[PATCH rtems-docs v2 3/6] rtems-docs: Edit command to install toolsuite
Thu Mar 18 05:36:45 UTC 2021
On Wed, Mar 17, 2021 at 9:04 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hello Ida,
> On Wed, Mar 17, 2021 at 8:42 PM Ida Delphine <idadelm at gmail.com> wrote:
> > I just installed texlive and trying to do a top level build using ./waf configure. But looks like it doesn't work well...I get this error at the end:
> > Setting top to                           : /home/idadel/Desktop/gsoc/docs/rtems-docs
> > Setting out to                           : /home/idadel/Desktop/gsoc/docs/rtems-docs/build
> > Checking for program 'git'               : /usr/bin/git
> > Checking for program 'sphinx-build'      : /home/idadel/anaconda3/bin/sphinx-build
> > Checking for program 'aspell'            : /usr/bin/aspell
> > Checking if Sphinx is at least 1.3       : yes (3.5)
> > Checking Sphinx Options                  : none
> > Checking Sphinx Nit-Pick mode            : no
> > Checking for 'sphinx.ext.autodoc'        : found
> > Checking for 'sphinx.ext.coverage'       : found
> > Checking for 'sphinx.ext.doctest'        : found
> > Checking for 'sphinx.ext.graphviz'       : found
> > Checking for 'sphinx.ext.intersphinx'    : found
> > Checking for 'sphinx.ext.mathjax'        : found
> > Checking for 'sphinxcontrib.bibtex'      : not found (see README.txt)
> This looks like a helpful error message ;)
> In the README.txt you'll find the "Host set up" section that has some instructions about the required packages: https://git.rtems.org/rtems-docs/tree/README.txt#n92
> The short answer to your question:
> pip install sphinx
> pip install sphinxcontrib-bibtex
I also strongly recommend following those README directions to do the
build within a virtualenv if you haven't been. This will help better
manage the python versions in use. (My host's native python
installation is broken quite badly, but virtualenv works well.)
> Best regards,
> Vijay
> > The configuration failed
> > (complete log in /home/idadel/Desktop/gsoc/docs/rtems-docs/build/config.log)
> > On Wed, Mar 17, 2021 at 9:37 PM Ida Delphine <idadelm at gmail.com> wrote:
> >> Ok, I will do that.
> >> On Tue, Mar 16, 2021 at 7:56 PM Gedare Bloom <gedare at rtems.org> wrote:
> >>> On Tue, Mar 16, 2021 at 12:16 PM Ida Delphine <idadelm at gmail.com> wrote:
> >>> > I ran the commands and copied and pasted wherever there were mismatches especially with respect to the version numbers.
> >>> OK, I noticed some inconsistencies and was wondering. It would be
> >>> better to provide the actual output for the entire snippets, see
> >>> further below what I noticed.
> >>> > Should I resend the patchset with a better commit message?
> >>> Yes. I think it would be better to also update the entire output
> >>> examples, and to separate them from the manual changes you make to the
> >>> version numbers. In other words, update the version numbers by hand
> >>> for some things, and update the console output examples separately.
> >>> You can put multiple changes together in one patch that are related,
> >>> for example you might just send one patch with all the console output
> >>> example updates.
> >>> > On Tue, 16 Mar 2021, 6:50 pm Gedare Bloom, <gedare at rtems.org> wrote:
> >>> >> Hi Ida,
> >>> >> Since the patches now indicate rtems-docs, you don't need to include
> >>> >> that in the commit message. Instead, it is recommended to put the
> >>> >> manual directory name that is modified as the first part of the
> >>> >> commit, e.g., "user: bump version 5 to 6 in start/tools.rst"
> >>> >> More below:
> >>> >> On Tue, Mar 16, 2021 at 2:16 AM Ida Delphine <idadelm at gmail.com> wrote:
> >>> >> > Edit edit sample output of tool suite installation.
> >>> >> > Edit command to check if C cross compiler works and sample output of this command.
