[PATCH 3/4] eng: Document expressions in action requirements
Sebastian Huber
Wed Mar 17 17:34:25 UTC 2021
Update #3715.
eng/req/items.rst | 209 +++++++++++++++++++++++++++++++++++++++++++---
1 file changed, 198 insertions(+), 11 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 9766598..64a32cb 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -1,6 +1,6 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2019, 2021 embedded brains GmbH (http://www.embedded-brains.de)
.. This file is part of the RTEMS quality process and was automatically
.. generated. If you find something that needs to be fixed or
@@ -2493,6 +2493,62 @@ test-target
Specification Attribute Sets and Value Types
+.. _SpecTypeActionRequirementBooleanExpression:
+Action Requirement Boolean Expression
+A value of this type is a boolean expression.
+A value of this type shall be of one of the following variants:
+* The value may be a set of attributes. Each attribute defines an operator.
+ Exactly one of the explicit attributes shall be specified. The explicit
+ attributes for this type are:
+ and
+ The attribute value shall be a list. Each list element shall be an
+ :ref:`SpecTypeActionRequirementBooleanExpression`. The *and* operator
+ evaluates to the *logical and* of the evaluation results of the
+ expressions in the list.
+ not
+ The attribute value shall be an
+ :ref:`SpecTypeActionRequirementBooleanExpression`. The *not* operator
+ evaluates to the *logical not* of the evaluation results of the
+ expression.
+ or
+ :ref:`SpecTypeActionRequirementBooleanExpression`. The *or* operator
+ evaluates to the *logical or* of the evaluation results of the
+ post-conditions
+ :ref:`SpecTypeActionRequirementExpressionConditionSet`. The
+ *post-conditions* operator evaluates to true, if the post-condition
+ states of the associated transition are contained in the specified
+ post-condition set, otherwise to false.
+ pre-conditions
+ *pre-conditions* operator evaluates to true, if the pre-condition states
+ of the associated transition are contained in the specified pre-condition
+ set, otherwise to false.
+* The value may be a list. Each list element shall be an
+ :ref:`SpecTypeActionRequirementBooleanExpression`. This list of expressions
+ evaluates to the *logical or* of the evaluation results of the expressions in
+ the list.
+This type is used by the following types:
+* :ref:`SpecTypeActionRequirementBooleanExpression`
+* :ref:`SpecTypeActionRequirementExpression`
.. _SpecTypeActionRequirementCondition:
Action Requirement Condition
@@ -2527,6 +2583,100 @@ This type is used by the following types:
* :ref:`SpecTypeActionRequirementItemType`
+.. _SpecTypeActionRequirementExpression:
+Action Requirement Expression
+This set of attributes defines an expression which may define the state of a
+post-condition. The ``else`` and ``specified-by`` shall be used individually.
+The ``if`` and ``then`` or ``then-specified-by`` expressions shall be used
+together. At least one of the explicit attributes shall be specified. The
+explicit attributes for this type are:
+else
+ :ref:`SpecTypeActionRequirementExpressionStateName`. It shall be the name
+ of the state of the post-condition.
+if
+ :ref:`SpecTypeActionRequirementBooleanExpression`. If the boolean
+ expression evaluates to true, then the state is defined according to the
+ ``then`` attribute value.
+specified-by
+ The attribute value shall be an :ref:`SpecTypeActionRequirementName`. It
+ shall be the name of a pre-condition. The name of the state of the
+ pre-condition in the associated transition defines the name of the state of
+ the post-condition.
+then
+then-specified-by
+.. _SpecTypeActionRequirementExpressionConditionSet:
+Action Requirement Expression Condition Set
+This set of attributes defines for the specified conditions a set of states.
+Generic attributes may be specified. Each generic attribute key shall be an
+:ref:`SpecTypeActionRequirementName`. Each generic attribute value shall be an
+:ref:`SpecTypeActionRequirementExpressionStateSet`. There shall be at most one
+generic attribute key for each condition. The key name shall be the condition
+name. The value of each generic attribute shall be a set of states of the
+condition.
