[PATCH 0/3] Renamed tests, test fix, additions to YAML files
Ryan Long
ryan.long at oarcorp.com
Thu Mar 18 20:27:05 UTC 2021
Hi,
These patches are pretty diverse. They are all from the work we've been
doing for AArch64.
Patch 1:
For this, if a test's YAML file's executable field differed from the
name of the file, it was renamed to the name specified in the executable
field. After this, I had to change any references to the previous file
names.
Patch 2:
This patch fixed an issue that prevented ts-validation-0 from
building/running. All I had to do was change the data type of
maximum_pending_messages from uint32_t to size_t.
Patch 3:
I just expanded upon what the comments were saying, and I added more
tests that we had seen to intermittently fail.
Thanks,
Ryan
Ryan Long (3):
bsps: Renamed YAML files to match test names
Changed variable type to fix AARCH64 test issues
bsps/aarch64: changed comments and test statuses
cpukit/include/rtems/rtems/message.h | 2 +-
cpukit/include/rtems/score/coremsgimpl.h | 2 +-
cpukit/score/src/coremsg.c | 2 +-
spec/build/bsps/aarch64/a53/tsta53.yml | 39 ++++-
spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 39 ++++-
spec/build/bsps/arm/atsam/tstatsamv.yml | 18 +--
spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml | 4 +-
spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml | 2 +-
.../bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml | 76 +++++-----
spec/build/bsps/arm/lpc24xx/tstlpc2362.yml | 10 +-
spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml | 12 +-
spec/build/bsps/tstnoiconv.yml | 4 +-
spec/build/bsps/tstnojffs2.yml | 16 +-
spec/build/bsps/tstnorfs.yml | 20 +--
spec/build/testsuites/ada/ada_base_sp.yml | 23 +++
spec/build/testsuites/ada/ada_hello.yml | 23 +++
spec/build/testsuites/ada/ada_mp01_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp01_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp03_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp03_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp04_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp04_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp05_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp05_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp06_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp06_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp07_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp07_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp08_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp08_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp09_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp09_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp10_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp10_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp11_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp11_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp12_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp12_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp13_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp13_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_mp14_node1.yml | 25 ++++
spec/build/testsuites/ada/ada_mp14_node2.yml | 25 ++++
spec/build/testsuites/ada/ada_nsecs.yml | 23 +++
spec/build/testsuites/ada/ada_sp01.yml | 23 +++
spec/build/testsuites/ada/ada_sp02.yml | 23 +++
spec/build/testsuites/ada/ada_sp03.yml | 23 +++
spec/build/testsuites/ada/ada_sp04.yml | 23 +++
spec/build/testsuites/ada/ada_sp05.yml | 23 +++
spec/build/testsuites/ada/ada_sp06.yml | 23 +++
spec/build/testsuites/ada/ada_sp07.yml | 23 +++
spec/build/testsuites/ada/ada_sp08.yml | 23 +++
spec/build/testsuites/ada/ada_sp09.yml | 23 +++
spec/build/testsuites/ada/ada_sp11.yml | 23 +++
spec/build/testsuites/ada/ada_sp12.yml | 23 +++
spec/build/testsuites/ada/ada_sp13.yml | 23 +++
spec/build/testsuites/ada/ada_sp14.yml | 23 +++
spec/build/testsuites/ada/ada_sp15.yml | 23 +++
spec/build/testsuites/ada/ada_sp16.yml | 23 +++
spec/build/testsuites/ada/ada_sp17.yml | 23 +++
spec/build/testsuites/ada/ada_sp19.yml | 23 +++
spec/build/testsuites/ada/ada_sp20.yml | 23 +++
spec/build/testsuites/ada/ada_sp22.yml | 23 +++
spec/build/testsuites/ada/ada_sp23.yml | 23 +++
spec/build/testsuites/ada/ada_sp24.yml | 23 +++
spec/build/testsuites/ada/ada_sp25.yml | 23 +++
spec/build/testsuites/ada/ada_spatcb01.yml | 24 +++
spec/build/testsuites/ada/ada_spname01.yml | 24 +++
spec/build/testsuites/ada/ada_ticker.yml | 23 +++
spec/build/testsuites/ada/ada_tm01.yml | 23 +++
spec/build/testsuites/ada/ada_tm02.yml | 23 +++
spec/build/testsuites/ada/ada_tm03.yml | 23 +++
spec/build/testsuites/ada/ada_tm04.yml | 23 +++
spec/build/testsuites/ada/ada_tm05.yml | 23 +++
spec/build/testsuites/ada/ada_tm06.yml | 23 +++
spec/build/testsuites/ada/ada_tm07.yml | 23 +++
spec/build/testsuites/ada/ada_tm08.yml | 23 +++
spec/build/testsuites/ada/ada_tm09.yml | 23 +++
spec/build/testsuites/ada/ada_tm10.yml | 23 +++
spec/build/testsuites/ada/ada_tm11.yml | 23 +++
spec/build/testsuites/ada/ada_tm12.yml | 23 +++
spec/build/testsuites/ada/ada_tm13.yml | 23 +++
spec/build/testsuites/ada/ada_tm14.yml | 23 +++
spec/build/testsuites/ada/ada_tm15.yml | 23 +++
spec/build/testsuites/ada/ada_tm16.yml | 23 +++
spec/build/testsuites/ada/ada_tm17.yml | 23 +++
spec/build/testsuites/ada/ada_tm18.yml | 23 +++
spec/build/testsuites/ada/ada_tm19.yml | 23 +++
