[PATCH 3/5] nvdisk.c: Fix Resource leak (CID #1439297)
Joel Sherrill
joel at rtems.org
Mon Mar 15 20:28:28 UTC 2021
On Mon, Mar 15, 2021, 3:10 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Mar 12, 2021 at 8:18 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> > CID 1439297: Resource leak in rtems_nvdisk_initialize().
> > Closes #4298
> > cpukit/libblock/src/nvdisk.c | 8 +++++++-
> > 1 file changed, 7 insertions(+), 1 deletion(-)
> > diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
> > index a7f4167..d742baf 100644
> > --- a/cpukit/libblock/src/nvdisk.c
> > +++ b/cpukit/libblock/src/nvdisk.c
> > @@ -766,8 +766,10 @@ rtems_nvdisk_initialize (rtems_device_major_number
> major RTEMS_UNUSED,
> > nvd->info_level = c->info_level;
> > nvd->devices = calloc (c->device_count, sizeof
> (rtems_nvdisk_device_ctl));
> > - if (!nvd->devices)
> > + if (!nvd->devices) {
> > + free(nvd);
> > return RTEMS_NO_MEMORY;
> > for (device = 0; device < c->device_count; device++)
> > @@ -790,6 +792,8 @@ rtems_nvdisk_initialize (rtems_device_major_number
> major RTEMS_UNUSED,
> > rtems_nvdisk_ioctl, nvd);
> > if (sc != RTEMS_SUCCESSFUL)
> > + free(nvd->devices);
> > + free(nvd);
> > rtems_nvdisk_error ("disk create phy failed");
> > return sc;
> > @@ -797,5 +801,7 @@ rtems_nvdisk_initialize (rtems_device_major_number
> major RTEMS_UNUSED,
> > rtems_mutex_init (&nvd->lock, "NV Disk");
> > + free(nvd);
> Does the rtems_blkdev_create() link the nvd? (I think the answer is
> yes.) Then, this is not correct.
I think this is my suggestion so what do you think should happen on this
case?
> > return RTEMS_SUCCESSFUL;
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210315/a241fbc4/attachment.html>
