[PATCH 1/3] bsps: Renamed YAML files to match test names
Ryan Long ryan.long at oarcorp.com
Thu Mar 18 20:27:06 UTC 2021
Made the YAML file match the file name specified in the 'executable'
field. Fixed any references to the previous file names.
 spec/build/bsps/arm/atsam/tstatsamv.yml            |  18 +--
 spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml       |   4 +-
 spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml        |   2 +-
 .../bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml   |  76 +++++-----
 spec/build/bsps/arm/lpc24xx/tstlpc2362.yml         |  10 +-
 spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml   |  12 +-
 spec/build/bsps/tstnoiconv.yml                     |   4 +-
 spec/build/bsps/tstnojffs2.yml                     |  16 +-
 spec/build/bsps/tstnorfs.yml                       |  20 +--
 spec/build/testsuites/ada/ada_base_sp.yml          |  23 +++
 spec/build/testsuites/ada/ada_hello.yml            |  23 +++
 spec/build/testsuites/ada/ada_mp01_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp01_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp03_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp03_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp04_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp04_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp05_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp05_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp06_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp06_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp07_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp07_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp08_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp08_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp09_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp09_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp10_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp10_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp11_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp11_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp12_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp12_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp13_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp13_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp14_node1.yml       |  25 ++++
 spec/build/testsuites/ada/ada_mp14_node2.yml       |  25 ++++
 spec/build/testsuites/ada/ada_nsecs.yml            |  23 +++
 spec/build/testsuites/ada/ada_sp01.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp02.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp03.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp04.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp05.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp06.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp07.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp08.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp09.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp11.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp12.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp13.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp14.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp15.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp16.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp17.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp19.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp20.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp22.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp23.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp24.yml             |  23 +++
 spec/build/testsuites/ada/ada_sp25.yml             |  23 +++
 spec/build/testsuites/ada/ada_spatcb01.yml         |  24 +++
 spec/build/testsuites/ada/ada_spname01.yml         |  24 +++
 spec/build/testsuites/ada/ada_ticker.yml           |  23 +++
 spec/build/testsuites/ada/ada_tm01.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm02.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm03.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm04.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm05.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm06.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm07.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm08.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm09.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm10.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm11.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm12.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm13.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm14.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm15.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm16.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm17.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm18.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm19.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm20.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm21.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm22.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm23.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm24.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm25.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm28.yml             |  23 +++
 spec/build/testsuites/ada/ada_tm29.yml             |  23 +++
 spec/build/testsuites/ada/ada_tmck.yml             |  23 +++
 spec/build/testsuites/ada/adabasesp.yml            |  23 ---
 spec/build/testsuites/ada/adahello.yml             |  23 ---
 spec/build/testsuites/ada/adamp01node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp01node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp03node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp03node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp04node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp04node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp05node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp05node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp06node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp06node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp07node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp07node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp08node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp08node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp09node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp09node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp10node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp10node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp11node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp11node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp12node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp12node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp13node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp13node2.yml         |  25 ----
 spec/build/testsuites/ada/adamp14node1.yml         |  25 ----
 spec/build/testsuites/ada/adamp14node2.yml         |  25 ----
 spec/build/testsuites/ada/adansecs.yml             |  23 ---
 spec/build/testsuites/ada/adasp01.yml              |  23 ---
 spec/build/testsuites/ada/adasp02.yml              |  23 ---
 spec/build/testsuites/ada/adasp03.yml              |  23 ---
 spec/build/testsuites/ada/adasp04.yml              |  23 ---
 spec/build/testsuites/ada/adasp05.yml              |  23 ---
 spec/build/testsuites/ada/adasp06.yml              |  23 ---
 spec/build/testsuites/ada/adasp07.yml              |  23 ---
 spec/build/testsuites/ada/adasp08.yml              |  23 ---
 spec/build/testsuites/ada/adasp09.yml              |  23 ---
 spec/build/testsuites/ada/adasp11.yml              |  23 ---
 spec/build/testsuites/ada/adasp12.yml              |  23 ---
 spec/build/testsuites/ada/adasp13.yml              |  23 ---
 spec/build/testsuites/ada/adasp14.yml              |  23 ---
 spec/build/testsuites/ada/adasp15.yml              |  23 ---
 spec/build/testsuites/ada/adasp16.yml              |  23 ---
 spec/build/testsuites/ada/adasp17.yml              |  23 ---
 spec/build/testsuites/ada/adasp19.yml              |  23 ---
 spec/build/testsuites/ada/adasp20.yml              |  23 ---
 spec/build/testsuites/ada/adasp22.yml              |  23 ---
 spec/build/testsuites/ada/adasp23.yml              |  23 ---
 spec/build/testsuites/ada/adasp24.yml              |  23 ---
 spec/build/testsuites/ada/adasp25.yml              |  23 ---
 spec/build/testsuites/ada/adaspatcb01.yml          |  24 ---
 spec/build/testsuites/ada/adaspname01.yml          |  24 ---
 spec/build/testsuites/ada/adaticker.yml            |  23 ---
 spec/build/testsuites/ada/adatm01.yml              |  23 ---
 spec/build/testsuites/ada/adatm02.yml              |  23 ---
 spec/build/testsuites/ada/adatm03.yml              |  23 ---
 spec/build/testsuites/ada/adatm04.yml              |  23 ---
 spec/build/testsuites/ada/adatm05.yml              |  23 ---
 spec/build/testsuites/ada/adatm06.yml              |  23 ---
 spec/build/testsuites/ada/adatm07.yml              |  23 ---
 spec/build/testsuites/ada/adatm08.yml              |  23 ---
 spec/build/testsuites/ada/adatm09.yml              |  23 ---
 spec/build/testsuites/ada/adatm10.yml              |  23 ---
 spec/build/testsuites/ada/adatm11.yml              |  23 ---
 spec/build/testsuites/ada/adatm12.yml              |  23 ---
 spec/build/testsuites/ada/adatm13.yml              |  23 ---
 spec/build/testsuites/ada/adatm14.yml              |  23 ---
 spec/build/testsuites/ada/adatm15.yml              |  23 ---
 spec/build/testsuites/ada/adatm16.yml              |  23 ---
 spec/build/testsuites/ada/adatm17.yml              |  23 ---
 spec/build/testsuites/ada/adatm18.yml              |  23 ---
 spec/build/testsuites/ada/adatm19.yml              |  23 ---
 spec/build/testsuites/ada/adatm20.yml              |  23 ---
 spec/build/testsuites/ada/adatm21.yml              |  23 ---
 spec/build/testsuites/ada/adatm22.yml              |  23 ---
 spec/build/testsuites/ada/adatm23.yml              |  23 ---
 spec/build/testsuites/ada/adatm24.yml              |  23 ---
 spec/build/testsuites/ada/adatm25.yml              |  23 ---
 spec/build/testsuites/ada/adatm28.yml              |  23 ---
 spec/build/testsuites/ada/adatm29.yml              |  23 ---
 spec/build/testsuites/ada/adatmck.yml              |  23 ---
 spec/build/testsuites/ada/grp.yml                  | 164 ++++++++++-----------
 spec/build/testsuites/fstests/grp.yml              |  82 +++++------
 spec/build/testsuites/fstests/imfs_fserror.yml     |  21 +++
 spec/build/testsuites/fstests/imfs_fslink.yml      |  21 +++
 spec/build/testsuites/fstests/imfs_fspatheval.yml  |  21 +++
 .../build/testsuites/fstests/imfs_fspermission.yml |  21 +++
 spec/build/testsuites/fstests/imfs_fsrdwr.yml      |  21 +++
 spec/build/testsuites/fstests/imfs_fsscandir01.yml |  21 +++
 spec/build/testsuites/fstests/imfs_fssymlink.yml   |  21 +++
 spec/build/testsuites/fstests/imfs_fstime.yml      |  21 +++
 spec/build/testsuites/fstests/imfsfserror.yml      |  21 ---
 spec/build/testsuites/fstests/imfsfslink.yml       |  21 ---
 spec/build/testsuites/fstests/imfsfspatheval.yml   |  21 ---
 spec/build/testsuites/fstests/imfsfspermission.yml |  21 ---
 spec/build/testsuites/fstests/imfsfsrdwr.yml       |  21 ---
 spec/build/testsuites/fstests/imfsfsscandir01.yml  |  21 ---
 spec/build/testsuites/fstests/imfsfssymlink.yml    |  21 ---
 spec/build/testsuites/fstests/imfsfstime.yml       |  21 ---
 spec/build/testsuites/fstests/jffs2_fserror.yml    |  22 +++
 spec/build/testsuites/fstests/jffs2_fslink.yml     |  22 +++
 spec/build/testsuites/fstests/jffs2_fspatheval.yml |  22 +++
 .../testsuites/fstests/jffs2_fspermission.yml      |  22 +++
 spec/build/testsuites/fstests/jffs2_fsrdwr.yml     |  22 +++
 .../build/testsuites/fstests/jffs2_fsscandir01.yml |  22 +++
 spec/build/testsuites/fstests/jffs2_fssymlink.yml  |  22 +++
 spec/build/testsuites/fstests/jffs2_fstime.yml     |  22 +++
 spec/build/testsuites/fstests/jffs2fserror.yml     |  22 ---
 spec/build/testsuites/fstests/jffs2fslink.yml      |  22 ---
 spec/build/testsuites/fstests/jffs2fspatheval.yml  |  22 ---
 .../build/testsuites/fstests/jffs2fspermission.yml |  22 ---
 spec/build/testsuites/fstests/jffs2fsrdwr.yml      |  22 ---
 spec/build/testsuites/fstests/jffs2fsscandir01.yml |  22 ---
 spec/build/testsuites/fstests/jffs2fssymlink.yml   |  22 ---
 spec/build/testsuites/fstests/jffs2fstime.yml      |  22 ---
 spec/build/testsuites/fstests/mdosfs_fserror.yml   |  21 +++
 .../build/testsuites/fstests/mdosfs_fspatheval.yml |  21 +++
 spec/build/testsuites/fstests/mdosfs_fsrdwr.yml    |  21 +++
 .../testsuites/fstests/mdosfs_fsscandir01.yml      |  21 +++
 spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml |  21 +++
 spec/build/testsuites/fstests/mdosfs_fstime.yml    |  21 +++
 spec/build/testsuites/fstests/mdosfsfserror.yml    |  21 ---
 spec/build/testsuites/fstests/mdosfsfspatheval.yml |  21 ---
 spec/build/testsuites/fstests/mdosfsfsrdwr.yml     |  21 ---
 .../build/testsuites/fstests/mdosfsfsscandir01.yml |  21 ---
 spec/build/testsuites/fstests/mdosfsfsstatvfs.yml  |  21 ---
 spec/build/testsuites/fstests/mdosfsfstime.yml     |  21 ---
 spec/build/testsuites/fstests/mimfs_fserror.yml    |  21 +++
 spec/build/testsuites/fstests/mimfs_fslink.yml     |  21 +++
 spec/build/testsuites/fstests/mimfs_fspatheval.yml |  21 +++
 .../testsuites/fstests/mimfs_fspermission.yml      |  21 +++
 spec/build/testsuites/fstests/mimfs_fsrdwr.yml     |  21 +++
 spec/build/testsuites/fstests/mimfs_fsrename.yml   |  21 +++
 .../build/testsuites/fstests/mimfs_fsscandir01.yml |  21 +++
 spec/build/testsuites/fstests/mimfs_fssymlink.yml  |  21 +++
 spec/build/testsuites/fstests/mimfs_fstime.yml     |  21 +++
 spec/build/testsuites/fstests/mimfsfserror.yml     |  21 ---
 spec/build/testsuites/fstests/mimfsfslink.yml      |  21 ---
 spec/build/testsuites/fstests/mimfsfspatheval.yml  |  21 ---
 .../build/testsuites/fstests/mimfsfspermission.yml |  21 ---
 spec/build/testsuites/fstests/mimfsfsrdwr.yml      |  21 ---
 spec/build/testsuites/fstests/mimfsfsrename.yml    |  21 ---
 spec/build/testsuites/fstests/mimfsfsscandir01.yml |  21 ---
 spec/build/testsuites/fstests/mimfsfssymlink.yml   |  21 ---
 spec/build/testsuites/fstests/mimfsfstime.yml      |  21 ---
 spec/build/testsuites/fstests/mrfs_fserror.yml     |  21 +++
 spec/build/testsuites/fstests/mrfs_fsfpathconf.yml |  21 +++
 spec/build/testsuites/fstests/mrfs_fslink.yml      |  21 +++
 spec/build/testsuites/fstests/mrfs_fspatheval.yml  |  21 +++
 .../build/testsuites/fstests/mrfs_fspermission.yml |  21 +++
 spec/build/testsuites/fstests/mrfs_fsrdwr.yml      |  21 +++
 spec/build/testsuites/fstests/mrfs_fsrename.yml    |  21 +++
 spec/build/testsuites/fstests/mrfs_fsscandir01.yml |  21 +++
 spec/build/testsuites/fstests/mrfs_fssymlink.yml   |  21 +++
 spec/build/testsuites/fstests/mrfs_fstime.yml      |  21 +++
 spec/build/testsuites/fstests/mrfsfserror.yml      |  21 ---
 spec/build/testsuites/fstests/mrfsfsfpathconf.yml  |  21 ---
 spec/build/testsuites/fstests/mrfsfslink.yml       |  21 ---
 spec/build/testsuites/fstests/mrfsfspatheval.yml   |  21 ---
 spec/build/testsuites/fstests/mrfsfspermission.yml |  21 ---
 spec/build/testsuites/fstests/mrfsfsrdwr.yml       |  21 ---
 spec/build/testsuites/fstests/mrfsfsrename.yml     |  21 ---
 spec/build/testsuites/fstests/mrfsfsscandir01.yml  |  21 ---
 spec/build/testsuites/fstests/mrfsfssymlink.yml    |  21 ---
 spec/build/testsuites/fstests/mrfsfstime.yml       |  21 ---
 spec/build/testsuites/libtests/clock_gettime.yml   |  20 +++
 spec/build/testsuites/libtests/clockgettime.yml    |  20 ---
 spec/build/testsuites/libtests/grp.yml             |   8 +-
 spec/build/testsuites/libtests/iconv_close.yml     |  20 +++
 spec/build/testsuites/libtests/iconv_open.yml      |  20 +++
 spec/build/testsuites/libtests/iconvclose.yml      |  20 ---
 spec/build/testsuites/libtests/iconvopen.yml       |  20 ---
 spec/build/testsuites/libtests/posix_memalign.yml  |  20 +++
 spec/build/testsuites/libtests/posixmemalign.yml   |  20 ---
 spec/build/testsuites/mptests/grp.yml              |  52 +++----
 spec/build/testsuites/mptests/mp01_node1.yml       |  21 +++
 spec/build/testsuites/mptests/mp01_node2.yml       |  21 +++
 spec/build/testsuites/mptests/mp01node1.yml        |  21 ---
 spec/build/testsuites/mptests/mp01node2.yml        |  21 ---
 spec/build/testsuites/mptests/mp03_node1.yml       |  22 +++
 spec/build/testsuites/mptests/mp03_node2.yml       |  22 +++
 spec/build/testsuites/mptests/mp03node1.yml        |  22 ---
 spec/build/testsuites/mptests/mp03node2.yml        |  22 ---
 spec/build/testsuites/mptests/mp04_node1.yml       |  21 +++
 spec/build/testsuites/mptests/mp04_node2.yml       |  21 +++
 spec/build/testsuites/mptests/mp04node1.yml        |  21 ---
 spec/build/testsuites/mptests/mp04node2.yml        |  21 ---
 spec/build/testsuites/mptests/mp05_node1.yml       |  22 +++
 spec/build/testsuites/mptests/mp05_node2.yml       |  22 +++
 spec/build/testsuites/mptests/mp05node1.yml        |  22 ---
 spec/build/testsuites/mptests/mp05node2.yml        |  22 ---
 spec/build/testsuites/mptests/mp06_node1.yml       |  21 +++
 spec/build/testsuites/mptests/mp06_node2.yml       |  21 +++
 spec/build/testsuites/mptests/mp06node1.yml        |  21 ---
 spec/build/testsuites/mptests/mp06node2.yml        |  21 ---
 spec/build/testsuites/mptests/mp07_node1.yml       |  21 +++
 spec/build/testsuites/mptests/mp07_node2.yml       |  21 +++
 spec/build/testsuites/mptests/mp07node1.yml        |  21 ---
 spec/build/testsuites/mptests/mp07node2.yml        |  21 ---
 spec/build/testsuites/mptests/mp08_node1.yml       |  21 +++
 spec/build/testsuites/mptests/mp08_node2.yml       |  21 +++
 spec/build/testsuites/mptests/mp08node1.yml        |  21 ---
 spec/build/testsuites/mptests/mp08node2.yml        |  21 ---
 spec/build/testsuites/mptests/mp09_node1.yml       |  23 +++
 spec/build/testsuites/mptests/mp09_node2.yml       |  23 +++
 spec/build/testsuites/mptests/mp09node1.yml        |  23 ---
 spec/build/testsuites/mptests/mp09node2.yml        |  23 ---
 spec/build/testsuites/mptests/mp10_node1.yml       |  23 +++
 spec/build/testsuites/mptests/mp10_node2.yml       |  23 +++
 spec/build/testsuites/mptests/mp10node1.yml        |  23 ---
 spec/build/testsuites/mptests/mp10node2.yml        |  23 ---
 spec/build/testsuites/mptests/mp11_node1.yml       |  20 +++
 spec/build/testsuites/mptests/mp11_node2.yml       |  20 +++
 spec/build/testsuites/mptests/mp11node1.yml        |  20 ---
 spec/build/testsuites/mptests/mp11node2.yml        |  20 ---
 spec/build/testsuites/mptests/mp12_node1.yml       |  20 +++
 spec/build/testsuites/mptests/mp12_node2.yml       |  20 +++
 spec/build/testsuites/mptests/mp12node1.yml        |  20 ---
 spec/build/testsuites/mptests/mp12node2.yml        |  20 ---
 spec/build/testsuites/mptests/mp13_node1.yml       |  22 +++
 spec/build/testsuites/mptests/mp13_node2.yml       |  22 +++
 spec/build/testsuites/mptests/mp13node1.yml        |  22 ---
 spec/build/testsuites/mptests/mp13node2.yml        |  22 ---
 spec/build/testsuites/mptests/mp14_node1.yml       |  27 ++++
 spec/build/testsuites/mptests/mp14_node2.yml       |  27 ++++
 spec/build/testsuites/mptests/mp14node1.yml        |  27 ----
 spec/build/testsuites/mptests/mp14node2.yml        |  27 ----
 spec/build/testsuites/psxtests/grp.yml             |   2 +-
 spec/build/testsuites/psxtests/psxeintr_join.yml   |  20 +++
 spec/build/testsuites/psxtests/psxeintrjoin.yml    |  20 ---
 .../build/testsuites/psxtests/psxfatal_support.yml |  19 +++
 spec/build/testsuites/psxtests/psxfatalsupport.yml |  19 ---
 spec/build/testsuites/samples/base_mp_node1.yml    |  21 +++
 spec/build/testsuites/samples/base_mp_node2.yml    |  21 +++
 spec/build/testsuites/samples/base_sp.yml          |  20 +++
 spec/build/testsuites/samples/basempnode1.yml      |  21 ---
 spec/build/testsuites/samples/basempnode2.yml      |  21 ---
 spec/build/testsuites/samples/basesp.yml           |  20 ---
 spec/build/testsuites/samples/grp.yml              |   6 +-
 spec/build/testsuites/sptests/grp.yml              |  40 ++---
 spec/build/testsuites/sptests/spclock_err01.yml    |  20 +++
 spec/build/testsuites/sptests/spclock_err02.yml    |  19 +++
 .../build/testsuites/sptests/spclock_todhook01.yml |  19 +++
 spec/build/testsuites/sptests/spclockerr01.yml     |  20 ---
 spec/build/testsuites/sptests/spclockerr02.yml     |  19 ---
 spec/build/testsuites/sptests/spclocktodhook01.yml |  19 ---
 spec/build/testsuites/sptests/spevent_err03.yml    |  19 +++
 spec/build/testsuites/sptests/speventerr03.yml     |  19 ---
 spec/build/testsuites/sptests/spfatal_support.yml  |  19 +++
 spec/build/testsuites/sptests/spfatalsupport.yml   |  19 ---
 spec/build/testsuites/sptests/spintr_err01.yml     |  20 +++
 spec/build/testsuites/sptests/spintrerr01.yml      |  20 ---
 spec/build/testsuites/sptests/spmsgq_err01.yml     |  19 +++
 spec/build/testsuites/sptests/spmsgq_err02.yml     |  20 +++
 spec/build/testsuites/sptests/spmsgqerr01.yml      |  19 ---
 spec/build/testsuites/sptests/spmsgqerr02.yml      |  20 ---
 .../build/testsuites/sptests/sppartition_err01.yml |  19 +++
 spec/build/testsuites/sptests/sppartitionerr01.yml |  19 ---
 spec/build/testsuites/sptests/spport_err01.yml     |  19 +++
 spec/build/testsuites/sptests/spporterr01.yml      |  19 ---
 spec/build/testsuites/sptests/spratemon_err01.yml  |  21 +++
 spec/build/testsuites/sptests/spratemonerr01.yml   |  21 ---
 spec/build/testsuites/sptests/spregion_err01.yml   |  19 +++
 spec/build/testsuites/sptests/spregionerr01.yml    |  19 ---
 spec/build/testsuites/sptests/spsem_err01.yml      |  19 +++
 spec/build/testsuites/sptests/spsem_err02.yml      |  20 +++
 spec/build/testsuites/sptests/spsemerr01.yml       |  19 ---
 spec/build/testsuites/sptests/spsemerr02.yml       |  20 ---
 spec/build/testsuites/sptests/spsignal_err01.yml   |  20 +++
 spec/build/testsuites/sptests/spsignalerr01.yml    |  20 ---
 spec/build/testsuites/sptests/sptask_err01.yml     |  20 +++
 spec/build/testsuites/sptests/sptask_err02.yml     |  19 +++
 spec/build/testsuites/sptests/sptask_err03.yml     |  19 +++
 spec/build/testsuites/sptests/sptask_err04.yml     |  20 +++
 spec/build/testsuites/sptests/sptaskerr01.yml      |  20 ---
 spec/build/testsuites/sptests/sptaskerr02.yml      |  19 ---
 spec/build/testsuites/sptests/sptaskerr03.yml      |  19 ---
 spec/build/testsuites/sptests/sptaskerr04.yml      |  20 ---
 spec/build/testsuites/sptests/sptimer_err01.yml    |  19 +++
 spec/build/testsuites/sptests/sptimer_err02.yml    |  19 +++
 spec/build/testsuites/sptests/sptimererr01.yml     |  19 ---
 spec/build/testsuites/sptests/sptimererr02.yml     |  19 ---
 374 files changed, 4224 insertions(+), 4224 deletions(-)
 create mode 100644 spec/build/testsuites/ada/ada_base_sp.yml
 create mode 100644 spec/build/testsuites/ada/ada_hello.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp01_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp01_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp03_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp03_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp04_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp04_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp05_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp05_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp06_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp06_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp07_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp07_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp08_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp08_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp09_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp09_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp10_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp10_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp11_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp11_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp12_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp12_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp13_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp13_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp14_node1.yml
