[PATCH 0/3] Renamed tests, test fix, additions to YAML files
Thu Mar 18 20:49:26 UTC 2021
I don't see 1/3 in my email, anyone else?
On Thu, Mar 18, 2021 at 2:27 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Hi,
> These patches are pretty diverse. They are all from the work we've been
> doing for AArch64.
> Patch 1:
> For this, if a test's YAML file's executable field differed from the
> name of the file, it was renamed to the name specified in the executable
> field. After this, I had to change any references to the previous file
> names.
> Patch 2:
> This patch fixed an issue that prevented ts-validation-0 from
> building/running. All I had to do was change the data type of
> maximum_pending_messages from uint32_t to size_t.
> Patch 3:
> I just expanded upon what the comments were saying, and I added more
> tests that we had seen to intermittently fail.
> Thanks,
> Ryan
> Ryan Long (3):
>   bsps: Renamed YAML files to match test names
>   Changed variable type to fix AARCH64 test issues
>   bsps/aarch64: changed comments and test statuses
>  cpukit/include/rtems/rtems/message.h               |   2 +-
>  cpukit/include/rtems/score/coremsgimpl.h           |   2 +-
>  cpukit/score/src/coremsg.c                         |   2 +-
>  spec/build/bsps/aarch64/a53/tsta53.yml             |  39 ++++-
>  spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml  |  39 ++++-
>  spec/build/bsps/arm/atsam/tstatsamv.yml            |  18 +--
>  spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml       |   4 +-
>  spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml        |   2 +-
>  .../bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml   |  76 +++++-----
>  spec/build/bsps/arm/lpc24xx/tstlpc2362.yml         |  10 +-
>  spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml   |  12 +-
>  spec/build/bsps/tstnoiconv.yml                     |   4 +-
>  spec/build/bsps/tstnojffs2.yml                     |  16 +-
>  spec/build/bsps/tstnorfs.yml                       |  20 +--
>  spec/build/testsuites/ada/ada_base_sp.yml          |  23 +++
>  spec/build/testsuites/ada/ada_hello.yml            |  23 +++
>  spec/build/testsuites/ada/ada_mp01_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp01_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp03_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp03_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp04_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp04_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp05_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp05_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp06_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp06_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp07_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp07_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp08_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp08_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp09_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp09_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp10_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp10_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp11_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp11_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp12_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp12_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp13_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp13_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp14_node1.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_mp14_node2.yml       |  25 ++++
>  spec/build/testsuites/ada/ada_nsecs.yml            |  23 +++
>  spec/build/testsuites/ada/ada_sp01.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp02.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp03.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp04.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp05.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp06.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp07.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp08.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp09.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp11.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp12.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp13.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp14.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp15.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp16.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp17.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp19.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp20.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp22.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp23.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp24.yml             |  23 +++
>  spec/build/testsuites/ada/ada_sp25.yml             |  23 +++
>  spec/build/testsuites/ada/ada_spatcb01.yml         |  24 +++
>  spec/build/testsuites/ada/ada_spname01.yml         |  24 +++
>  spec/build/testsuites/ada/ada_ticker.yml           |  23 +++
