[PATCH 6/6] rtems-docs: Edit commands to build first app
Gedare Bloom
gedare at rtems.org
Mon Mar 15 19:50:31 UTC 2021
Hi Ida,
did you send the same set of patches twice, or are there changes
between the two sets?
On Sun, Mar 14, 2021 at 8:26 PM Ida Delphine <idadelm at gmail.com> wrote:
> user/start/app.rst | 104 ++++++++++++++++++++++-----------------------
> 1 file changed, 52 insertions(+), 52 deletions(-)
> diff --git a/user/start/app.rst b/user/start/app.rst
> index 8900f78..c343551 100644
> --- a/user/start/app.rst
> +++ b/user/start/app.rst
> @@ -8,7 +8,7 @@ Build Your Application
> You tested a BSP in the previous section. We built the ``erc32`` BSP
> -and it is installed under :file:`$HOME/quick-start/rtems/5`.
> +and it is installed under :file:`$HOME/quick-start/rtems/6`.
> We will now create a simple Hello World application with a Git
> repository and using the `Waf <https://waf.io>`_ build system.
> @@ -107,7 +107,7 @@ and copy the Waf script:
> from __future__ import print_function
> - rtems_version = "5"
> + rtems_version = "6"
> try:
> import rtems_waf.rtems as rtems
> @@ -142,52 +142,52 @@ Configure the application using Waf's ``configure`` command:
> .. code-block:: none
> - ./waf configure --rtems=$HOME/quick-start/rtems/5 --rtems-bsp=sparc/erc32
> + ./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32 --rtems-version=6
> The output will be something close to:
> - Setting top to : $BASE/app/hello
> - Setting out to : $BASE/app/hello/build
> - RTEMS Version : 5
> - Architectures : sparc-rtems5
> - Board Support Package (BSP) : sparc-rtems5-erc32
> - Show commands : no
> - Long commands : no
> - Checking for program 'sparc-rtems5-gcc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
> - Checking for program 'sparc-rtems5-g++' : $BASE/rtems/5/bin/sparc-rtems5-g++
> - Checking for program 'sparc-rtems5-ld' : $BASE/rtems/5/bin/sparc-rtems5-ld
> - Checking for program 'sparc-rtems5-ar' : $BASE/rtems/5/bin/sparc-rtems5-ar
> - Checking for program 'sparc-rtems5-nm' : $BASE/rtems/5/bin/sparc-rtems5-nm
> - Checking for program 'sparc-rtems5-objdump' : $BASE/rtems/5/bin/sparc-rtems5-objdump
> - Checking for program 'sparc-rtems5-objcopy' : $BASE/rtems/5/bin/sparc-rtems5-objcopy
> - Checking for program 'sparc-rtems5-readelf' : $BASE/rtems/5/bin/sparc-rtems5-readelf
> - Checking for program 'sparc-rtems5-strip' : $BASE/rtems/5/bin/sparc-rtems5-strip
> - Checking for program 'sparc-rtems5-ranlib' : $BASE/rtems/5/bin/sparc-rtems5-ranlib
> - Checking for program 'rtems-ld' : $BASE/rtems/5/bin/rtems-ld
> - Checking for program 'rtems-tld' : $BASE/rtems/5/bin/rtems-tld
> - Checking for program 'rtems-syms' : $BASE/rtems/5/bin/rtems-syms
> - Checking for program 'rtems-bin2c' : $BASE/rtems/5/bin/rtems-bin2c
> - Checking for program 'tar' : /usr/bin/tar
> - Checking for program 'gcc, cc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
> - Checking for program 'ar' : $BASE/rtems/5/bin/sparc-rtems5-ar
> - Checking for program 'g++, c++' : $BASE/rtems/5/bin/sparc-rtems5-g++
> - Checking for program 'gas, gcc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
> - Checking for c flags '-MMD' : yes
> - Checking for cxx flags '-MMD' : yes
> - Compiler version (sparc-rtems5-gcc) : 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
> - Checking for a valid RTEMS BSP installation : yes
> - Checking for RTEMS_DEBUG : no
> - Checking for RTEMS_MULTIPROCESSING : no
> - Checking for RTEMS_NEWLIB : yes
> - Checking for RTEMS_POSIX_API : yes
> - Checking for RTEMS_SMP : no
> - Checking for RTEMS_NETWORKING : no
> - 'configure' finished successfully (0.686s)
> + Setting top to : $BASE/app/hello
> + Setting out to : $BASE/app/hello/build
> + RTEMS Version : 6
> + Architectures : sparc-rtems6