> >>> >> >  user/start/tools.rst | 26 +++++++++++++-------------
> >>> >> >  1 file changed, 13 insertions(+), 13 deletions(-)
> >>> >> > diff --git a/user/start/tools.rst b/user/start/tools.rst
> >>> >> > index baa2387..9a915ab 100644
> >>> >> > --- a/user/start/tools.rst
> >>> >> > +++ b/user/start/tools.rst
> >>> >> > @@ -12,7 +12,7 @@ Install the Tool Suite
> >>> >> >  You have chosen an installation prefix, the BSP to build, the tool's
> >>> >> >  architecure and prepared the source for the RSB in the previous sections.  We
> >>> unrelated, fix typo: architecture
> >>> >> > -have chosen :file:`$HOME/quick-start/rtems/5` as the installation prefix, the
> >>> >> > +have chosen :file:`$HOME/quick-start/rtems/6` as the installation prefix, the
> >>> >> >  ``erc32`` BSP and the SPARC architecture name of ``sparc-rtems5``, and unpacked
> >>> >> >  the RSB source in :file:`$HOME/quick-start/src`.
> >>> >> > @@ -25,7 +25,7 @@ Build and install the tool suite:
> >>> >> >  .. code-block:: none
> >>> >> >      cd $HOME/quick-start/src/rsb/rtems
> >>> >> > -    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 5/rtems-sparc
> >>> >> > +    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 6/rtems-sparc
> >>> >> >  This command should output something like this (omitted lines are denoted by
> >>> >> >  ...). The build host appears as part of the name of the package being
> >>> >> > @@ -33,19 +33,19 @@ built. The name you see may vary depending on the host you are using:
> >>> >> > -    RTEMS Source Builder - Set Builder, 5.1.0
> >>> >> > -    Build Set: 5/rtems-sparc
> >>> >> > +    RTEMS Source Builder - Set Builder, 6
> >>> >> > +    Build Set: 6/rtems-sparc
> >>> >> >      config: tools/rtems-binutils-2.34.cfg
> >>> >> > -    package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> >>> >> > -    building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> >>> >> > -    sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB (installed: 29.966MB)
> >>> >> > -    cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> >>> >> > +    package: sparc-rtems6=-binutils-2.34-x86_64-freebsd12.1-1
> >>> The = sign here is what got me thinking something odd is going on.
> >>> Please copy-paste the entire output/snippet you get, and update the
> >>> examples completely so that each snippet is self-consistent at least.
> >>> >> > +    building: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
> >>> >> > +    sizes: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB (installed: 29.966MB)
> >>> >> > +    cleaning: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
> >>> >> >      reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
> >>> >> >      reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
> >>> >> >      config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
> >>> >> > -    package: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> >>> >> > -    building: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> >>> >> > +    package: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> >>> >> > +    building: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> >>> >> >      Build Sizes: usage: 5.684GB total: 1.112GB (sources: 143.803MB, patches: 21.348KB, installed 995.188MB)
> >>> >> >      Build Set: Time 0:21:35.626294
> >>> >> Did you run the command and capture the sample output, or do you edit
> >>> >> the sample output manually?
> >>> >> It would be better to copy-paste the actual sample output. Making this
> >>> >> version change update automatic could be a nice small scripting
> >>> >> exercise.
> >>> >> > @@ -55,7 +55,7 @@ works with the following command:
> >>> >> > -    $HOME/quick-start/rtems/5/bin/sparc-rtems5-gcc --version
> >>> >> > +    $HOME/quick-start/rtems/6/bin/sparc-rtems6-gcc --version
> >>> >> >  This command should output something like below.  The version informtion helps
> >>> >> Unrelated, but can you fix this typo: information
> >>> >> >  you to identify the exact sources used to build the cross compiler of your
> >>> >> > @@ -69,8 +69,8 @@ source code used.
> >>> >> > -    sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
> >>> >> > -    Copyright (C) 2017 Free Software Foundation, Inc.
> >>> >> > +    sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
> >>> >> > +    Copyright (C) 2020 Free Software Foundation, Inc.
> >>> >> >      This is free software; see the source for copying conditions.  There is NO
> >>> >> >      warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> >>> >> > 2.25.1
> >>> >> > _______________________________________________
> >>> >> > devel mailing list
> >>> >> > devel at rtems.org
> >>> >> > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
