[PATCH 2/4] eng: Add build/appl config clauses to how-to
Sebastian Huber
Wed Mar 17 17:34:24 UTC 2021
Update #3715.
eng/req/howto.rst | 123 ++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 123 insertions(+)
diff --git a/eng/req/howto.rst b/eng/req/howto.rst
index ee239d4..e7c35b3 100644
--- a/eng/req/howto.rst
+++ b/eng/req/howto.rst
@@ -280,6 +280,129 @@ an :ref:`SpecTypeInterfaceForwardDeclarationItemType` item.
value: ${/if/c/null}
type: interface
+Requirements Depending on Build Configuration Options
+Use the ``enabled-by`` attribute of items or parts of an item to make it
+dependent on build configuration options such as :c:data:`RTEMS_SMP` or
+architecture-specific options such as
+:c:data:`CPU_ENABLE_ROBUST_THREAD_DISPATCH`, see
+:ref:`SpecTypeEnabledByExpression`. With this attribute the specification can
+be customized at the level of an item or parts of an item. If the
+``enabled-by`` attribute evaluates to false for a particular configuration,
+then the item or the associated part is disabled in the specification. The
+``enabled-by`` attribute acts as a formalized *where* clause, see
+:ref:`recommended requirements syntax <ReqEngSyntax>`.
+Please have a look at the following example which specifies the transition map
+of :c:func:`rtems_signal_catch`:
+.. code-block:: yaml
+ transition-map:
+ - enabled-by: true
+ post-conditions:
+ Status: Ok
+ ASRInfo:
+ - if:
+ pre-conditions:
+ Handler: Valid
+ then: New
+ - else: Inactive
+ pre-conditions:
+ Pending: all
+ Handler: all
+ Preempt: all
+ Timeslice: all
+ ASR: all
+ IntLvl: all
+ - enabled-by: CPU_ENABLE_ROBUST_THREAD_DISPATCH
+ post-conditions:
+ Status: NotImplIntLvl
+ ASRInfo: NopIntLvl
+ pre-conditions:
+ Pending: all
+ Handler:
+ - Valid
+ Preempt: all
+ Timeslice: all
+ ASR: all
+ IntLvl:
+ - Positive
+ - enabled-by: RTEMS_SMP
+ post-conditions:
+ Status: NotImplNoPreempt
+ ASRInfo: NopNoPreempt
+ pre-conditions:
+ Pending: all
+ Handler:
+ - Valid
+ Preempt:
+ - 'No'
+ Timeslice: all
+ ASR: all
+ IntLvl: all
+Requirements Depending on Application Configuration Options
+Requirements which depend on application configuration options such as
+:c:data:`CONFIGURE_MAXIMUM_PROCESSORS` should be written in the following
+:ref:`syntax <ReqEngSyntax>`:
+ **Where** <feature is included>, the <system name> shall <system response>.
+Use these clauses with care. Make sure all feature combinations are covered.
+Using a truth table may help. If a requirement depends on multiple features,
+use:
+ **Where** <feature 0>, **where** <feature 1>, **where** <feature ...>, the
+ <system name> shall <system response>.
+For application configuration options, use the clauses like this:
+:c:data:`CONFIGURE_MAXIMUM_PROCESSORS` equal to one
+ **Where** the system was configured with a processor maximum of exactly
+ one, ...
+:c:data:`CONFIGURE_MAXIMUM_PROCESSORS` greater than one
+ **Where** the system was configured with a processor maximum greater than
+ one, ...
+Please have a look at the following example used to specify
+:c:func:`rtems_signal_catch`. The example is a post-condition state
+specification of an action requirement, so there is an implicit set of
+pre-conditions and the trigger:
+ **While** <pre-condition>, **while** ..., **when** rtems_signal_catch() is
+ called, ...
+The *where* clauses should be mentally placed before the *while* clauses.
+ post-conditions:
+ - name: ASRInfo
+ states:
+ - name: NopNoPreempt
+ test-code: |
+ if ( rtems_configuration_get_maximum_processors() > 1 ) {
+ CheckNoASRChange( ctx );
+ } else {
+ CheckNewASRSettings( ctx );
+ text: |
+ Where the scheduler does not support the no-preempt mode, the ASR
+ information of the caller of ${../if/catch:/name} shall not be
+ changed by the ${../if/catch:/name} call.
+ Where the scheduler does support the no-preempt mode, the ASR
+ processing for the caller of ${../if/catch:/name} shall be done using
+ the handler specified by ${../if/catch:/params[0]/name} in the mode
+ specified by ${../if/catch:/params[1]/name}.
Action Requirements
2.26.2
