[PATCH v3] covoar: Handle periods in symbols from objdump
Joel Sherrill
joel at rtems.org
Tue Mar 16 14:52:30 UTC 2021
On Tue, Mar 16, 2021 at 9:25 AM Alex White <alex.white at oarcorp.com> wrote:
> Occasionally the compiler will generate symbols that look similar to
> symbols defined in RTEMS code except that they contain some suffix.
> These symbol suffixes are only found in the ELF symbol table; the
> symbols appear to be normal in the DWARF info. This appears to be
> happening on all architectures.
> For example, the function _Message_queue_Create from rtems appears as
> "_Message_queue_Create.part.0". Other suffixes include ".isra.0",
> ".constprop.0", and ".0".
> This looks to be related to compiler optimizations. Symbols with
> suffixes were being treated as unique. For our purposes, they should be
> mapped to the equivalent symbols in the DWARF info. This has been
> fixed.
Everything Alex said is correct. It appears to be related to the compiler
optimizing and moving a section of a method "out of line". I suspect it
could
be that it is moving an alternate path ahead of the code generated for the
entry point to improve some straight execution path through the method.
Perhaps Alex can point to a BSP and test exe for an example.
But they definitely were there and looked like GCC had split the method
into different pieces and at least one had an address before the method
entry point. He never showed me a method split into more than one piece
but given they ended with a number, that seems likely.
--joel
> tester/covoar/ExecutableInfo.cc | 22 +++++++++++++++++++---
> tester/covoar/ObjdumpProcessor.cc | 6 ++++++
> tester/covoar/SymbolTable.cc | 12 +++++++++---
> 3 files changed, 34 insertions(+), 6 deletions(-)
> diff --git a/tester/covoar/ExecutableInfo.cc
> b/tester/covoar/ExecutableInfo.cc
> index c996d75..9384973 100644
> --- a/tester/covoar/ExecutableInfo.cc
> +++ b/tester/covoar/ExecutableInfo.cc
> @@ -118,8 +118,7 @@ namespace Coverage {
> // Obtain the coverage map containing the specified address.
> itsSymbol = theSymbolTable.getSymbol( address );
> if (itsSymbol != "") {
> - it = coverageMaps.find( itsSymbol );
> - aCoverageMap = (*it).second;
> + aCoverageMap = &findCoverageMap(itsSymbol);
> return aCoverageMap;
> @@ -150,8 +149,25 @@ namespace Coverage {
> CoverageMaps::iterator cmi = coverageMaps.find( symbolName );
> - if ( cmi == coverageMaps.end() )
> + if ( cmi != coverageMaps.end() ) {
> + return *(cmi->second);
> + size_t periodIndex = symbolName.find(".");
> + if (periodIndex == std::string::npos) {
> + // Symbol name has no '.', can't do another lookup.
> throw CoverageMapNotFoundError(symbolName);
> + cmi = coverageMaps.find(
> + symbolName.substr(0, periodIndex)
> + if ( cmi == coverageMaps.end() ) {
> + throw CoverageMapNotFoundError(symbolName);
> diff --git a/tester/covoar/ObjdumpProcessor.cc
> b/tester/covoar/ObjdumpProcessor.cc
> index fa9894d..544bfa1 100644
> --- a/tester/covoar/ObjdumpProcessor.cc
> +++ b/tester/covoar/ObjdumpProcessor.cc
> @@ -417,6 +417,12 @@ namespace Coverage {
> processSymbol = false;
> theInstructions.clear();
> + // Look for a '.' character and strip everything after it.
> + char *periodIndex = strstr(symbol, ".");
> + if (periodIndex != NULL) {
> + *periodIndex = 0;
> // See if the new symbol is one that we care about.
> if (SymbolsToAnalyze->isDesired( symbol )) {
> currentSymbol = symbol;
> diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
> index 53bc8af..00062cc 100644
> --- a/tester/covoar/SymbolTable.cc
> +++ b/tester/covoar/SymbolTable.cc
> @@ -46,12 +46,18 @@ namespace Coverage {
> symbolData.startingAddress = start;
> symbolData.length = length;
> - if ( info[ symbol ].empty() == false ) {
> - if ( info[ symbol ].front().length != length ) {
> + for (auto& symData : info[ symbol ]) {
> + // The starting address could differ since we strip any suffixes
> beginning
> + // with a '.'
> + if (symData.startingAddress != start) {
> + continue;
> + if (symData.length != length) {
> std::ostringstream what;
> what << "Different lengths for the symbol "
> << symbol
> - << " (" << info[ symbol ].front().length
> + << " (" << symData.length
> << " and " << length
> throw rld::error( what, "SymbolTable::addSymbol" );
> 2.27.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210316/7d10c07a/attachment-0001.html>