>  spec/build/testsuites/ada/ada_tm01.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm02.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm03.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm04.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm05.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm06.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm07.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm08.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm09.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm10.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm11.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm12.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm13.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm14.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm15.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm16.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm17.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm18.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm19.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm20.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm21.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm22.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm23.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm24.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm25.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm28.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tm29.yml             |  23 +++
>  spec/build/testsuites/ada/ada_tmck.yml             |  23 +++
>  spec/build/testsuites/ada/adabasesp.yml            |  23 ---
>  spec/build/testsuites/ada/adahello.yml             |  23 ---
>  spec/build/testsuites/ada/adamp01node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp01node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp03node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp03node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp04node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp04node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp05node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp05node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp06node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp06node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp07node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp07node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp08node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp08node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp09node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp09node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp10node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp10node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp11node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp11node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp12node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp12node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp13node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp13node2.yml         |  25 ----
>  spec/build/testsuites/ada/adamp14node1.yml         |  25 ----
>  spec/build/testsuites/ada/adamp14node2.yml         |  25 ----
>  spec/build/testsuites/ada/adansecs.yml             |  23 ---
>  spec/build/testsuites/ada/adasp01.yml              |  23 ---
>  spec/build/testsuites/ada/adasp02.yml              |  23 ---
>  spec/build/testsuites/ada/adasp03.yml              |  23 ---
>  spec/build/testsuites/ada/adasp04.yml              |  23 ---
>  spec/build/testsuites/ada/adasp05.yml              |  23 ---
>  spec/build/testsuites/ada/adasp06.yml              |  23 ---
>  spec/build/testsuites/ada/adasp07.yml              |  23 ---
>  spec/build/testsuites/ada/adasp08.yml              |  23 ---
>  spec/build/testsuites/ada/adasp09.yml              |  23 ---
>  spec/build/testsuites/ada/adasp11.yml              |  23 ---
>  spec/build/testsuites/ada/adasp12.yml              |  23 ---
>  spec/build/testsuites/ada/adasp13.yml              |  23 ---
>  spec/build/testsuites/ada/adasp14.yml              |  23 ---
>  spec/build/testsuites/ada/adasp15.yml              |  23 ---
>  spec/build/testsuites/ada/adasp16.yml              |  23 ---
>  spec/build/testsuites/ada/adasp17.yml              |  23 ---
>  spec/build/testsuites/ada/adasp19.yml              |  23 ---
>  spec/build/testsuites/ada/adasp20.yml              |  23 ---
>  spec/build/testsuites/ada/adasp22.yml              |  23 ---
>  spec/build/testsuites/ada/adasp23.yml              |  23 ---
>  spec/build/testsuites/ada/adasp24.yml              |  23 ---
>  spec/build/testsuites/ada/adasp25.yml              |  23 ---
>  spec/build/testsuites/ada/adaspatcb01.yml          |  24 ---
>  spec/build/testsuites/ada/adaspname01.yml          |  24 ---
>  spec/build/testsuites/ada/adaticker.yml            |  23 ---
>  spec/build/testsuites/ada/adatm01.yml              |  23 ---
>  spec/build/testsuites/ada/adatm02.yml              |  23 ---
>  spec/build/testsuites/ada/adatm03.yml              |  23 ---
>  spec/build/testsuites/ada/adatm04.yml              |  23 ---
>  spec/build/testsuites/ada/adatm05.yml              |  23 ---
>  spec/build/testsuites/ada/adatm06.yml              |  23 ---
>  spec/build/testsuites/ada/adatm07.yml              |  23 ---
>  spec/build/testsuites/ada/adatm08.yml              |  23 ---
>  spec/build/testsuites/ada/adatm09.yml              |  23 ---
>  spec/build/testsuites/ada/adatm10.yml              |  23 ---
>  spec/build/testsuites/ada/adatm11.yml              |  23 ---
>  spec/build/testsuites/ada/adatm12.yml              |  23 ---
>  spec/build/testsuites/ada/adatm13.yml              |  23 ---
>  spec/build/testsuites/ada/adatm14.yml              |  23 ---
>  spec/build/testsuites/ada/adatm15.yml              |  23 ---
>  spec/build/testsuites/ada/adatm16.yml              |  23 ---
>  spec/build/testsuites/ada/adatm17.yml              |  23 ---
>  spec/build/testsuites/ada/adatm18.yml              |  23 ---
>  spec/build/testsuites/ada/adatm19.yml              |  23 ---
>  spec/build/testsuites/ada/adatm20.yml              |  23 ---
>  spec/build/testsuites/ada/adatm21.yml              |  23 ---
>  spec/build/testsuites/ada/adatm22.yml              |  23 ---
>  spec/build/testsuites/ada/adatm23.yml              |  23 ---
>  spec/build/testsuites/ada/adatm24.yml              |  23 ---
>  spec/build/testsuites/ada/adatm25.yml              |  23 ---