spec/build/testsuites/ada/ada_tm20.yml | 23 +++
spec/build/testsuites/ada/ada_tm21.yml | 23 +++
spec/build/testsuites/ada/ada_tm22.yml | 23 +++
spec/build/testsuites/ada/ada_tm23.yml | 23 +++
spec/build/testsuites/ada/ada_tm24.yml | 23 +++
spec/build/testsuites/ada/ada_tm25.yml | 23 +++
spec/build/testsuites/ada/ada_tm28.yml | 23 +++
spec/build/testsuites/ada/ada_tm29.yml | 23 +++
spec/build/testsuites/ada/ada_tmck.yml | 23 +++
spec/build/testsuites/ada/adabasesp.yml | 23 ---
spec/build/testsuites/ada/adahello.yml | 23 ---
spec/build/testsuites/ada/adamp01node1.yml | 25 ----
spec/build/testsuites/ada/adamp01node2.yml | 25 ----
spec/build/testsuites/ada/adamp03node1.yml | 25 ----
spec/build/testsuites/ada/adamp03node2.yml | 25 ----
spec/build/testsuites/ada/adamp04node1.yml | 25 ----
spec/build/testsuites/ada/adamp04node2.yml | 25 ----
spec/build/testsuites/ada/adamp05node1.yml | 25 ----
spec/build/testsuites/ada/adamp05node2.yml | 25 ----
spec/build/testsuites/ada/adamp06node1.yml | 25 ----
spec/build/testsuites/ada/adamp06node2.yml | 25 ----
spec/build/testsuites/ada/adamp07node1.yml | 25 ----
spec/build/testsuites/ada/adamp07node2.yml | 25 ----
spec/build/testsuites/ada/adamp08node1.yml | 25 ----
spec/build/testsuites/ada/adamp08node2.yml | 25 ----
spec/build/testsuites/ada/adamp09node1.yml | 25 ----
spec/build/testsuites/ada/adamp09node2.yml | 25 ----
spec/build/testsuites/ada/adamp10node1.yml | 25 ----
spec/build/testsuites/ada/adamp10node2.yml | 25 ----
spec/build/testsuites/ada/adamp11node1.yml | 25 ----
spec/build/testsuites/ada/adamp11node2.yml | 25 ----
spec/build/testsuites/ada/adamp12node1.yml | 25 ----
spec/build/testsuites/ada/adamp12node2.yml | 25 ----
spec/build/testsuites/ada/adamp13node1.yml | 25 ----
spec/build/testsuites/ada/adamp13node2.yml | 25 ----
spec/build/testsuites/ada/adamp14node1.yml | 25 ----
spec/build/testsuites/ada/adamp14node2.yml | 25 ----
spec/build/testsuites/ada/adansecs.yml | 23 ---
spec/build/testsuites/ada/adasp01.yml | 23 ---
spec/build/testsuites/ada/adasp02.yml | 23 ---
spec/build/testsuites/ada/adasp03.yml | 23 ---
spec/build/testsuites/ada/adasp04.yml | 23 ---
spec/build/testsuites/ada/adasp05.yml | 23 ---
spec/build/testsuites/ada/adasp06.yml | 23 ---
spec/build/testsuites/ada/adasp07.yml | 23 ---
spec/build/testsuites/ada/adasp08.yml | 23 ---
spec/build/testsuites/ada/adasp09.yml | 23 ---
spec/build/testsuites/ada/adasp11.yml | 23 ---
spec/build/testsuites/ada/adasp12.yml | 23 ---
spec/build/testsuites/ada/adasp13.yml | 23 ---
spec/build/testsuites/ada/adasp14.yml | 23 ---
spec/build/testsuites/ada/adasp15.yml | 23 ---
spec/build/testsuites/ada/adasp16.yml | 23 ---
spec/build/testsuites/ada/adasp17.yml | 23 ---
spec/build/testsuites/ada/adasp19.yml | 23 ---
spec/build/testsuites/ada/adasp20.yml | 23 ---
spec/build/testsuites/ada/adasp22.yml | 23 ---
spec/build/testsuites/ada/adasp23.yml | 23 ---
spec/build/testsuites/ada/adasp24.yml | 23 ---
spec/build/testsuites/ada/adasp25.yml | 23 ---
spec/build/testsuites/ada/adaspatcb01.yml | 24 ---
spec/build/testsuites/ada/adaspname01.yml | 24 ---
spec/build/testsuites/ada/adaticker.yml | 23 ---
spec/build/testsuites/ada/adatm01.yml | 23 ---
spec/build/testsuites/ada/adatm02.yml | 23 ---
spec/build/testsuites/ada/adatm03.yml | 23 ---
spec/build/testsuites/ada/adatm04.yml | 23 ---
spec/build/testsuites/ada/adatm05.yml | 23 ---
spec/build/testsuites/ada/adatm06.yml | 23 ---
spec/build/testsuites/ada/adatm07.yml | 23 ---
spec/build/testsuites/ada/adatm08.yml | 23 ---
spec/build/testsuites/ada/adatm09.yml | 23 ---
spec/build/testsuites/ada/adatm10.yml | 23 ---
spec/build/testsuites/ada/adatm11.yml | 23 ---
spec/build/testsuites/ada/adatm12.yml | 23 ---
spec/build/testsuites/ada/adatm13.yml | 23 ---
spec/build/testsuites/ada/adatm14.yml | 23 ---
spec/build/testsuites/ada/adatm15.yml | 23 ---
spec/build/testsuites/ada/adatm16.yml | 23 ---
spec/build/testsuites/ada/adatm17.yml | 23 ---
spec/build/testsuites/ada/adatm18.yml | 23 ---
spec/build/testsuites/ada/adatm19.yml | 23 ---
spec/build/testsuites/ada/adatm20.yml | 23 ---
spec/build/testsuites/ada/adatm21.yml | 23 ---
spec/build/testsuites/ada/adatm22.yml | 23 ---
spec/build/testsuites/ada/adatm23.yml | 23 ---
spec/build/testsuites/ada/adatm24.yml | 23 ---
spec/build/testsuites/ada/adatm25.yml | 23 ---
spec/build/testsuites/ada/adatm28.yml | 23 ---
spec/build/testsuites/ada/adatm29.yml | 23 ---
spec/build/testsuites/ada/adatmck.yml | 23 ---
spec/build/testsuites/ada/grp.yml | 164 ++++++++++-----------
spec/build/testsuites/fstests/grp.yml | 82 +++++------
spec/build/testsuites/fstests/imfs_fserror.yml | 21 +++
spec/build/testsuites/fstests/imfs_fslink.yml | 21 +++
spec/build/testsuites/fstests/imfs_fspatheval.yml | 21 +++
.../build/testsuites/fstests/imfs_fspermission.yml | 21 +++
spec/build/testsuites/fstests/imfs_fsrdwr.yml | 21 +++
spec/build/testsuites/fstests/imfs_fsscandir01.yml | 21 +++
spec/build/testsuites/fstests/imfs_fssymlink.yml | 21 +++
spec/build/testsuites/fstests/imfs_fstime.yml | 21 +++
spec/build/testsuites/fstests/imfsfserror.yml | 21 ---
spec/build/testsuites/fstests/imfsfslink.yml | 21 ---
spec/build/testsuites/fstests/imfsfspatheval.yml | 21 ---
spec/build/testsuites/fstests/imfsfspermission.yml | 21 ---
spec/build/testsuites/fstests/imfsfsrdwr.yml | 21 ---
spec/build/testsuites/fstests/imfsfsscandir01.yml | 21 ---