 create mode 100644 spec/build/testsuites/ada/ada_mp14_node2.yml
 create mode 100644 spec/build/testsuites/ada/ada_nsecs.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp01.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp02.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp03.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp04.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp05.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp06.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp07.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp08.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp09.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp11.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp12.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp13.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp14.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp15.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp16.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp17.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp19.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp20.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp22.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp23.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp24.yml
 create mode 100644 spec/build/testsuites/ada/ada_sp25.yml
 create mode 100644 spec/build/testsuites/ada/ada_spatcb01.yml
 create mode 100644 spec/build/testsuites/ada/ada_spname01.yml
 create mode 100644 spec/build/testsuites/ada/ada_ticker.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm01.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm02.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm03.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm04.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm05.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm06.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm07.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm08.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm09.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm10.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm11.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm12.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm13.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm14.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm15.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm16.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm17.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm18.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm19.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm20.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm21.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm22.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm23.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm24.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm25.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm28.yml
 create mode 100644 spec/build/testsuites/ada/ada_tm29.yml
 create mode 100644 spec/build/testsuites/ada/ada_tmck.yml
 delete mode 100644 spec/build/testsuites/ada/adabasesp.yml
 delete mode 100644 spec/build/testsuites/ada/adahello.yml
 delete mode 100644 spec/build/testsuites/ada/adamp01node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp01node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp03node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp03node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp04node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp04node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp05node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp05node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp06node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp06node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp07node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp07node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp08node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp08node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp09node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp09node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp10node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp10node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp11node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp11node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp12node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp12node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp13node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp13node2.yml
 delete mode 100644 spec/build/testsuites/ada/adamp14node1.yml
 delete mode 100644 spec/build/testsuites/ada/adamp14node2.yml
 delete mode 100644 spec/build/testsuites/ada/adansecs.yml
 delete mode 100644 spec/build/testsuites/ada/adasp01.yml
 delete mode 100644 spec/build/testsuites/ada/adasp02.yml
 delete mode 100644 spec/build/testsuites/ada/adasp03.yml
 delete mode 100644 spec/build/testsuites/ada/adasp04.yml
 delete mode 100644 spec/build/testsuites/ada/adasp05.yml
 delete mode 100644 spec/build/testsuites/ada/adasp06.yml
 delete mode 100644 spec/build/testsuites/ada/adasp07.yml
 delete mode 100644 spec/build/testsuites/ada/adasp08.yml
 delete mode 100644 spec/build/testsuites/ada/adasp09.yml
 delete mode 100644 spec/build/testsuites/ada/adasp11.yml
 delete mode 100644 spec/build/testsuites/ada/adasp12.yml
 delete mode 100644 spec/build/testsuites/ada/adasp13.yml
 delete mode 100644 spec/build/testsuites/ada/adasp14.yml
 delete mode 100644 spec/build/testsuites/ada/adasp15.yml
 delete mode 100644 spec/build/testsuites/ada/adasp16.yml
 delete mode 100644 spec/build/testsuites/ada/adasp17.yml
 delete mode 100644 spec/build/testsuites/ada/adasp19.yml
 delete mode 100644 spec/build/testsuites/ada/adasp20.yml
 delete mode 100644 spec/build/testsuites/ada/adasp22.yml
 delete mode 100644 spec/build/testsuites/ada/adasp23.yml
 delete mode 100644 spec/build/testsuites/ada/adasp24.yml
 delete mode 100644 spec/build/testsuites/ada/adasp25.yml
 delete mode 100644 spec/build/testsuites/ada/adaspatcb01.yml
 delete mode 100644 spec/build/testsuites/ada/adaspname01.yml
 delete mode 100644 spec/build/testsuites/ada/adaticker.yml
 delete mode 100644 spec/build/testsuites/ada/adatm01.yml
 delete mode 100644 spec/build/testsuites/ada/adatm02.yml
 delete mode 100644 spec/build/testsuites/ada/adatm03.yml
 delete mode 100644 spec/build/testsuites/ada/adatm04.yml
 delete mode 100644 spec/build/testsuites/ada/adatm05.yml
 delete mode 100644 spec/build/testsuites/ada/adatm06.yml
 delete mode 100644 spec/build/testsuites/ada/adatm07.yml
 delete mode 100644 spec/build/testsuites/ada/adatm08.yml
 delete mode 100644 spec/build/testsuites/ada/adatm09.yml
 delete mode 100644 spec/build/testsuites/ada/adatm10.yml
 delete mode 100644 spec/build/testsuites/ada/adatm11.yml
 delete mode 100644 spec/build/testsuites/ada/adatm12.yml
 delete mode 100644 spec/build/testsuites/ada/adatm13.yml
 delete mode 100644 spec/build/testsuites/ada/adatm14.yml
 delete mode 100644 spec/build/testsuites/ada/adatm15.yml
 delete mode 100644 spec/build/testsuites/ada/adatm16.yml
 delete mode 100644 spec/build/testsuites/ada/adatm17.yml
 delete mode 100644 spec/build/testsuites/ada/adatm18.yml
 delete mode 100644 spec/build/testsuites/ada/adatm19.yml
 delete mode 100644 spec/build/testsuites/ada/adatm20.yml
 delete mode 100644 spec/build/testsuites/ada/adatm21.yml
 delete mode 100644 spec/build/testsuites/ada/adatm22.yml
 delete mode 100644 spec/build/testsuites/ada/adatm23.yml
 delete mode 100644 spec/build/testsuites/ada/adatm24.yml
 delete mode 100644 spec/build/testsuites/ada/adatm25.yml
 delete mode 100644 spec/build/testsuites/ada/adatm28.yml
 delete mode 100644 spec/build/testsuites/ada/adatm29.yml
 delete mode 100644 spec/build/testsuites/ada/adatmck.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fserror.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fslink.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fspatheval.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fspermission.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fsrdwr.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fsscandir01.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fssymlink.yml
 create mode 100644 spec/build/testsuites/fstests/imfs_fstime.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfserror.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfslink.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfspatheval.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfspermission.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfsrdwr.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfsscandir01.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfssymlink.yml
 delete mode 100644 spec/build/testsuites/fstests/imfsfstime.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fserror.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fslink.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fspatheval.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fspermission.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fsrdwr.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fsscandir01.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fssymlink.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2_fstime.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fserror.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fslink.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fspatheval.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fspermission.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fsrdwr.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fsscandir01.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fssymlink.yml
 delete mode 100644 spec/build/testsuites/fstests/jffs2fstime.yml
 create mode 100644 spec/build/testsuites/fstests/mdosfs_fserror.yml
 create mode 100644 spec/build/testsuites/fstests/mdosfs_fspatheval.yml
 create mode 100644 spec/build/testsuites/fstests/mdosfs_fsrdwr.yml
 create mode 100644 spec/build/testsuites/fstests/mdosfs_fsscandir01.yml
 create mode 100644 spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml
 create mode 100644 spec/build/testsuites/fstests/mdosfs_fstime.yml
 delete mode 100644 spec/build/testsuites/fstests/mdosfsfserror.yml
 delete mode 100644 spec/build/testsuites/fstests/mdosfsfspatheval.yml
 delete mode 100644 spec/build/testsuites/fstests/mdosfsfsrdwr.yml
 delete mode 100644 spec/build/testsuites/fstests/mdosfsfsscandir01.yml
 delete mode 100644 spec/build/testsuites/fstests/mdosfsfsstatvfs.yml
 delete mode 100644 spec/build/testsuites/fstests/mdosfsfstime.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fserror.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fslink.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fspatheval.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fspermission.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fsrdwr.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fsrename.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fsscandir01.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fssymlink.yml
 create mode 100644 spec/build/testsuites/fstests/mimfs_fstime.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfserror.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfslink.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfspatheval.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfspermission.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfsrdwr.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfsrename.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfsscandir01.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfssymlink.yml
 delete mode 100644 spec/build/testsuites/fstests/mimfsfstime.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fserror.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fsfpathconf.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fslink.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fspatheval.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fspermission.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fsrdwr.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fsrename.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fsscandir01.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fssymlink.yml
 create mode 100644 spec/build/testsuites/fstests/mrfs_fstime.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfserror.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfsfpathconf.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfslink.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfspatheval.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfspermission.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfsrdwr.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfsrename.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfsscandir01.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfssymlink.yml
 delete mode 100644 spec/build/testsuites/fstests/mrfsfstime.yml
 create mode 100644 spec/build/testsuites/libtests/clock_gettime.yml
 delete mode 100644 spec/build/testsuites/libtests/clockgettime.yml
 create mode 100644 spec/build/testsuites/libtests/iconv_close.yml
 create mode 100644 spec/build/testsuites/libtests/iconv_open.yml
 delete mode 100644 spec/build/testsuites/libtests/iconvclose.yml
 delete mode 100644 spec/build/testsuites/libtests/iconvopen.yml
 create mode 100644 spec/build/testsuites/libtests/posix_memalign.yml
 delete mode 100644 spec/build/testsuites/libtests/posixmemalign.yml
 create mode 100644 spec/build/testsuites/mptests/mp01_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp01_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp01node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp01node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp03_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp03_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp03node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp03node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp04_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp04_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp04node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp04node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp05_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp05_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp05node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp05node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp06_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp06_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp06node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp06node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp07_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp07_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp07node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp07node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp08_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp08_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp08node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp08node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp09_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp09_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp09node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp09node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp10_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp10_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp10node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp10node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp11_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp11_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp11node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp11node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp12_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp12_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp12node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp12node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp13_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp13_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp13node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp13node2.yml
 create mode 100644 spec/build/testsuites/mptests/mp14_node1.yml
 create mode 100644 spec/build/testsuites/mptests/mp14_node2.yml
 delete mode 100644 spec/build/testsuites/mptests/mp14node1.yml
 delete mode 100644 spec/build/testsuites/mptests/mp14node2.yml
 create mode 100644 spec/build/testsuites/psxtests/psxeintr_join.yml
 delete mode 100644 spec/build/testsuites/psxtests/psxeintrjoin.yml
 create mode 100644 spec/build/testsuites/psxtests/psxfatal_support.yml
 delete mode 100644 spec/build/testsuites/psxtests/psxfatalsupport.yml
 create mode 100644 spec/build/testsuites/samples/base_mp_node1.yml
 create mode 100644 spec/build/testsuites/samples/base_mp_node2.yml
 create mode 100644 spec/build/testsuites/samples/base_sp.yml
 delete mode 100644 spec/build/testsuites/samples/basempnode1.yml
 delete mode 100644 spec/build/testsuites/samples/basempnode2.yml
 delete mode 100644 spec/build/testsuites/samples/basesp.yml
 create mode 100644 spec/build/testsuites/sptests/spclock_err01.yml
 create mode 100644 spec/build/testsuites/sptests/spclock_err02.yml
 create mode 100644 spec/build/testsuites/sptests/spclock_todhook01.yml
 delete mode 100644 spec/build/testsuites/sptests/spclockerr01.yml
 delete mode 100644 spec/build/testsuites/sptests/spclockerr02.yml
 delete mode 100644 spec/build/testsuites/sptests/spclocktodhook01.yml
 create mode 100644 spec/build/testsuites/sptests/spevent_err03.yml
 delete mode 100644 spec/build/testsuites/sptests/speventerr03.yml
 create mode 100644 spec/build/testsuites/sptests/spfatal_support.yml
 delete mode 100644 spec/build/testsuites/sptests/spfatalsupport.yml
 create mode 100644 spec/build/testsuites/sptests/spintr_err01.yml
 delete mode 100644 spec/build/testsuites/sptests/spintrerr01.yml
 create mode 100644 spec/build/testsuites/sptests/spmsgq_err01.yml
 create mode 100644 spec/build/testsuites/sptests/spmsgq_err02.yml
 delete mode 100644 spec/build/testsuites/sptests/spmsgqerr01.yml
 delete mode 100644 spec/build/testsuites/sptests/spmsgqerr02.yml
 create mode 100644 spec/build/testsuites/sptests/sppartition_err01.yml
 delete mode 100644 spec/build/testsuites/sptests/sppartitionerr01.yml
 create mode 100644 spec/build/testsuites/sptests/spport_err01.yml
 delete mode 100644 spec/build/testsuites/sptests/spporterr01.yml
 create mode 100644 spec/build/testsuites/sptests/spratemon_err01.yml
 delete mode 100644 spec/build/testsuites/sptests/spratemonerr01.yml
 create mode 100644 spec/build/testsuites/sptests/spregion_err01.yml
 delete mode 100644 spec/build/testsuites/sptests/spregionerr01.yml
 create mode 100644 spec/build/testsuites/sptests/spsem_err01.yml
 create mode 100644 spec/build/testsuites/sptests/spsem_err02.yml
 delete mode 100644 spec/build/testsuites/sptests/spsemerr01.yml
 delete mode 100644 spec/build/testsuites/sptests/spsemerr02.yml
 create mode 100644 spec/build/testsuites/sptests/spsignal_err01.yml
 delete mode 100644 spec/build/testsuites/sptests/spsignalerr01.yml
 create mode 100644 spec/build/testsuites/sptests/sptask_err01.yml
 create mode 100644 spec/build/testsuites/sptests/sptask_err02.yml
 create mode 100644 spec/build/testsuites/sptests/sptask_err03.yml
 create mode 100644 spec/build/testsuites/sptests/sptask_err04.yml
 delete mode 100644 spec/build/testsuites/sptests/sptaskerr01.yml
 delete mode 100644 spec/build/testsuites/sptests/sptaskerr02.yml
 delete mode 100644 spec/build/testsuites/sptests/sptaskerr03.yml
 delete mode 100644 spec/build/testsuites/sptests/sptaskerr04.yml
 create mode 100644 spec/build/testsuites/sptests/sptimer_err01.yml
 create mode 100644 spec/build/testsuites/sptests/sptimer_err02.yml
 delete mode 100644 spec/build/testsuites/sptests/sptimererr01.yml
 delete mode 100644 spec/build/testsuites/sptests/sptimererr02.yml
diff --git a/spec/build/bsps/arm/atsam/tstatsamv.yml b/spec/build/bsps/arm/atsam/tstatsamv.yml
index 41d2865..18afe07 100644
--- a/spec/build/bsps/arm/atsam/tstatsamv.yml
+++ b/spec/build/bsps/arm/atsam/tstatsamv.yml
@@ -5,14 +5,14 @@ actions:
     flashdisk01: exclude
     fsdosfsname01: exclude
     ftp01: exclude
-    jffs2fserror: exclude
-    jffs2fslink: exclude
-    jffs2fspatheval: exclude
-    jffs2fspermission: exclude
-    jffs2fsrdwr: exclude
-    jffs2fsscandir01: exclude
-    jffs2fssymlink: exclude
-    jffs2fstime: exclude
+    jffs2_fserror: exclude
+    jffs2_fslink: exclude
+    jffs2_fspatheval: exclude
+    jffs2_fspermission: exclude
+    jffs2_fsrdwr: exclude
+    jffs2_fsscandir01: exclude
+    jffs2_fssymlink: exclude
+    jffs2_fstime: exclude
     linpack: exclude
     mghttpd01: exclude
     pppd: exclude
@@ -21,7 +21,7 @@ actions:
     sp16: exclude
     sp25: exclude
     sp48: exclude
-    spregionerr01: exclude
+    spregion_err01: exclude
     spstkalloc02: exclude
     tmfine01: exclude
 build-type: option
diff --git a/spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml b/spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml
index 05ee3fc..067e81f 100644
--- a/spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml
+++ b/spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml
@@ -10,8 +10,8 @@ actions:
     iostream: exclude
     loopback: exclude
     math: exclude
-    mdosfsfserror: exclude
-    mdosfsfsrdwr: exclude
+    mdosfs_fserror: exclude
+    mdosfs_fsrdwr: exclude
     mghttpd01: exclude
     monitor02: exclude
     paranoia: exclude
diff --git a/spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml b/spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml
index f11ad4e..7f470bc 100644
--- a/spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml
+++ b/spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml
@@ -20,7 +20,7 @@ actions:
     sp42: exclude
     sp48: exclude
     sp71: exclude
     sptimecounter02: exclude
     sptimecounter03: exclude
     telnetd01: exclude
diff --git a/spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml b/spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml
index 4760c9d..14a21d0 100644
--- a/spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml
+++ b/spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml
@@ -5,7 +5,7 @@ actions:
     calloc: exclude
     capture: exclude
     cdtest: exclude
-    clockgettime: exclude
+    clock_gettime: exclude
     close: exclude
     debugger01: exclude
     defaultconfig01: exclude
@@ -29,14 +29,14 @@ actions:
     getuid: exclude
     heapwalk: exclude
     htonl: exclude
-    imfsfserror: exclude
-    imfsfslink: exclude
-    imfsfspatheval: exclude
-    imfsfspermission: exclude
-    imfsfsrdwr: exclude
-    imfsfsscandir01: exclude
-    imfsfssymlink: exclude
-    imfsfstime: exclude
+    imfs_fserror: exclude
+    imfs_fslink: exclude
+    imfs_fspatheval: exclude
+    imfs_fspermission: exclude
+    imfs_fsrdwr: exclude
+    imfs_fsscandir01: exclude
+    imfs_fssymlink: exclude
+    imfs_fstime: exclude
     iostream: exclude
     kill: exclude
     longjmp: exclude
@@ -44,29 +44,29 @@ actions:
     lseek: exclude
     lstat: exclude
     malloc: exclude
-    mdosfsfspatheval: exclude
-    mdosfsfsscandir01: exclude
-    mdosfsfsstatvfs: exclude
-    mdosfsfstime: exclude
+    mdosfs_fspatheval: exclude
+    mdosfs_fsscandir01: exclude
+    mdosfs_fsstatvfs: exclude
+    mdosfs_fstime: exclude
     mghttpd01: exclude
-    mimfsfserror: exclude
-    mimfsfslink: exclude
-    mimfsfspatheval: exclude
-    mimfsfspermission: exclude
-    mimfsfsrdwr: exclude
-    mimfsfsrename: exclude
-    mimfsfsscandir01: exclude
-    mimfsfssymlink: exclude
-    mimfsfstime: exclude
+    mimfs_fserror: exclude
+    mimfs_fslink: exclude
+    mimfs_fspatheval: exclude
+    mimfs_fspermission: exclude
