[PATCH 3/5] nvdisk.c: Fix Resource leak (CID #1439297)
Gedare Bloom
gedare at rtems.org
Mon Mar 15 20:10:17 UTC 2021
On Fri, Mar 12, 2021 at 8:18 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> CID 1439297: Resource leak in rtems_nvdisk_initialize().
> Closes #4298
> cpukit/libblock/src/nvdisk.c | 8 +++++++-
> 1 file changed, 7 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
> index a7f4167..d742baf 100644
> --- a/cpukit/libblock/src/nvdisk.c
> +++ b/cpukit/libblock/src/nvdisk.c
> @@ -766,8 +766,10 @@ rtems_nvdisk_initialize (rtems_device_major_number major RTEMS_UNUSED,
> nvd->info_level = c->info_level;
> nvd->devices = calloc (c->device_count, sizeof (rtems_nvdisk_device_ctl));
> - if (!nvd->devices)
> + if (!nvd->devices) {
> + free(nvd);
> return RTEMS_NO_MEMORY;
> for (device = 0; device < c->device_count; device++)
> @@ -790,6 +792,8 @@ rtems_nvdisk_initialize (rtems_device_major_number major RTEMS_UNUSED,
> rtems_nvdisk_ioctl, nvd);
> if (sc != RTEMS_SUCCESSFUL)
> + free(nvd->devices);
> + free(nvd);
> rtems_nvdisk_error ("disk create phy failed");
> return sc;
> @@ -797,5 +801,7 @@ rtems_nvdisk_initialize (rtems_device_major_number major RTEMS_UNUSED,
> rtems_mutex_init (&nvd->lock, "NV Disk");
> + free(nvd);
Does the rtems_blkdev_create() link the nvd? (I think the answer is
yes.) Then, this is not correct.
> return RTEMS_SUCCESSFUL;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
