[PATCH rtems-docs v2 3/6] rtems-docs: Edit command to install toolsuite
Vijay Kumar Banerjee
vijay at rtems.org
Thu Mar 18 03:04:28 UTC 2021
Hello Ida,
On Wed, Mar 17, 2021 at 8:42 PM Ida Delphine <idadelm at gmail.com> wrote:
> I just installed texlive and trying to do a top level build using ./waf
configure. But looks like it doesn't work well...I get this error at the
end:
> Setting top to :
/home/idadel/Desktop/gsoc/docs/rtems-docs
> Setting out to :
/home/idadel/Desktop/gsoc/docs/rtems-docs/build
> Checking for program 'git' : /usr/bin/git
> Checking for program 'sphinx-build' :
/home/idadel/anaconda3/bin/sphinx-build
> Checking for program 'aspell' : /usr/bin/aspell
> Checking if Sphinx is at least 1.3 : yes (3.5)
> Checking Sphinx Options : none
> Checking Sphinx Nit-Pick mode : no
> Checking for 'sphinx.ext.autodoc' : found
> Checking for 'sphinx.ext.coverage' : found
> Checking for 'sphinx.ext.doctest' : found
> Checking for 'sphinx.ext.graphviz' : found
> Checking for 'sphinx.ext.intersphinx' : found
> Checking for 'sphinx.ext.mathjax' : found
> Checking for 'sphinxcontrib.bibtex' : not found (see README.txt)
This looks like a helpful error message ;)
In the README.txt you'll find the "Host set up" section that has some
instructions about the required packages:
https://git.rtems.org/rtems-docs/tree/README.txt#n92
The short answer to your question:
pip install sphinx
pip install sphinxcontrib-bibtex
Best regards,
Vijay
> The configuration failed
> (complete log in
/home/idadel/Desktop/gsoc/docs/rtems-docs/build/config.log)
> On Wed, Mar 17, 2021 at 9:37 PM Ida Delphine <idadelm at gmail.com> wrote:
>> Ok, I will do that.
>> On Tue, Mar 16, 2021 at 7:56 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Tue, Mar 16, 2021 at 12:16 PM Ida Delphine <idadelm at gmail.com> wrote:
>>> > I ran the commands and copied and pasted wherever there were
mismatches especially with respect to the version numbers.
>>> OK, I noticed some inconsistencies and was wondering. It would be
>>> better to provide the actual output for the entire snippets, see
>>> further below what I noticed.
>>> > Should I resend the patchset with a better commit message?
>>> Yes. I think it would be better to also update the entire output
>>> examples, and to separate them from the manual changes you make to the
>>> version numbers. In other words, update the version numbers by hand
>>> for some things, and update the console output examples separately.
>>> You can put multiple changes together in one patch that are related,
>>> for example you might just send one patch with all the console output
>>> example updates.
>>> > On Tue, 16 Mar 2021, 6:50 pm Gedare Bloom, <gedare at rtems.org> wrote:
>>> >> Hi Ida,
>>> >> Since the patches now indicate rtems-docs, you don't need to include
>>> >> that in the commit message. Instead, it is recommended to put the
>>> >> manual directory name that is modified as the first part of the
>>> >> commit, e.g., "user: bump version 5 to 6 in start/tools.rst"
>>> >> More below:
>>> >> On Tue, Mar 16, 2021 at 2:16 AM Ida Delphine <idadelm at gmail.com>
wrote:
>>> >> > Edit edit sample output of tool suite installation.
>>> >> > Edit command to check if C cross compiler works and sample output
of this command.