+    mimfs_fsrdwr: exclude
+    mimfs_fsrename: exclude
+    mimfs_fsscandir01: exclude
+    mimfs_fssymlink: exclude
+    mimfs_fstime: exclude
     monitor: exclude
     monitor01: exclude
     monitor02: exclude
     nanosleep: exclude
     open: exclude
     pipe: exclude
-    posixmemalign: exclude
+    posix_memalign: exclude
     pppd: exclude
     psxaio01: exclude
     psxaio02: exclude
@@ -95,20 +95,20 @@ actions:
     sp35: exclude
     sp42: exclude
     sp48: exclude
-    spclockerr01: exclude
-    speventerr03: exclude
-    spintrerr01: exclude
-    spmsgqerr01: exclude
-    spmsgqerr02: exclude
-    spporterr01: exclude
-    spratemonerr01: exclude
-    spsemerr01: exclude
-    spsemerr02: exclude
-    spsignalerr01: exclude
+    spclock_err01: exclude
+    spevent_err03: exclude
+    spintr_err01: exclude
+    spmsgq_err01: exclude
+    spmsgq_err02: exclude
+    spport_err01: exclude
+    spratemon_err01: exclude
+    spsem_err01: exclude
+    spsem_err02: exclude
+    spsignal_err01: exclude
     spstkalloc: exclude
-    sptaskerr01: exclude
-    sptaskerr03: exclude
+    sptask_err01: exclude
+    sptask_err03: exclude
     sptls02: exclude
diff --git a/spec/build/bsps/arm/lpc24xx/tstlpc2362.yml b/spec/build/bsps/arm/lpc24xx/tstlpc2362.yml
index 8cf193b..9b84f1e 100644
--- a/spec/build/bsps/arm/lpc24xx/tstlpc2362.yml
+++ b/spec/build/bsps/arm/lpc24xx/tstlpc2362.yml
@@ -15,11 +15,11 @@ actions:
     iostream: exclude
     loopback: exclude
     math: exclude
     mghttpd01: exclude
     monitor: exclude
     monitor02: exclude
diff --git a/spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml b/spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml
index b1885e5..2ac7c34 100644
--- a/spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml
+++ b/spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml
@@ -18,12 +18,12 @@ actions:
     loopback: exclude
     math: exclude
     mathf: exclude
     mghttpd01: exclude
     monitor: exclude
     monitor02: exclude
diff --git a/spec/build/bsps/tstnoiconv.yml b/spec/build/bsps/tstnoiconv.yml
index 30de0ef..18b7e66 100644
--- a/spec/build/bsps/tstnoiconv.yml
+++ b/spec/build/bsps/tstnoiconv.yml
@@ -2,8 +2,8 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
 actions:
 - set-test-state:
     iconv: exclude
-    iconvclose: exclude
-    iconvopen: exclude
+    iconv_close: exclude
+    iconv_open: exclude
 build-type: option
 copyrights:
 - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
diff --git a/spec/build/bsps/tstnojffs2.yml b/spec/build/bsps/tstnojffs2.yml
index 4742d42..9f6cf70 100644
--- a/spec/build/bsps/tstnojffs2.yml
+++ b/spec/build/bsps/tstnojffs2.yml
@@ -2,14 +2,14 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
 actions:
 - set-test-state:
     fsjffs2gc01: exclude
 build-type: option
 copyrights:
diff --git a/spec/build/bsps/tstnorfs.yml b/spec/build/bsps/tstnorfs.yml
index ba8ae1c..c89366f 100644
--- a/spec/build/bsps/tstnorfs.yml
+++ b/spec/build/bsps/tstnorfs.yml
@@ -1,16 +1,16 @@
 actions:
 - set-test-state:
-    mrfsfserror: exclude
-    mrfsfsfpathconf: exclude
-    mrfsfslink: exclude
-    mrfsfspatheval: exclude
-    mrfsfspermission: exclude
-    mrfsfsrdwr: exclude
-    mrfsfsrename: exclude
-    mrfsfsscandir01: exclude
-    mrfsfssymlink: exclude
-    mrfsfstime: exclude
+    mrfs_fserror: exclude
+    mrfs_fsfpathconf: exclude
+    mrfs_fslink: exclude
+    mrfs_fspatheval: exclude
+    mrfs_fspermission: exclude
+    mrfs_fsrdwr: exclude
+    mrfs_fsrename: exclude
+    mrfs_fsscandir01: exclude
+    mrfs_fssymlink: exclude
+    mrfs_fstime: exclude
 build-type: option
 copyrights:
diff --git a/spec/build/testsuites/ada/ada_base_sp.yml b/spec/build/testsuites/ada/ada_base_sp.yml
new file mode 100644
index 0000000..4b22cae
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_base_sp.yml
@@ -0,0 +1,23 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+ada-main: testsuites/ada/samples/base_sp/base_sp.adb
+ada-object-directory: testsuites/ada/samples/base_sp
+adaflags: []
+adaincludes:
+- cpukit/include/adainclude
+- testsuites/ada/support
+build-type: ada-test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/samples/base_sp/init.c
+stlib: []
+target: testsuites/ada/ada_base_sp.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_hello.yml b/spec/build/testsuites/ada/ada_hello.yml
index 0000000..379d252
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_hello.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/samples/hello/hello.adb
+ada-object-directory: testsuites/ada/samples/hello
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/samples/hello/init.c
+stlib: []
+target: testsuites/ada/ada_hello.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp01_node1.yml b/spec/build/testsuites/ada/ada_mp01_node1.yml
index 0000000..e3991d4
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp01_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp01/node1/mp01_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp01/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp01
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+- RTEMS_MULTIPROCESSING
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp01/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp01_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp01_node2.yml b/spec/build/testsuites/ada/ada_mp01_node2.yml
index 0000000..a27e8fa
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp01_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp01/node2/mp01_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp01/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp01/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp01_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp03_node1.yml b/spec/build/testsuites/ada/ada_mp03_node1.yml
index 0000000..7702b2e
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp03_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp03/node1/mp03_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp03/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp03
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp03/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp03_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp03_node2.yml b/spec/build/testsuites/ada/ada_mp03_node2.yml
index 0000000..5e689af
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp03_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp03/node2/mp03_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp03/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp03/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp03_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp04_node1.yml b/spec/build/testsuites/ada/ada_mp04_node1.yml
index 0000000..396d48a
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp04_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp04/node1/mp04_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp04/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp04
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp04/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp04_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp04_node2.yml b/spec/build/testsuites/ada/ada_mp04_node2.yml
index 0000000..36a5763
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp04_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp04/node2/mp04_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp04/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp04/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp04_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp05_node1.yml b/spec/build/testsuites/ada/ada_mp05_node1.yml
index 0000000..0b49355
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp05_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp05/node1/mp05_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp05/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp05
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp05/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp05_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp05_node2.yml b/spec/build/testsuites/ada/ada_mp05_node2.yml
index 0000000..f71a7db
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp05_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp05/node2/mp05_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp05/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp05/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp05_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp06_node1.yml b/spec/build/testsuites/ada/ada_mp06_node1.yml
index 0000000..23a5c5c
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp06_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp06/node1/mp06_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp06/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp06
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp06/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp06_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp06_node2.yml b/spec/build/testsuites/ada/ada_mp06_node2.yml
index 0000000..4b6f6ea
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp06_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp06/node2/mp06_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp06/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp06/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp06_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp07_node1.yml b/spec/build/testsuites/ada/ada_mp07_node1.yml
index 0000000..2894034
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp07_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp07/node1/mp07_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp07/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp07
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp07/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp07_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp07_node2.yml b/spec/build/testsuites/ada/ada_mp07_node2.yml
index 0000000..9aba0f8
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp07_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp07/node2/mp07_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp07/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp07/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp07_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp08_node1.yml b/spec/build/testsuites/ada/ada_mp08_node1.yml
index 0000000..2ee9c77
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp08_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp08/node1/mp08_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp08/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp08
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp08/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp08_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp08_node2.yml b/spec/build/testsuites/ada/ada_mp08_node2.yml
index 0000000..e55d8cc
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp08_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp08/node2/mp08_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp08/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp08/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp08_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp09_node1.yml b/spec/build/testsuites/ada/ada_mp09_node1.yml
index 0000000..7623594
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp09_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp09/node1/mp09_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp09/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp09
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp09/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp09_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp09_node2.yml b/spec/build/testsuites/ada/ada_mp09_node2.yml
index 0000000..f117c82
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp09_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp09/node2/mp09_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp09/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp09/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp09_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp10_node1.yml b/spec/build/testsuites/ada/ada_mp10_node1.yml
index 0000000..4ff7981
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp10_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp10/node1/mp10_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp10/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp10
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp10/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp10_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp10_node2.yml b/spec/build/testsuites/ada/ada_mp10_node2.yml
index 0000000..fbe59f6
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp10_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp10/node2/mp10_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp10/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp10/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp10_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp11_node1.yml b/spec/build/testsuites/ada/ada_mp11_node1.yml
index 0000000..d16fd1b
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp11_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp11/node1/mp11_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp11/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp11
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp11/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp11_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp11_node2.yml b/spec/build/testsuites/ada/ada_mp11_node2.yml
index 0000000..7f94e5c
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp11_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp11/node2/mp11_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp11/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp11/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp11_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp12_node1.yml b/spec/build/testsuites/ada/ada_mp12_node1.yml
index 0000000..fc81bfe
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp12_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp12/node1/mp12_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp12/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp12
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp12/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp12_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp12_node2.yml b/spec/build/testsuites/ada/ada_mp12_node2.yml
index 0000000..3817ff8
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp12_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp12/node2/mp12_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp12/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp12/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp12_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp13_node1.yml b/spec/build/testsuites/ada/ada_mp13_node1.yml
index 0000000..947f89b
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp13_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp13/node1/mp13_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp13/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp13
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp13/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp13_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp13_node2.yml b/spec/build/testsuites/ada/ada_mp13_node2.yml
index 0000000..5fe7bfa
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp13_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp13/node2/mp13_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp13/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp13/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp13_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp14_node1.yml b/spec/build/testsuites/ada/ada_mp14_node1.yml
index 0000000..e6a753c
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp14_node1.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp14/node1/mp14_node1.adb
+ada-object-directory: testsuites/ada/mptests/mp14/node1
+adaflags: []
+adaincludes:
+- testsuites/ada/mptests/mp14
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp14/node1/init.c
+stlib: []
+target: testsuites/ada/ada_mp14_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_mp14_node2.yml b/spec/build/testsuites/ada/ada_mp14_node2.yml
index 0000000..1bdf328
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_mp14_node2.yml
@@ -0,0 +1,25 @@
+ada-main: testsuites/ada/mptests/mp14/node2/mp14_node2.adb
+ada-object-directory: testsuites/ada/mptests/mp14/node2
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/mptests/mp14/node2/init.c
+stlib: []
+target: testsuites/ada/ada_mp14_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_nsecs.yml b/spec/build/testsuites/ada/ada_nsecs.yml
index 0000000..088baf2
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_nsecs.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/samples/nsecs/nsecs.adb
+ada-object-directory: testsuites/ada/samples/nsecs
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/samples/nsecs/init.c
+stlib: []
+target: testsuites/ada/ada_nsecs.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp01.yml b/spec/build/testsuites/ada/ada_sp01.yml
index 0000000..2992e1e
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp01.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp01/sp01.adb
+ada-object-directory: testsuites/ada/sptests/sp01
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp01/init.c
+stlib: []
+target: testsuites/ada/ada_sp01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp02.yml b/spec/build/testsuites/ada/ada_sp02.yml
index 0000000..238b0ef
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp02.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp02/sp02.adb
+ada-object-directory: testsuites/ada/sptests/sp02
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp02/init.c
+stlib: []
+target: testsuites/ada/ada_sp02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp03.yml b/spec/build/testsuites/ada/ada_sp03.yml
index 0000000..7083244
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp03.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp03/sp03.adb
+ada-object-directory: testsuites/ada/sptests/sp03
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp03/init.c
+stlib: []
+target: testsuites/ada/ada_sp03.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp04.yml b/spec/build/testsuites/ada/ada_sp04.yml
index 0000000..f6bf5b7
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp04.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp04/sp04.adb
+ada-object-directory: testsuites/ada/sptests/sp04
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp04/init.c
+stlib: []
+target: testsuites/ada/ada_sp04.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp05.yml b/spec/build/testsuites/ada/ada_sp05.yml
index 0000000..b2ee7bb
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp05.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp05/sp05.adb
+ada-object-directory: testsuites/ada/sptests/sp05
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp05/init.c
+stlib: []
+target: testsuites/ada/ada_sp05.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp06.yml b/spec/build/testsuites/ada/ada_sp06.yml
index 0000000..d837c29
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp06.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp06/sp06.adb
+ada-object-directory: testsuites/ada/sptests/sp06
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp06/init.c
+stlib: []
+target: testsuites/ada/ada_sp06.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp07.yml b/spec/build/testsuites/ada/ada_sp07.yml
index 0000000..7a646d8
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp07.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp07/sp07.adb
+ada-object-directory: testsuites/ada/sptests/sp07
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp07/init.c
+stlib: []
+target: testsuites/ada/ada_sp07.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp08.yml b/spec/build/testsuites/ada/ada_sp08.yml
index 0000000..25a91b7
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp08.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp08/sp08.adb
+ada-object-directory: testsuites/ada/sptests/sp08
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp08/init.c
+stlib: []
+target: testsuites/ada/ada_sp08.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp09.yml b/spec/build/testsuites/ada/ada_sp09.yml
index 0000000..1396562
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp09.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp09/sp09.adb
+ada-object-directory: testsuites/ada/sptests/sp09
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp09/init.c
+stlib: []
+target: testsuites/ada/ada_sp09.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp11.yml b/spec/build/testsuites/ada/ada_sp11.yml
index 0000000..dbd158d
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp11.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp11/sp11.adb
+ada-object-directory: testsuites/ada/sptests/sp11
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp11/init.c
+stlib: []
+target: testsuites/ada/ada_sp11.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp12.yml b/spec/build/testsuites/ada/ada_sp12.yml
index 0000000..2da8f47
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp12.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp12/sp12.adb
+ada-object-directory: testsuites/ada/sptests/sp12
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp12/init.c
+stlib: []
+target: testsuites/ada/ada_sp12.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp13.yml b/spec/build/testsuites/ada/ada_sp13.yml
index 0000000..8110a2e
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp13.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp13/sp13.adb
+ada-object-directory: testsuites/ada/sptests/sp13
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp13/init.c
+stlib: []
+target: testsuites/ada/ada_sp13.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp14.yml b/spec/build/testsuites/ada/ada_sp14.yml
index 0000000..4804d93
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp14.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp14/sp14.adb
+ada-object-directory: testsuites/ada/sptests/sp14
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp14/init.c
+stlib: []
+target: testsuites/ada/ada_sp14.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp15.yml b/spec/build/testsuites/ada/ada_sp15.yml
index 0000000..896ddff
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp15.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp15/sp15.adb
+ada-object-directory: testsuites/ada/sptests/sp15
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp15/init.c
+stlib: []
+target: testsuites/ada/ada_sp15.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp16.yml b/spec/build/testsuites/ada/ada_sp16.yml
index 0000000..fa77565
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp16.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp16/sp16.adb
+ada-object-directory: testsuites/ada/sptests/sp16
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp16/init.c
+stlib: []
+target: testsuites/ada/ada_sp16.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp17.yml b/spec/build/testsuites/ada/ada_sp17.yml
index 0000000..1d1be12
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp17.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp17/sp17.adb
+ada-object-directory: testsuites/ada/sptests/sp17
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp17/init.c
+stlib: []
+target: testsuites/ada/ada_sp17.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp19.yml b/spec/build/testsuites/ada/ada_sp19.yml
index 0000000..2c3a0b0
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp19.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp19/sp19.adb
+ada-object-directory: testsuites/ada/sptests/sp19
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp19/init.c
+stlib: []
+target: testsuites/ada/ada_sp19.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp20.yml b/spec/build/testsuites/ada/ada_sp20.yml
index 0000000..52d4cf4
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp20.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp20/sp20.adb
+ada-object-directory: testsuites/ada/sptests/sp20
