[PATCH 6/6] rtems-docs: Edit commands to build first app
Gedare Bloom
gedare at rtems.org
Mon Mar 15 19:56:58 UTC 2021
Hi Ida,
On Mon, Mar 15, 2021 at 1:50 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Ida,
> did you send the same set of patches twice, or are there changes
> between the two sets?
Since I'm not quite sure what to look at here, please do me a favor
and send a new patchset with a -v2 indicator [1], and also set the
patch message to specify rtems-docs. git format patch supports to set
the prefix with:
git format-patch HEAD^ --subject-prefix="PATCH rtems-docs"
You can also create an alias to make this simpler [2]. In fact, if you
can send a patch to add instructions how to set up patch message with
the repo name to the text at [1] that would be another nice
contribution :)
[1] https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
[2] https://lists.rtems.org/pipermail/devel/2020-April/059308.html
Thank you,
Gedare
> On Sun, Mar 14, 2021 at 8:26 PM Ida Delphine <idadelm at gmail.com> wrote:
> > user/start/app.rst | 104 ++++++++++++++++++++++-----------------------
> > 1 file changed, 52 insertions(+), 52 deletions(-)
> > diff --git a/user/start/app.rst b/user/start/app.rst
> > index 8900f78..c343551 100644
> > --- a/user/start/app.rst
> > +++ b/user/start/app.rst
> > @@ -8,7 +8,7 @@ Build Your Application
> > You tested a BSP in the previous section. We built the ``erc32`` BSP
> > -and it is installed under :file:`$HOME/quick-start/rtems/5`.
> > +and it is installed under :file:`$HOME/quick-start/rtems/6`.
> > We will now create a simple Hello World application with a Git
> > repository and using the `Waf <https://waf.io>`_ build system.
> > @@ -107,7 +107,7 @@ and copy the Waf script:
> > from __future__ import print_function
> > - rtems_version = "5"
> > + rtems_version = "6"
> > try:
> > import rtems_waf.rtems as rtems
> > @@ -142,52 +142,52 @@ Configure the application using Waf's ``configure`` command:
> > .. code-block:: none
> > - ./waf configure --rtems=$HOME/quick-start/rtems/5 --rtems-bsp=sparc/erc32
> > + ./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32 --rtems-version=6
> > The output will be something close to:
> > - Setting top to : $BASE/app/hello
> > - Setting out to : $BASE/app/hello/build
> > - RTEMS Version : 5
> > - Architectures : sparc-rtems5
> > - Board Support Package (BSP) : sparc-rtems5-erc32
> > - Show commands : no
> > - Long commands : no
> > - Checking for program 'sparc-rtems5-gcc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
> > - Checking for program 'sparc-rtems5-g++' : $BASE/rtems/5/bin/sparc-rtems5-g++
> > - Checking for program 'sparc-rtems5-ld' : $BASE/rtems/5/bin/sparc-rtems5-ld
> > - Checking for program 'sparc-rtems5-ar' : $BASE/rtems/5/bin/sparc-rtems5-ar
> > - Checking for program 'sparc-rtems5-nm' : $BASE/rtems/5/bin/sparc-rtems5-nm
> > - Checking for program 'sparc-rtems5-objdump' : $BASE/rtems/5/bin/sparc-rtems5-objdump
> > - Checking for program 'sparc-rtems5-objcopy' : $BASE/rtems/5/bin/sparc-rtems5-objcopy
> > - Checking for program 'sparc-rtems5-readelf' : $BASE/rtems/5/bin/sparc-rtems5-readelf
> > - Checking for program 'sparc-rtems5-strip' : $BASE/rtems/5/bin/sparc-rtems5-strip
> > - Checking for program 'sparc-rtems5-ranlib' : $BASE/rtems/5/bin/sparc-rtems5-ranlib
> > - Checking for program 'rtems-ld' : $BASE/rtems/5/bin/rtems-ld
> > - Checking for program 'rtems-tld' : $BASE/rtems/5/bin/rtems-tld
> > - Checking for program 'rtems-syms' : $BASE/rtems/5/bin/rtems-syms
> > - Checking for program 'rtems-bin2c' : $BASE/rtems/5/bin/rtems-bin2c
> > - Checking for program 'tar' : /usr/bin/tar
> > - Checking for program 'gcc, cc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
> > - Checking for program 'ar' : $BASE/rtems/5/bin/sparc-rtems5-ar
> > - Checking for program 'g++, c++' : $BASE/rtems/5/bin/sparc-rtems5-g++
> > - Checking for program 'gas, gcc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
> > - Checking for c flags '-MMD' : yes
> > - Checking for cxx flags '-MMD' : yes
> > - Compiler version (sparc-rtems5-gcc) : 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
> > - Checking for a valid RTEMS BSP installation : yes
> > - Checking for RTEMS_DEBUG : no
> > - Checking for RTEMS_MULTIPROCESSING : no