> + Board Support Package (BSP) : sparc-rtems6-erc32
> + Show commands : no
> + Long commands : no
> + Checking for program 'sparc-rtems6-gcc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
> + Checking for program 'sparc-rtems6-g++' : $BASE/rtems/6/bin/sparc-rtems6-g++
> + Checking for program 'sparc-rtems6-ld' : $BASE/rtems/6/bin/sparc-rtems6-ld
> + Checking for program 'sparc-rtems6-ar' : $BASE/rtems/6/bin/sparc-rtems6-ar
> + Checking for program 'sparc-rtems6-nm' : $BASE/rtems/6/bin/sparc-rtems6-nm
> + Checking for program 'sparc-rtems6-objdump' : $BASE/rtems/6/bin/sparc-rtems6-objdump
> + Checking for program 'sparc-rtems6-objcopy' : $BASE/rtems/6/bin/sparc-rtems6-objcopy
> + Checking for program 'sparc-rtems6-readelf' : $BASE/rtems/6/bin/sparc-rtems6-readelf
> + Checking for program 'sparc-rtems6-strip' : $BASE/rtems/6/bin/sparc-rtems6-strip
> + Checking for program 'sparc-rtems6-ranlib' : $BASE/rtems/6/bin/sparc-rtems6-ranlib
> + Checking for program 'rtems-ld' : $BASE/rtems/6/bin/rtems-ld
> + Checking for program 'rtems-tld' : $BASE/rtems/6/bin/rtems-tld
> + Checking for program 'rtems-syms' : $BASE/rtems/6/bin/rtems-syms
> + Checking for program 'rtems-bin2c' : $BASE/rtems/6/bin/rtems-bin2c
> + Checking for program 'tar' : /usr/bin/tar
> + Checking for program 'gcc, cc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
> + Checking for program 'ar' : $BASE/rtems/6/bin/sparc-rtems6-ar
> + Checking for program 'g++, c++' : $BASE/rtems/6/bin/sparc-rtems6-g++
> + Checking for program 'gas, gcc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
> + Checking for c flags '-MMD' : yes
> + Checking for cxx flags '-MMD' : yes
> + Compiler version (sparc-rtems6-gcc) : 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
> + Checking for a valid RTEMS BSP installation : yes
> + Checking for RTEMS_DEBUG : no
> + Checking for RTEMS_MULTIPROCESSING : no
> + Checking for RTEMS_NEWLIB : yes
> + Checking for RTEMS_POSIX_API : no
> + Checking for RTEMS_SMP : no
> + Checking for RTEMS_NETWORKING : no
> + 'configure' finished successfully (1.142s)
> Build the application:
> @@ -199,24 +199,24 @@ The output will be something close to:
> - Waf: Entering directory `$BASE/app/hello/build/sparc-rtems5-erc32'
> + Waf: Entering directory `$BASE/app/hello/build/sparc-rtems6-erc32'
> [1/3] Compiling init.c
> [2/3] Compiling hello.c
> - [3/3] Linking build/sparc-rtems5-erc32/hello.exe
> - Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems5-erc32'
> - 'build-sparc-rtems5-erc32' finished successfully (0.183s)
> + [3/3] Linking build/sparc-rtems6-erc32/hello.exe
> + Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems6-erc32'
> + 'build-sparc-rtems6-erc32' finished successfully (0.183s)
> Run the executable:
> - $HOME/quick-start/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
> + $HOME/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems6-erc32/hello.exe
> - RTEMS Testing - Run, 5.1.0
> + RTEMS Testing - Run, 6
> Command Line: $BASE/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
> Host: FreeBSD hihi 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64
> Python: 3.7.6 (default, Jan 30 2020, 01:18:54) [Clang 6.0.1 (tags/RELEASE_601/final 335540)]
> @@ -232,10 +232,10 @@ The output will be something close to:
> Hello World
> *** FATAL ***
> - fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> + fatal source: 6 (RTEMS_FATAL_SOURCE_EXIT)
> fatal code: 0 (0x00000000)
> - RTEMS version: 5.1.0
> - RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
> + RTEMS version: 6
> + RTEMS tools: 7.5.0 20191114 (RTEMS 6, RSB 6, Newlib fbaa096)
> executing thread ID: 0x08a010001
> executing thread name: UI1
> cpu 0 in error mode (tt = 0x101)
> 2.25.1
> devel mailing list
> devel at rtems.org