>  spec/build/testsuites/ada/adatm28.yml              |  23 ---
>  spec/build/testsuites/ada/adatm29.yml              |  23 ---
>  spec/build/testsuites/ada/adatmck.yml              |  23 ---
>  spec/build/testsuites/ada/grp.yml                  | 164 ++++++++++-----------
>  spec/build/testsuites/fstests/grp.yml              |  82 +++++------
>  spec/build/testsuites/fstests/imfs_fserror.yml     |  21 +++
>  spec/build/testsuites/fstests/imfs_fslink.yml      |  21 +++
>  spec/build/testsuites/fstests/imfs_fspatheval.yml  |  21 +++
>  .../build/testsuites/fstests/imfs_fspermission.yml |  21 +++
>  spec/build/testsuites/fstests/imfs_fsrdwr.yml      |  21 +++
>  spec/build/testsuites/fstests/imfs_fsscandir01.yml |  21 +++
>  spec/build/testsuites/fstests/imfs_fssymlink.yml   |  21 +++
>  spec/build/testsuites/fstests/imfs_fstime.yml      |  21 +++
>  spec/build/testsuites/fstests/imfsfserror.yml      |  21 ---
>  spec/build/testsuites/fstests/imfsfslink.yml       |  21 ---
>  spec/build/testsuites/fstests/imfsfspatheval.yml   |  21 ---
>  spec/build/testsuites/fstests/imfsfspermission.yml |  21 ---
>  spec/build/testsuites/fstests/imfsfsrdwr.yml       |  21 ---
>  spec/build/testsuites/fstests/imfsfsscandir01.yml  |  21 ---
>  spec/build/testsuites/fstests/imfsfssymlink.yml    |  21 ---
>  spec/build/testsuites/fstests/imfsfstime.yml       |  21 ---
>  spec/build/testsuites/fstests/jffs2_fserror.yml    |  22 +++
>  spec/build/testsuites/fstests/jffs2_fslink.yml     |  22 +++
>  spec/build/testsuites/fstests/jffs2_fspatheval.yml |  22 +++
>  .../testsuites/fstests/jffs2_fspermission.yml      |  22 +++
>  spec/build/testsuites/fstests/jffs2_fsrdwr.yml     |  22 +++
>  .../build/testsuites/fstests/jffs2_fsscandir01.yml |  22 +++
>  spec/build/testsuites/fstests/jffs2_fssymlink.yml  |  22 +++
>  spec/build/testsuites/fstests/jffs2_fstime.yml     |  22 +++
>  spec/build/testsuites/fstests/jffs2fserror.yml     |  22 ---
>  spec/build/testsuites/fstests/jffs2fslink.yml      |  22 ---
>  spec/build/testsuites/fstests/jffs2fspatheval.yml  |  22 ---
>  .../build/testsuites/fstests/jffs2fspermission.yml |  22 ---
>  spec/build/testsuites/fstests/jffs2fsrdwr.yml      |  22 ---
>  spec/build/testsuites/fstests/jffs2fsscandir01.yml |  22 ---
>  spec/build/testsuites/fstests/jffs2fssymlink.yml   |  22 ---
>  spec/build/testsuites/fstests/jffs2fstime.yml      |  22 ---
>  spec/build/testsuites/fstests/mdosfs_fserror.yml   |  21 +++
>  .../build/testsuites/fstests/mdosfs_fspatheval.yml |  21 +++
>  spec/build/testsuites/fstests/mdosfs_fsrdwr.yml    |  21 +++
>  .../testsuites/fstests/mdosfs_fsscandir01.yml      |  21 +++
>  spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml |  21 +++
>  spec/build/testsuites/fstests/mdosfs_fstime.yml    |  21 +++
>  spec/build/testsuites/fstests/mdosfsfserror.yml    |  21 ---
>  spec/build/testsuites/fstests/mdosfsfspatheval.yml |  21 ---
>  spec/build/testsuites/fstests/mdosfsfsrdwr.yml     |  21 ---
>  .../build/testsuites/fstests/mdosfsfsscandir01.yml |  21 ---
>  spec/build/testsuites/fstests/mdosfsfsstatvfs.yml  |  21 ---
>  spec/build/testsuites/fstests/mdosfsfstime.yml     |  21 ---
>  spec/build/testsuites/fstests/mimfs_fserror.yml    |  21 +++
>  spec/build/testsuites/fstests/mimfs_fslink.yml     |  21 +++
>  spec/build/testsuites/fstests/mimfs_fspatheval.yml |  21 +++
>  .../testsuites/fstests/mimfs_fspermission.yml      |  21 +++
>  spec/build/testsuites/fstests/mimfs_fsrdwr.yml     |  21 +++
>  spec/build/testsuites/fstests/mimfs_fsrename.yml   |  21 +++
>  .../build/testsuites/fstests/mimfs_fsscandir01.yml |  21 +++
>  spec/build/testsuites/fstests/mimfs_fssymlink.yml  |  21 +++
>  spec/build/testsuites/fstests/mimfs_fstime.yml     |  21 +++
>  spec/build/testsuites/fstests/mimfsfserror.yml     |  21 ---
>  spec/build/testsuites/fstests/mimfsfslink.yml      |  21 ---
>  spec/build/testsuites/fstests/mimfsfspatheval.yml  |  21 ---
>  .../build/testsuites/fstests/mimfsfspermission.yml |  21 ---
>  spec/build/testsuites/fstests/mimfsfsrdwr.yml      |  21 ---
>  spec/build/testsuites/fstests/mimfsfsrename.yml    |  21 ---
>  spec/build/testsuites/fstests/mimfsfsscandir01.yml |  21 ---
>  spec/build/testsuites/fstests/mimfsfssymlink.yml   |  21 ---
>  spec/build/testsuites/fstests/mimfsfstime.yml      |  21 ---
>  spec/build/testsuites/fstests/mrfs_fserror.yml     |  21 +++
>  spec/build/testsuites/fstests/mrfs_fsfpathconf.yml |  21 +++
>  spec/build/testsuites/fstests/mrfs_fslink.yml      |  21 +++
>  spec/build/testsuites/fstests/mrfs_fspatheval.yml  |  21 +++
>  .../build/testsuites/fstests/mrfs_fspermission.yml |  21 +++
>  spec/build/testsuites/fstests/mrfs_fsrdwr.yml      |  21 +++
>  spec/build/testsuites/fstests/mrfs_fsrename.yml    |  21 +++
>  spec/build/testsuites/fstests/mrfs_fsscandir01.yml |  21 +++
>  spec/build/testsuites/fstests/mrfs_fssymlink.yml   |  21 +++
>  spec/build/testsuites/fstests/mrfs_fstime.yml      |  21 +++
>  spec/build/testsuites/fstests/mrfsfserror.yml      |  21 ---
>  spec/build/testsuites/fstests/mrfsfsfpathconf.yml  |  21 ---
>  spec/build/testsuites/fstests/mrfsfslink.yml       |  21 ---
>  spec/build/testsuites/fstests/mrfsfspatheval.yml   |  21 ---
>  spec/build/testsuites/fstests/mrfsfspermission.yml |  21 ---
>  spec/build/testsuites/fstests/mrfsfsrdwr.yml       |  21 ---
>  spec/build/testsuites/fstests/mrfsfsrename.yml     |  21 ---
>  spec/build/testsuites/fstests/mrfsfsscandir01.yml  |  21 ---
>  spec/build/testsuites/fstests/mrfsfssymlink.yml    |  21 ---
>  spec/build/testsuites/fstests/mrfsfstime.yml       |  21 ---
>  spec/build/testsuites/libtests/clock_gettime.yml   |  20 +++
>  spec/build/testsuites/libtests/clockgettime.yml    |  20 ---
>  spec/build/testsuites/libtests/grp.yml             |   8 +-
>  spec/build/testsuites/libtests/iconv_close.yml     |  20 +++
>  spec/build/testsuites/libtests/iconv_open.yml      |  20 +++
