[PATCH rtems-docs v2 3/6] rtems-docs: Edit command to install toolsuite
Ida Delphine
idadelm at gmail.com
Sat Mar 20 06:32:35 UTC 2021
Hi Vijay,
Will send a v3 soon
On Sat, 20 Mar 2021, 7:07 am Gedare Bloom, <gedare at rtems.org> wrote:
> Hi Ida,
> On Wed, Mar 17, 2021 at 11:36 PM Gedare Bloom <gedare at rtems.org> wrote:
> > On Wed, Mar 17, 2021 at 9:04 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> > > Hello Ida,
> > > On Wed, Mar 17, 2021 at 8:42 PM Ida Delphine <idadelm at gmail.com>
> wrote:
> > > > I just installed texlive and trying to do a top level build using
> ./waf configure. But looks like it doesn't work well...I get this error at
> the end:
> > > > Setting top to :
> /home/idadel/Desktop/gsoc/docs/rtems-docs
> > > > Setting out to :
> /home/idadel/Desktop/gsoc/docs/rtems-docs/build
> > > > Checking for program 'git' : /usr/bin/git
> > > > Checking for program 'sphinx-build' :
> /home/idadel/anaconda3/bin/sphinx-build
> > > > Checking for program 'aspell' : /usr/bin/aspell
> > > > Checking if Sphinx is at least 1.3 : yes (3.5)
> > > > Checking Sphinx Options : none
> > > > Checking Sphinx Nit-Pick mode : no
> > > > Checking for 'sphinx.ext.autodoc' : found
> > > > Checking for 'sphinx.ext.coverage' : found
> > > > Checking for 'sphinx.ext.doctest' : found
> > > > Checking for 'sphinx.ext.graphviz' : found
> > > > Checking for 'sphinx.ext.intersphinx' : found
> > > > Checking for 'sphinx.ext.mathjax' : found
> > > > Checking for 'sphinxcontrib.bibtex' : not found (see README.txt)
> Did you manage to get past this yet? After you confirm you can build
> and see the changes for your pending documentation (example output)
> patch series, if you're happy with the ones on the list just ping one
> of them, or if you want to resend another version then prepare it with
> the -v3 I guess it would be by now.
> > > This looks like a helpful error message ;)
> > > In the README.txt you'll find the "Host set up" section that has some
> instructions about the required packages:
> https://git.rtems.org/rtems-docs/tree/README.txt#n92
> > > The short answer to your question:
> > > pip install sphinx
> > > pip install sphinxcontrib-bibtex
> > I also strongly recommend following those README directions to do the
> > build within a virtualenv if you haven't been. This will help better
> > manage the python versions in use. (My host's native python
> > installation is broken quite badly, but virtualenv works well.)
> > > Best regards,
> > > Vijay
> > > > The configuration failed
> > > > (complete log in
> /home/idadel/Desktop/gsoc/docs/rtems-docs/build/config.log)
> > > > On Wed, Mar 17, 2021 at 9:37 PM Ida Delphine <idadelm at gmail.com>
> wrote:
> > > >> Ok, I will do that.
> > > >> On Tue, Mar 16, 2021 at 7:56 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> > > >>> On Tue, Mar 16, 2021 at 12:16 PM Ida Delphine <idadelm at gmail.com>
> wrote:
> > > >>> > I ran the commands and copied and pasted wherever there were
> mismatches especially with respect to the version numbers.
> > > >>> OK, I noticed some inconsistencies and was wondering. It would be
> > > >>> better to provide the actual output for the entire snippets, see
> > > >>> further below what I noticed.
> > > >>> > Should I resend the patchset with a better commit message?
> > > >>> Yes. I think it would be better to also update the entire output
> > > >>> examples, and to separate them from the manual changes you make to
> the
> > > >>> version numbers. In other words, update the version numbers by hand
> > > >>> for some things, and update the console output examples separately.
> > > >>> You can put multiple changes together in one patch that are
> related,
> > > >>> for example you might just send one patch with all the console
> output
> > > >>> example updates.
> > > >>> > On Tue, 16 Mar 2021, 6:50 pm Gedare Bloom, <gedare at rtems.org>
> wrote:
> > > >>> >> Hi Ida,
> > > >>> >> Since the patches now indicate rtems-docs, you don't need to
> include
> > > >>> >> that in the commit message. Instead, it is recommended to put
> the
> > > >>> >> manual directory name that is modified as the first part of the
> > > >>> >> commit, e.g., "user: bump version 5 to 6 in start/tools.rst"
> > > >>> >> More below:
> > > >>> >> On Tue, Mar 16, 2021 at 2:16 AM Ida Delphine <idadelm at gmail.com>
> wrote:
> > > >>> >> > Edit edit sample output of tool suite installation.
> > > >>> >> > Edit command to check if C cross compiler works and sample
> output of this command.
