[PATCH 1/5] hexdump-parse.c: Fix Resource leak (CID #26032)
Joel Sherrill
joel at rtems.org
Mon Mar 15 19:55:10 UTC 2021
On Mon, Mar 15, 2021 at 2:46 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Mar 14, 2021 at 8:27 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 13/3/21 2:18 am, Ryan Long wrote:
> > > CID 26032: Resource leak in rtems_shell_hexdump_rewrite().
> > > Closes #4296
> > > cpukit/libmisc/shell/hexdump-parse.c | 3 +++
> > > 1 file changed, 3 insertions(+)
> > > diff --git a/cpukit/libmisc/shell/hexdump-parse.c
> b/cpukit/libmisc/shell/hexdump-parse.c
> > > index 88b9d56..5b56bbf 100644
> > > --- a/cpukit/libmisc/shell/hexdump-parse.c
> > > +++ b/cpukit/libmisc/shell/hexdump-parse.c
> > > @@ -462,6 +462,9 @@ isint2:
> switch(fu->bcnt) {
> > > (void)printf("\n");
> > > #endif
> > > +#ifdef __rtems__
> > > + free(nextpr);
> > > +#endif
> > I know this has not been done in imported code in rtems.git before but
> should we
> > adopt the libbsd standard of adding /* __rtems__ */ to the #else and
> #endif?
> Probably, but we also clone-and-own this shell/ code, and we should
> not bother with these #ifdefs in there. I think I have said this 3
> times this past week about shell/. The upstream does not want our
> changes, and we don't import from them anymore.
Some of these files have massive changes and some don't. Ryan and
I looked at main_cp.c and it had at least 40 revisions since the version
we have. The same Coverity issue appeared to be present but the variable
names were changed and much clearer.
Chris imported this code initially. I'll trust his ruling on this since I
assume
he is likely to either be the one to update it eventually or have to help
someone
a lot. :)
And some of it is close enough that the ifdef's are worth it. Some isn't.
Hard call on the overall value.
--joel
> > Chris
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210315/022fa577/attachment.html>