>  spec/build/testsuites/libtests/iconvclose.yml      |  20 ---
>  spec/build/testsuites/libtests/iconvopen.yml       |  20 ---
>  spec/build/testsuites/libtests/posix_memalign.yml  |  20 +++
>  spec/build/testsuites/libtests/posixmemalign.yml   |  20 ---
>  spec/build/testsuites/mptests/grp.yml              |  52 +++----
>  spec/build/testsuites/mptests/mp01_node1.yml       |  21 +++
>  spec/build/testsuites/mptests/mp01_node2.yml       |  21 +++
>  spec/build/testsuites/mptests/mp01node1.yml        |  21 ---
>  spec/build/testsuites/mptests/mp01node2.yml        |  21 ---
>  spec/build/testsuites/mptests/mp03_node1.yml       |  22 +++
>  spec/build/testsuites/mptests/mp03_node2.yml       |  22 +++
>  spec/build/testsuites/mptests/mp03node1.yml        |  22 ---
>  spec/build/testsuites/mptests/mp03node2.yml        |  22 ---
>  spec/build/testsuites/mptests/mp04_node1.yml       |  21 +++
>  spec/build/testsuites/mptests/mp04_node2.yml       |  21 +++
>  spec/build/testsuites/mptests/mp04node1.yml        |  21 ---
>  spec/build/testsuites/mptests/mp04node2.yml        |  21 ---
>  spec/build/testsuites/mptests/mp05_node1.yml       |  22 +++
>  spec/build/testsuites/mptests/mp05_node2.yml       |  22 +++
>  spec/build/testsuites/mptests/mp05node1.yml        |  22 ---
>  spec/build/testsuites/mptests/mp05node2.yml        |  22 ---
>  spec/build/testsuites/mptests/mp06_node1.yml       |  21 +++
>  spec/build/testsuites/mptests/mp06_node2.yml       |  21 +++
>  spec/build/testsuites/mptests/mp06node1.yml        |  21 ---
>  spec/build/testsuites/mptests/mp06node2.yml        |  21 ---
>  spec/build/testsuites/mptests/mp07_node1.yml       |  21 +++
>  spec/build/testsuites/mptests/mp07_node2.yml       |  21 +++
>  spec/build/testsuites/mptests/mp07node1.yml        |  21 ---
>  spec/build/testsuites/mptests/mp07node2.yml        |  21 ---
>  spec/build/testsuites/mptests/mp08_node1.yml       |  21 +++
>  spec/build/testsuites/mptests/mp08_node2.yml       |  21 +++
>  spec/build/testsuites/mptests/mp08node1.yml        |  21 ---
>  spec/build/testsuites/mptests/mp08node2.yml        |  21 ---
>  spec/build/testsuites/mptests/mp09_node1.yml       |  23 +++
>  spec/build/testsuites/mptests/mp09_node2.yml       |  23 +++
>  spec/build/testsuites/mptests/mp09node1.yml        |  23 ---
>  spec/build/testsuites/mptests/mp09node2.yml        |  23 ---
>  spec/build/testsuites/mptests/mp10_node1.yml       |  23 +++
>  spec/build/testsuites/mptests/mp10_node2.yml       |  23 +++
>  spec/build/testsuites/mptests/mp10node1.yml        |  23 ---
>  spec/build/testsuites/mptests/mp10node2.yml        |  23 ---
>  spec/build/testsuites/mptests/mp11_node1.yml       |  20 +++
>  spec/build/testsuites/mptests/mp11_node2.yml       |  20 +++
>  spec/build/testsuites/mptests/mp11node1.yml        |  20 ---
>  spec/build/testsuites/mptests/mp11node2.yml        |  20 ---
>  spec/build/testsuites/mptests/mp12_node1.yml       |  20 +++
>  spec/build/testsuites/mptests/mp12_node2.yml       |  20 +++
>  spec/build/testsuites/mptests/mp12node1.yml        |  20 ---
>  spec/build/testsuites/mptests/mp12node2.yml        |  20 ---
>  spec/build/testsuites/mptests/mp13_node1.yml       |  22 +++
>  spec/build/testsuites/mptests/mp13_node2.yml       |  22 +++
>  spec/build/testsuites/mptests/mp13node1.yml        |  22 ---
>  spec/build/testsuites/mptests/mp13node2.yml        |  22 ---
>  spec/build/testsuites/mptests/mp14_node1.yml       |  27 ++++
>  spec/build/testsuites/mptests/mp14_node2.yml       |  27 ++++
>  spec/build/testsuites/mptests/mp14node1.yml        |  27 ----
>  spec/build/testsuites/mptests/mp14node2.yml        |  27 ----
>  spec/build/testsuites/psxtests/grp.yml             |   2 +-
>  spec/build/testsuites/psxtests/psxeintr_join.yml   |  20 +++
>  spec/build/testsuites/psxtests/psxeintrjoin.yml    |  20 ---
>  .../build/testsuites/psxtests/psxfatal_support.yml |  19 +++
>  spec/build/testsuites/psxtests/psxfatalsupport.yml |  19 ---
>  spec/build/testsuites/samples/base_mp_node1.yml    |  21 +++
>  spec/build/testsuites/samples/base_mp_node2.yml    |  21 +++
>  spec/build/testsuites/samples/base_sp.yml          |  20 +++
>  spec/build/testsuites/samples/basempnode1.yml      |  21 ---
>  spec/build/testsuites/samples/basempnode2.yml      |  21 ---
>  spec/build/testsuites/samples/basesp.yml           |  20 ---
>  spec/build/testsuites/samples/grp.yml              |   6 +-
>  spec/build/testsuites/sptests/grp.yml              |  40 ++---
>  spec/build/testsuites/sptests/spclock_err01.yml    |  20 +++
>  spec/build/testsuites/sptests/spclock_err02.yml    |  19 +++
>  .../build/testsuites/sptests/spclock_todhook01.yml |  19 +++
>  spec/build/testsuites/sptests/spclockerr01.yml     |  20 ---
>  spec/build/testsuites/sptests/spclockerr02.yml     |  19 ---
>  spec/build/testsuites/sptests/spclocktodhook01.yml |  19 ---
>  spec/build/testsuites/sptests/spevent_err03.yml    |  19 +++
>  spec/build/testsuites/sptests/speventerr03.yml     |  19 ---
>  spec/build/testsuites/sptests/spfatal_support.yml  |  19 +++
>  spec/build/testsuites/sptests/spfatalsupport.yml   |  19 ---
>  spec/build/testsuites/sptests/spintr_err01.yml     |  20 +++
>  spec/build/testsuites/sptests/spintrerr01.yml      |  20 ---
>  spec/build/testsuites/sptests/spmsgq_err01.yml     |  19 +++
>  spec/build/testsuites/sptests/spmsgq_err02.yml     |  20 +++
>  spec/build/testsuites/sptests/spmsgqerr01.yml      |  19 ---
>  spec/build/testsuites/sptests/spmsgqerr02.yml      |  20 ---
>  .../build/testsuites/sptests/sppartition_err01.yml |  19 +++
>  spec/build/testsuites/sptests/sppartitionerr01.yml |  19 ---
>  spec/build/testsuites/sptests/spport_err01.yml     |  19 +++
>  spec/build/testsuites/sptests/spporterr01.yml      |  19 ---
>  spec/build/testsuites/sptests/spratemon_err01.yml  |  21 +++
>  spec/build/testsuites/sptests/spratemonerr01.yml   |  21 ---