> > > >>> >> > user/start/tools.rst | 26 +++++++++++++-------------
> > > >>> >> > 1 file changed, 13 insertions(+), 13 deletions(-)
> > > >>> >> > diff --git a/user/start/tools.rst b/user/start/tools.rst
> > > >>> >> > index baa2387..9a915ab 100644
> > > >>> >> > --- a/user/start/tools.rst
> > > >>> >> > +++ b/user/start/tools.rst
> > > >>> >> > @@ -12,7 +12,7 @@ Install the Tool Suite
> > > >>> >> > You have chosen an installation prefix, the BSP to build,
> the tool's
> > > >>> >> > architecure and prepared the source for the RSB in the
> previous sections. We
> > > >>> unrelated, fix typo: architecture
> > > >>> >> > -have chosen :file:`$HOME/quick-start/rtems/5` as the
> > > >>> >> > +have chosen :file:`$HOME/quick-start/rtems/6` as the
> > > >>> >> > ``erc32`` BSP and the SPARC architecture name of
> ``sparc-rtems5``, and unpacked
> > > >>> >> > the RSB source in :file:`$HOME/quick-start/src`.
> > > >>> >> > @@ -25,7 +25,7 @@ Build and install the tool suite:
> > > >>> >> > .. code-block:: none
> > > >>> >> > cd $HOME/quick-start/src/rsb/rtems
> > > >>> >> > - ../source-builder/sb-set-builder
> --prefix=$HOME/quick-start/rtems/5 5/rtems-sparc
> > > >>> >> > + ../source-builder/sb-set-builder
> --prefix=$HOME/quick-start/rtems/6 6/rtems-sparc
> > > >>> >> > This command should output something like this (omitted
> lines are denoted by
> > > >>> >> > ...). The build host appears as part of the name of the
> package being
> > > >>> >> > @@ -33,19 +33,19 @@ built. The name you see may vary
> depending on the host you are using:
> > > >>> >> > - RTEMS Source Builder - Set Builder, 5.1.0
> > > >>> >> > - Build Set: 5/rtems-sparc
> > > >>> >> > + RTEMS Source Builder - Set Builder, 6
> > > >>> >> > + Build Set: 6/rtems-sparc
> > > >>> >> > config: tools/rtems-binutils-2.34.cfg
> > > >>> >> > - package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > > >>> >> > - building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > > >>> >> > - sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1:
> 305.866MB (installed: 29.966MB)
> > > >>> >> > - cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > > >>> >> > + package: sparc-rtems6=-binutils-2.34-x86_64-freebsd12.1-1
> > > >>> The = sign here is what got me thinking something odd is going on.
> > > >>> Please copy-paste the entire output/snippet you get, and update the
> > > >>> examples completely so that each snippet is self-consistent at
> least.
> > > >>> >> > + building: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
> > > >>> >> > + sizes: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1:
> > > >>> >> > + cleaning: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
> > > >>> >> > reporting: tools/rtems-binutils-2.34.cfg ->
> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
> > > >>> >> > config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
> > > >>> >> > - package:
> sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> > > >>> >> > - building:
> > > >>> >> > + package:
> sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> > > >>> >> > + building:
> > > >>> >> > Build Sizes: usage: 5.684GB total: 1.112GB (sources:
> 143.803MB, patches: 21.348KB, installed 995.188MB)
> > > >>> >> > Build Set: Time 0:21:35.626294
> > > >>> >> Did you run the command and capture the sample output, or do
> you edit
> > > >>> >> the sample output manually?
> > > >>> >> It would be better to copy-paste the actual sample output.
> Making this
> > > >>> >> version change update automatic could be a nice small scripting
> > > >>> >> exercise.
> > > >>> >> > @@ -55,7 +55,7 @@ works with the following command:
> > > >>> >> > - $HOME/quick-start/rtems/5/bin/sparc-rtems5-gcc --version
> > > >>> >> > + $HOME/quick-start/rtems/6/bin/sparc-rtems6-gcc --version
> > > >>> >> > This command should output something like below. The
> version informtion helps
> > > >>> >> Unrelated, but can you fix this typo: information
> > > >>> >> > you to identify the exact sources used to build the cross
> compiler of your
> > > >>> >> > @@ -69,8 +69,8 @@ source code used.
> > > >>> >> > - sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB
> 5.1.0, Newlib fbaa096)
> > > >>> >> > - Copyright (C) 2017 Free Software Foundation, Inc.
> > > >>> >> > + sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB
> 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
> > > >>> >> > + Copyright (C) 2020 Free Software Foundation, Inc.
> > > >>> >> > This is free software; see the source for copying
> conditions. There is NO
> > > >>> >> > warranty; not even for MERCHANTABILITY or FITNESS FOR A
> PARTICULAR PURPOSE.
> > > >>> >> > 2.25.1
> > > >>> >> > _______________________________________________
> > > >>> >> > devel mailing list
> > > >>> >> > devel at rtems.org
> > > >>> >> > http://lists.rtems.org/mailman/listinfo/devel
> > > > devel mailing list
> > > > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210320/fd01fdcb/attachment-0001.html>