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp20/init.c
+stlib: []
+target: testsuites/ada/ada_sp20.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp22.yml b/spec/build/testsuites/ada/ada_sp22.yml
index 0000000..6f297b9
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp22.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp22/sp22.adb
+ada-object-directory: testsuites/ada/sptests/sp22
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp22/init.c
+stlib: []
+target: testsuites/ada/ada_sp22.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp23.yml b/spec/build/testsuites/ada/ada_sp23.yml
index 0000000..8ca322c
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp23.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp23/sp23.adb
+ada-object-directory: testsuites/ada/sptests/sp23
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp23/init.c
+stlib: []
+target: testsuites/ada/ada_sp23.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp24.yml b/spec/build/testsuites/ada/ada_sp24.yml
index 0000000..0425ec9
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp24.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp24/sp24.adb
+ada-object-directory: testsuites/ada/sptests/sp24
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp24/init.c
+stlib: []
+target: testsuites/ada/ada_sp24.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_sp25.yml b/spec/build/testsuites/ada/ada_sp25.yml
index 0000000..14c747d
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_sp25.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/sptests/sp25/sp25.adb
+ada-object-directory: testsuites/ada/sptests/sp25
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/sp25/init.c
+stlib: []
+target: testsuites/ada/ada_sp25.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_spatcb01.yml b/spec/build/testsuites/ada/ada_spatcb01.yml
index 0000000..5aa34a8
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_spatcb01.yml
@@ -0,0 +1,24 @@
+ada-main: testsuites/ada/sptests/spatcb01/spatcb01.adb
+ada-object-directory: testsuites/ada/sptests/spatcb01
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+- RTEMS_POSIX_API
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/spatcb01/init.c
+stlib: []
+target: testsuites/ada/ada_spatcb01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_spname01.yml b/spec/build/testsuites/ada/ada_spname01.yml
index 0000000..2f28f32
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_spname01.yml
@@ -0,0 +1,24 @@
+ada-main: testsuites/ada/sptests/spname01/spname01.adb
+ada-object-directory: testsuites/ada/sptests/spname01
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by:
+- RTEMS_POSIX_API
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/sptests/spname01/init.c
+stlib: []
+target: testsuites/ada/ada_spname01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_ticker.yml b/spec/build/testsuites/ada/ada_ticker.yml
index 0000000..29e16d7
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_ticker.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/samples/ticker/ticker.adb
+ada-object-directory: testsuites/ada/samples/ticker
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/samples/ticker/init.c
+stlib: []
+target: testsuites/ada/ada_ticker.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm01.yml b/spec/build/testsuites/ada/ada_tm01.yml
index 0000000..5513a2f
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm01.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm01/tm01.adb
+ada-object-directory: testsuites/ada/tmtests/tm01
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm01/init.c
+stlib: []
+target: testsuites/ada/ada_tm01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm02.yml b/spec/build/testsuites/ada/ada_tm02.yml
index 0000000..d82e803
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm02.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm02/tm02.adb
+ada-object-directory: testsuites/ada/tmtests/tm02
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm02/init.c
+stlib: []
+target: testsuites/ada/ada_tm02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm03.yml b/spec/build/testsuites/ada/ada_tm03.yml
index 0000000..8c659ef
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm03.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm03/tm03.adb
+ada-object-directory: testsuites/ada/tmtests/tm03
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm03/init.c
+stlib: []
+target: testsuites/ada/ada_tm03.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm04.yml b/spec/build/testsuites/ada/ada_tm04.yml
index 0000000..dfcaa24
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm04.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm04/tm04.adb
+ada-object-directory: testsuites/ada/tmtests/tm04
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm04/init.c
+stlib: []
+target: testsuites/ada/ada_tm04.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm05.yml b/spec/build/testsuites/ada/ada_tm05.yml
index 0000000..0af8fcf
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm05.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm05/tm05.adb
+ada-object-directory: testsuites/ada/tmtests/tm05
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm05/init.c
+stlib: []
+target: testsuites/ada/ada_tm05.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm06.yml b/spec/build/testsuites/ada/ada_tm06.yml
index 0000000..c1d50d3
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm06.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm06/tm06.adb
+ada-object-directory: testsuites/ada/tmtests/tm06
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm06/init.c
+stlib: []
+target: testsuites/ada/ada_tm06.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm07.yml b/spec/build/testsuites/ada/ada_tm07.yml
index 0000000..6a5fc62
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm07.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm07/tm07.adb
+ada-object-directory: testsuites/ada/tmtests/tm07
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm07/init.c
+stlib: []
+target: testsuites/ada/ada_tm07.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm08.yml b/spec/build/testsuites/ada/ada_tm08.yml
index 0000000..5661bc2
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm08.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm08/tm08.adb
+ada-object-directory: testsuites/ada/tmtests/tm08
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm08/init.c
+stlib: []
+target: testsuites/ada/ada_tm08.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm09.yml b/spec/build/testsuites/ada/ada_tm09.yml
index 0000000..c2fed17
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm09.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm09/tm09.adb
+ada-object-directory: testsuites/ada/tmtests/tm09
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm09/init.c
+stlib: []
+target: testsuites/ada/ada_tm09.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm10.yml b/spec/build/testsuites/ada/ada_tm10.yml
index 0000000..1fe5441
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm10.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm10/tm10.adb
+ada-object-directory: testsuites/ada/tmtests/tm10
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm10/init.c
+stlib: []
+target: testsuites/ada/ada_tm10.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm11.yml b/spec/build/testsuites/ada/ada_tm11.yml
index 0000000..cd4d590
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm11.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm11/tm11.adb
+ada-object-directory: testsuites/ada/tmtests/tm11
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm11/init.c
+stlib: []
+target: testsuites/ada/ada_tm11.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm12.yml b/spec/build/testsuites/ada/ada_tm12.yml
index 0000000..ab3adc5
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm12.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm12/tm12.adb
+ada-object-directory: testsuites/ada/tmtests/tm12
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm12/init.c
+stlib: []
+target: testsuites/ada/ada_tm12.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm13.yml b/spec/build/testsuites/ada/ada_tm13.yml
index 0000000..b45d321
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm13.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm13/tm13.adb
+ada-object-directory: testsuites/ada/tmtests/tm13
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm13/init.c
+stlib: []
+target: testsuites/ada/ada_tm13.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm14.yml b/spec/build/testsuites/ada/ada_tm14.yml
index 0000000..7c8a0f1
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm14.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm14/tm14.adb
+ada-object-directory: testsuites/ada/tmtests/tm14
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm14/init.c
+stlib: []
+target: testsuites/ada/ada_tm14.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm15.yml b/spec/build/testsuites/ada/ada_tm15.yml
index 0000000..8f92cdd
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm15.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm15/tm15.adb
+ada-object-directory: testsuites/ada/tmtests/tm15
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm15/init.c
+stlib: []
+target: testsuites/ada/ada_tm15.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm16.yml b/spec/build/testsuites/ada/ada_tm16.yml
index 0000000..105f9a2
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm16.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm16/tm16.adb
+ada-object-directory: testsuites/ada/tmtests/tm16
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm16/init.c
+stlib: []
+target: testsuites/ada/ada_tm16.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm17.yml b/spec/build/testsuites/ada/ada_tm17.yml
index 0000000..ac8094b
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm17.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm17/tm17.adb
+ada-object-directory: testsuites/ada/tmtests/tm17
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm17/init.c
+stlib: []
+target: testsuites/ada/ada_tm17.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm18.yml b/spec/build/testsuites/ada/ada_tm18.yml
index 0000000..28a5f18
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm18.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm18/tm18.adb
+ada-object-directory: testsuites/ada/tmtests/tm18
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm18/init.c
+stlib: []
+target: testsuites/ada/ada_tm18.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm19.yml b/spec/build/testsuites/ada/ada_tm19.yml
index 0000000..782a368
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm19.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm19/tm19.adb
+ada-object-directory: testsuites/ada/tmtests/tm19
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm19/init.c
+stlib: []
+target: testsuites/ada/ada_tm19.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm20.yml b/spec/build/testsuites/ada/ada_tm20.yml
index 0000000..d090f68
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm20.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm20/tm20.adb
+ada-object-directory: testsuites/ada/tmtests/tm20
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm20/init.c
+stlib: []
+target: testsuites/ada/ada_tm20.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm21.yml b/spec/build/testsuites/ada/ada_tm21.yml
index 0000000..fc77f09
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm21.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm21/tm21.adb
+ada-object-directory: testsuites/ada/tmtests/tm21
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm21/init.c
+stlib: []
+target: testsuites/ada/ada_tm21.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm22.yml b/spec/build/testsuites/ada/ada_tm22.yml
index 0000000..5654a5b
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm22.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm22/tm22.adb
+ada-object-directory: testsuites/ada/tmtests/tm22
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm22/init.c
+stlib: []
+target: testsuites/ada/ada_tm22.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm23.yml b/spec/build/testsuites/ada/ada_tm23.yml
index 0000000..f44623c
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm23.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm23/tm23.adb
+ada-object-directory: testsuites/ada/tmtests/tm23
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm23/init.c
+stlib: []
+target: testsuites/ada/ada_tm23.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm24.yml b/spec/build/testsuites/ada/ada_tm24.yml
index 0000000..a7985ef
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm24.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm24/tm24.adb
+ada-object-directory: testsuites/ada/tmtests/tm24
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm24/init.c
+stlib: []
+target: testsuites/ada/ada_tm24.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm25.yml b/spec/build/testsuites/ada/ada_tm25.yml
index 0000000..312eff3
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm25.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm25/tm25.adb
+ada-object-directory: testsuites/ada/tmtests/tm25
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm25/init.c
+stlib: []
+target: testsuites/ada/ada_tm25.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm28.yml b/spec/build/testsuites/ada/ada_tm28.yml
index 0000000..c21f26c
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm28.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm28/tm28.adb
+ada-object-directory: testsuites/ada/tmtests/tm28
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm28/init.c
+stlib: []
+target: testsuites/ada/ada_tm28.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tm29.yml b/spec/build/testsuites/ada/ada_tm29.yml
index 0000000..365b291
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tm29.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tm29/tm29.adb
+ada-object-directory: testsuites/ada/tmtests/tm29
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tm29/init.c
+stlib: []
+target: testsuites/ada/ada_tm29.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/ada_tmck.yml b/spec/build/testsuites/ada/ada_tmck.yml
index 0000000..410a083
--- /dev/null
+++ b/spec/build/testsuites/ada/ada_tmck.yml
@@ -0,0 +1,23 @@
+ada-main: testsuites/ada/tmtests/tmck/tmck.adb
+ada-object-directory: testsuites/ada/tmtests/tmck
+adaflags: []
+adaincludes:
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/ada/tmtests/tmck/init.c
+stlib: []
+target: testsuites/ada/ada_tmck.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/ada/adabasesp.yml b/spec/build/testsuites/ada/adabasesp.yml
deleted file mode 100644
index 4b22cae..0000000
--- a/spec/build/testsuites/ada/adabasesp.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-ada-main: testsuites/ada/samples/base_sp/base_sp.adb
-ada-object-directory: testsuites/ada/samples/base_sp
-adaflags: []
-adaincludes:
-- cpukit/include/adainclude
-- testsuites/ada/support
-build-type: ada-test-program
-cflags: []
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/samples/base_sp/init.c
-stlib: []
-target: testsuites/ada/ada_base_sp.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adahello.yml b/spec/build/testsuites/ada/adahello.yml
index 379d252..0000000
--- a/spec/build/testsuites/ada/adahello.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/samples/hello/hello.adb
-ada-object-directory: testsuites/ada/samples/hello
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/samples/hello/init.c
-stlib: []
-target: testsuites/ada/ada_hello.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp01node1.yml b/spec/build/testsuites/ada/adamp01node1.yml
index e3991d4..0000000
--- a/spec/build/testsuites/ada/adamp01node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp01/node1/mp01_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp01/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp01
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-- RTEMS_MULTIPROCESSING
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp01/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp01_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp01node2.yml b/spec/build/testsuites/ada/adamp01node2.yml
index a27e8fa..0000000
--- a/spec/build/testsuites/ada/adamp01node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp01/node2/mp01_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp01/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp01/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp01_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp03node1.yml b/spec/build/testsuites/ada/adamp03node1.yml
index 7702b2e..0000000
--- a/spec/build/testsuites/ada/adamp03node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp03/node1/mp03_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp03/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp03
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp03/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp03_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp03node2.yml b/spec/build/testsuites/ada/adamp03node2.yml
index 5e689af..0000000
--- a/spec/build/testsuites/ada/adamp03node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp03/node2/mp03_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp03/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp03/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp03_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp04node1.yml b/spec/build/testsuites/ada/adamp04node1.yml
index 396d48a..0000000
--- a/spec/build/testsuites/ada/adamp04node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp04/node1/mp04_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp04/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp04
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp04/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp04_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp04node2.yml b/spec/build/testsuites/ada/adamp04node2.yml
index 36a5763..0000000
--- a/spec/build/testsuites/ada/adamp04node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp04/node2/mp04_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp04/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp04/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp04_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp05node1.yml b/spec/build/testsuites/ada/adamp05node1.yml
index 0b49355..0000000
--- a/spec/build/testsuites/ada/adamp05node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp05/node1/mp05_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp05/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp05
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp05/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp05_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp05node2.yml b/spec/build/testsuites/ada/adamp05node2.yml
index f71a7db..0000000
--- a/spec/build/testsuites/ada/adamp05node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp05/node2/mp05_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp05/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp05/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp05_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp06node1.yml b/spec/build/testsuites/ada/adamp06node1.yml
index 23a5c5c..0000000
--- a/spec/build/testsuites/ada/adamp06node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp06/node1/mp06_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp06/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp06
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp06/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp06_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp06node2.yml b/spec/build/testsuites/ada/adamp06node2.yml
index 4b6f6ea..0000000
--- a/spec/build/testsuites/ada/adamp06node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp06/node2/mp06_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp06/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp06/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp06_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp07node1.yml b/spec/build/testsuites/ada/adamp07node1.yml
index 2894034..0000000
--- a/spec/build/testsuites/ada/adamp07node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp07/node1/mp07_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp07/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp07
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp07/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp07_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp07node2.yml b/spec/build/testsuites/ada/adamp07node2.yml
index 9aba0f8..0000000
--- a/spec/build/testsuites/ada/adamp07node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp07/node2/mp07_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp07/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp07/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp07_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp08node1.yml b/spec/build/testsuites/ada/adamp08node1.yml
index 2ee9c77..0000000
--- a/spec/build/testsuites/ada/adamp08node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp08/node1/mp08_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp08/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp08
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp08/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp08_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp08node2.yml b/spec/build/testsuites/ada/adamp08node2.yml
index e55d8cc..0000000
--- a/spec/build/testsuites/ada/adamp08node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp08/node2/mp08_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp08/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp08/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp08_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp09node1.yml b/spec/build/testsuites/ada/adamp09node1.yml
index 7623594..0000000
--- a/spec/build/testsuites/ada/adamp09node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp09/node1/mp09_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp09/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp09
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp09/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp09_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp09node2.yml b/spec/build/testsuites/ada/adamp09node2.yml
index f117c82..0000000
--- a/spec/build/testsuites/ada/adamp09node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp09/node2/mp09_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp09/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp09/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp09_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp10node1.yml b/spec/build/testsuites/ada/adamp10node1.yml
index 4ff7981..0000000
--- a/spec/build/testsuites/ada/adamp10node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp10/node1/mp10_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp10/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp10
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp10/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp10_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp10node2.yml b/spec/build/testsuites/ada/adamp10node2.yml
index fbe59f6..0000000
--- a/spec/build/testsuites/ada/adamp10node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp10/node2/mp10_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp10/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp10/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp10_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp11node1.yml b/spec/build/testsuites/ada/adamp11node1.yml
index d16fd1b..0000000
--- a/spec/build/testsuites/ada/adamp11node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp11/node1/mp11_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp11/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp11
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp11/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp11_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp11node2.yml b/spec/build/testsuites/ada/adamp11node2.yml
index 7f94e5c..0000000