>  spec/build/testsuites/sptests/spregion_err01.yml   |  19 +++
>  spec/build/testsuites/sptests/spregionerr01.yml    |  19 ---
>  spec/build/testsuites/sptests/spsem_err01.yml      |  19 +++
>  spec/build/testsuites/sptests/spsem_err02.yml      |  20 +++
>  spec/build/testsuites/sptests/spsemerr01.yml       |  19 ---
>  spec/build/testsuites/sptests/spsemerr02.yml       |  20 ---
>  spec/build/testsuites/sptests/spsignal_err01.yml   |  20 +++
>  spec/build/testsuites/sptests/spsignalerr01.yml    |  20 ---
>  spec/build/testsuites/sptests/sptask_err01.yml     |  20 +++
>  spec/build/testsuites/sptests/sptask_err02.yml     |  19 +++
>  spec/build/testsuites/sptests/sptask_err03.yml     |  19 +++
>  spec/build/testsuites/sptests/sptask_err04.yml     |  20 +++
>  spec/build/testsuites/sptests/sptaskerr01.yml      |  20 ---
>  spec/build/testsuites/sptests/sptaskerr02.yml      |  19 ---
>  spec/build/testsuites/sptests/sptaskerr03.yml      |  19 ---
>  spec/build/testsuites/sptests/sptaskerr04.yml      |  20 ---
>  spec/build/testsuites/sptests/sptimer_err01.yml    |  19 +++
>  spec/build/testsuites/sptests/sptimer_err02.yml    |  19 +++
>  spec/build/testsuites/sptests/sptimererr01.yml     |  19 ---
>  spec/build/testsuites/sptests/sptimererr02.yml     |  19 ---
>  .../validation/tc-message-construct-errors.c       |   2 +-
>  380 files changed, 4294 insertions(+), 4240 deletions(-)
>  create mode 100644 spec/build/testsuites/ada/ada_base_sp.yml
>  create mode 100644 spec/build/testsuites/ada/ada_hello.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp01_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp01_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp03_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp03_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp04_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp04_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp05_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp05_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp06_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp06_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp07_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp07_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp08_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp08_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp09_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp09_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp10_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp10_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp11_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp11_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp12_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp12_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp13_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp13_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp14_node1.yml
>  create mode 100644 spec/build/testsuites/ada/ada_mp14_node2.yml
>  create mode 100644 spec/build/testsuites/ada/ada_nsecs.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp01.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp02.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp03.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp04.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp05.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp06.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp07.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp08.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp09.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp11.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp12.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp13.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp14.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp15.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp16.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp17.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp19.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp20.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp22.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp23.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp24.yml
>  create mode 100644 spec/build/testsuites/ada/ada_sp25.yml
>  create mode 100644 spec/build/testsuites/ada/ada_spatcb01.yml
>  create mode 100644 spec/build/testsuites/ada/ada_spname01.yml
>  create mode 100644 spec/build/testsuites/ada/ada_ticker.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm01.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm02.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm03.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm04.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm05.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm06.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm07.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm08.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm09.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm10.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm11.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm12.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm13.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm14.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm15.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm16.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm17.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm18.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm19.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm20.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm21.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm22.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm23.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm24.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm25.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm28.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tm29.yml
