[PATCH rtems-docs v2 3/6] rtems-docs: Edit command to install toolsuite
Tue Mar 16 18:56:41 UTC 2021
On Tue, Mar 16, 2021 at 12:16 PM Ida Delphine <idadelm at gmail.com> wrote:
> I ran the commands and copied and pasted wherever there were mismatches especially with respect to the version numbers.
OK, I noticed some inconsistencies and was wondering. It would be
better to provide the actual output for the entire snippets, see
further below what I noticed.
> Should I resend the patchset with a better commit message?
Yes. I think it would be better to also update the entire output
examples, and to separate them from the manual changes you make to the
version numbers. In other words, update the version numbers by hand
for some things, and update the console output examples separately.
You can put multiple changes together in one patch that are related,
for example you might just send one patch with all the console output
example updates.
> On Tue, 16 Mar 2021, 6:50 pm Gedare Bloom, <gedare at rtems.org> wrote:
>> Hi Ida,
>> Since the patches now indicate rtems-docs, you don't need to include
>> that in the commit message. Instead, it is recommended to put the
>> manual directory name that is modified as the first part of the
>> commit, e.g., "user: bump version 5 to 6 in start/tools.rst"
>> More below:
>> On Tue, Mar 16, 2021 at 2:16 AM Ida Delphine <idadelm at gmail.com> wrote:
>> > Edit edit sample output of tool suite installation.
>> > Edit command to check if C cross compiler works and sample output of this command.
>> >  user/start/tools.rst | 26 +++++++++++++-------------
>> >  1 file changed, 13 insertions(+), 13 deletions(-)
>> > diff --git a/user/start/tools.rst b/user/start/tools.rst
>> > index baa2387..9a915ab 100644
>> > --- a/user/start/tools.rst
>> > +++ b/user/start/tools.rst
>> > @@ -12,7 +12,7 @@ Install the Tool Suite
>> >  You have chosen an installation prefix, the BSP to build, the tool's
>> >  architecure and prepared the source for the RSB in the previous sections.  We
unrelated, fix typo: architecture
>> > -have chosen :file:`$HOME/quick-start/rtems/5` as the installation prefix, the
>> > +have chosen :file:`$HOME/quick-start/rtems/6` as the installation prefix, the
>> >  ``erc32`` BSP and the SPARC architecture name of ``sparc-rtems5``, and unpacked
>> >  the RSB source in :file:`$HOME/quick-start/src`.
>> > @@ -25,7 +25,7 @@ Build and install the tool suite:
>> >  .. code-block:: none
>> >      cd $HOME/quick-start/src/rsb/rtems
>> > -    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 5/rtems-sparc
>> > +    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 6/rtems-sparc
>> >  This command should output something like this (omitted lines are denoted by
>> >  ...). The build host appears as part of the name of the package being
>> > @@ -33,19 +33,19 @@ built. The name you see may vary depending on the host you are using:
>> > -    RTEMS Source Builder - Set Builder, 5.1.0
>> > -    Build Set: 5/rtems-sparc
>> > +    RTEMS Source Builder - Set Builder, 6
>> > +    Build Set: 6/rtems-sparc
>> >      config: tools/rtems-binutils-2.34.cfg
>> > -    package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>> > -    building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>> > -    sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB (installed: 29.966MB)
>> > -    cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>> > +    package: sparc-rtems6=-binutils-2.34-x86_64-freebsd12.1-1
The = sign here is what got me thinking something odd is going on.
Please copy-paste the entire output/snippet you get, and update the
examples completely so that each snippet is self-consistent at least.
>> > +    building: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
>> > +    sizes: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB (installed: 29.966MB)
>> > +    cleaning: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
>> >      reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
>> >      reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
>> >      config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
>> > -    package: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>> > -    building: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>> > +    package: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>> > +    building: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>> >      Build Sizes: usage: 5.684GB total: 1.112GB (sources: 143.803MB, patches: 21.348KB, installed 995.188MB)
>> >      Build Set: Time 0:21:35.626294
>> Did you run the command and capture the sample output, or do you edit
>> the sample output manually?
>> It would be better to copy-paste the actual sample output. Making this
>> version change update automatic could be a nice small scripting
>> exercise.
>> > @@ -55,7 +55,7 @@ works with the following command:
>> > -    $HOME/quick-start/rtems/5/bin/sparc-rtems5-gcc --version
>> > +    $HOME/quick-start/rtems/6/bin/sparc-rtems6-gcc --version
>> >  This command should output something like below.  The version informtion helps
>> Unrelated, but can you fix this typo: information
>> >  you to identify the exact sources used to build the cross compiler of your
>> > @@ -69,8 +69,8 @@ source code used.
>> > -    sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
>> > -    Copyright (C) 2017 Free Software Foundation, Inc.
>> > +    sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
>> > +    Copyright (C) 2020 Free Software Foundation, Inc.
>> >      This is free software; see the source for copying conditions.  There is NO
>> >      warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
>> > 2.25.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