--- a/spec/build/testsuites/ada/adamp11node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp11/node2/mp11_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp11/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp11/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp11_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp12node1.yml b/spec/build/testsuites/ada/adamp12node1.yml
index fc81bfe..0000000
--- a/spec/build/testsuites/ada/adamp12node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp12/node1/mp12_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp12/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp12
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp12/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp12_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp12node2.yml b/spec/build/testsuites/ada/adamp12node2.yml
index 3817ff8..0000000
--- a/spec/build/testsuites/ada/adamp12node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp12/node2/mp12_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp12/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp12/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp12_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp13node1.yml b/spec/build/testsuites/ada/adamp13node1.yml
index 947f89b..0000000
--- a/spec/build/testsuites/ada/adamp13node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp13/node1/mp13_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp13/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp13
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp13/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp13_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp13node2.yml b/spec/build/testsuites/ada/adamp13node2.yml
index 5fe7bfa..0000000
--- a/spec/build/testsuites/ada/adamp13node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp13/node2/mp13_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp13/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp13/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp13_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp14node1.yml b/spec/build/testsuites/ada/adamp14node1.yml
index e6a753c..0000000
--- a/spec/build/testsuites/ada/adamp14node1.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp14/node1/mp14_node1.adb
-ada-object-directory: testsuites/ada/mptests/mp14/node1
-adaflags: []
-adaincludes:
-- testsuites/ada/mptests/mp14
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp14/node1/init.c
-stlib: []
-target: testsuites/ada/ada_mp14_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adamp14node2.yml b/spec/build/testsuites/ada/adamp14node2.yml
index 1bdf328..0000000
--- a/spec/build/testsuites/ada/adamp14node2.yml
+++ /dev/null
@@ -1,25 +0,0 @@
-ada-main: testsuites/ada/mptests/mp14/node2/mp14_node2.adb
-ada-object-directory: testsuites/ada/mptests/mp14/node2
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/mptests/mp14/node2/init.c
-stlib: []
-target: testsuites/ada/ada_mp14_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adansecs.yml b/spec/build/testsuites/ada/adansecs.yml
index 088baf2..0000000
--- a/spec/build/testsuites/ada/adansecs.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/samples/nsecs/nsecs.adb
-ada-object-directory: testsuites/ada/samples/nsecs
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/samples/nsecs/init.c
-stlib: []
-target: testsuites/ada/ada_nsecs.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp01.yml b/spec/build/testsuites/ada/adasp01.yml
index 2992e1e..0000000
--- a/spec/build/testsuites/ada/adasp01.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp01/sp01.adb
-ada-object-directory: testsuites/ada/sptests/sp01
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp01/init.c
-stlib: []
-target: testsuites/ada/ada_sp01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp02.yml b/spec/build/testsuites/ada/adasp02.yml
index 238b0ef..0000000
--- a/spec/build/testsuites/ada/adasp02.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp02/sp02.adb
-ada-object-directory: testsuites/ada/sptests/sp02
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp02/init.c
-stlib: []
-target: testsuites/ada/ada_sp02.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp03.yml b/spec/build/testsuites/ada/adasp03.yml
index 7083244..0000000
--- a/spec/build/testsuites/ada/adasp03.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp03/sp03.adb
-ada-object-directory: testsuites/ada/sptests/sp03
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp03/init.c
-stlib: []
-target: testsuites/ada/ada_sp03.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp04.yml b/spec/build/testsuites/ada/adasp04.yml
index f6bf5b7..0000000
--- a/spec/build/testsuites/ada/adasp04.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp04/sp04.adb
-ada-object-directory: testsuites/ada/sptests/sp04
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp04/init.c
-stlib: []
-target: testsuites/ada/ada_sp04.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp05.yml b/spec/build/testsuites/ada/adasp05.yml
index b2ee7bb..0000000
--- a/spec/build/testsuites/ada/adasp05.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp05/sp05.adb
-ada-object-directory: testsuites/ada/sptests/sp05
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp05/init.c
-stlib: []
-target: testsuites/ada/ada_sp05.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp06.yml b/spec/build/testsuites/ada/adasp06.yml
index d837c29..0000000
--- a/spec/build/testsuites/ada/adasp06.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp06/sp06.adb
-ada-object-directory: testsuites/ada/sptests/sp06
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp06/init.c
-stlib: []
-target: testsuites/ada/ada_sp06.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp07.yml b/spec/build/testsuites/ada/adasp07.yml
index 7a646d8..0000000
--- a/spec/build/testsuites/ada/adasp07.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp07/sp07.adb
-ada-object-directory: testsuites/ada/sptests/sp07
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp07/init.c
-stlib: []
-target: testsuites/ada/ada_sp07.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp08.yml b/spec/build/testsuites/ada/adasp08.yml
index 25a91b7..0000000
--- a/spec/build/testsuites/ada/adasp08.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp08/sp08.adb
-ada-object-directory: testsuites/ada/sptests/sp08
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp08/init.c
-stlib: []
-target: testsuites/ada/ada_sp08.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp09.yml b/spec/build/testsuites/ada/adasp09.yml
index 1396562..0000000
--- a/spec/build/testsuites/ada/adasp09.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp09/sp09.adb
-ada-object-directory: testsuites/ada/sptests/sp09
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp09/init.c
-stlib: []
-target: testsuites/ada/ada_sp09.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp11.yml b/spec/build/testsuites/ada/adasp11.yml
index dbd158d..0000000
--- a/spec/build/testsuites/ada/adasp11.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp11/sp11.adb
-ada-object-directory: testsuites/ada/sptests/sp11
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp11/init.c
-stlib: []
-target: testsuites/ada/ada_sp11.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp12.yml b/spec/build/testsuites/ada/adasp12.yml
index 2da8f47..0000000
--- a/spec/build/testsuites/ada/adasp12.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp12/sp12.adb
-ada-object-directory: testsuites/ada/sptests/sp12
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp12/init.c
-stlib: []
-target: testsuites/ada/ada_sp12.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp13.yml b/spec/build/testsuites/ada/adasp13.yml
index 8110a2e..0000000
--- a/spec/build/testsuites/ada/adasp13.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp13/sp13.adb
-ada-object-directory: testsuites/ada/sptests/sp13
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp13/init.c
-stlib: []
-target: testsuites/ada/ada_sp13.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp14.yml b/spec/build/testsuites/ada/adasp14.yml
index 4804d93..0000000
--- a/spec/build/testsuites/ada/adasp14.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp14/sp14.adb
-ada-object-directory: testsuites/ada/sptests/sp14
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp14/init.c
-stlib: []
-target: testsuites/ada/ada_sp14.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp15.yml b/spec/build/testsuites/ada/adasp15.yml
index 896ddff..0000000
--- a/spec/build/testsuites/ada/adasp15.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp15/sp15.adb
-ada-object-directory: testsuites/ada/sptests/sp15
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp15/init.c
-stlib: []
-target: testsuites/ada/ada_sp15.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp16.yml b/spec/build/testsuites/ada/adasp16.yml
index fa77565..0000000
--- a/spec/build/testsuites/ada/adasp16.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp16/sp16.adb
-ada-object-directory: testsuites/ada/sptests/sp16
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp16/init.c
-stlib: []
-target: testsuites/ada/ada_sp16.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp17.yml b/spec/build/testsuites/ada/adasp17.yml
index 1d1be12..0000000
--- a/spec/build/testsuites/ada/adasp17.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp17/sp17.adb
-ada-object-directory: testsuites/ada/sptests/sp17
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp17/init.c
-stlib: []
-target: testsuites/ada/ada_sp17.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp19.yml b/spec/build/testsuites/ada/adasp19.yml
index 2c3a0b0..0000000
--- a/spec/build/testsuites/ada/adasp19.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp19/sp19.adb
-ada-object-directory: testsuites/ada/sptests/sp19
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp19/init.c
-stlib: []
-target: testsuites/ada/ada_sp19.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp20.yml b/spec/build/testsuites/ada/adasp20.yml
index 52d4cf4..0000000
--- a/spec/build/testsuites/ada/adasp20.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp20/sp20.adb
-ada-object-directory: testsuites/ada/sptests/sp20
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp20/init.c
-stlib: []
-target: testsuites/ada/ada_sp20.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp22.yml b/spec/build/testsuites/ada/adasp22.yml
index 6f297b9..0000000
--- a/spec/build/testsuites/ada/adasp22.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp22/sp22.adb
-ada-object-directory: testsuites/ada/sptests/sp22
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp22/init.c
-stlib: []
-target: testsuites/ada/ada_sp22.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp23.yml b/spec/build/testsuites/ada/adasp23.yml
index 8ca322c..0000000
--- a/spec/build/testsuites/ada/adasp23.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp23/sp23.adb
-ada-object-directory: testsuites/ada/sptests/sp23
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp23/init.c
-stlib: []
-target: testsuites/ada/ada_sp23.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp24.yml b/spec/build/testsuites/ada/adasp24.yml
index 0425ec9..0000000
--- a/spec/build/testsuites/ada/adasp24.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp24/sp24.adb
-ada-object-directory: testsuites/ada/sptests/sp24
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp24/init.c
-stlib: []
-target: testsuites/ada/ada_sp24.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adasp25.yml b/spec/build/testsuites/ada/adasp25.yml
index 14c747d..0000000
--- a/spec/build/testsuites/ada/adasp25.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/sptests/sp25/sp25.adb
-ada-object-directory: testsuites/ada/sptests/sp25
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/sp25/init.c
-stlib: []
-target: testsuites/ada/ada_sp25.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adaspatcb01.yml b/spec/build/testsuites/ada/adaspatcb01.yml
index 5aa34a8..0000000
--- a/spec/build/testsuites/ada/adaspatcb01.yml
+++ /dev/null
@@ -1,24 +0,0 @@
-ada-main: testsuites/ada/sptests/spatcb01/spatcb01.adb
-ada-object-directory: testsuites/ada/sptests/spatcb01
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-- RTEMS_POSIX_API
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/spatcb01/init.c
-stlib: []
-target: testsuites/ada/ada_spatcb01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adaspname01.yml b/spec/build/testsuites/ada/adaspname01.yml
index 2f28f32..0000000
--- a/spec/build/testsuites/ada/adaspname01.yml
+++ /dev/null
@@ -1,24 +0,0 @@
-ada-main: testsuites/ada/sptests/spname01/spname01.adb
-ada-object-directory: testsuites/ada/sptests/spname01
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by:
-- RTEMS_POSIX_API
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/sptests/spname01/init.c
-stlib: []
-target: testsuites/ada/ada_spname01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adaticker.yml b/spec/build/testsuites/ada/adaticker.yml
index 29e16d7..0000000
--- a/spec/build/testsuites/ada/adaticker.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/samples/ticker/ticker.adb
-ada-object-directory: testsuites/ada/samples/ticker
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/samples/ticker/init.c
-stlib: []
-target: testsuites/ada/ada_ticker.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm01.yml b/spec/build/testsuites/ada/adatm01.yml
index 5513a2f..0000000
--- a/spec/build/testsuites/ada/adatm01.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm01/tm01.adb
-ada-object-directory: testsuites/ada/tmtests/tm01
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm01/init.c
-stlib: []
-target: testsuites/ada/ada_tm01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm02.yml b/spec/build/testsuites/ada/adatm02.yml
index d82e803..0000000
--- a/spec/build/testsuites/ada/adatm02.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm02/tm02.adb
-ada-object-directory: testsuites/ada/tmtests/tm02
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm02/init.c
-stlib: []
-target: testsuites/ada/ada_tm02.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm03.yml b/spec/build/testsuites/ada/adatm03.yml
index 8c659ef..0000000
--- a/spec/build/testsuites/ada/adatm03.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm03/tm03.adb
-ada-object-directory: testsuites/ada/tmtests/tm03
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm03/init.c
-stlib: []
-target: testsuites/ada/ada_tm03.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm04.yml b/spec/build/testsuites/ada/adatm04.yml
index dfcaa24..0000000
--- a/spec/build/testsuites/ada/adatm04.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm04/tm04.adb
-ada-object-directory: testsuites/ada/tmtests/tm04
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm04/init.c
-stlib: []
-target: testsuites/ada/ada_tm04.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm05.yml b/spec/build/testsuites/ada/adatm05.yml
index 0af8fcf..0000000
--- a/spec/build/testsuites/ada/adatm05.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm05/tm05.adb
-ada-object-directory: testsuites/ada/tmtests/tm05
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm05/init.c
-stlib: []
-target: testsuites/ada/ada_tm05.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm06.yml b/spec/build/testsuites/ada/adatm06.yml
index c1d50d3..0000000
--- a/spec/build/testsuites/ada/adatm06.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm06/tm06.adb
-ada-object-directory: testsuites/ada/tmtests/tm06
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm06/init.c
-stlib: []
-target: testsuites/ada/ada_tm06.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm07.yml b/spec/build/testsuites/ada/adatm07.yml
index 6a5fc62..0000000
--- a/spec/build/testsuites/ada/adatm07.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm07/tm07.adb
-ada-object-directory: testsuites/ada/tmtests/tm07
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm07/init.c
-stlib: []
-target: testsuites/ada/ada_tm07.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm08.yml b/spec/build/testsuites/ada/adatm08.yml
index 5661bc2..0000000
--- a/spec/build/testsuites/ada/adatm08.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm08/tm08.adb
-ada-object-directory: testsuites/ada/tmtests/tm08
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm08/init.c
-stlib: []
-target: testsuites/ada/ada_tm08.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm09.yml b/spec/build/testsuites/ada/adatm09.yml
index c2fed17..0000000
--- a/spec/build/testsuites/ada/adatm09.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm09/tm09.adb
-ada-object-directory: testsuites/ada/tmtests/tm09
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm09/init.c
-stlib: []
-target: testsuites/ada/ada_tm09.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm10.yml b/spec/build/testsuites/ada/adatm10.yml
index 1fe5441..0000000
--- a/spec/build/testsuites/ada/adatm10.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm10/tm10.adb
-ada-object-directory: testsuites/ada/tmtests/tm10
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm10/init.c
-stlib: []
-target: testsuites/ada/ada_tm10.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm11.yml b/spec/build/testsuites/ada/adatm11.yml
index cd4d590..0000000
--- a/spec/build/testsuites/ada/adatm11.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm11/tm11.adb
-ada-object-directory: testsuites/ada/tmtests/tm11
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm11/init.c
-stlib: []
-target: testsuites/ada/ada_tm11.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm12.yml b/spec/build/testsuites/ada/adatm12.yml
index ab3adc5..0000000
--- a/spec/build/testsuites/ada/adatm12.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm12/tm12.adb
-ada-object-directory: testsuites/ada/tmtests/tm12
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm12/init.c
-stlib: []
-target: testsuites/ada/ada_tm12.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm13.yml b/spec/build/testsuites/ada/adatm13.yml
index b45d321..0000000
--- a/spec/build/testsuites/ada/adatm13.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm13/tm13.adb
-ada-object-directory: testsuites/ada/tmtests/tm13
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm13/init.c
-stlib: []
-target: testsuites/ada/ada_tm13.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm14.yml b/spec/build/testsuites/ada/adatm14.yml
index 7c8a0f1..0000000
--- a/spec/build/testsuites/ada/adatm14.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm14/tm14.adb
-ada-object-directory: testsuites/ada/tmtests/tm14
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm14/init.c
-stlib: []
-target: testsuites/ada/ada_tm14.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm15.yml b/spec/build/testsuites/ada/adatm15.yml
index 8f92cdd..0000000
--- a/spec/build/testsuites/ada/adatm15.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm15/tm15.adb
-ada-object-directory: testsuites/ada/tmtests/tm15
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm15/init.c
-stlib: []
-target: testsuites/ada/ada_tm15.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm16.yml b/spec/build/testsuites/ada/adatm16.yml
index 105f9a2..0000000
--- a/spec/build/testsuites/ada/adatm16.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm16/tm16.adb
-ada-object-directory: testsuites/ada/tmtests/tm16
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm16/init.c
-stlib: []
-target: testsuites/ada/ada_tm16.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm17.yml b/spec/build/testsuites/ada/adatm17.yml
index ac8094b..0000000
--- a/spec/build/testsuites/ada/adatm17.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm17/tm17.adb
-ada-object-directory: testsuites/ada/tmtests/tm17
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm17/init.c
-stlib: []
-target: testsuites/ada/ada_tm17.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm18.yml b/spec/build/testsuites/ada/adatm18.yml
index 28a5f18..0000000
--- a/spec/build/testsuites/ada/adatm18.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm18/tm18.adb
-ada-object-directory: testsuites/ada/tmtests/tm18
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm18/init.c
-stlib: []
-target: testsuites/ada/ada_tm18.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm19.yml b/spec/build/testsuites/ada/adatm19.yml
index 782a368..0000000
--- a/spec/build/testsuites/ada/adatm19.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm19/tm19.adb
-ada-object-directory: testsuites/ada/tmtests/tm19
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm19/init.c
-stlib: []
-target: testsuites/ada/ada_tm19.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm20.yml b/spec/build/testsuites/ada/adatm20.yml
index d090f68..0000000
--- a/spec/build/testsuites/ada/adatm20.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm20/tm20.adb
-ada-object-directory: testsuites/ada/tmtests/tm20
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm20/init.c
-stlib: []
-target: testsuites/ada/ada_tm20.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm21.yml b/spec/build/testsuites/ada/adatm21.yml
index fc77f09..0000000
--- a/spec/build/testsuites/ada/adatm21.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm21/tm21.adb
-ada-object-directory: testsuites/ada/tmtests/tm21
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm21/init.c
-stlib: []
-target: testsuites/ada/ada_tm21.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm22.yml b/spec/build/testsuites/ada/adatm22.yml
index 5654a5b..0000000
--- a/spec/build/testsuites/ada/adatm22.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm22/tm22.adb
-ada-object-directory: testsuites/ada/tmtests/tm22
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm22/init.c
-stlib: []
-target: testsuites/ada/ada_tm22.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm23.yml b/spec/build/testsuites/ada/adatm23.yml
index f44623c..0000000
--- a/spec/build/testsuites/ada/adatm23.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm23/tm23.adb
-ada-object-directory: testsuites/ada/tmtests/tm23
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm23/init.c
-stlib: []
-target: testsuites/ada/ada_tm23.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm24.yml b/spec/build/testsuites/ada/adatm24.yml
index a7985ef..0000000
--- a/spec/build/testsuites/ada/adatm24.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm24/tm24.adb
-ada-object-directory: testsuites/ada/tmtests/tm24
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm24/init.c
-stlib: []
-target: testsuites/ada/ada_tm24.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm25.yml b/spec/build/testsuites/ada/adatm25.yml
index 312eff3..0000000
--- a/spec/build/testsuites/ada/adatm25.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm25/tm25.adb
-ada-object-directory: testsuites/ada/tmtests/tm25
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm25/init.c
-stlib: []
-target: testsuites/ada/ada_tm25.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm28.yml b/spec/build/testsuites/ada/adatm28.yml
index c21f26c..0000000
--- a/spec/build/testsuites/ada/adatm28.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm28/tm28.adb
-ada-object-directory: testsuites/ada/tmtests/tm28
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm28/init.c
-stlib: []
-target: testsuites/ada/ada_tm28.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatm29.yml b/spec/build/testsuites/ada/adatm29.yml
index 365b291..0000000
--- a/spec/build/testsuites/ada/adatm29.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tm29/tm29.adb
-ada-object-directory: testsuites/ada/tmtests/tm29
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tm29/init.c
-stlib: []
-target: testsuites/ada/ada_tm29.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/adatmck.yml b/spec/build/testsuites/ada/adatmck.yml
index 410a083..0000000
--- a/spec/build/testsuites/ada/adatmck.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-ada-main: testsuites/ada/tmtests/tmck/tmck.adb
-ada-object-directory: testsuites/ada/tmtests/tmck
-adaflags: []
-adaincludes:
-cflags: []
-copyrights:
-cppflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/ada/tmtests/tmck/init.c
-stlib: []
-target: testsuites/ada/ada_tmck.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/ada/grp.yml b/spec/build/testsuites/ada/grp.yml
index ef84203..7502a7d 100644
--- a/spec/build/testsuites/ada/grp.yml
