[PATCH v3] covoar: Handle periods in symbols from objdump
Alex White alex.white at oarcorp.com
Tue Mar 16 14:25:22 UTC 2021
Occasionally the compiler will generate symbols that look similar to
symbols defined in RTEMS code except that they contain some suffix.
These symbol suffixes are only found in the ELF symbol table; the
symbols appear to be normal in the DWARF info. This appears to be
happening on all architectures.
For example, the function _Message_queue_Create from rtems appears as
"_Message_queue_Create.part.0". Other suffixes include ".isra.0",
".constprop.0", and ".0".
This looks to be related to compiler optimizations. Symbols with
suffixes were being treated as unique. For our purposes, they should be
mapped to the equivalent symbols in the DWARF info. This has been
fixed.
 tester/covoar/ExecutableInfo.cc   | 22 +++++++++++++++++++---
 tester/covoar/ObjdumpProcessor.cc |  6 ++++++
 tester/covoar/SymbolTable.cc      | 12 +++++++++---
 3 files changed, 34 insertions(+), 6 deletions(-)
diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
index c996d75..9384973 100644
--- a/tester/covoar/ExecutableInfo.cc
+++ b/tester/covoar/ExecutableInfo.cc
@@ -118,8 +118,7 @@ namespace Coverage {
     // Obtain the coverage map containing the specified address.
     itsSymbol = theSymbolTable.getSymbol( address );
     if (itsSymbol != "") {
-      it = coverageMaps.find( itsSymbol );
-      aCoverageMap = (*it).second;
+      aCoverageMap = &findCoverageMap(itsSymbol);
     return aCoverageMap;
@@ -150,8 +149,25 @@ namespace Coverage {
     CoverageMaps::iterator cmi = coverageMaps.find( symbolName );
-    if ( cmi == coverageMaps.end() )
+    if ( cmi != coverageMaps.end() ) {
+      return *(cmi->second);
+    size_t periodIndex = symbolName.find(".");
+    if (periodIndex == std::string::npos) {
+      // Symbol name has no '.', can't do another lookup.
       throw CoverageMapNotFoundError(symbolName);
+    cmi = coverageMaps.find(
+      symbolName.substr(0, periodIndex)
+    if ( cmi == coverageMaps.end() ) {
+      throw CoverageMapNotFoundError(symbolName);
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index fa9894d..544bfa1 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -417,6 +417,12 @@ namespace Coverage {
         processSymbol = false;
         theInstructions.clear();
+        // Look for a '.' character and strip everything after it.
+        char *periodIndex = strstr(symbol, ".");
+        if (periodIndex != NULL) {
+          *periodIndex = 0;
         // See if the new symbol is one that we care about.
         if (SymbolsToAnalyze->isDesired( symbol )) {
           currentSymbol = symbol;
diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
index 53bc8af..00062cc 100644
--- a/tester/covoar/SymbolTable.cc
+++ b/tester/covoar/SymbolTable.cc
@@ -46,12 +46,18 @@ namespace Coverage {
     symbolData.startingAddress = start;
     symbolData.length = length;
-    if ( info[ symbol ].empty() == false ) {
-      if ( info[ symbol ].front().length != length ) {
+    for (auto& symData : info[ symbol ]) {
+      // The starting address could differ since we strip any suffixes beginning
+      // with a '.'
+      if (symData.startingAddress != start) {
+        continue;
+      if (symData.length != length) {
         std::ostringstream what;
         what << "Different lengths for the symbol "
              << symbol
-             << " (" << info[ symbol ].front().length
+             << " (" << symData.length
              << " and " << length
         throw rld::error( what, "SymbolTable::addSymbol" );
2.27.0