spec/build/testsuites/fstests/imfsfssymlink.yml | 21 ---
spec/build/testsuites/fstests/imfsfstime.yml | 21 ---
spec/build/testsuites/fstests/jffs2_fserror.yml | 22 +++
spec/build/testsuites/fstests/jffs2_fslink.yml | 22 +++
spec/build/testsuites/fstests/jffs2_fspatheval.yml | 22 +++
.../testsuites/fstests/jffs2_fspermission.yml | 22 +++
spec/build/testsuites/fstests/jffs2_fsrdwr.yml | 22 +++
.../build/testsuites/fstests/jffs2_fsscandir01.yml | 22 +++
spec/build/testsuites/fstests/jffs2_fssymlink.yml | 22 +++
spec/build/testsuites/fstests/jffs2_fstime.yml | 22 +++
spec/build/testsuites/fstests/jffs2fserror.yml | 22 ---
spec/build/testsuites/fstests/jffs2fslink.yml | 22 ---
spec/build/testsuites/fstests/jffs2fspatheval.yml | 22 ---
.../build/testsuites/fstests/jffs2fspermission.yml | 22 ---
spec/build/testsuites/fstests/jffs2fsrdwr.yml | 22 ---
spec/build/testsuites/fstests/jffs2fsscandir01.yml | 22 ---
spec/build/testsuites/fstests/jffs2fssymlink.yml | 22 ---
spec/build/testsuites/fstests/jffs2fstime.yml | 22 ---
spec/build/testsuites/fstests/mdosfs_fserror.yml | 21 +++
.../build/testsuites/fstests/mdosfs_fspatheval.yml | 21 +++
spec/build/testsuites/fstests/mdosfs_fsrdwr.yml | 21 +++
.../testsuites/fstests/mdosfs_fsscandir01.yml | 21 +++
spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml | 21 +++
spec/build/testsuites/fstests/mdosfs_fstime.yml | 21 +++
spec/build/testsuites/fstests/mdosfsfserror.yml | 21 ---
spec/build/testsuites/fstests/mdosfsfspatheval.yml | 21 ---
spec/build/testsuites/fstests/mdosfsfsrdwr.yml | 21 ---
.../build/testsuites/fstests/mdosfsfsscandir01.yml | 21 ---
spec/build/testsuites/fstests/mdosfsfsstatvfs.yml | 21 ---
spec/build/testsuites/fstests/mdosfsfstime.yml | 21 ---
spec/build/testsuites/fstests/mimfs_fserror.yml | 21 +++
spec/build/testsuites/fstests/mimfs_fslink.yml | 21 +++
spec/build/testsuites/fstests/mimfs_fspatheval.yml | 21 +++
.../testsuites/fstests/mimfs_fspermission.yml | 21 +++
spec/build/testsuites/fstests/mimfs_fsrdwr.yml | 21 +++
spec/build/testsuites/fstests/mimfs_fsrename.yml | 21 +++
.../build/testsuites/fstests/mimfs_fsscandir01.yml | 21 +++
spec/build/testsuites/fstests/mimfs_fssymlink.yml | 21 +++
spec/build/testsuites/fstests/mimfs_fstime.yml | 21 +++
spec/build/testsuites/fstests/mimfsfserror.yml | 21 ---
spec/build/testsuites/fstests/mimfsfslink.yml | 21 ---
spec/build/testsuites/fstests/mimfsfspatheval.yml | 21 ---
.../build/testsuites/fstests/mimfsfspermission.yml | 21 ---
spec/build/testsuites/fstests/mimfsfsrdwr.yml | 21 ---
spec/build/testsuites/fstests/mimfsfsrename.yml | 21 ---
spec/build/testsuites/fstests/mimfsfsscandir01.yml | 21 ---
spec/build/testsuites/fstests/mimfsfssymlink.yml | 21 ---
spec/build/testsuites/fstests/mimfsfstime.yml | 21 ---
spec/build/testsuites/fstests/mrfs_fserror.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fsfpathconf.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fslink.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fspatheval.yml | 21 +++
.../build/testsuites/fstests/mrfs_fspermission.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fsrdwr.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fsrename.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fsscandir01.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fssymlink.yml | 21 +++
spec/build/testsuites/fstests/mrfs_fstime.yml | 21 +++
spec/build/testsuites/fstests/mrfsfserror.yml | 21 ---
spec/build/testsuites/fstests/mrfsfsfpathconf.yml | 21 ---
spec/build/testsuites/fstests/mrfsfslink.yml | 21 ---
spec/build/testsuites/fstests/mrfsfspatheval.yml | 21 ---
spec/build/testsuites/fstests/mrfsfspermission.yml | 21 ---
spec/build/testsuites/fstests/mrfsfsrdwr.yml | 21 ---
spec/build/testsuites/fstests/mrfsfsrename.yml | 21 ---
spec/build/testsuites/fstests/mrfsfsscandir01.yml | 21 ---
spec/build/testsuites/fstests/mrfsfssymlink.yml | 21 ---
spec/build/testsuites/fstests/mrfsfstime.yml | 21 ---
spec/build/testsuites/libtests/clock_gettime.yml | 20 +++
spec/build/testsuites/libtests/clockgettime.yml | 20 ---
spec/build/testsuites/libtests/grp.yml | 8 +-
spec/build/testsuites/libtests/iconv_close.yml | 20 +++
spec/build/testsuites/libtests/iconv_open.yml | 20 +++
spec/build/testsuites/libtests/iconvclose.yml | 20 ---
spec/build/testsuites/libtests/iconvopen.yml | 20 ---
spec/build/testsuites/libtests/posix_memalign.yml | 20 +++
spec/build/testsuites/libtests/posixmemalign.yml | 20 ---
spec/build/testsuites/mptests/grp.yml | 52 +++----
spec/build/testsuites/mptests/mp01_node1.yml | 21 +++
spec/build/testsuites/mptests/mp01_node2.yml | 21 +++
spec/build/testsuites/mptests/mp01node1.yml | 21 ---
spec/build/testsuites/mptests/mp01node2.yml | 21 ---
spec/build/testsuites/mptests/mp03_node1.yml | 22 +++
spec/build/testsuites/mptests/mp03_node2.yml | 22 +++
spec/build/testsuites/mptests/mp03node1.yml | 22 ---
spec/build/testsuites/mptests/mp03node2.yml | 22 ---
spec/build/testsuites/mptests/mp04_node1.yml | 21 +++
spec/build/testsuites/mptests/mp04_node2.yml | 21 +++
spec/build/testsuites/mptests/mp04node1.yml | 21 ---
spec/build/testsuites/mptests/mp04node2.yml | 21 ---
spec/build/testsuites/mptests/mp05_node1.yml | 22 +++
spec/build/testsuites/mptests/mp05_node2.yml | 22 +++
spec/build/testsuites/mptests/mp05node1.yml | 22 ---
spec/build/testsuites/mptests/mp05node2.yml | 22 ---
spec/build/testsuites/mptests/mp06_node1.yml | 21 +++
