[PATCH 1/3] bsps: Renamed YAML files to match test names
Fri Mar 19 15:42:37 UTC 2021
On 19/03/2021 14:26, Kinsey Moore wrote:
> This was my suggestion since the introduction of the waf build system
> preserved the names of the executables generated as compared to the
> autotools build, but offered different internal names when setting
> expected test states. The waf build system was new and different, so I
> thought it better to continue matching existing behavior.
The waf based build system was intended to work with Doorstop. This is
one of the reasons why the items are in YAML format. A limitation of
Doorstop was that links had no role attribute. This was one of the
reasons why I replaced Doorstop with custom modules. The
  actions:
  - set-test-state:
      spconfig01: exclude
is an early hack which was necessary to avoid cyclic dependencies. Since links have now a role, we have more flexibility. We could introduce a new link role for BSP-specific test program states. These links can be automatically verified and also processed.
Also the comments you added to the items contradict the philosophy of the structured information in the items. A rationale why a test program has a BSP-specific state should be in a dedicated attribute. Custom links can have custom attributes for example.
Before we rename hundreds of files we should try to fix the underlining problem.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