>  create mode 100644 spec/build/testsuites/ada/ada_tmck.yml
>  delete mode 100644 spec/build/testsuites/ada/adabasesp.yml
>  delete mode 100644 spec/build/testsuites/ada/adahello.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp01node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp01node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp03node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp03node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp04node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp04node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp05node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp05node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp06node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp06node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp07node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp07node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp08node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp08node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp09node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp09node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp10node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp10node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp11node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp11node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp12node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp12node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp13node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp13node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp14node1.yml
>  delete mode 100644 spec/build/testsuites/ada/adamp14node2.yml
>  delete mode 100644 spec/build/testsuites/ada/adansecs.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp01.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp02.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp03.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp04.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp05.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp06.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp07.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp08.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp09.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp11.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp12.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp13.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp14.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp15.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp16.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp17.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp19.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp20.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp22.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp23.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp24.yml
>  delete mode 100644 spec/build/testsuites/ada/adasp25.yml
>  delete mode 100644 spec/build/testsuites/ada/adaspatcb01.yml
>  delete mode 100644 spec/build/testsuites/ada/adaspname01.yml
>  delete mode 100644 spec/build/testsuites/ada/adaticker.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm01.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm02.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm03.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm04.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm05.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm06.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm07.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm08.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm09.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm10.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm11.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm12.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm13.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm14.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm15.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm16.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm17.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm18.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm19.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm20.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm21.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm22.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm23.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm24.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm25.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm28.yml
>  delete mode 100644 spec/build/testsuites/ada/adatm29.yml
>  delete mode 100644 spec/build/testsuites/ada/adatmck.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fserror.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fslink.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fspatheval.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fspermission.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fsrdwr.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fsscandir01.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fssymlink.yml
>  create mode 100644 spec/build/testsuites/fstests/imfs_fstime.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfserror.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfslink.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfspatheval.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfspermission.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfsrdwr.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfsscandir01.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfssymlink.yml
