashdisk.c: Fix Resource leak (CID #1439298)
Mon Mar 15 00:37:34 UTC 2021
On 13/3/21 2:18 am, Ryan Long wrote:
> CID 1439298: Resource leak in rtems_fdisk_initialize().
> Closes #4299
>  cpukit/libblock/src/flashdisk.c | 42 ++++++++++++++++++++++++++++++-----------
>  1 file changed, 31 insertions(+), 11 deletions(-)
> diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
> index 91f99e0..c4bac82 100644
> --- a/cpukit/libblock/src/flashdisk.c
> +++ b/cpukit/libblock/src/flashdisk.c
> @@ -2463,6 +2463,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
>      char     name[] = RTEMS_FLASHDISK_DEVICE_BASE_NAME "a";
>      uint32_t device;
> +    uint32_t device_to_free;
>      uint32_t blocks = 0;
>      int      ret;
> @@ -2485,18 +2486,27 @@ rtems_fdisk_initialize (rtems_device_major_number major,
>       * One copy buffer of a page size.
>      fd->copy_buffer = malloc (c->block_size);
> -    if (!fd->copy_buffer)
> +    if (!fd->copy_buffer) {
> +      free(fd);
>        return RTEMS_NO_MEMORY;
>      fd->blocks = calloc (blocks, sizeof (rtems_fdisk_block_ctl));
> -    if (!fd->blocks)
> +    if (!fd->blocks) {
> +      free(fd->copy_buffer);
> +      free(fd);
>      fd->block_count = blocks;
>      fd->devices = calloc (c->device_count, sizeof (rtems_fdisk_device_ctl));
> -    if (!fd->devices)
> +    if (!fd->devices) {
> +      free (fd->blocks);
> +      free (fd->copy_buffer);
> +      free (fd);
>      rtems_mutex_init (&fd->lock, "Flash Disk");
> @@ -2505,9 +2515,10 @@ rtems_fdisk_initialize (rtems_device_major_number major,
>      if (sc != RTEMS_SUCCESSFUL)
>        rtems_mutex_destroy (&fd->lock);
> -      free (fd->copy_buffer);
> -      free (fd->blocks);
>        free (fd->devices);
Why the order change?
> +      free (fd);
What happens to the created blkdev the fd is passed into? Does that need to be
destroyed before this is released?
Same for the other cases below?
>        rtems_fdisk_error ("disk create phy failed");
>        return sc;
> @@ -2524,11 +2535,14 @@ rtems_fdisk_initialize (rtems_device_major_number major,
>                                               sizeof (rtems_fdisk_segment_ctl));
>        if (!fd->devices[device].segments)
> +        for (device_to_free = device - 1; device_to_free >= 0; device_to_free--)
> +	  free(fd->devices[device_to_free].segments);
>          unlink (name);
>          free (fd->devices);
> +        free (fd);
> @@ -2559,11 +2573,14 @@ rtems_fdisk_initialize (rtems_device_major_number major,
>      ret = rtems_fdisk_recover_block_mappings (fd);
>      if (ret)
>        unlink (name);
>        free (fd->devices);
> +      free (fd);
>        rtems_fdisk_error ("recovery of disk failed: %s (%d)",
>                           strerror (ret), ret);
>        return ret;
> @@ -2572,11 +2589,14 @@ rtems_fdisk_initialize (rtems_device_major_number major,
>      ret = rtems_fdisk_compact (fd);
>      if (ret)
>        unlink (name);
>        free (fd->devices);
> +      free (fd);
>        rtems_fdisk_error ("compacting of disk failed: %s (%d)",
>        return ret;
