[PATCH rtems-docs v2 4/6] rtems-docs: Edit command to build BSP and
Ida Delphine
idadelm at gmail.com
Tue Mar 16 08:15:13 UTC 2021
Edit sample output output as well substituting "5" with "6"
with regards to the current branch.
user/start/bsp-build.rst | 74 ++++++++++++++++++++--------------------
1 file changed, 37 insertions(+), 37 deletions(-)
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
index 137b3ab..c4d6db6 100644
--- a/user/start/bsp-build.rst
+++ b/user/start/bsp-build.rst
@@ -11,7 +11,7 @@ Build a Board Support Package (BSP)
You installed the tool suite in your installation prefix, made ready the source
for two RTEMS source packages and if you are using a Git clone bootstrapped the
RTEMS sources in the previous sections. We installed the tool suite in
-:file:`$HOME/quick-start/rtems/5` and unpacked the source in
+:file:`$HOME/quick-start/rtems/6` and unpacked the source in
:file:`$HOME/quick-start/src`.
You are now able to build :ref:`Board Support Packages (BSPs) <BSPs>` for all
@@ -44,24 +44,24 @@ To build the BSP with all the tests run this command:
.. code-block:: none
cd $HOME/quick-start/src/rsb/rtems
- ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 \
- --target=sparc-rtems5 --with-rtems-bsp=erc32 --with-rtems-tests=yes 5/rtems-kernel
+ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 \
+ --target=sparc-rtems6 --with-rtems-bsp=erc32 --with-rtems-tests=yes 6/rtems-kernel
This command should output something like this:
- RTEMS Source Builder - Set Builder, 5.1.0
- Build Set: 5/rtems-kernel
+ RTEMS Source Builder - Set Builder, 6
+ Build Set: 6/rtems-kernel
config: tools/rtems-kernel-5.cfg
- package: sparc-rtems5-kernel-erc32-1
- building: sparc-rtems5-kernel-erc32-1
- sizes: sparc-rtems5-kernel-erc32-1: 2.279GB (installed: 44.612MB)
- cleaning: sparc-rtems5-kernel-erc32-1
- reporting: tools/rtems-kernel-5.cfg -> sparc-rtems5-kernel-erc32-1.txt
- reporting: tools/rtems-kernel-5.cfg -> sparc-rtems5-kernel-erc32-1.xml
- installing: sparc-rtems5-kernel-erc32-1 -> $BASE/
+ package: sparc-rtems6-kernel-erc32-1
+ building: sparc-rtems6-kernel-erc32-1
+ sizes: sparc-rtems6-kernel-erc32-1: 2.279GB (installed: 44.612MB)
+ cleaning: sparc-rtems6-kernel-erc32-1
+ reporting: tools/rtems-kernel-5.cfg -> sparc-rtems6-kernel-erc32-1.txt
+ reporting: tools/rtems-kernel-5.cfg -> sparc-rtems6-kernel-erc32-1.xml
+ installing: sparc-rtems6-kernel-erc32-1 -> $BASE/
Build Set: Time 0:03:09.896961
The RSB BSP build can be customised with following RSB command line options:
@@ -112,13 +112,13 @@ directory to your ``$PATH`` throughout the remaining steps. Run the command:
- export PATH=$HOME/quick-start/rtems/5/bin:"$PATH"
+ export PATH=$HOME/quick-start/rtems/6/bin:"$PATH"
Check your installed tools can be found by running:
- command -v sparc-rtems5-gcc && echo "found" || echo "not found"
+ command -v sparc-rtems6-gcc && echo "found" || echo "not found"
The output should be:
@@ -128,7 +128,7 @@ The output should be:
If ``not found`` is printed the tools are not correctly installed or the path
has not been correctly set. Check the contents of the path
-:file:`$HOME/quick-start/rtems/5/bin` manually and if :file:`sparc-rtems5-gcc`
+:file:`$HOME/quick-start/rtems/6/bin` manually and if :file:`sparc-rtems6-gcc`
is present the path is wrong. If the file cannot be found return to
:ref:`QuickStartTools` and install the tools again.
@@ -145,7 +145,7 @@ everything else. For detailed information about the BSP build system, see
cd $HOME/quick-start/src/rtems
echo "[sparc/erc32]" > config.ini
echo "BUILD_TESTS = True" >> config.ini
- ./waf configure --prefix=$HOME/quick-start/rtems/5
+ ./waf configure --prefix=$HOME/quick-start/rtems/6
The first invocation of ``./waf`` needs a bit of time (e.g. 10 seconds) since an
internal cache file is populated. This command should output something like
@@ -158,24 +158,24 @@ by ``$BASE``.