> > - Checking for RTEMS_NEWLIB : yes
> > - Checking for RTEMS_POSIX_API : yes
> > - Checking for RTEMS_SMP : no
> > - Checking for RTEMS_NETWORKING : no
> > - 'configure' finished successfully (0.686s)
> > + Setting top to : $BASE/app/hello
> > + Setting out to : $BASE/app/hello/build
> > + RTEMS Version : 6
> > + Architectures : sparc-rtems6
> > + Board Support Package (BSP) : sparc-rtems6-erc32
> > + Show commands : no
> > + Long commands : no
> > + Checking for program 'sparc-rtems6-gcc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
> > + Checking for program 'sparc-rtems6-g++' : $BASE/rtems/6/bin/sparc-rtems6-g++
> > + Checking for program 'sparc-rtems6-ld' : $BASE/rtems/6/bin/sparc-rtems6-ld
> > + Checking for program 'sparc-rtems6-ar' : $BASE/rtems/6/bin/sparc-rtems6-ar
> > + Checking for program 'sparc-rtems6-nm' : $BASE/rtems/6/bin/sparc-rtems6-nm
> > + Checking for program 'sparc-rtems6-objdump' : $BASE/rtems/6/bin/sparc-rtems6-objdump
> > + Checking for program 'sparc-rtems6-objcopy' : $BASE/rtems/6/bin/sparc-rtems6-objcopy
> > + Checking for program 'sparc-rtems6-readelf' : $BASE/rtems/6/bin/sparc-rtems6-readelf
> > + Checking for program 'sparc-rtems6-strip' : $BASE/rtems/6/bin/sparc-rtems6-strip
> > + Checking for program 'sparc-rtems6-ranlib' : $BASE/rtems/6/bin/sparc-rtems6-ranlib
> > + Checking for program 'rtems-ld' : $BASE/rtems/6/bin/rtems-ld
> > + Checking for program 'rtems-tld' : $BASE/rtems/6/bin/rtems-tld
> > + Checking for program 'rtems-syms' : $BASE/rtems/6/bin/rtems-syms
> > + Checking for program 'rtems-bin2c' : $BASE/rtems/6/bin/rtems-bin2c
> > + Checking for program 'tar' : /usr/bin/tar
> > + Checking for program 'gcc, cc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
> > + Checking for program 'ar' : $BASE/rtems/6/bin/sparc-rtems6-ar
> > + Checking for program 'g++, c++' : $BASE/rtems/6/bin/sparc-rtems6-g++
> > + Checking for program 'gas, gcc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
> > + Checking for c flags '-MMD' : yes
> > + Checking for cxx flags '-MMD' : yes
> > + Compiler version (sparc-rtems6-gcc) : 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
> > + Checking for a valid RTEMS BSP installation : yes
> > + Checking for RTEMS_DEBUG : no
> > + Checking for RTEMS_MULTIPROCESSING : no
> > + Checking for RTEMS_NEWLIB : yes
> > + Checking for RTEMS_POSIX_API : no
> > + Checking for RTEMS_SMP : no
> > + Checking for RTEMS_NETWORKING : no
> > + 'configure' finished successfully (1.142s)
> > Build the application:
> > @@ -199,24 +199,24 @@ The output will be something close to:
> > - Waf: Entering directory `$BASE/app/hello/build/sparc-rtems5-erc32'
> > + Waf: Entering directory `$BASE/app/hello/build/sparc-rtems6-erc32'
> > [1/3] Compiling init.c
> > [2/3] Compiling hello.c
> > - [3/3] Linking build/sparc-rtems5-erc32/hello.exe
> > - Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems5-erc32'
> > - 'build-sparc-rtems5-erc32' finished successfully (0.183s)
> > + [3/3] Linking build/sparc-rtems6-erc32/hello.exe
> > + Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems6-erc32'
> > + 'build-sparc-rtems6-erc32' finished successfully (0.183s)
> > Run the executable:
> > - $HOME/quick-start/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
> > + $HOME/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems6-erc32/hello.exe
> > - RTEMS Testing - Run, 5.1.0
> > + RTEMS Testing - Run, 6
> > Command Line: $BASE/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
> > Host: FreeBSD hihi 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64
> > Python: 3.7.6 (default, Jan 30 2020, 01:18:54) [Clang 6.0.1 (tags/RELEASE_601/final 335540)]
> > @@ -232,10 +232,10 @@ The output will be something close to:
> > Hello World
> > *** FATAL ***
> > - fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> > + fatal source: 6 (RTEMS_FATAL_SOURCE_EXIT)
> > fatal code: 0 (0x00000000)
> > - RTEMS version: 5.1.0
> > - RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
> > + RTEMS version: 6
> > + RTEMS tools: 7.5.0 20191114 (RTEMS 6, RSB 6, Newlib fbaa096)
> > executing thread ID: 0x08a010001
> > executing thread name: UI1
> > cpu 0 in error mode (tt = 0x101)
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