+++ b/spec/build/testsuites/ada/grp.yml
@@ -17,169 +17,169 @@ links:
 - role: build-dependency
   uid: optgnat
-  uid: adabasesp
+  uid: ada_base_sp
-  uid: adahello
+  uid: ada_hello
-  uid: adamp01node1
+  uid: ada_mp01_node1
-  uid: adamp01node2
+  uid: ada_mp01_node2
-  uid: adamp03node1
+  uid: ada_mp03_node1
-  uid: adamp03node2
+  uid: ada_mp03_node2
-  uid: adamp04node1
+  uid: ada_mp04_node1
-  uid: adamp04node2
+  uid: ada_mp04_node2
-  uid: adamp05node1
+  uid: ada_mp05_node1
-  uid: adamp05node2
+  uid: ada_mp05_node2
-  uid: adamp06node1
+  uid: ada_mp06_node1
-  uid: adamp06node2
+  uid: ada_mp06_node2
-  uid: adamp07node1
+  uid: ada_mp07_node1
-  uid: adamp07node2
+  uid: ada_mp07_node2
-  uid: adamp08node1
+  uid: ada_mp08_node1
-  uid: adamp08node2
+  uid: ada_mp08_node2
-  uid: adamp09node1
+  uid: ada_mp09_node1
-  uid: adamp09node2
+  uid: ada_mp09_node2
-  uid: adamp10node1
+  uid: ada_mp10_node1
-  uid: adamp10node2
+  uid: ada_mp10_node2
-  uid: adamp11node1
+  uid: ada_mp11_node1
-  uid: adamp11node2
+  uid: ada_mp11_node2
-  uid: adamp12node1
+  uid: ada_mp12_node1
-  uid: adamp12node2
+  uid: ada_mp12_node2
-  uid: adamp13node1
+  uid: ada_mp13_node1
-  uid: adamp13node2
+  uid: ada_mp13_node2
-  uid: adamp14node1
+  uid: ada_mp14_node1
-  uid: adamp14node2
+  uid: ada_mp14_node2
-  uid: adansecs
+  uid: ada_nsecs
-  uid: adasp01
+  uid: ada_sp01
-  uid: adasp02
+  uid: ada_sp02
-  uid: adasp03
+  uid: ada_sp03
-  uid: adasp04
+  uid: ada_sp04
-  uid: adasp05
+  uid: ada_sp05
-  uid: adasp06
+  uid: ada_sp06
-  uid: adasp07
+  uid: ada_sp07
-  uid: adasp08
+  uid: ada_sp08
-  uid: adasp09
+  uid: ada_sp09
-  uid: adasp11
+  uid: ada_sp11
-  uid: adasp12
+  uid: ada_sp12
-  uid: adasp13
+  uid: ada_sp13
-  uid: adasp14
+  uid: ada_sp14
-  uid: adasp15
+  uid: ada_sp15
-  uid: adasp16
+  uid: ada_sp16
-  uid: adasp17
+  uid: ada_sp17
-  uid: adasp19
+  uid: ada_sp19
-  uid: adasp20
+  uid: ada_sp20
-  uid: adasp22
+  uid: ada_sp22
-  uid: adasp23
+  uid: ada_sp23
-  uid: adasp24
+  uid: ada_sp24
-  uid: adasp25
+  uid: ada_sp25
-  uid: adaspatcb01
+  uid: ada_spatcb01
-  uid: adaspname01
+  uid: ada_spname01
-  uid: adaticker
+  uid: ada_ticker
-  uid: adatm01
+  uid: ada_tm01
-  uid: adatm02
+  uid: ada_tm02
-  uid: adatm03
+  uid: ada_tm03
-  uid: adatm04
+  uid: ada_tm04
-  uid: adatm05
+  uid: ada_tm05
-  uid: adatm06
+  uid: ada_tm06
-  uid: adatm07
+  uid: ada_tm07
-  uid: adatm08
+  uid: ada_tm08
-  uid: adatm09
+  uid: ada_tm09
-  uid: adatm10
+  uid: ada_tm10
-  uid: adatm11
+  uid: ada_tm11
-  uid: adatm12
+  uid: ada_tm12
-  uid: adatm13
+  uid: ada_tm13
-  uid: adatm14
+  uid: ada_tm14
-  uid: adatm15
+  uid: ada_tm15
-  uid: adatm16
+  uid: ada_tm16
-  uid: adatm17
+  uid: ada_tm17
-  uid: adatm18
+  uid: ada_tm18
-  uid: adatm19
+  uid: ada_tm19
-  uid: adatm20
+  uid: ada_tm20
-  uid: adatm21
+  uid: ada_tm21
-  uid: adatm22
+  uid: ada_tm22
-  uid: adatm23
+  uid: ada_tm23
-  uid: adatm24
+  uid: ada_tm24
-  uid: adatm25
+  uid: ada_tm25
-  uid: adatm28
+  uid: ada_tm28
-  uid: adatm29
+  uid: ada_tm29
-  uid: adatmck
+  uid: ada_tmck
 type: build
 use-after:
 - rtemstest
diff --git a/spec/build/testsuites/fstests/grp.yml b/spec/build/testsuites/fstests/grp.yml
index 4c98778..411cf15 100644
--- a/spec/build/testsuites/fstests/grp.yml
+++ b/spec/build/testsuites/fstests/grp.yml
@@ -56,87 +56,87 @@ links:
   uid: fsrofs01
-  uid: imfsfserror
+  uid: imfs_fserror
-  uid: imfsfslink
+  uid: imfs_fslink
-  uid: imfsfspatheval
+  uid: imfs_fspatheval
-  uid: imfsfspermission
+  uid: imfs_fspermission
-  uid: imfsfsrdwr
+  uid: imfs_fsrdwr
-  uid: imfsfsscandir01
+  uid: imfs_fsscandir01
-  uid: imfsfssymlink
+  uid: imfs_fssymlink
-  uid: imfsfstime
+  uid: imfs_fstime
-  uid: jffs2fserror
+  uid: jffs2_fserror
-  uid: jffs2fslink
+  uid: jffs2_fslink
-  uid: jffs2fspatheval
+  uid: jffs2_fspatheval
-  uid: jffs2fspermission
+  uid: jffs2_fspermission
-  uid: jffs2fsrdwr
+  uid: jffs2_fsrdwr
-  uid: jffs2fsscandir01
+  uid: jffs2_fsscandir01
-  uid: jffs2fssymlink
+  uid: jffs2_fssymlink
-  uid: jffs2fstime
+  uid: jffs2_fstime
-  uid: mdosfsfserror
+  uid: mdosfs_fserror
-  uid: mdosfsfspatheval
+  uid: mdosfs_fspatheval
-  uid: mdosfsfsrdwr
+  uid: mdosfs_fsrdwr
-  uid: mdosfsfsscandir01
+  uid: mdosfs_fsscandir01
-  uid: mdosfsfsstatvfs
+  uid: mdosfs_fsstatvfs
-  uid: mdosfsfstime
+  uid: mdosfs_fstime
-  uid: mimfsfserror
+  uid: mimfs_fserror
-  uid: mimfsfslink
+  uid: mimfs_fslink
-  uid: mimfsfspatheval
+  uid: mimfs_fspatheval
-  uid: mimfsfspermission
+  uid: mimfs_fspermission
-  uid: mimfsfsrdwr
+  uid: mimfs_fsrdwr
-  uid: mimfsfsrename
+  uid: mimfs_fsrename
-  uid: mimfsfsscandir01
+  uid: mimfs_fsscandir01
-  uid: mimfsfssymlink
+  uid: mimfs_fssymlink
-  uid: mimfsfstime
+  uid: mimfs_fstime
-  uid: mrfsfserror
+  uid: mrfs_fserror
-  uid: mrfsfsfpathconf
+  uid: mrfs_fsfpathconf
-  uid: mrfsfslink
+  uid: mrfs_fslink
-  uid: mrfsfspatheval
+  uid: mrfs_fspatheval
-  uid: mrfsfspermission
+  uid: mrfs_fspermission
-  uid: mrfsfsrdwr
+  uid: mrfs_fsrdwr
-  uid: mrfsfsrename
+  uid: mrfs_fsrename
-  uid: mrfsfsscandir01
+  uid: mrfs_fsscandir01
-  uid: mrfsfssymlink
+  uid: mrfs_fssymlink
-  uid: mrfsfstime
+  uid: mrfs_fstime
 type: build
 use-after: []
 use-before:
diff --git a/spec/build/testsuites/fstests/imfs_fserror.yml b/spec/build/testsuites/fstests/imfs_fserror.yml
new file mode 100644
index 0000000..246ddbc
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fserror.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes:
+- testsuites/fstests/imfs_support
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fserror/test.c
+stlib: []
+target: testsuites/fstests/imfs_fserror.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfs_fslink.yml b/spec/build/testsuites/fstests/imfs_fslink.yml
index 0000000..e65c943
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fslink.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fslink/test.c
+stlib: []
+target: testsuites/fstests/imfs_fslink.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfs_fspatheval.yml b/spec/build/testsuites/fstests/imfs_fspatheval.yml
index 0000000..8192a85
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fspatheval.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fspatheval/test.c
+stlib: []
+target: testsuites/fstests/imfs_fspatheval.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfs_fspermission.yml b/spec/build/testsuites/fstests/imfs_fspermission.yml
index 0000000..99f6627
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fspermission.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fspermission/test.c
+stlib: []
+target: testsuites/fstests/imfs_fspermission.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfs_fsrdwr.yml b/spec/build/testsuites/fstests/imfs_fsrdwr.yml
index 0000000..88a4ba0
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fsrdwr.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fsrdwr/init.c
+stlib: []
+target: testsuites/fstests/imfs_fsrdwr.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfs_fsscandir01.yml b/spec/build/testsuites/fstests/imfs_fsscandir01.yml
index 0000000..009ef6b
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fsscandir01.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fsscandir01/init.c
+stlib: []
+target: testsuites/fstests/imfs_fsscandir01.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfs_fssymlink.yml b/spec/build/testsuites/fstests/imfs_fssymlink.yml
index 0000000..5ebdac6
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fssymlink.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fssymlink/test.c
+stlib: []
+target: testsuites/fstests/imfs_fssymlink.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfs_fstime.yml b/spec/build/testsuites/fstests/imfs_fstime.yml
index 0000000..77318d9
--- /dev/null
+++ b/spec/build/testsuites/fstests/imfs_fstime.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fstime/test.c
+stlib: []
+target: testsuites/fstests/imfs_fstime.exe
+type: build
+use-after: []
+use-before:
+- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfserror.yml b/spec/build/testsuites/fstests/imfsfserror.yml
index 246ddbc..0000000
--- a/spec/build/testsuites/fstests/imfsfserror.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-build-type: test-program
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-features: c cprogram
-includes:
-- testsuites/fstests/imfs_support
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fserror/test.c
-stlib: []
-target: testsuites/fstests/imfs_fserror.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfslink.yml b/spec/build/testsuites/fstests/imfsfslink.yml
index e65c943..0000000
--- a/spec/build/testsuites/fstests/imfsfslink.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fslink/test.c
-stlib: []
-target: testsuites/fstests/imfs_fslink.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfspatheval.yml b/spec/build/testsuites/fstests/imfsfspatheval.yml
index 8192a85..0000000
--- a/spec/build/testsuites/fstests/imfsfspatheval.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fspatheval/test.c
-stlib: []
-target: testsuites/fstests/imfs_fspatheval.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfspermission.yml b/spec/build/testsuites/fstests/imfsfspermission.yml
index 99f6627..0000000
--- a/spec/build/testsuites/fstests/imfsfspermission.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fspermission/test.c
-stlib: []
-target: testsuites/fstests/imfs_fspermission.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfsrdwr.yml b/spec/build/testsuites/fstests/imfsfsrdwr.yml
index 88a4ba0..0000000
--- a/spec/build/testsuites/fstests/imfsfsrdwr.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fsrdwr/init.c
-stlib: []
-target: testsuites/fstests/imfs_fsrdwr.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfsscandir01.yml b/spec/build/testsuites/fstests/imfsfsscandir01.yml
index 009ef6b..0000000
--- a/spec/build/testsuites/fstests/imfsfsscandir01.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fsscandir01/init.c
-stlib: []
-target: testsuites/fstests/imfs_fsscandir01.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfssymlink.yml b/spec/build/testsuites/fstests/imfsfssymlink.yml
index 5ebdac6..0000000
--- a/spec/build/testsuites/fstests/imfsfssymlink.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fssymlink/test.c
-stlib: []
-target: testsuites/fstests/imfs_fssymlink.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/imfsfstime.yml b/spec/build/testsuites/fstests/imfsfstime.yml
index 77318d9..0000000
--- a/spec/build/testsuites/fstests/imfsfstime.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fstime/test.c
-stlib: []
-target: testsuites/fstests/imfs_fstime.exe
-type: build
-use-after: []
-use-before:
-- testimfs
diff --git a/spec/build/testsuites/fstests/jffs2_fserror.yml b/spec/build/testsuites/fstests/jffs2_fserror.yml
index 0000000..a3b73dc
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fserror.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- testsuites/fstests/jffs2_support
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fserror.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2_fslink.yml b/spec/build/testsuites/fstests/jffs2_fslink.yml
index 0000000..7ae4d3c
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fslink.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fslink.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2_fspatheval.yml b/spec/build/testsuites/fstests/jffs2_fspatheval.yml
index 0000000..2908143
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fspatheval.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fspatheval.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2_fspermission.yml b/spec/build/testsuites/fstests/jffs2_fspermission.yml
index 0000000..f3cc6e9
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fspermission.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fspermission.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2_fsrdwr.yml b/spec/build/testsuites/fstests/jffs2_fsrdwr.yml
index 0000000..2a010e1
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fsrdwr.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fsrdwr.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2_fsscandir01.yml b/spec/build/testsuites/fstests/jffs2_fsscandir01.yml
index 0000000..af52c1c
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fsscandir01.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fsscandir01.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2_fssymlink.yml b/spec/build/testsuites/fstests/jffs2_fssymlink.yml
index 0000000..bd11fcd
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fssymlink.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fssymlink.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2_fstime.yml b/spec/build/testsuites/fstests/jffs2_fstime.yml
index 0000000..eb7f26c
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2_fstime.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/jffs2_fstime.exe
+type: build
+use-after: []
+use-before:
+- testjffs2
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fserror.yml b/spec/build/testsuites/fstests/jffs2fserror.yml
deleted file mode 100644
index a3b73dc..0000000
--- a/spec/build/testsuites/fstests/jffs2fserror.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-cflags: []
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-- testsuites/fstests/jffs2_support
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fserror.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fslink.yml b/spec/build/testsuites/fstests/jffs2fslink.yml
index 7ae4d3c..0000000
--- a/spec/build/testsuites/fstests/jffs2fslink.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fslink.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fspatheval.yml b/spec/build/testsuites/fstests/jffs2fspatheval.yml
index 2908143..0000000
--- a/spec/build/testsuites/fstests/jffs2fspatheval.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fspatheval.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fspermission.yml b/spec/build/testsuites/fstests/jffs2fspermission.yml
index f3cc6e9..0000000
--- a/spec/build/testsuites/fstests/jffs2fspermission.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fspermission.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fsrdwr.yml b/spec/build/testsuites/fstests/jffs2fsrdwr.yml
index 2a010e1..0000000
--- a/spec/build/testsuites/fstests/jffs2fsrdwr.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fsrdwr.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fsscandir01.yml b/spec/build/testsuites/fstests/jffs2fsscandir01.yml
index af52c1c..0000000
--- a/spec/build/testsuites/fstests/jffs2fsscandir01.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fsscandir01.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fssymlink.yml b/spec/build/testsuites/fstests/jffs2fssymlink.yml
index bd11fcd..0000000
--- a/spec/build/testsuites/fstests/jffs2fssymlink.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fssymlink.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2fstime.yml b/spec/build/testsuites/fstests/jffs2fstime.yml
index eb7f26c..0000000
--- a/spec/build/testsuites/fstests/jffs2fstime.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/jffs2_fstime.exe
-type: build
-use-after: []
-use-before:
-- testjffs2
-- jffs2
diff --git a/spec/build/testsuites/fstests/mdosfs_fserror.yml b/spec/build/testsuites/fstests/mdosfs_fserror.yml
index 0000000..0ac2ac8
--- /dev/null
+++ b/spec/build/testsuites/fstests/mdosfs_fserror.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- testsuites/fstests/mdosfs_support
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mdosfs_fserror.exe
+type: build
+use-after: []
+use-before:
+- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfs_fspatheval.yml b/spec/build/testsuites/fstests/mdosfs_fspatheval.yml
index 0000000..6569609
--- /dev/null
+++ b/spec/build/testsuites/fstests/mdosfs_fspatheval.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mdosfs_fspatheval.exe
+type: build
+use-after: []
+use-before:
+- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfs_fsrdwr.yml b/spec/build/testsuites/fstests/mdosfs_fsrdwr.yml
index 0000000..36f9389
--- /dev/null
+++ b/spec/build/testsuites/fstests/mdosfs_fsrdwr.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mdosfs_fsrdwr.exe
+type: build
+use-after: []
+use-before:
+- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfs_fsscandir01.yml b/spec/build/testsuites/fstests/mdosfs_fsscandir01.yml
index 0000000..2b5ab69
--- /dev/null
+++ b/spec/build/testsuites/fstests/mdosfs_fsscandir01.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mdosfs_fsscandir01.exe
+type: build
+use-after: []
+use-before:
+- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml b/spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml
index 0000000..34011bc
--- /dev/null
+++ b/spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fsstatvfs/test.c
+stlib: []
+target: testsuites/fstests/mdosfs_fsstatvfs.exe
+type: build
+use-after: []
+use-before:
+- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfs_fstime.yml b/spec/build/testsuites/fstests/mdosfs_fstime.yml
index 0000000..fd4cf68
--- /dev/null
+++ b/spec/build/testsuites/fstests/mdosfs_fstime.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mdosfs_fstime.exe
+type: build
+use-after: []
+use-before:
+- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfsfserror.yml b/spec/build/testsuites/fstests/mdosfsfserror.yml
index 0ac2ac8..0000000
--- a/spec/build/testsuites/fstests/mdosfsfserror.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-- testsuites/fstests/mdosfs_support
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mdosfs_fserror.exe
-type: build
-use-after: []
-use-before:
-- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfsfspatheval.yml b/spec/build/testsuites/fstests/mdosfsfspatheval.yml
index 6569609..0000000
--- a/spec/build/testsuites/fstests/mdosfsfspatheval.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mdosfs_fspatheval.exe
-type: build
-use-after: []
-use-before:
-- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfsfsrdwr.yml b/spec/build/testsuites/fstests/mdosfsfsrdwr.yml
index 36f9389..0000000
--- a/spec/build/testsuites/fstests/mdosfsfsrdwr.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mdosfs_fsrdwr.exe
-type: build
-use-after: []
-use-before:
-- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfsfsscandir01.yml b/spec/build/testsuites/fstests/mdosfsfsscandir01.yml
index 2b5ab69..0000000
--- a/spec/build/testsuites/fstests/mdosfsfsscandir01.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mdosfs_fsscandir01.exe
-type: build
-use-after: []
-use-before:
-- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfsfsstatvfs.yml b/spec/build/testsuites/fstests/mdosfsfsstatvfs.yml
index 34011bc..0000000
--- a/spec/build/testsuites/fstests/mdosfsfsstatvfs.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fsstatvfs/test.c
-stlib: []
-target: testsuites/fstests/mdosfs_fsstatvfs.exe
-type: build
-use-after: []
-use-before:
-- testdosfs
diff --git a/spec/build/testsuites/fstests/mdosfsfstime.yml b/spec/build/testsuites/fstests/mdosfsfstime.yml
index fd4cf68..0000000
--- a/spec/build/testsuites/fstests/mdosfsfstime.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mdosfs_fstime.exe
-type: build
-use-after: []
-use-before:
-- testdosfs
diff --git a/spec/build/testsuites/fstests/mimfs_fserror.yml b/spec/build/testsuites/fstests/mimfs_fserror.yml
index 0000000..d16d784
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fserror.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- testsuites/fstests/mimfs_support
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fserror.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fslink.yml b/spec/build/testsuites/fstests/mimfs_fslink.yml
index 0000000..dfbcde5
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fslink.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fslink.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fspatheval.yml b/spec/build/testsuites/fstests/mimfs_fspatheval.yml
index 0000000..67a36a5
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fspatheval.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fspatheval.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fspermission.yml b/spec/build/testsuites/fstests/mimfs_fspermission.yml
index 0000000..3257b36
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fspermission.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fspermission.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fsrdwr.yml b/spec/build/testsuites/fstests/mimfs_fsrdwr.yml
index 0000000..bf343a5
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fsrdwr.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fsrdwr.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fsrename.yml b/spec/build/testsuites/fstests/mimfs_fsrename.yml
index 0000000..b8ad300
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fsrename.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fsrename/test.c
+stlib: []
+target: testsuites/fstests/mimfs_fsrename.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fsscandir01.yml b/spec/build/testsuites/fstests/mimfs_fsscandir01.yml
index 0000000..d733530
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fsscandir01.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fsscandir01.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fssymlink.yml b/spec/build/testsuites/fstests/mimfs_fssymlink.yml
index 0000000..84b2cdd
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fssymlink.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fssymlink.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfs_fstime.yml b/spec/build/testsuites/fstests/mimfs_fstime.yml
index 0000000..1b1df5e
--- /dev/null
+++ b/spec/build/testsuites/fstests/mimfs_fstime.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mimfs_fstime.exe
+type: build
+use-after: []
+use-before:
+- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfserror.yml b/spec/build/testsuites/fstests/mimfsfserror.yml
index d16d784..0000000
--- a/spec/build/testsuites/fstests/mimfsfserror.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-- testsuites/fstests/mimfs_support
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fserror.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfslink.yml b/spec/build/testsuites/fstests/mimfsfslink.yml
index dfbcde5..0000000
--- a/spec/build/testsuites/fstests/mimfsfslink.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fslink.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfspatheval.yml b/spec/build/testsuites/fstests/mimfsfspatheval.yml
index 67a36a5..0000000
--- a/spec/build/testsuites/fstests/mimfsfspatheval.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fspatheval.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfspermission.yml b/spec/build/testsuites/fstests/mimfsfspermission.yml
index 3257b36..0000000
--- a/spec/build/testsuites/fstests/mimfsfspermission.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fspermission.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfsrdwr.yml b/spec/build/testsuites/fstests/mimfsfsrdwr.yml
index bf343a5..0000000
--- a/spec/build/testsuites/fstests/mimfsfsrdwr.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fsrdwr.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfsrename.yml b/spec/build/testsuites/fstests/mimfsfsrename.yml
index b8ad300..0000000
--- a/spec/build/testsuites/fstests/mimfsfsrename.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fsrename/test.c
-stlib: []
-target: testsuites/fstests/mimfs_fsrename.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfsscandir01.yml b/spec/build/testsuites/fstests/mimfsfsscandir01.yml
index d733530..0000000
--- a/spec/build/testsuites/fstests/mimfsfsscandir01.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fsscandir01.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfssymlink.yml b/spec/build/testsuites/fstests/mimfsfssymlink.yml
index 84b2cdd..0000000
--- a/spec/build/testsuites/fstests/mimfsfssymlink.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fssymlink.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mimfsfstime.yml b/spec/build/testsuites/fstests/mimfsfstime.yml
index 1b1df5e..0000000
--- a/spec/build/testsuites/fstests/mimfsfstime.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mimfs_fstime.exe
