[rtems commit] pwdgrp.c: Fix Unchecked return value from library ( CID #1255518)
Tue Mar 16 14:21:03 UTC 2021
On Tue, Mar 16, 2021 at 9:15 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> I found this error yesterday, when doing more testing based on Chris's
> feedback. I've taken out the _Assert_Unused_variable_equals() in pwdgrp.c
> and replaced it with just a (void). The test passed afterwards, but Joel
> wants me to test it a little further. I'll get the patch in to fix that by
> the end of the day.
I wanted to see fileio run OK but it looks like the Zynq BSP on Qemu
doesn't have working input at the moment. I had Ryan switch over to leon3
just to test this.
Does console input work for you on Zynq qemu right now? I emailed Jan last
night to see if he had tested that.
--joel
> -----Original Message-----
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Sent: Tuesday, March 16, 2021 6:33 AM
> To: RTEMS <devel at rtems.org>; Ryan Long <ryan.long at oarcorp.com>
> Subject: Re: [rtems commit] pwdgrp.c: Fix Unchecked return value from
> On 16/03/2021 12:30, Sebastian Huber wrote:
> > On 08/03/2021 21:56, Joel Sherrill wrote:
> >> Module:    rtems
> >> Branch:    master
> >> Commit:    55ba229d228d1b7372256978828c573dd0af56d4
> >> Changeset:http://git.rtems.org/rtems/commit/?id=55ba229d228d1b7372256
> >> 978828c573dd0af56d4
> >> Author:    Ryan Long<ryan.long at oarcorp.com>
> >> Date:      Tue Mar  2 11:46:02 2021 -0500
> >> pwdgrp.c: Fix Unchecked return value from library (CID #1255518)
> >> CID 1255518: Unchecked return value from library in pwdgrp_init().
> >> Closes #4282
> > I get an assertion in the tests with RTEMS_DEBUG enabled:
> >     test start: PWDGRP 1
> >     *** BEGIN OF TEST PWDGRP 1 ***
> >     *** TEST VERSION: 6.0.0.ca801609a7100804520809d1407174f465befee5
> >     *** TEST STATE: EXPECTED_PASS
> >     *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API
> >     *** TEST TOOLS: 10.2.1 20210315 (RTEMS 6, RSB
> > 62363ba982213588ef5d8bc8c4ff3acc28075f3f,
> >     Newlib d10d0d9)
> >     assertion "(sc) == (0)" failed: file
> > "/home/EB/sebastian_h/src/rtems/cpukit/libcsupport/src/pwdgrp.c",
> >     line 72, function: pwdgrp_init
> Also these tests:
>      test start: PSXPASSWD 2
>      *** BEGIN OF TEST PSXPASSWD 2 ***
>      Newlib d10d0d9)
>      Init - Creating /etc
>      Init - Creating /etc/passwd
>      Init - Creating /etc/group
>      Init - setpwent() -- OK
>      test start: SHELL 1
>      *** BEGIN OF TEST SHELL 1 ***
>      Newlib d10d0d9)
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210316/5f3e302c/attachment-0001.html>