>  delete mode 100644 spec/build/testsuites/fstests/imfsfstime.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fserror.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fslink.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fspatheval.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fspermission.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fsrdwr.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fsscandir01.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fssymlink.yml
>  create mode 100644 spec/build/testsuites/fstests/jffs2_fstime.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fserror.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fslink.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fspatheval.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fspermission.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fsrdwr.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fsscandir01.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fssymlink.yml
>  delete mode 100644 spec/build/testsuites/fstests/jffs2fstime.yml
>  create mode 100644 spec/build/testsuites/fstests/mdosfs_fserror.yml
>  create mode 100644 spec/build/testsuites/fstests/mdosfs_fspatheval.yml
>  create mode 100644 spec/build/testsuites/fstests/mdosfs_fsrdwr.yml
>  create mode 100644 spec/build/testsuites/fstests/mdosfs_fsscandir01.yml
>  create mode 100644 spec/build/testsuites/fstests/mdosfs_fsstatvfs.yml
>  create mode 100644 spec/build/testsuites/fstests/mdosfs_fstime.yml
>  delete mode 100644 spec/build/testsuites/fstests/mdosfsfserror.yml
>  delete mode 100644 spec/build/testsuites/fstests/mdosfsfspatheval.yml
>  delete mode 100644 spec/build/testsuites/fstests/mdosfsfsrdwr.yml
>  delete mode 100644 spec/build/testsuites/fstests/mdosfsfsscandir01.yml
>  delete mode 100644 spec/build/testsuites/fstests/mdosfsfsstatvfs.yml
>  delete mode 100644 spec/build/testsuites/fstests/mdosfsfstime.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fserror.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fslink.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fspatheval.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fspermission.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fsrdwr.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fsrename.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fsscandir01.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fssymlink.yml
>  create mode 100644 spec/build/testsuites/fstests/mimfs_fstime.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfserror.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfslink.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfspatheval.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfspermission.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfsrdwr.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfsrename.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfsscandir01.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfssymlink.yml
>  delete mode 100644 spec/build/testsuites/fstests/mimfsfstime.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fserror.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fsfpathconf.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fslink.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fspatheval.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fspermission.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fsrdwr.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fsrename.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fsscandir01.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fssymlink.yml
>  create mode 100644 spec/build/testsuites/fstests/mrfs_fstime.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfserror.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfsfpathconf.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfslink.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfspatheval.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfspermission.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfsrdwr.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfsrename.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfsscandir01.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfssymlink.yml
>  delete mode 100644 spec/build/testsuites/fstests/mrfsfstime.yml
>  create mode 100644 spec/build/testsuites/libtests/clock_gettime.yml
>  delete mode 100644 spec/build/testsuites/libtests/clockgettime.yml
>  create mode 100644 spec/build/testsuites/libtests/iconv_close.yml
>  create mode 100644 spec/build/testsuites/libtests/iconv_open.yml
>  delete mode 100644 spec/build/testsuites/libtests/iconvclose.yml
>  delete mode 100644 spec/build/testsuites/libtests/iconvopen.yml
>  create mode 100644 spec/build/testsuites/libtests/posix_memalign.yml
>  delete mode 100644 spec/build/testsuites/libtests/posixmemalign.yml