spec/build/testsuites/mptests/mp06_node2.yml | 21 +++
spec/build/testsuites/mptests/mp06node1.yml | 21 ---
spec/build/testsuites/mptests/mp06node2.yml | 21 ---
spec/build/testsuites/mptests/mp07_node1.yml | 21 +++
spec/build/testsuites/mptests/mp07_node2.yml | 21 +++
spec/build/testsuites/mptests/mp07node1.yml | 21 ---
spec/build/testsuites/mptests/mp07node2.yml | 21 ---
spec/build/testsuites/mptests/mp08_node1.yml | 21 +++
spec/build/testsuites/mptests/mp08_node2.yml | 21 +++
spec/build/testsuites/mptests/mp08node1.yml | 21 ---
spec/build/testsuites/mptests/mp08node2.yml | 21 ---
spec/build/testsuites/mptests/mp09_node1.yml | 23 +++
spec/build/testsuites/mptests/mp09_node2.yml | 23 +++
spec/build/testsuites/mptests/mp09node1.yml | 23 ---
spec/build/testsuites/mptests/mp09node2.yml | 23 ---
spec/build/testsuites/mptests/mp10_node1.yml | 23 +++
spec/build/testsuites/mptests/mp10_node2.yml | 23 +++
spec/build/testsuites/mptests/mp10node1.yml | 23 ---
spec/build/testsuites/mptests/mp10node2.yml | 23 ---
spec/build/testsuites/mptests/mp11_node1.yml | 20 +++
spec/build/testsuites/mptests/mp11_node2.yml | 20 +++
spec/build/testsuites/mptests/mp11node1.yml | 20 ---
spec/build/testsuites/mptests/mp11node2.yml | 20 ---
spec/build/testsuites/mptests/mp12_node1.yml | 20 +++
spec/build/testsuites/mptests/mp12_node2.yml | 20 +++
spec/build/testsuites/mptests/mp12node1.yml | 20 ---
spec/build/testsuites/mptests/mp12node2.yml | 20 ---
spec/build/testsuites/mptests/mp13_node1.yml | 22 +++
spec/build/testsuites/mptests/mp13_node2.yml | 22 +++
spec/build/testsuites/mptests/mp13node1.yml | 22 ---
spec/build/testsuites/mptests/mp13node2.yml | 22 ---
spec/build/testsuites/mptests/mp14_node1.yml | 27 ++++
spec/build/testsuites/mptests/mp14_node2.yml | 27 ++++
spec/build/testsuites/mptests/mp14node1.yml | 27 ----
spec/build/testsuites/mptests/mp14node2.yml | 27 ----
spec/build/testsuites/psxtests/grp.yml | 2 +-
spec/build/testsuites/psxtests/psxeintr_join.yml | 20 +++
spec/build/testsuites/psxtests/psxeintrjoin.yml | 20 ---
.../build/testsuites/psxtests/psxfatal_support.yml | 19 +++
spec/build/testsuites/psxtests/psxfatalsupport.yml | 19 ---
spec/build/testsuites/samples/base_mp_node1.yml | 21 +++
spec/build/testsuites/samples/base_mp_node2.yml | 21 +++
spec/build/testsuites/samples/base_sp.yml | 20 +++
spec/build/testsuites/samples/basempnode1.yml | 21 ---
spec/build/testsuites/samples/basempnode2.yml | 21 ---
spec/build/testsuites/samples/basesp.yml | 20 ---
spec/build/testsuites/samples/grp.yml | 6 +-
spec/build/testsuites/sptests/grp.yml | 40 ++---
spec/build/testsuites/sptests/spclock_err01.yml | 20 +++
spec/build/testsuites/sptests/spclock_err02.yml | 19 +++
.../build/testsuites/sptests/spclock_todhook01.yml | 19 +++
spec/build/testsuites/sptests/spclockerr01.yml | 20 ---
spec/build/testsuites/sptests/spclockerr02.yml | 19 ---
spec/build/testsuites/sptests/spclocktodhook01.yml | 19 ---
spec/build/testsuites/sptests/spevent_err03.yml | 19 +++
spec/build/testsuites/sptests/speventerr03.yml | 19 ---
spec/build/testsuites/sptests/spfatal_support.yml | 19 +++
spec/build/testsuites/sptests/spfatalsupport.yml | 19 ---
spec/build/testsuites/sptests/spintr_err01.yml | 20 +++
spec/build/testsuites/sptests/spintrerr01.yml | 20 ---
spec/build/testsuites/sptests/spmsgq_err01.yml | 19 +++
spec/build/testsuites/sptests/spmsgq_err02.yml | 20 +++
spec/build/testsuites/sptests/spmsgqerr01.yml | 19 ---
spec/build/testsuites/sptests/spmsgqerr02.yml | 20 ---
.../build/testsuites/sptests/sppartition_err01.yml | 19 +++
spec/build/testsuites/sptests/sppartitionerr01.yml | 19 ---
spec/build/testsuites/sptests/spport_err01.yml | 19 +++
spec/build/testsuites/sptests/spporterr01.yml | 19 ---
spec/build/testsuites/sptests/spratemon_err01.yml | 21 +++
spec/build/testsuites/sptests/spratemonerr01.yml | 21 ---
spec/build/testsuites/sptests/spregion_err01.yml | 19 +++
spec/build/testsuites/sptests/spregionerr01.yml | 19 ---
spec/build/testsuites/sptests/spsem_err01.yml | 19 +++
spec/build/testsuites/sptests/spsem_err02.yml | 20 +++
spec/build/testsuites/sptests/spsemerr01.yml | 19 ---
spec/build/testsuites/sptests/spsemerr02.yml | 20 ---
spec/build/testsuites/sptests/spsignal_err01.yml | 20 +++
spec/build/testsuites/sptests/spsignalerr01.yml | 20 ---
spec/build/testsuites/sptests/sptask_err01.yml | 20 +++
spec/build/testsuites/sptests/sptask_err02.yml | 19 +++
spec/build/testsuites/sptests/sptask_err03.yml | 19 +++
spec/build/testsuites/sptests/sptask_err04.yml | 20 +++
spec/build/testsuites/sptests/sptaskerr01.yml | 20 ---
spec/build/testsuites/sptests/sptaskerr02.yml | 19 ---
spec/build/testsuites/sptests/sptaskerr03.yml | 19 ---
spec/build/testsuites/sptests/sptaskerr04.yml | 20 ---
spec/build/testsuites/sptests/sptimer_err01.yml | 19 +++
spec/build/testsuites/sptests/sptimer_err02.yml | 19 +++
spec/build/testsuites/sptests/sptimererr01.yml | 19 ---
spec/build/testsuites/sptests/sptimererr02.yml | 19 ---
.../validation/tc-message-construct-errors.c | 2 +-
380 files changed, 4294 insertions(+), 4240 deletions(-)
create mode 100644 spec/build/testsuites/ada/ada_base_sp.yml
create mode 100644 spec/build/testsuites/ada/ada_hello.yml
