#4328: New APIs added to POSIX Standard (2021)
Joel Sherrill
joel at rtems.org
Fri Mar 19 12:13:01 UTC 2021
On Fri, Mar 19, 2021, 6:40 AM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Mar 19, 2021, 5:48 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> https://docs.google.com/spreadsheets/d/1reCNOIZC5JTwQENgl-hvG8THfQqNtlUDVy_07PYodic/edit?usp=sharing
>> Hello,
>> As suggested by Dr. Sherril, I've taken an initial look through this
>> document https://www.opengroup.org/austin/docs/austin_1110.pdf and
>> added the new methods to a Googe Sheet, linked above.
>> None of them appear to be in the RTEMS POSIX API Users Guide, but
>> maybe that's not the right place to look. I'll stand by for your
>> feedback regarding what's possible / desirable to add to RTEMS.
> It is possible they are in our C Library or Math Library. Or just not in
> the manual. The POSIX manual tends to be sparse since you can always use
> man pages or the POSIX standard.
> Since you have RTEMS and tools built. Find one of the libc.a and libm.a
> files in the tools install and librtemscpu.a in the RTEMS build or install.
> Then try a command something like this:
> CPU-rtems6-nm LIBRARY | grep SYMBOL
> If you see it list with T then it is in the text section and there.
Following up, I initially answered from my phone and didn't look at
source. I am still on my phone but looked through the list and think the
last four methods are probably the only ones currently supported.
https://sourceware.org/git/?p=newlib-cygwin.git;a=tree;f=newlib/libc/string;h=ceeec602cdd0e6b5c6b002b741bda9b41da4e441;hb=HEAD
POSIX support comes from a mix of RTEMS and newlib. That's key to this type
of project.
--joel
>> Thanks very much for your time!
>> Sincerely,
>> Matt
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210319/cc6d5cba/attachment.html>
