[PATCH rtems-docs v2 3/6] rtems-docs: Edit command to install toolsuite
Ida Delphine idadelm at gmail.com
Tue Mar 16 18:15:56 UTC 2021
I ran the commands and copied and pasted wherever there were mismatches
especially with respect to the version numbers.
Should I resend the patchset with a better commit message?
On Tue, 16 Mar 2021, 6:50 pm Gedare Bloom, <gedare at rtems.org> wrote:
> Hi Ida,
> Since the patches now indicate rtems-docs, you don't need to include
> that in the commit message. Instead, it is recommended to put the
> manual directory name that is modified as the first part of the
> commit, e.g., "user: bump version 5 to 6 in start/tools.rst"
> More below:
> On Tue, Mar 16, 2021 at 2:16 AM Ida Delphine <idadelm at gmail.com> wrote:
> > Edit edit sample output of tool suite installation.
> > Edit command to check if C cross compiler works and sample output of
> this command.
> >  user/start/tools.rst | 26 +++++++++++++-------------
> >  1 file changed, 13 insertions(+), 13 deletions(-)
> > diff --git a/user/start/tools.rst b/user/start/tools.rst
> > index baa2387..9a915ab 100644
> > --- a/user/start/tools.rst
> > +++ b/user/start/tools.rst
> > @@ -12,7 +12,7 @@ Install the Tool Suite
> >  You have chosen an installation prefix, the BSP to build, the tool's
> >  architecure and prepared the source for the RSB in the previous
> sections.  We
> > -have chosen :file:`$HOME/quick-start/rtems/5` as the installation
> prefix, the
> > +have chosen :file:`$HOME/quick-start/rtems/6` as the installation
> prefix, the
> >  ``erc32`` BSP and the SPARC architecture name of ``sparc-rtems5``, and
> unpacked
> >  the RSB source in :file:`$HOME/quick-start/src`.
> > @@ -25,7 +25,7 @@ Build and install the tool suite:
> >  .. code-block:: none
> >      cd $HOME/quick-start/src/rsb/rtems
> > -    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
> 5/rtems-sparc
> > +    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6
> 6/rtems-sparc
> >  This command should output something like this (omitted lines are
> denoted by
> >  ...). The build host appears as part of the name of the package being
> > @@ -33,19 +33,19 @@ built. The name you see may vary depending on the
> host you are using:
> > -    RTEMS Source Builder - Set Builder, 5.1.0
> > -    Build Set: 5/rtems-sparc
> > +    RTEMS Source Builder - Set Builder, 6
> > +    Build Set: 6/rtems-sparc
> >      config: tools/rtems-binutils-2.34.cfg
> > -    package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > -    building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > -    sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB
> (installed: 29.966MB)
> > -    cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > +    package: sparc-rtems6=-binutils-2.34-x86_64-freebsd12.1-1
> > +    building: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
> > +    sizes: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB
> > +    cleaning: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
> >      reporting: tools/rtems-binutils-2.34.cfg ->
> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
> >      config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
> > -    package: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> > -    building: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> > +    package: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> > +    building: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> >      Build Sizes: usage: 5.684GB total: 1.112GB (sources: 143.803MB,
> patches: 21.348KB, installed 995.188MB)
> >      Build Set: Time 0:21:35.626294
> Did you run the command and capture the sample output, or do you edit
> the sample output manually?
> It would be better to copy-paste the actual sample output. Making this
> version change update automatic could be a nice small scripting
> exercise.
> > @@ -55,7 +55,7 @@ works with the following command:
> > -    $HOME/quick-start/rtems/5/bin/sparc-rtems5-gcc --version
> > +    $HOME/quick-start/rtems/6/bin/sparc-rtems6-gcc --version
> >  This command should output something like below.  The version
> informtion helps
> Unrelated, but can you fix this typo: information
> >  you to identify the exact sources used to build the cross compiler of
> your
> > @@ -69,8 +69,8 @@ source code used.
> > -    sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib
> fbaa096)
> > -    Copyright (C) 2017 Free Software Foundation, Inc.
> > +    sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB
> 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
> > +    Copyright (C) 2020 Free Software Foundation, Inc.
> >      This is free software; see the source for copying conditions.
> There is NO
> >      warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> PURPOSE.
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210316/a4f974c7/attachment.html>