create mode 100644 spec/build/testsuites/ada/ada_mp01_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp01_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp03_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp03_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp04_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp04_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp05_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp05_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp06_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp06_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp07_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp07_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp08_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp08_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp09_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp09_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp10_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp10_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp11_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp11_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp12_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp12_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp13_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp13_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_mp14_node1.yml
create mode 100644 spec/build/testsuites/ada/ada_mp14_node2.yml
create mode 100644 spec/build/testsuites/ada/ada_nsecs.yml
create mode 100644 spec/build/testsuites/ada/ada_sp01.yml
create mode 100644 spec/build/testsuites/ada/ada_sp02.yml
create mode 100644 spec/build/testsuites/ada/ada_sp03.yml
create mode 100644 spec/build/testsuites/ada/ada_sp04.yml
create mode 100644 spec/build/testsuites/ada/ada_sp05.yml
create mode 100644 spec/build/testsuites/ada/ada_sp06.yml
create mode 100644 spec/build/testsuites/ada/ada_sp07.yml
create mode 100644 spec/build/testsuites/ada/ada_sp08.yml
create mode 100644 spec/build/testsuites/ada/ada_sp09.yml
create mode 100644 spec/build/testsuites/ada/ada_sp11.yml
create mode 100644 spec/build/testsuites/ada/ada_sp12.yml
create mode 100644 spec/build/testsuites/ada/ada_sp13.yml
create mode 100644 spec/build/testsuites/ada/ada_sp14.yml
create mode 100644 spec/build/testsuites/ada/ada_sp15.yml
create mode 100644 spec/build/testsuites/ada/ada_sp16.yml
create mode 100644 spec/build/testsuites/ada/ada_sp17.yml
create mode 100644 spec/build/testsuites/ada/ada_sp19.yml
create mode 100644 spec/build/testsuites/ada/ada_sp20.yml
create mode 100644 spec/build/testsuites/ada/ada_sp22.yml
create mode 100644 spec/build/testsuites/ada/ada_sp23.yml
create mode 100644 spec/build/testsuites/ada/ada_sp24.yml
create mode 100644 spec/build/testsuites/ada/ada_sp25.yml
create mode 100644 spec/build/testsuites/ada/ada_spatcb01.yml
create mode 100644 spec/build/testsuites/ada/ada_spname01.yml
create mode 100644 spec/build/testsuites/ada/ada_ticker.yml
create mode 100644 spec/build/testsuites/ada/ada_tm01.yml
create mode 100644 spec/build/testsuites/ada/ada_tm02.yml
create mode 100644 spec/build/testsuites/ada/ada_tm03.yml
create mode 100644 spec/build/testsuites/ada/ada_tm04.yml
create mode 100644 spec/build/testsuites/ada/ada_tm05.yml
create mode 100644 spec/build/testsuites/ada/ada_tm06.yml
create mode 100644 spec/build/testsuites/ada/ada_tm07.yml
create mode 100644 spec/build/testsuites/ada/ada_tm08.yml
create mode 100644 spec/build/testsuites/ada/ada_tm09.yml
create mode 100644 spec/build/testsuites/ada/ada_tm10.yml
create mode 100644 spec/build/testsuites/ada/ada_tm11.yml
create mode 100644 spec/build/testsuites/ada/ada_tm12.yml
create mode 100644 spec/build/testsuites/ada/ada_tm13.yml
create mode 100644 spec/build/testsuites/ada/ada_tm14.yml
create mode 100644 spec/build/testsuites/ada/ada_tm15.yml
create mode 100644 spec/build/testsuites/ada/ada_tm16.yml
create mode 100644 spec/build/testsuites/ada/ada_tm17.yml
create mode 100644 spec/build/testsuites/ada/ada_tm18.yml
create mode 100644 spec/build/testsuites/ada/ada_tm19.yml
create mode 100644 spec/build/testsuites/ada/ada_tm20.yml
create mode 100644 spec/build/testsuites/ada/ada_tm21.yml
create mode 100644 spec/build/testsuites/ada/ada_tm22.yml
create mode 100644 spec/build/testsuites/ada/ada_tm23.yml
create mode 100644 spec/build/testsuites/ada/ada_tm24.yml
create mode 100644 spec/build/testsuites/ada/ada_tm25.yml
create mode 100644 spec/build/testsuites/ada/ada_tm28.yml
create mode 100644 spec/build/testsuites/ada/ada_tm29.yml
create mode 100644 spec/build/testsuites/ada/ada_tmck.yml
delete mode 100644 spec/build/testsuites/ada/adabasesp.yml
delete mode 100644 spec/build/testsuites/ada/adahello.yml
delete mode 100644 spec/build/testsuites/ada/adamp01node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp01node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp03node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp03node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp04node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp04node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp05node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp05node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp06node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp06node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp07node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp07node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp08node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp08node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp09node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp09node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp10node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp10node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp11node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp11node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp12node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp12node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp13node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp13node2.yml