+.. _SpecTypeActionRequirementExpressionStateName:
+Action Requirement Expression State Name
+The value shall be a string. It shall be the name of a state of the condition
+or ``N/A`` if the condition is not applicable. The value
+* shall match with the regular expression "``^[A-Z][a-zA-Z0-9]+$``",
+* or, shall be equal to "``N/A``".
+.. _SpecTypeActionRequirementExpressionStateSet:
+Action Requirement Expression State Set
+ :ref:`SpecTypeActionRequirementExpressionStateName`. The list defines a set
+ of states of the condition.
+* The value may be a string. It shall be the name of a state of the condition
+ or ``N/A`` if the condition is not applicable. The value
+ * shall match with the regular expression "``^[A-Z][a-zA-Z0-9]+$``",
+ * or, shall be equal to "``N/A``".
+* :ref:`SpecTypeActionRequirementExpressionConditionSet`
.. _SpecTypeActionRequirementName:
Action Requirement Name
@@ -2548,6 +2698,10 @@ This type is used by the following types:
* :ref:`SpecTypeActionRequirementCondition`
* :ref:`SpecTypeActionRequirementSkipReasons`
* :ref:`SpecTypeActionRequirementState`
@@ -2635,6 +2789,29 @@ This type is used by the following types:
+.. _SpecTypeActionRequirementTransitionPostConditionState:
+Action Requirement Transition Post-Condition State
+ :ref:`SpecTypeActionRequirementExpression`. The list contains expressions to
+ define the state of the corresponding post-condition.
+ corresponding post-condition or ``N/A`` if the post-condition is not
+ applicable. The value
+* :ref:`SpecTypeActionRequirementTransitionPostConditions`
.. _SpecTypeActionRequirementTransitionPostConditions:
Action Requirement Transition Post-Conditions
@@ -2646,10 +2823,12 @@ A value of this type shall be of one of the following variants:
post-condition the state after the action for a transition in an action
requirement. Generic attributes may be specified. Each generic attribute key
shall be an :ref:`SpecTypeActionRequirementName`. Each generic attribute
- value shall be an :ref:`SpecTypeActionRequirementName`. There shall be
+ value shall be an
+ :ref:`SpecTypeActionRequirementTransitionPostConditionState`. There shall be
exactly one generic attribute key for each post-condition. The key name
shall be the post-condition name. The value of each generic attribute shall
- be the state of the post-condition.
+ be the state of the post-condition or ``N/A`` if the post-condition is not
+ applicable.
* The value may be a string. It shall be the name of a skip reason. If a skip
reason is given instead of a listing of post-condition states, then this
@@ -2691,14 +2870,22 @@ This type is used by the following types:
Action Requirement Transition Pre-Conditions
-This set of attributes defines for each pre-condition the set of states before
-the action for a transition in an actin requirement. Generic attributes may be
-specified. Each generic attribute key shall be an
-:ref:`SpecTypeActionRequirementName`. Each generic attribute value shall be an
-:ref:`SpecTypeActionRequirementTransitionPreConditionStateSet`. There shall be
-exactly one generic attribute key for each pre-condition. The key name shall
-be the pre-condition name. The value of each generic attribute shall be a set
-of states of the pre-condition.
+* The value may be a set of attributes. This set of attributes defines for each
+ pre-condition the set of states before the action for a transition in an
+ action requirement. Generic attributes may be specified. Each generic
+ attribute key shall be an :ref:`SpecTypeActionRequirementName`. Each generic
+ attribute value shall be an
+ :ref:`SpecTypeActionRequirementTransitionPreConditionStateSet`. There shall
+ be exactly one generic attribute key for each pre-condition. The key name
+ shall be the pre-condition name. The value of each generic attribute shall
+ be a set of states of the pre-condition.
+* The value may be a string. If this name is specified instead of explicit
+ pre-condition states, then the post-condition states of this entry are used
+ to define all remaining transitions of the map. The value shall be equal to
+ "``default``".
2.26.2