-type: build
-use-after: []
-use-before:
-- testmimfs
diff --git a/spec/build/testsuites/fstests/mrfs_fserror.yml b/spec/build/testsuites/fstests/mrfs_fserror.yml
index 0000000..6cf9538
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fserror.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- testsuites/fstests/mrfs_support
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fserror.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fsfpathconf.yml b/spec/build/testsuites/fstests/mrfs_fsfpathconf.yml
index 0000000..d87c5ec
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fsfpathconf.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fsfpathconf/test.c
+stlib: []
+target: testsuites/fstests/mrfs_fsfpathconf.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fslink.yml b/spec/build/testsuites/fstests/mrfs_fslink.yml
index 0000000..9d22ced
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fslink.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fslink.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fspatheval.yml b/spec/build/testsuites/fstests/mrfs_fspatheval.yml
index 0000000..a8f3595
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fspatheval.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fspatheval.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fspermission.yml b/spec/build/testsuites/fstests/mrfs_fspermission.yml
index 0000000..8755a9b
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fspermission.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fspermission.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fsrdwr.yml b/spec/build/testsuites/fstests/mrfs_fsrdwr.yml
index 0000000..e3a21f4
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fsrdwr.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fsrdwr.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fsrename.yml b/spec/build/testsuites/fstests/mrfs_fsrename.yml
index 0000000..c997ee4
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fsrename.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fsrename.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fsscandir01.yml b/spec/build/testsuites/fstests/mrfs_fsscandir01.yml
index 0000000..98b88d0
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fsscandir01.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fsscandir01.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fssymlink.yml b/spec/build/testsuites/fstests/mrfs_fssymlink.yml
index 0000000..dd2906f
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fssymlink.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fssymlink.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfs_fstime.yml b/spec/build/testsuites/fstests/mrfs_fstime.yml
index 0000000..8405163
--- /dev/null
+++ b/spec/build/testsuites/fstests/mrfs_fstime.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+stlib: []
+target: testsuites/fstests/mrfs_fstime.exe
+type: build
+use-after: []
+use-before:
+- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfserror.yml b/spec/build/testsuites/fstests/mrfsfserror.yml
index 6cf9538..0000000
--- a/spec/build/testsuites/fstests/mrfsfserror.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-- testsuites/fstests/mrfs_support
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fserror.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfsfpathconf.yml b/spec/build/testsuites/fstests/mrfsfsfpathconf.yml
index d87c5ec..0000000
--- a/spec/build/testsuites/fstests/mrfsfsfpathconf.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-- testsuites/fstests/fsfpathconf/test.c
-stlib: []
-target: testsuites/fstests/mrfs_fsfpathconf.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfslink.yml b/spec/build/testsuites/fstests/mrfsfslink.yml
index 9d22ced..0000000
--- a/spec/build/testsuites/fstests/mrfsfslink.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fslink.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfspatheval.yml b/spec/build/testsuites/fstests/mrfsfspatheval.yml
index a8f3595..0000000
--- a/spec/build/testsuites/fstests/mrfsfspatheval.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fspatheval.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfspermission.yml b/spec/build/testsuites/fstests/mrfsfspermission.yml
index 8755a9b..0000000
--- a/spec/build/testsuites/fstests/mrfsfspermission.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fspermission.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfsrdwr.yml b/spec/build/testsuites/fstests/mrfsfsrdwr.yml
index e3a21f4..0000000
--- a/spec/build/testsuites/fstests/mrfsfsrdwr.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fsrdwr.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfsrename.yml b/spec/build/testsuites/fstests/mrfsfsrename.yml
index c997ee4..0000000
--- a/spec/build/testsuites/fstests/mrfsfsrename.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fsrename.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfsscandir01.yml b/spec/build/testsuites/fstests/mrfsfsscandir01.yml
index 98b88d0..0000000
--- a/spec/build/testsuites/fstests/mrfsfsscandir01.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fsscandir01.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfssymlink.yml b/spec/build/testsuites/fstests/mrfsfssymlink.yml
index dd2906f..0000000
--- a/spec/build/testsuites/fstests/mrfsfssymlink.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fssymlink.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/fstests/mrfsfstime.yml b/spec/build/testsuites/fstests/mrfsfstime.yml
index 8405163..0000000
--- a/spec/build/testsuites/fstests/mrfsfstime.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes:
-ldflags: []
-links: []
-source:
-stlib: []
-target: testsuites/fstests/mrfs_fstime.exe
-type: build
-use-after: []
-use-before:
-- testrfs
diff --git a/spec/build/testsuites/libtests/clock_gettime.yml b/spec/build/testsuites/libtests/clock_gettime.yml
index 0000000..1810d3f
--- /dev/null
+++ b/spec/build/testsuites/libtests/clock_gettime.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/POSIX/clock_gettime.c
+stlib: []
+target: testsuites/libtests/clock_gettime.norun.exe
+type: build
+use-after: []
+use-before:
+- rtemsdefaultconfig
diff --git a/spec/build/testsuites/libtests/clockgettime.yml b/spec/build/testsuites/libtests/clockgettime.yml
index 1810d3f..0000000
--- a/spec/build/testsuites/libtests/clockgettime.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/libtests/POSIX/clock_gettime.c
-stlib: []
-target: testsuites/libtests/clock_gettime.norun.exe
-type: build
-use-after: []
-use-before:
-- rtemsdefaultconfig
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index 1aa1368..3362ba2 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -63,7 +63,7 @@ links:
   uid: capture01
-  uid: clockgettime
+  uid: clock_gettime
   uid: close
@@ -153,9 +153,9 @@ links:
   uid: iconv
-  uid: iconvclose
+  uid: iconv_close
-  uid: iconvopen
+  uid: iconv_open
   uid: irqs01
@@ -205,7 +205,7 @@ links:
   uid: pipe
-  uid: posixmemalign
+  uid: posix_memalign
   uid: putenvtest
diff --git a/spec/build/testsuites/libtests/iconv_close.yml b/spec/build/testsuites/libtests/iconv_close.yml
index 0000000..634b45b
--- /dev/null
+++ b/spec/build/testsuites/libtests/iconv_close.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/POSIX/iconv_close.c
+stlib: []
+target: testsuites/libtests/iconv_close.norun.exe
+type: build
+use-after: []
+use-before:
diff --git a/spec/build/testsuites/libtests/iconv_open.yml b/spec/build/testsuites/libtests/iconv_open.yml
index 0000000..dd59e9b
--- /dev/null
+++ b/spec/build/testsuites/libtests/iconv_open.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/POSIX/iconv_open.c
+stlib: []
+target: testsuites/libtests/iconv_open.norun.exe
+type: build
+use-after: []
+use-before:
diff --git a/spec/build/testsuites/libtests/iconvclose.yml b/spec/build/testsuites/libtests/iconvclose.yml
index 634b45b..0000000
--- a/spec/build/testsuites/libtests/iconvclose.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/libtests/POSIX/iconv_close.c
-stlib: []
-target: testsuites/libtests/iconv_close.norun.exe
-type: build
-use-after: []
-use-before:
diff --git a/spec/build/testsuites/libtests/iconvopen.yml b/spec/build/testsuites/libtests/iconvopen.yml
index dd59e9b..0000000
--- a/spec/build/testsuites/libtests/iconvopen.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/libtests/POSIX/iconv_open.c
-stlib: []
-target: testsuites/libtests/iconv_open.norun.exe
-type: build
-use-after: []
-use-before:
diff --git a/spec/build/testsuites/libtests/posix_memalign.yml b/spec/build/testsuites/libtests/posix_memalign.yml
index 0000000..3ea147b
--- /dev/null
+++ b/spec/build/testsuites/libtests/posix_memalign.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/POSIX/posix_memalign.c
+stlib: []
+target: testsuites/libtests/posix_memalign.norun.exe
+type: build
+use-after: []
+use-before:
diff --git a/spec/build/testsuites/libtests/posixmemalign.yml b/spec/build/testsuites/libtests/posixmemalign.yml
index 3ea147b..0000000
--- a/spec/build/testsuites/libtests/posixmemalign.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/libtests/POSIX/posix_memalign.c
-stlib: []
-target: testsuites/libtests/posix_memalign.norun.exe
-type: build
-use-after: []
-use-before:
diff --git a/spec/build/testsuites/mptests/grp.yml b/spec/build/testsuites/mptests/grp.yml
index 6965b50..e9bf66d 100644
--- a/spec/build/testsuites/mptests/grp.yml
+++ b/spec/build/testsuites/mptests/grp.yml
@@ -13,57 +13,57 @@ ldflags:
 - -Wl,--wrap=puts
 links:
-  uid: mp01node1
+  uid: mp01_node1
-  uid: mp01node2
+  uid: mp01_node2
-  uid: mp03node1
+  uid: mp03_node1
-  uid: mp03node2
+  uid: mp03_node2
-  uid: mp04node1
+  uid: mp04_node1
-  uid: mp04node2
+  uid: mp04_node2
-  uid: mp05node1
+  uid: mp05_node1
-  uid: mp05node2
+  uid: mp05_node2
-  uid: mp06node1
+  uid: mp06_node1
-  uid: mp06node2
+  uid: mp06_node2
-  uid: mp07node1
+  uid: mp07_node1
-  uid: mp07node2
+  uid: mp07_node2
-  uid: mp08node1
+  uid: mp08_node1
-  uid: mp08node2
+  uid: mp08_node2
-  uid: mp09node1
+  uid: mp09_node1
-  uid: mp09node2
+  uid: mp09_node2
-  uid: mp10node1
+  uid: mp10_node1
-  uid: mp10node2
+  uid: mp10_node2
-  uid: mp11node1
+  uid: mp11_node1
-  uid: mp11node2
+  uid: mp11_node2
-  uid: mp12node1
+  uid: mp12_node1
-  uid: mp12node2
+  uid: mp12_node2
-  uid: mp13node1
+  uid: mp13_node1
-  uid: mp13node2
+  uid: mp13_node2
-  uid: mp14node1
+  uid: mp14_node1
-  uid: mp14node2
+  uid: mp14_node2
 type: build
 use-after:
 - rtemstest
diff --git a/spec/build/testsuites/mptests/mp01_node1.yml b/spec/build/testsuites/mptests/mp01_node1.yml
index 0000000..87fee1d
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp01_node1.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_MULTIPROCESSING
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp01/init1.c
+- testsuites/mptests/mp01/task1.c
+stlib: []
+target: testsuites/mptests/mp01_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp01_node2.yml b/spec/build/testsuites/mptests/mp01_node2.yml
index 0000000..3316edd
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp01_node2.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp01/init2.c
+stlib: []
+target: testsuites/mptests/mp01_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp01node1.yml b/spec/build/testsuites/mptests/mp01node1.yml
index 87fee1d..0000000
--- a/spec/build/testsuites/mptests/mp01node1.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-- RTEMS_MULTIPROCESSING
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp01/init1.c
-- testsuites/mptests/mp01/task1.c
-stlib: []
-target: testsuites/mptests/mp01_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp01node2.yml b/spec/build/testsuites/mptests/mp01node2.yml
index 3316edd..0000000
--- a/spec/build/testsuites/mptests/mp01node2.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp01/init2.c
-stlib: []
-target: testsuites/mptests/mp01_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp03_node1.yml b/spec/build/testsuites/mptests/mp03_node1.yml
index 0000000..a231f30
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp03_node1.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp03/init1.c
+- testsuites/mptests/mp03/task1.c
+- testsuites/mptests/mp03/delay.c
+stlib: []
+target: testsuites/mptests/mp03_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp03_node2.yml b/spec/build/testsuites/mptests/mp03_node2.yml
index 0000000..81b9347
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp03_node2.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp03/init2.c
+stlib: []
+target: testsuites/mptests/mp03_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp03node1.yml b/spec/build/testsuites/mptests/mp03node1.yml
index 5ab2139..0000000
--- a/spec/build/testsuites/mptests/mp03node1.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp03/delay.c
-- testsuites/mptests/mp03/init1.c
-- testsuites/mptests/mp03/task1.c
-stlib: []
-target: testsuites/mptests/mp03_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp03node2.yml b/spec/build/testsuites/mptests/mp03node2.yml
index 4ebbb03..0000000
--- a/spec/build/testsuites/mptests/mp03node2.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp03/init2.c
-stlib: []
-target: testsuites/mptests/mp03_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp04_node1.yml b/spec/build/testsuites/mptests/mp04_node1.yml
index 0000000..731f7ca
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp04_node1.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp04/init1.c
+- testsuites/mptests/mp04/task1.c
+stlib: []
+target: testsuites/mptests/mp04_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp04_node2.yml b/spec/build/testsuites/mptests/mp04_node2.yml
index 0000000..6938f02
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp04_node2.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp04/init2.c
+stlib: []
+target: testsuites/mptests/mp04_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp04node1.yml b/spec/build/testsuites/mptests/mp04node1.yml
index 731f7ca..0000000
--- a/spec/build/testsuites/mptests/mp04node1.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp04/init1.c
-- testsuites/mptests/mp04/task1.c
-stlib: []
-target: testsuites/mptests/mp04_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp04node2.yml b/spec/build/testsuites/mptests/mp04node2.yml
index 6938f02..0000000
--- a/spec/build/testsuites/mptests/mp04node2.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp04/init2.c
-stlib: []
-target: testsuites/mptests/mp04_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp05_node1.yml b/spec/build/testsuites/mptests/mp05_node1.yml
index 0000000..342ebce
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp05_node1.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp05/init1.c
+- testsuites/mptests/mp05/task1.c
+- testsuites/mptests/mp05/asr.c
+stlib: []
+target: testsuites/mptests/mp05_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp05_node2.yml b/spec/build/testsuites/mptests/mp05_node2.yml
index 0000000..8248ba1
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp05_node2.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp05/init2.c
+stlib: []
+target: testsuites/mptests/mp05_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp05node1.yml b/spec/build/testsuites/mptests/mp05node1.yml
index e5144fc..0000000
--- a/spec/build/testsuites/mptests/mp05node1.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp05/asr.c
-- testsuites/mptests/mp05/init1.c
-- testsuites/mptests/mp05/task1.c
-stlib: []
-target: testsuites/mptests/mp05_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp05node2.yml b/spec/build/testsuites/mptests/mp05node2.yml
index 6ba8db5..0000000
--- a/spec/build/testsuites/mptests/mp05node2.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp05/init2.c
-stlib: []
-target: testsuites/mptests/mp05_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp06_node1.yml b/spec/build/testsuites/mptests/mp06_node1.yml
index 0000000..6a01a75
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp06_node1.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp06/init1.c
+- testsuites/mptests/mp06/task1.c
+stlib: []
+target: testsuites/mptests/mp06_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp06_node2.yml b/spec/build/testsuites/mptests/mp06_node2.yml
index 0000000..2af00e4
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp06_node2.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp06/init2.c
+stlib: []
+target: testsuites/mptests/mp06_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp06node1.yml b/spec/build/testsuites/mptests/mp06node1.yml
index 6a01a75..0000000
--- a/spec/build/testsuites/mptests/mp06node1.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp06/init1.c
-- testsuites/mptests/mp06/task1.c
-stlib: []
-target: testsuites/mptests/mp06_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp06node2.yml b/spec/build/testsuites/mptests/mp06node2.yml
index 2af00e4..0000000
--- a/spec/build/testsuites/mptests/mp06node2.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp06/init2.c
-stlib: []
-target: testsuites/mptests/mp06_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp07_node1.yml b/spec/build/testsuites/mptests/mp07_node1.yml
index 0000000..948bcb3
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp07_node1.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp07/init1.c
+- testsuites/mptests/mp07/task1.c
+stlib: []
+target: testsuites/mptests/mp07_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp07_node2.yml b/spec/build/testsuites/mptests/mp07_node2.yml
index 0000000..ec70919
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp07_node2.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp07/init2.c
+stlib: []
+target: testsuites/mptests/mp07_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp07node1.yml b/spec/build/testsuites/mptests/mp07node1.yml
index 948bcb3..0000000
--- a/spec/build/testsuites/mptests/mp07node1.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp07/init1.c
-- testsuites/mptests/mp07/task1.c
-stlib: []
-target: testsuites/mptests/mp07_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp07node2.yml b/spec/build/testsuites/mptests/mp07node2.yml
index ec70919..0000000
--- a/spec/build/testsuites/mptests/mp07node2.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp07/init2.c
-stlib: []
-target: testsuites/mptests/mp07_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp08_node1.yml b/spec/build/testsuites/mptests/mp08_node1.yml
index 0000000..1f1f42d
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp08_node1.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp08/init1.c
+- testsuites/mptests/mp08/task1.c
+stlib: []
+target: testsuites/mptests/mp08_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp08_node2.yml b/spec/build/testsuites/mptests/mp08_node2.yml
index 0000000..5fa4ea5
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp08_node2.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp08/init2.c
+stlib: []
+target: testsuites/mptests/mp08_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp08node1.yml b/spec/build/testsuites/mptests/mp08node1.yml
index 1f1f42d..0000000
--- a/spec/build/testsuites/mptests/mp08node1.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp08/init1.c
-- testsuites/mptests/mp08/task1.c
-stlib: []
-target: testsuites/mptests/mp08_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp08node2.yml b/spec/build/testsuites/mptests/mp08node2.yml
index 5fa4ea5..0000000
--- a/spec/build/testsuites/mptests/mp08node2.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp08/init2.c
-stlib: []
-target: testsuites/mptests/mp08_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp09_node1.yml b/spec/build/testsuites/mptests/mp09_node1.yml
index 0000000..a2ea0e8
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp09_node1.yml
@@ -0,0 +1,23 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp09/init1.c
+- testsuites/mptests/mp09/task1.c
+- testsuites/mptests/mp09/recvmsg.c
+- testsuites/mptests/mp09/sendmsg.c
+stlib: []
+target: testsuites/mptests/mp09_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp09_node2.yml b/spec/build/testsuites/mptests/mp09_node2.yml
index 0000000..fdbccdc
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp09_node2.yml
@@ -0,0 +1,23 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp09/init2.c
+stlib: []
+target: testsuites/mptests/mp09_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp09node1.yml b/spec/build/testsuites/mptests/mp09node1.yml
index 1f4220d..0000000
--- a/spec/build/testsuites/mptests/mp09node1.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp09/init1.c
-- testsuites/mptests/mp09/recvmsg.c
-- testsuites/mptests/mp09/sendmsg.c
-- testsuites/mptests/mp09/task1.c
-stlib: []
-target: testsuites/mptests/mp09_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp09node2.yml b/spec/build/testsuites/mptests/mp09node2.yml
index fc33d4a..0000000
--- a/spec/build/testsuites/mptests/mp09node2.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp09/init2.c
-stlib: []
-target: testsuites/mptests/mp09_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp10_node1.yml b/spec/build/testsuites/mptests/mp10_node1.yml
index 0000000..69d1736
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp10_node1.yml
@@ -0,0 +1,23 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp10/init1.c
+- testsuites/mptests/mp10/task1.c
+- testsuites/mptests/mp10/task2.c
+- testsuites/mptests/mp10/task3.c
+stlib: []
+target: testsuites/mptests/mp10_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp10_node2.yml b/spec/build/testsuites/mptests/mp10_node2.yml
new file mode 100644
index 0000000..90b1144
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp10_node2.yml
@@ -0,0 +1,23 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by:
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp10/init2.c
+stlib: []
+target: testsuites/mptests/mp10_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp10node1.yml b/spec/build/testsuites/mptests/mp10node1.yml
index 69d1736..0000000
--- a/spec/build/testsuites/mptests/mp10node1.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp10/init1.c
-- testsuites/mptests/mp10/task1.c
-- testsuites/mptests/mp10/task2.c
-- testsuites/mptests/mp10/task3.c
-stlib: []
-target: testsuites/mptests/mp10_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp10node2.yml b/spec/build/testsuites/mptests/mp10node2.yml
index 90b1144..0000000
--- a/spec/build/testsuites/mptests/mp10node2.yml
+++ /dev/null
@@ -1,23 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp10/init2.c
-stlib: []
-target: testsuites/mptests/mp10_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp11_node1.yml b/spec/build/testsuites/mptests/mp11_node1.yml
index 0000000..fb81d7f
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp11_node1.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp11/init1.c
+stlib: []
+target: testsuites/mptests/mp11_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp11_node2.yml b/spec/build/testsuites/mptests/mp11_node2.yml
index 0000000..38ea46e
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp11_node2.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp11/init2.c
+stlib: []
+target: testsuites/mptests/mp11_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp11node1.yml b/spec/build/testsuites/mptests/mp11node1.yml
index fb81d7f..0000000
--- a/spec/build/testsuites/mptests/mp11node1.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp11/init1.c
-stlib: []
-target: testsuites/mptests/mp11_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp11node2.yml b/spec/build/testsuites/mptests/mp11node2.yml
index 38ea46e..0000000
--- a/spec/build/testsuites/mptests/mp11node2.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp11/init2.c
-stlib: []
-target: testsuites/mptests/mp11_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp12_node1.yml b/spec/build/testsuites/mptests/mp12_node1.yml
index 0000000..1b5e58c
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp12_node1.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp12/init1.c
+stlib: []
+target: testsuites/mptests/mp12_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp12_node2.yml b/spec/build/testsuites/mptests/mp12_node2.yml
index 0000000..d2bcd18
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp12_node2.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp12/init2.c
+stlib: []