delete mode 100644 spec/build/testsuites/ada/adamp14node1.yml
delete mode 100644 spec/build/testsuites/ada/adamp14node2.yml
delete mode 100644 spec/build/testsuites/ada/adansecs.yml
delete mode 100644 spec/build/testsuites/ada/adasp01.yml
delete mode 100644 spec/build/testsuites/ada/adasp02.yml
delete mode 100644 spec/build/testsuites/ada/adasp03.yml
delete mode 100644 spec/build/testsuites/ada/adasp04.yml
delete mode 100644 spec/build/testsuites/ada/adasp05.yml
delete mode 100644 spec/build/testsuites/ada/adasp06.yml
delete mode 100644 spec/build/testsuites/ada/adasp07.yml
delete mode 100644 spec/build/testsuites/ada/adasp08.yml
delete mode 100644 spec/build/testsuites/ada/adasp09.yml
delete mode 100644 spec/build/testsuites/ada/adasp11.yml
delete mode 100644 spec/build/testsuites/ada/adasp12.yml
delete mode 100644 spec/build/testsuites/ada/adasp13.yml
delete mode 100644 spec/build/testsuites/ada/adasp14.yml
delete mode 100644 spec/build/testsuites/ada/adasp15.yml
delete mode 100644 spec/build/testsuites/ada/adasp16.yml
delete mode 100644 spec/build/testsuites/ada/adasp17.yml
delete mode 100644 spec/build/testsuites/ada/adasp19.yml
delete mode 100644 spec/build/testsuites/ada/adasp20.yml
delete mode 100644 spec/build/testsuites/ada/adasp22.yml
delete mode 100644 spec/build/testsuites/ada/adasp23.yml
delete mode 100644 spec/build/testsuites/ada/adasp24.yml
delete mode 100644 spec/build/testsuites/ada/adasp25.yml
delete mode 100644 spec/build/testsuites/ada/adaspatcb01.yml
delete mode 100644 spec/build/testsuites/ada/adaspname01.yml
delete mode 100644 spec/build/testsuites/ada/adaticker.yml
delete mode 100644 spec/build/testsuites/ada/adatm01.yml
delete mode 100644 spec/build/testsuites/ada/adatm02.yml
delete mode 100644 spec/build/testsuites/ada/adatm03.yml
delete mode 100644 spec/build/testsuites/ada/adatm04.yml
delete mode 100644 spec/build/testsuites/ada/adatm05.yml
delete mode 100644 spec/build/testsuites/ada/adatm06.yml
delete mode 100644 spec/build/testsuites/ada/adatm07.yml
delete mode 100644 spec/build/testsuites/ada/adatm08.yml
delete mode 100644 spec/build/testsuites/ada/adatm09.yml
delete mode 100644 spec/build/testsuites/ada/adatm10.yml
delete mode 100644 spec/build/testsuites/ada/adatm11.yml
delete mode 100644 spec/build/testsuites/ada/adatm12.yml
delete mode 100644 spec/build/testsuites/ada/adatm13.yml
delete mode 100644 spec/build/testsuites/ada/adatm14.yml
delete mode 100644 spec/build/testsuites/ada/adatm15.yml
delete mode 100644 spec/build/testsuites/ada/adatm16.yml
delete mode 100644 spec/build/testsuites/ada/adatm17.yml
delete mode 100644 spec/build/testsuites/ada/adatm18.yml
delete mode 100644 spec/build/testsuites/ada/adatm19.yml
delete mode 100644 spec/build/testsuites/ada/adatm20.yml
delete mode 100644 spec/build/testsuites/ada/adatm21.yml
delete mode 100644 spec/build/testsuites/ada/adatm22.yml
delete mode 100644 spec/build/testsuites/ada/adatm23.yml
delete mode 100644 spec/build/testsuites/ada/adatm24.yml
delete mode 100644 spec/build/testsuites/ada/adatm25.yml
delete mode 100644 spec/build/testsuites/ada/adatm28.yml
delete mode 100644 spec/build/testsuites/ada/adatm29.yml
delete mode 100644 spec/build/testsuites/ada/adatmck.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fserror.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fslink.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fspatheval.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fspermission.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fsrdwr.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fsscandir01.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fssymlink.yml
create mode 100644 spec/build/testsuites/fstests/imfs_fstime.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfserror.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfslink.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfspatheval.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfspermission.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfsrdwr.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfsscandir01.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfssymlink.yml
delete mode 100644 spec/build/testsuites/fstests/imfsfstime.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fserror.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fslink.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fspatheval.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fspermission.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fsrdwr.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fsscandir01.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fssymlink.yml