>>> >> > user/start/tools.rst | 26 +++++++++++++-------------
>>> >> > 1 file changed, 13 insertions(+), 13 deletions(-)
>>> >> > diff --git a/user/start/tools.rst b/user/start/tools.rst
>>> >> > index baa2387..9a915ab 100644
>>> >> > --- a/user/start/tools.rst
>>> >> > +++ b/user/start/tools.rst
>>> >> > @@ -12,7 +12,7 @@ Install the Tool Suite
>>> >> > You have chosen an installation prefix, the BSP to build, the
tool's
>>> >> > architecure and prepared the source for the RSB in the previous
sections. We
>>> unrelated, fix typo: architecture
>>> >> > -have chosen :file:`$HOME/quick-start/rtems/5` as the installation
prefix, the
>>> >> > +have chosen :file:`$HOME/quick-start/rtems/6` as the installation
prefix, the
>>> >> > ``erc32`` BSP and the SPARC architecture name of
``sparc-rtems5``, and unpacked
>>> >> > the RSB source in :file:`$HOME/quick-start/src`.
>>> >> > @@ -25,7 +25,7 @@ Build and install the tool suite:
>>> >> > .. code-block:: none
>>> >> > cd $HOME/quick-start/src/rsb/rtems
>>> >> > - ../source-builder/sb-set-builder
--prefix=$HOME/quick-start/rtems/5 5/rtems-sparc
>>> >> > + ../source-builder/sb-set-builder
--prefix=$HOME/quick-start/rtems/6 6/rtems-sparc
>>> >> > This command should output something like this (omitted lines are
denoted by
>>> >> > ...). The build host appears as part of the name of the package
being
>>> >> > @@ -33,19 +33,19 @@ built. The name you see may vary depending on
the host you are using:
>>> >> > - RTEMS Source Builder - Set Builder, 5.1.0
>>> >> > - Build Set: 5/rtems-sparc
>>> >> > + RTEMS Source Builder - Set Builder, 6
>>> >> > + Build Set: 6/rtems-sparc
>>> >> > config: tools/rtems-binutils-2.34.cfg
>>> >> > - package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>>> >> > - building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>>> >> > - sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1:
305.866MB (installed: 29.966MB)
>>> >> > - cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>>> >> > + package: sparc-rtems6=-binutils-2.34-x86_64-freebsd12.1-1
>>> The = sign here is what got me thinking something odd is going on.
>>> Please copy-paste the entire output/snippet you get, and update the
>>> examples completely so that each snippet is self-consistent at least.
>>> >> > + building: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
>>> >> > + sizes: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1:
>>> >> > + cleaning: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
>>> >> > reporting: tools/rtems-binutils-2.34.cfg ->
sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
>>> >> > config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
>>> >> > - package:
sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>>> >> > - building:
>>> >> > + package:
sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>>> >> > + building:
>>> >> > Build Sizes: usage: 5.684GB total: 1.112GB (sources:
143.803MB, patches: 21.348KB, installed 995.188MB)
>>> >> > Build Set: Time 0:21:35.626294
>>> >> Did you run the command and capture the sample output, or do you edit
>>> >> the sample output manually?
>>> >> It would be better to copy-paste the actual sample output. Making
this
>>> >> version change update automatic could be a nice small scripting
>>> >> exercise.
>>> >> > @@ -55,7 +55,7 @@ works with the following command:
>>> >> > - $HOME/quick-start/rtems/5/bin/sparc-rtems5-gcc --version
>>> >> > + $HOME/quick-start/rtems/6/bin/sparc-rtems6-gcc --version
>>> >> > This command should output something like below. The version
informtion helps
>>> >> Unrelated, but can you fix this typo: information
>>> >> > you to identify the exact sources used to build the cross
compiler of your
>>> >> > @@ -69,8 +69,8 @@ source code used.
>>> >> > - sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0,
Newlib fbaa096)
>>> >> > - Copyright (C) 2017 Free Software Foundation, Inc.
>>> >> > + sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB
5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
>>> >> > + Copyright (C) 2020 Free Software Foundation, Inc.
>>> >> > This is free software; see the source for copying
conditions. There is NO
>>> >> > warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
>>> >> > 2.25.1
>>> >> > _______________________________________________
>>> >> > devel mailing list
>>> >> > devel at rtems.org
>>> >> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210317/1b80d2cb/attachment-0001.html>