+target: testsuites/mptests/mp12_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp12node1.yml b/spec/build/testsuites/mptests/mp12node1.yml
index 1b5e58c..0000000
--- a/spec/build/testsuites/mptests/mp12node1.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-build-type: test-program
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-features: c cprogram
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp12/init1.c
-stlib: []
-target: testsuites/mptests/mp12_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp12node2.yml b/spec/build/testsuites/mptests/mp12node2.yml
index d2bcd18..0000000
--- a/spec/build/testsuites/mptests/mp12node2.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp12/init2.c
-stlib: []
-target: testsuites/mptests/mp12_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp13_node1.yml b/spec/build/testsuites/mptests/mp13_node1.yml
index 0000000..5a9a2df
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp13_node1.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp13/init1.c
+- testsuites/mptests/mp13/task1.c
+- testsuites/mptests/mp13/task2.c
+stlib: []
+target: testsuites/mptests/mp13_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp13_node2.yml b/spec/build/testsuites/mptests/mp13_node2.yml
index 0000000..8e1eda3
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp13_node2.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp13/init2.c
+stlib: []
+target: testsuites/mptests/mp13_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp13node1.yml b/spec/build/testsuites/mptests/mp13node1.yml
index 5a9a2df..0000000
--- a/spec/build/testsuites/mptests/mp13node1.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp13/init1.c
-- testsuites/mptests/mp13/task1.c
-- testsuites/mptests/mp13/task2.c
-stlib: []
-target: testsuites/mptests/mp13_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp13node2.yml b/spec/build/testsuites/mptests/mp13node2.yml
index 8e1eda3..0000000
--- a/spec/build/testsuites/mptests/mp13node2.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp13/init2.c
-stlib: []
-target: testsuites/mptests/mp13_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp14_node1.yml b/spec/build/testsuites/mptests/mp14_node1.yml
index 0000000..031c234
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp14_node1.yml
@@ -0,0 +1,27 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp14/init1.c
+- testsuites/mptests/mp14/exit.c
+- testsuites/mptests/mp14/delay.c
+- testsuites/mptests/mp14/evtask1.c
+- testsuites/mptests/mp14/evtmtask.c
+- testsuites/mptests/mp14/pttask1.c
+- testsuites/mptests/mp14/smtask1.c
+- testsuites/mptests/mp14/msgtask1.c
+stlib: []
+target: testsuites/mptests/mp14_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp14_node2.yml b/spec/build/testsuites/mptests/mp14_node2.yml
index 0000000..524e1c7
--- /dev/null
+++ b/spec/build/testsuites/mptests/mp14_node2.yml
@@ -0,0 +1,27 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/mptests/mp14/init2.c
+stlib: []
+target: testsuites/mptests/mp14_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/mptests/mp14node1.yml b/spec/build/testsuites/mptests/mp14node1.yml
index d391ca7..0000000
--- a/spec/build/testsuites/mptests/mp14node1.yml
+++ /dev/null
@@ -1,27 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp14/delay.c
-- testsuites/mptests/mp14/evtask1.c
-- testsuites/mptests/mp14/evtmtask.c
-- testsuites/mptests/mp14/exit.c
-- testsuites/mptests/mp14/init1.c
-- testsuites/mptests/mp14/msgtask1.c
-- testsuites/mptests/mp14/pttask1.c
-- testsuites/mptests/mp14/smtask1.c
-stlib: []
-target: testsuites/mptests/mp14_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/mptests/mp14node2.yml b/spec/build/testsuites/mptests/mp14node2.yml
index 63c12c9..0000000
--- a/spec/build/testsuites/mptests/mp14node2.yml
+++ /dev/null
@@ -1,27 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/mptests/mp14/init2.c
-stlib: []
-target: testsuites/mptests/mp14_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index fb7ce46..a8de2f0 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -92,7 +92,7 @@ links:
 - role: build-dependency
   uid: psxdevctl01
-  uid: psxeintrjoin
+  uid: psxeintr_join
   uid: psxenosys
diff --git a/spec/build/testsuites/psxtests/psxeintr_join.yml b/spec/build/testsuites/psxtests/psxeintr_join.yml
index 0000000..c6236f8
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxeintr_join.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_POSIX_API
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxeintr_join/init.c
+stlib: []
+target: testsuites/psxtests/psxeintr_join.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/psxtests/psxeintrjoin.yml b/spec/build/testsuites/psxtests/psxeintrjoin.yml
index c6236f8..0000000
--- a/spec/build/testsuites/psxtests/psxeintrjoin.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-- RTEMS_POSIX_API
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/psxtests/psxeintr_join/init.c
-stlib: []
-target: testsuites/psxtests/psxeintr_join.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/psxtests/psxfatal_support.yml b/spec/build/testsuites/psxtests/psxfatal_support.yml
index 0000000..4b1ef10
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxfatal_support.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxfatal_support/init.c
+stlib: []
+target: testsuites/psxtests/psxfatal_support.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/psxtests/psxfatalsupport.yml b/spec/build/testsuites/psxtests/psxfatalsupport.yml
index 4b1ef10..0000000
--- a/spec/build/testsuites/psxtests/psxfatalsupport.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/psxtests/psxfatal_support/init.c
-stlib: []
-target: testsuites/psxtests/psxfatal_support.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/samples/base_mp_node1.yml b/spec/build/testsuites/samples/base_mp_node1.yml
index 0000000..e4da6b6
--- /dev/null
+++ b/spec/build/testsuites/samples/base_mp_node1.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/samples/base_mp/init1.c
+- testsuites/samples/base_mp/apptask.c
+stlib: []
+target: testsuites/samples/base_mp_node1.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/samples/base_mp_node2.yml b/spec/build/testsuites/samples/base_mp_node2.yml
index 0000000..6a83bc6
--- /dev/null
+++ b/spec/build/testsuites/samples/base_mp_node2.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/samples/base_mp/init2.c
+stlib: []
+target: testsuites/samples/base_mp_node2.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/samples/base_sp.yml b/spec/build/testsuites/samples/base_sp.yml
index 0000000..8431be7
--- /dev/null
+++ b/spec/build/testsuites/samples/base_sp.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/samples/base_sp/init.c
+- testsuites/samples/base_sp/apptask.c
+stlib: []
+target: testsuites/samples/base_sp.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/samples/basempnode1.yml b/spec/build/testsuites/samples/basempnode1.yml
deleted file mode 100644
index 5e5cbc8..0000000
--- a/spec/build/testsuites/samples/basempnode1.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-cflags: []
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/samples/base_mp/apptask.c
-- testsuites/samples/base_mp/init1.c
-stlib: []
-target: testsuites/samples/base_mp_node1.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/samples/basempnode2.yml b/spec/build/testsuites/samples/basempnode2.yml
index d62e68e..0000000
--- a/spec/build/testsuites/samples/basempnode2.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by:
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/samples/base_mp/init2.c
-stlib: []
-target: testsuites/samples/base_mp_node2.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/samples/basesp.yml b/spec/build/testsuites/samples/basesp.yml
index d357e7c..0000000
--- a/spec/build/testsuites/samples/basesp.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/samples/base_sp/apptask.c
-- testsuites/samples/base_sp/init.c
-stlib: []
-target: testsuites/samples/base_sp.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/samples/grp.yml b/spec/build/testsuites/samples/grp.yml
index c7591dc..cfc2da9 100644
--- a/spec/build/testsuites/samples/grp.yml
+++ b/spec/build/testsuites/samples/grp.yml
@@ -13,11 +13,11 @@ ldflags:
 - -Wl,--wrap=puts
 links:
-  uid: basempnode1
+  uid: base_mp_node1
-  uid: basempnode2
+  uid: base_mp_node2
-  uid: basesp
+  uid: base_sp
   uid: capture
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index 3ceddfa..758db1a 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -173,11 +173,11 @@ links:
   uid: spchain
-  uid: spclockerr01
+  uid: spclock_err01
-  uid: spclockerr02
+  uid: spclock_err02
-  uid: spclocktodhook01
+  uid: spclock_todhook01
   uid: spconfig01
@@ -209,7 +209,7 @@ links:
   uid: sperror03
-  uid: speventerr03
+  uid: spevent_err03
   uid: speventsystem01
@@ -319,7 +319,7 @@ links:
   uid: spintrcritical24
-  uid: spintrerr01
+  uid: spintr_err01
   uid: splinkersets01
@@ -331,9 +331,9 @@ links:
   uid: spmrsp01
-  uid: spmsgqerr01
+  uid: spmsgq_err01
-  uid: spmsgqerr02
+  uid: spmsgq_err02
   uid: spmutex01
@@ -343,11 +343,11 @@ links:
   uid: sppagesize
-  uid: sppartitionerr01
+  uid: sppartition_err01
   uid: sppercpudata01
-  uid: spporterr01
+  uid: spport_err01
   uid: spprintk
@@ -357,11 +357,11 @@ links:
   uid: spqreslib
-  uid: spratemonerr01
+  uid: spratemon_err01
   uid: sprbtree01
-  uid: spregionerr01
+  uid: spregion_err01
   uid: sprmsched01
@@ -375,11 +375,11 @@ links:
   uid: spsem03
-  uid: spsemerr01
+  uid: spsem_err01
-  uid: spsemerr02
+  uid: spsem_err02
-  uid: spsignalerr01
+  uid: spsignal_err01
   uid: spsimplesched01
@@ -399,13 +399,13 @@ links:
   uid: spsyslock01
-  uid: sptaskerr01
+  uid: sptask_err01
-  uid: sptaskerr02
+  uid: sptask_err02
-  uid: sptaskerr03
+  uid: sptask_err03
-  uid: sptaskerr04
+  uid: sptask_err04
   uid: sptasknopreempt01
@@ -423,9 +423,9 @@ links:
   uid: sptimecounter04
-  uid: sptimererr01
+  uid: sptimer_err01
-  uid: sptimererr02
+  uid: sptimer_err02
   uid: sptimerserver01
diff --git a/spec/build/testsuites/sptests/spclock_err01.yml b/spec/build/testsuites/sptests/spclock_err01.yml
index 0000000..b522d6e
--- /dev/null
+++ b/spec/build/testsuites/sptests/spclock_err01.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spclock_err01/delay.c
+- testsuites/sptests/spclock_err01/init.c
+stlib: []
+target: testsuites/sptests/spclock_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spclock_err02.yml b/spec/build/testsuites/sptests/spclock_err02.yml
index 0000000..a730c07
--- /dev/null
+++ b/spec/build/testsuites/sptests/spclock_err02.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spclock_err02/init.c
+stlib: []
+target: testsuites/sptests/spclock_err02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spclock_todhook01.yml b/spec/build/testsuites/sptests/spclock_todhook01.yml
index 0000000..1b09b23
--- /dev/null
+++ b/spec/build/testsuites/sptests/spclock_todhook01.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spclock_todhook01/init.c
+stlib: []
+target: testsuites/sptests/spclock_todhook01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spclockerr01.yml b/spec/build/testsuites/sptests/spclockerr01.yml
index b522d6e..0000000
--- a/spec/build/testsuites/sptests/spclockerr01.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spclock_err01/delay.c
-- testsuites/sptests/spclock_err01/init.c
-stlib: []
-target: testsuites/sptests/spclock_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spclockerr02.yml b/spec/build/testsuites/sptests/spclockerr02.yml
index a730c07..0000000
--- a/spec/build/testsuites/sptests/spclockerr02.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spclock_err02/init.c
-stlib: []
-target: testsuites/sptests/spclock_err02.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spclocktodhook01.yml b/spec/build/testsuites/sptests/spclocktodhook01.yml
index 1b09b23..0000000
--- a/spec/build/testsuites/sptests/spclocktodhook01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spclock_todhook01/init.c
-stlib: []
-target: testsuites/sptests/spclock_todhook01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spevent_err03.yml b/spec/build/testsuites/sptests/spevent_err03.yml
index 0000000..541d533
--- /dev/null
+++ b/spec/build/testsuites/sptests/spevent_err03.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spevent_err03/init.c
+stlib: []
+target: testsuites/sptests/spevent_err03.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/speventerr03.yml b/spec/build/testsuites/sptests/speventerr03.yml
index 541d533..0000000
--- a/spec/build/testsuites/sptests/speventerr03.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spevent_err03/init.c
-stlib: []
-target: testsuites/sptests/spevent_err03.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spfatal_support.yml b/spec/build/testsuites/sptests/spfatal_support.yml
index 0000000..89a3de3
--- /dev/null
+++ b/spec/build/testsuites/sptests/spfatal_support.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spfatal_support/init.c
+stlib: []
+target: testsuites/sptests/spfatal_support.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spfatalsupport.yml b/spec/build/testsuites/sptests/spfatalsupport.yml
index 89a3de3..0000000
--- a/spec/build/testsuites/sptests/spfatalsupport.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spfatal_support/init.c
-stlib: []
-target: testsuites/sptests/spfatal_support.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spintr_err01.yml b/spec/build/testsuites/sptests/spintr_err01.yml
index 0000000..1b26e2d
--- /dev/null
+++ b/spec/build/testsuites/sptests/spintr_err01.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spintr_err01/init.c
+- testsuites/sptests/spintr_err01/isr.c
+stlib: []
+target: testsuites/sptests/spintr_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spintrerr01.yml b/spec/build/testsuites/sptests/spintrerr01.yml
index 1b26e2d..0000000
--- a/spec/build/testsuites/sptests/spintrerr01.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spintr_err01/init.c
-- testsuites/sptests/spintr_err01/isr.c
-stlib: []
-target: testsuites/sptests/spintr_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spmsgq_err01.yml b/spec/build/testsuites/sptests/spmsgq_err01.yml
index 0000000..3359402
--- /dev/null
+++ b/spec/build/testsuites/sptests/spmsgq_err01.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spmsgq_err01/init.c
+stlib: []
+target: testsuites/sptests/spmsgq_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spmsgq_err02.yml b/spec/build/testsuites/sptests/spmsgq_err02.yml
index 0000000..81f6546
--- /dev/null
+++ b/spec/build/testsuites/sptests/spmsgq_err02.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spmsgq_err02/init.c
+- testsuites/sptests/spmsgq_err02/task3.c
+stlib: []
+target: testsuites/sptests/spmsgq_err02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spmsgqerr01.yml b/spec/build/testsuites/sptests/spmsgqerr01.yml
index 3359402..0000000
--- a/spec/build/testsuites/sptests/spmsgqerr01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spmsgq_err01/init.c
-stlib: []
-target: testsuites/sptests/spmsgq_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spmsgqerr02.yml b/spec/build/testsuites/sptests/spmsgqerr02.yml
index 81f6546..0000000
--- a/spec/build/testsuites/sptests/spmsgqerr02.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spmsgq_err02/init.c
-- testsuites/sptests/spmsgq_err02/task3.c
-stlib: []
-target: testsuites/sptests/spmsgq_err02.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/sppartition_err01.yml b/spec/build/testsuites/sptests/sppartition_err01.yml
index 0000000..8e6479a
--- /dev/null
+++ b/spec/build/testsuites/sptests/sppartition_err01.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sppartition_err01/init.c
+stlib: []
+target: testsuites/sptests/sppartition_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/sppartitionerr01.yml b/spec/build/testsuites/sptests/sppartitionerr01.yml
index 8e6479a..0000000
--- a/spec/build/testsuites/sptests/sppartitionerr01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/sppartition_err01/init.c
-stlib: []
-target: testsuites/sptests/sppartition_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spport_err01.yml b/spec/build/testsuites/sptests/spport_err01.yml
index 0000000..e111cd6
--- /dev/null
+++ b/spec/build/testsuites/sptests/spport_err01.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spport_err01/init.c
+stlib: []
+target: testsuites/sptests/spport_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spporterr01.yml b/spec/build/testsuites/sptests/spporterr01.yml
index e111cd6..0000000
--- a/spec/build/testsuites/sptests/spporterr01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spport_err01/init.c
-stlib: []
-target: testsuites/sptests/spport_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spratemon_err01.yml b/spec/build/testsuites/sptests/spratemon_err01.yml
index 0000000..db46968
--- /dev/null
+++ b/spec/build/testsuites/sptests/spratemon_err01.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spratemon_err01/init.c
+- testsuites/sptests/spratemon_err01/screen10.c
+- testsuites/sptests/spratemon_err01/task4.c
+stlib: []
+target: testsuites/sptests/spratemon_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spratemonerr01.yml b/spec/build/testsuites/sptests/spratemonerr01.yml
index db46968..0000000
--- a/spec/build/testsuites/sptests/spratemonerr01.yml
+++ /dev/null
@@ -1,21 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spratemon_err01/init.c
-- testsuites/sptests/spratemon_err01/screen10.c
-- testsuites/sptests/spratemon_err01/task4.c
-stlib: []
-target: testsuites/sptests/spratemon_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spregion_err01.yml b/spec/build/testsuites/sptests/spregion_err01.yml
index 0000000..84859c6
--- /dev/null
+++ b/spec/build/testsuites/sptests/spregion_err01.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spregion_err01/init.c
+stlib: []
+target: testsuites/sptests/spregion_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spregionerr01.yml b/spec/build/testsuites/sptests/spregionerr01.yml
index 84859c6..0000000
--- a/spec/build/testsuites/sptests/spregionerr01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spregion_err01/init.c
-stlib: []
-target: testsuites/sptests/spregion_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spsem_err01.yml b/spec/build/testsuites/sptests/spsem_err01.yml
index 0000000..cd1f6d9
--- /dev/null
+++ b/spec/build/testsuites/sptests/spsem_err01.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spsem_err01/init.c
+stlib: []
+target: testsuites/sptests/spsem_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spsem_err02.yml b/spec/build/testsuites/sptests/spsem_err02.yml
index 0000000..e0c6a94
--- /dev/null
+++ b/spec/build/testsuites/sptests/spsem_err02.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spsem_err02/init.c
+- testsuites/sptests/spsem_err02/task2.c
+stlib: []
+target: testsuites/sptests/spsem_err02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spsemerr01.yml b/spec/build/testsuites/sptests/spsemerr01.yml
index cd1f6d9..0000000
--- a/spec/build/testsuites/sptests/spsemerr01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spsem_err01/init.c
-stlib: []
-target: testsuites/sptests/spsem_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spsemerr02.yml b/spec/build/testsuites/sptests/spsemerr02.yml
index e0c6a94..0000000
--- a/spec/build/testsuites/sptests/spsemerr02.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spsem_err02/init.c
-- testsuites/sptests/spsem_err02/task2.c
-stlib: []
-target: testsuites/sptests/spsem_err02.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spsignal_err01.yml b/spec/build/testsuites/sptests/spsignal_err01.yml
index 0000000..6d8788d
--- /dev/null
+++ b/spec/build/testsuites/sptests/spsignal_err01.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spsignal_err01/init.c
+- testsuites/sptests/spsignal_err01/isr.c
+stlib: []
+target: testsuites/sptests/spsignal_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/spsignalerr01.yml b/spec/build/testsuites/sptests/spsignalerr01.yml
index 6d8788d..0000000
--- a/spec/build/testsuites/sptests/spsignalerr01.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spsignal_err01/init.c
-- testsuites/sptests/spsignal_err01/isr.c
-stlib: []
-target: testsuites/sptests/spsignal_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/sptask_err01.yml b/spec/build/testsuites/sptests/sptask_err01.yml
index 0000000..5b0ec72
--- /dev/null
+++ b/spec/build/testsuites/sptests/sptask_err01.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sptask_err01/init.c
+- testsuites/sptests/sptask_err01/task2.c
+stlib: []
+target: testsuites/sptests/sptask_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/sptask_err02.yml b/spec/build/testsuites/sptests/sptask_err02.yml
index 0000000..dd265b7
--- /dev/null
+++ b/spec/build/testsuites/sptests/sptask_err02.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sptask_err02/init.c
+stlib: []
+target: testsuites/sptests/sptask_err02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/sptask_err03.yml b/spec/build/testsuites/sptests/sptask_err03.yml
index 0000000..48786b3
--- /dev/null
+++ b/spec/build/testsuites/sptests/sptask_err03.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sptask_err03/init.c
+stlib: []
+target: testsuites/sptests/sptask_err03.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/sptask_err04.yml b/spec/build/testsuites/sptests/sptask_err04.yml
index 0000000..82ff215
--- /dev/null
+++ b/spec/build/testsuites/sptests/sptask_err04.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sptask_err04/init.c
+- testsuites/sptests/sptask_err04/task1.c
+stlib: []
+target: testsuites/sptests/sptask_err04.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/sptaskerr01.yml b/spec/build/testsuites/sptests/sptaskerr01.yml
index 5b0ec72..0000000
--- a/spec/build/testsuites/sptests/sptaskerr01.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/sptask_err01/init.c
-- testsuites/sptests/sptask_err01/task2.c
-stlib: []
-target: testsuites/sptests/sptask_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/sptaskerr02.yml b/spec/build/testsuites/sptests/sptaskerr02.yml
index dd265b7..0000000
--- a/spec/build/testsuites/sptests/sptaskerr02.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/sptask_err02/init.c
-stlib: []
-target: testsuites/sptests/sptask_err02.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/sptaskerr03.yml b/spec/build/testsuites/sptests/sptaskerr03.yml
index 48786b3..0000000
--- a/spec/build/testsuites/sptests/sptaskerr03.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/sptask_err03/init.c
-stlib: []
-target: testsuites/sptests/sptask_err03.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/sptaskerr04.yml b/spec/build/testsuites/sptests/sptaskerr04.yml
index 82ff215..0000000
--- a/spec/build/testsuites/sptests/sptaskerr04.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/sptask_err04/init.c
-- testsuites/sptests/sptask_err04/task1.c
-stlib: []
-target: testsuites/sptests/sptask_err04.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/sptimer_err01.yml b/spec/build/testsuites/sptests/sptimer_err01.yml
index 0000000..58e5f08
--- /dev/null
+++ b/spec/build/testsuites/sptests/sptimer_err01.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sptimer_err01/init.c
+stlib: []
+target: testsuites/sptests/sptimer_err01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/sptimer_err02.yml b/spec/build/testsuites/sptests/sptimer_err02.yml
index 0000000..600c42b
--- /dev/null
+++ b/spec/build/testsuites/sptests/sptimer_err02.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sptimer_err02/init.c
+stlib: []
+target: testsuites/sptests/sptimer_err02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/sptests/sptimererr01.yml b/spec/build/testsuites/sptests/sptimererr01.yml
index 58e5f08..0000000
--- a/spec/build/testsuites/sptests/sptimererr01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/sptimer_err01/init.c
-stlib: []
-target: testsuites/sptests/sptimer_err01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/sptimererr02.yml b/spec/build/testsuites/sptests/sptimererr02.yml
index 600c42b..0000000
--- a/spec/build/testsuites/sptests/sptimererr02.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/sptimer_err02/init.c
-stlib: []
-target: testsuites/sptests/sptimer_err02.exe
-type: build
-use-after: []
-use-before: []
1.8.3.1