create mode 100644 spec/build/testsuites/fstests/jffs2_fstime.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fserror.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fslink.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fspatheval.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fspermission.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fsrdwr.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fsscandir01.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fssymlink.yml
delete mode 100644 spec/build/testsuites/fstests/jffs2fstime.yml
create mode 100644 spec/build/testsuites/fstests/mdosfs_fserror.yml
create mode 100644 spec/build/testsuites/fstests/mdosfs_fspatheval.yml
create mode 100644 spec/build/testsuites/fstests/mdosfs_fsrdwr.yml
create mode 100644 spec/build/testsuites/fstests/mdosfs_fsscandir01.yml
create mode 100644 spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml
create mode 100644 spec/build/testsuites/fstests/mdosfs_fstime.yml
delete mode 100644 spec/build/testsuites/fstests/mdosfsfserror.yml
delete mode 100644 spec/build/testsuites/fstests/mdosfsfspatheval.yml
delete mode 100644 spec/build/testsuites/fstests/mdosfsfsrdwr.yml
delete mode 100644 spec/build/testsuites/fstests/mdosfsfsscandir01.yml
delete mode 100644 spec/build/testsuites/fstests/mdosfsfsstatvfs.yml
delete mode 100644 spec/build/testsuites/fstests/mdosfsfstime.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fserror.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fslink.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fspatheval.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fspermission.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fsrdwr.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fsrename.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fsscandir01.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fssymlink.yml
create mode 100644 spec/build/testsuites/fstests/mimfs_fstime.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfserror.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfslink.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfspatheval.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfspermission.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfsrdwr.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfsrename.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfsscandir01.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfssymlink.yml
delete mode 100644 spec/build/testsuites/fstests/mimfsfstime.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fserror.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fsfpathconf.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fslink.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fspatheval.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fspermission.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fsrdwr.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fsrename.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fsscandir01.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fssymlink.yml
create mode 100644 spec/build/testsuites/fstests/mrfs_fstime.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfserror.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfsfpathconf.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfslink.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfspatheval.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfspermission.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfsrdwr.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfsrename.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfsscandir01.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfssymlink.yml
delete mode 100644 spec/build/testsuites/fstests/mrfsfstime.yml
create mode 100644 spec/build/testsuites/libtests/clock_gettime.yml
delete mode 100644 spec/build/testsuites/libtests/clockgettime.yml
create mode 100644 spec/build/testsuites/libtests/iconv_close.yml
create mode 100644 spec/build/testsuites/libtests/iconv_open.yml
delete mode 100644 spec/build/testsuites/libtests/iconvclose.yml
delete mode 100644 spec/build/testsuites/libtests/iconvopen.yml
create mode 100644 spec/build/testsuites/libtests/posix_memalign.yml
delete mode 100644 spec/build/testsuites/libtests/posixmemalign.yml
create mode 100644 spec/build/testsuites/mptests/mp01_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp01_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp01node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp01node2.yml
create mode 100644 spec/build/testsuites/mptests/mp03_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp03_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp03node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp03node2.yml
create mode 100644 spec/build/testsuites/mptests/mp04_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp04_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp04node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp04node2.yml
create mode 100644 spec/build/testsuites/mptests/mp05_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp05_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp05node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp05node2.yml
create mode 100644 spec/build/testsuites/mptests/mp06_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp06_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp06node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp06node2.yml