>  create mode 100644 spec/build/testsuites/mptests/mp01_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp01_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp01node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp01node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp03_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp03_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp03node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp03node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp04_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp04_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp04node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp04node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp05_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp05_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp05node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp05node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp06_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp06_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp06node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp06node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp07_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp07_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp07node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp07node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp08_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp08_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp08node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp08node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp09_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp09_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp09node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp09node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp10_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp10_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp10node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp10node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp11_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp11_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp11node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp11node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp12_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp12_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp12node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp12node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp13_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp13_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp13node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp13node2.yml
>  create mode 100644 spec/build/testsuites/mptests/mp14_node1.yml
>  create mode 100644 spec/build/testsuites/mptests/mp14_node2.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp14node1.yml
>  delete mode 100644 spec/build/testsuites/mptests/mp14node2.yml
>  create mode 100644 spec/build/testsuites/psxtests/psxeintr_join.yml
>  delete mode 100644 spec/build/testsuites/psxtests/psxeintrjoin.yml
>  create mode 100644 spec/build/testsuites/psxtests/psxfatal_support.yml
>  delete mode 100644 spec/build/testsuites/psxtests/psxfatalsupport.yml
>  create mode 100644 spec/build/testsuites/samples/base_mp_node1.yml
>  create mode 100644 spec/build/testsuites/samples/base_mp_node2.yml
>  create mode 100644 spec/build/testsuites/samples/base_sp.yml
>  delete mode 100644 spec/build/testsuites/samples/basempnode1.yml
>  delete mode 100644 spec/build/testsuites/samples/basempnode2.yml
>  delete mode 100644 spec/build/testsuites/samples/basesp.yml
>  create mode 100644 spec/build/testsuites/sptests/spclock_err01.yml
>  create mode 100644 spec/build/testsuites/sptests/spclock_err02.yml
>  create mode 100644 spec/build/testsuites/sptests/spclock_todhook01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spclockerr01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spclockerr02.yml
>  delete mode 100644 spec/build/testsuites/sptests/spclocktodhook01.yml
>  create mode 100644 spec/build/testsuites/sptests/spevent_err03.yml
>  delete mode 100644 spec/build/testsuites/sptests/speventerr03.yml
>  create mode 100644 spec/build/testsuites/sptests/spfatal_support.yml
>  delete mode 100644 spec/build/testsuites/sptests/spfatalsupport.yml
>  create mode 100644 spec/build/testsuites/sptests/spintr_err01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spintrerr01.yml
>  create mode 100644 spec/build/testsuites/sptests/spmsgq_err01.yml
>  create mode 100644 spec/build/testsuites/sptests/spmsgq_err02.yml
>  delete mode 100644 spec/build/testsuites/sptests/spmsgqerr01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spmsgqerr02.yml
>  create mode 100644 spec/build/testsuites/sptests/sppartition_err01.yml
>  delete mode 100644 spec/build/testsuites/sptests/sppartitionerr01.yml
>  create mode 100644 spec/build/testsuites/sptests/spport_err01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spporterr01.yml
>  create mode 100644 spec/build/testsuites/sptests/spratemon_err01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spratemonerr01.yml
>  create mode 100644 spec/build/testsuites/sptests/spregion_err01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spregionerr01.yml
>  create mode 100644 spec/build/testsuites/sptests/spsem_err01.yml
>  create mode 100644 spec/build/testsuites/sptests/spsem_err02.yml
>  delete mode 100644 spec/build/testsuites/sptests/spsemerr01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spsemerr02.yml
>  create mode 100644 spec/build/testsuites/sptests/spsignal_err01.yml
>  delete mode 100644 spec/build/testsuites/sptests/spsignalerr01.yml
>  create mode 100644 spec/build/testsuites/sptests/sptask_err01.yml
>  create mode 100644 spec/build/testsuites/sptests/sptask_err02.yml
>  create mode 100644 spec/build/testsuites/sptests/sptask_err03.yml
>  create mode 100644 spec/build/testsuites/sptests/sptask_err04.yml
>  delete mode 100644 spec/build/testsuites/sptests/sptaskerr01.yml
>  delete mode 100644 spec/build/testsuites/sptests/sptaskerr02.yml
>  delete mode 100644 spec/build/testsuites/sptests/sptaskerr03.yml
>  delete mode 100644 spec/build/testsuites/sptests/sptaskerr04.yml
>  create mode 100644 spec/build/testsuites/sptests/sptimer_err01.yml
>  create mode 100644 spec/build/testsuites/sptests/sptimer_err02.yml
>  delete mode 100644 spec/build/testsuites/sptests/sptimererr01.yml
>  delete mode 100644 spec/build/testsuites/sptests/sptimererr02.yml
> 1.8.3.1
> devel mailing list
> devel at rtems.org