Setting out to : $BASE/src/rtems/build
Regenerate build specification cache (needs a couple of seconds)...
Configure board support package (BSP) : sparc/erc32
- Checking for program 'sparc-rtems5-gcc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
- Checking for program 'sparc-rtems5-g++' : $BASE/rtems/5/bin/sparc-rtems5-g++
- Checking for program 'sparc-rtems5-ar' : $BASE/rtems/5/bin/sparc-rtems5-ar
- Checking for program 'sparc-rtems5-ld' : $BASE/rtems/5/bin/sparc-rtems5-ld
- Checking for program 'ar' : $BASE/rtems/5/bin/sparc-rtems5-ar
- Checking for program 'g++, c++' : $BASE/rtems/5/bin/sparc-rtems5-g++
- Checking for program 'gas, gcc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
- Checking for program 'gcc, cc' : $BASE/rtems/5/bin/sparc-rtems5-gcc
+ Checking for program 'sparc-rtems5-gcc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
+ Checking for program 'sparc-rtems5-g++' : $BASE/rtems/6/bin/sparc-rtems6-g++
+ Checking for program 'sparc-rtems5-ar' : $BASE/rtems/6/bin/sparc-rtems6-ar
+ Checking for program 'sparc-rtems5-ld' : $BASE/rtems/6/bin/sparc-rtems6-ld
+ Checking for program 'ar' : $BASE/rtems/6/bin/sparc-rtems6-ar
+ Checking for program 'g++, c++' : $BASE/rtems/6/bin/sparc-rtems6-g++
+ Checking for program 'gas, gcc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
+ Checking for program 'gcc, cc' : $BASE/rtems/6/bin/sparc-rtems6-gcc
Checking for c flags '-MMD' : yes
Checking for cxx flags '-MMD' : yes
- Checking for program 'rtems-bin2c' : $BASE/rtems/5/bin/rtems-bin2c
+ Checking for program 'rtems-bin2c' : $BASE/rtems/6/bin/rtems-bin2c
Checking for program 'gzip' : /usr/bin/gzip
Checking for program 'pax' : /usr/bin/pax
- Checking for program 'rtems-ld' : $BASE/rtems/5/bin/rtems-ld
- Checking for program 'rtems-syms' : $BASE/rtems/5/bin/rtems-syms
+ Checking for program 'rtems-ld' : $BASE/rtems/6/bin/rtems-ld
+ Checking for program 'rtems-syms' : $BASE/rtems/6/bin/rtems-syms
Checking for program 'xz' : /usr/bin/xz
'configure' finished successfully (11.069s)
@@ -220,12 +220,12 @@ by ``$BASE``.
Waf: Leaving directory `$BASE/src/rtems/build'
'install' finished successfully (0.544s)
Waf: Entering directory `$BASE/src/rtems/build/sparc/erc32'
- + install $BASE/rtems/5/sparc-rtems5/erc32/lib/start.o (from build/sparc/erc32/start.o)
- + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/bspopts.h (from build/sparc/erc32/bsps/include/bspopts.h)
- + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/zilog/z8036.h (from bsps/include/rtems/zilog/z8036.h)
+ + install $BASE/rtems/6/sparc-rtems6/erc32/lib/start.o (from build/sparc/erc32/start.o)
+ + install $BASE/rtems/6/sparc-rtems6/erc32/lib/include/bspopts.h (from build/sparc/erc32/bsps/include/bspopts.h)
+ + install $BASE/rtems/6/sparc-rtems6/erc32/lib/include/rtems/zilog/z8036.h (from bsps/include/rtems/zilog/z8036.h)
- + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/score/watchdogimpl.h (from cpukit/include/rtems/score/watchdogimpl.h)
- + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/score/watchdogticks.h (from cpukit/include/rtems/score/watchdogticks.h)
- + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/score/wkspace.h (from cpukit/include/rtems/score/wkspace.h)
+ + install $BASE/rtems/6/sparc-rtems6/erc32/lib/include/rtems/score/watchdogimpl.h (from cpukit/include/rtems/score/watchdogimpl.h)
+ + install $BASE/rtems/6/sparc-rtems6/erc32/lib/include/rtems/score/watchdogticks.h (from cpukit/include/rtems/score/watchdogticks.h)
+ + install $BASE/rtems/6/sparc-rtems6/erc32/lib/include/rtems/score/wkspace.h (from cpukit/include/rtems/score/wkspace.h)
Waf: Leaving directory `$BASE/src/rtems/build/sparc/erc32'
'install_sparc/erc32' finished successfully (2.985s)
2.25.1