create mode 100644 spec/build/testsuites/mptests/mp07_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp07_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp07node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp07node2.yml
create mode 100644 spec/build/testsuites/mptests/mp08_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp08_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp08node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp08node2.yml
create mode 100644 spec/build/testsuites/mptests/mp09_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp09_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp09node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp09node2.yml
create mode 100644 spec/build/testsuites/mptests/mp10_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp10_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp10node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp10node2.yml
create mode 100644 spec/build/testsuites/mptests/mp11_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp11_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp11node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp11node2.yml
create mode 100644 spec/build/testsuites/mptests/mp12_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp12_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp12node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp12node2.yml
create mode 100644 spec/build/testsuites/mptests/mp13_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp13_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp13node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp13node2.yml
create mode 100644 spec/build/testsuites/mptests/mp14_node1.yml
create mode 100644 spec/build/testsuites/mptests/mp14_node2.yml
delete mode 100644 spec/build/testsuites/mptests/mp14node1.yml
delete mode 100644 spec/build/testsuites/mptests/mp14node2.yml
create mode 100644 spec/build/testsuites/psxtests/psxeintr_join.yml
delete mode 100644 spec/build/testsuites/psxtests/psxeintrjoin.yml
create mode 100644 spec/build/testsuites/psxtests/psxfatal_support.yml
delete mode 100644 spec/build/testsuites/psxtests/psxfatalsupport.yml
create mode 100644 spec/build/testsuites/samples/base_mp_node1.yml
create mode 100644 spec/build/testsuites/samples/base_mp_node2.yml
create mode 100644 spec/build/testsuites/samples/base_sp.yml
delete mode 100644 spec/build/testsuites/samples/basempnode1.yml
delete mode 100644 spec/build/testsuites/samples/basempnode2.yml
delete mode 100644 spec/build/testsuites/samples/basesp.yml
create mode 100644 spec/build/testsuites/sptests/spclock_err01.yml
create mode 100644 spec/build/testsuites/sptests/spclock_err02.yml
create mode 100644 spec/build/testsuites/sptests/spclock_todhook01.yml
delete mode 100644 spec/build/testsuites/sptests/spclockerr01.yml
delete mode 100644 spec/build/testsuites/sptests/spclockerr02.yml
delete mode 100644 spec/build/testsuites/sptests/spclocktodhook01.yml
create mode 100644 spec/build/testsuites/sptests/spevent_err03.yml
delete mode 100644 spec/build/testsuites/sptests/speventerr03.yml
create mode 100644 spec/build/testsuites/sptests/spfatal_support.yml
delete mode 100644 spec/build/testsuites/sptests/spfatalsupport.yml
create mode 100644 spec/build/testsuites/sptests/spintr_err01.yml
delete mode 100644 spec/build/testsuites/sptests/spintrerr01.yml
create mode 100644 spec/build/testsuites/sptests/spmsgq_err01.yml
create mode 100644 spec/build/testsuites/sptests/spmsgq_err02.yml
delete mode 100644 spec/build/testsuites/sptests/spmsgqerr01.yml
delete mode 100644 spec/build/testsuites/sptests/spmsgqerr02.yml
create mode 100644 spec/build/testsuites/sptests/sppartition_err01.yml
delete mode 100644 spec/build/testsuites/sptests/sppartitionerr01.yml
create mode 100644 spec/build/testsuites/sptests/spport_err01.yml
delete mode 100644 spec/build/testsuites/sptests/spporterr01.yml
create mode 100644 spec/build/testsuites/sptests/spratemon_err01.yml
delete mode 100644 spec/build/testsuites/sptests/spratemonerr01.yml
create mode 100644 spec/build/testsuites/sptests/spregion_err01.yml
delete mode 100644 spec/build/testsuites/sptests/spregionerr01.yml
create mode 100644 spec/build/testsuites/sptests/spsem_err01.yml
create mode 100644 spec/build/testsuites/sptests/spsem_err02.yml
delete mode 100644 spec/build/testsuites/sptests/spsemerr01.yml
delete mode 100644 spec/build/testsuites/sptests/spsemerr02.yml
create mode 100644 spec/build/testsuites/sptests/spsignal_err01.yml
delete mode 100644 spec/build/testsuites/sptests/spsignalerr01.yml
create mode 100644 spec/build/testsuites/sptests/sptask_err01.yml
create mode 100644 spec/build/testsuites/sptests/sptask_err02.yml
create mode 100644 spec/build/testsuites/sptests/sptask_err03.yml
create mode 100644 spec/build/testsuites/sptests/sptask_err04.yml
delete mode 100644 spec/build/testsuites/sptests/sptaskerr01.yml
delete mode 100644 spec/build/testsuites/sptests/sptaskerr02.yml
delete mode 100644 spec/build/testsuites/sptests/sptaskerr03.yml
delete mode 100644 spec/build/testsuites/sptests/sptaskerr04.yml
create mode 100644 spec/build/testsuites/sptests/sptimer_err01.yml
create mode 100644 spec/build/testsuites/sptests/sptimer_err02.yml
delete mode 100644 spec/build/testsuites/sptests/sptimererr01.yml
delete mode 100644 spec/build/testsuites/sptests/sptimererr02.yml
1.8.3.1
