[PATCH v3] covoar: Handle periods in symbols from objdump
Wed Mar 17 00:15:37 UTC 2021
On 17/3/21 8:16 am, Alex White wrote:
> Assuming I'm sending a v4 of this patch out, should I add the explanation of the compiler-generated suffixes to the commit message or perhaps as a comment in the code?
Yes if you think it helps. In the end what you are doing makes the tool work and
this doco help maintain the code because we now know why it is being done.
