[PATCH v4] covoar: Handle periods in symbols from objdump
Alex White
alex.white at oarcorp.com
Fri Mar 19 19:10:19 UTC 2021
Occasionally the compiler will generate symbols that look similar to
symbols defined in RTEMS code except that they contain some suffix.
These symbol suffixes are only found in the ELF symbol table; the
symbols appear to be normal in the DWARF info. This appears to be
happening on all architectures.
For example, the function _Message_queue_Create from rtems appears as
"_Message_queue_Create.part.0". Other suffixes include ".isra.0",
".constprop.0", and ".0".
This looks to be related to compiler optimizations. Symbols with
suffixes were being treated as unique. For our purposes, they should be
mapped to the equivalent symbols in the DWARF info. This has been
fixed.
tester/covoar/ExecutableInfo.cc | 3 +--
tester/covoar/ObjdumpProcessor.cc | 15 +++++++++++++++
tester/covoar/SymbolTable.cc | 12 +++++++++---
3 files changed, 25 insertions(+), 5 deletions(-)
diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
index c996d75..1e14721 100644
--- a/tester/covoar/ExecutableInfo.cc
+++ b/tester/covoar/ExecutableInfo.cc
@@ -118,8 +118,7 @@ namespace Coverage {
// Obtain the coverage map containing the specified address.
itsSymbol = theSymbolTable.getSymbol( address );
if (itsSymbol != "") {
- it = coverageMaps.find( itsSymbol );
- aCoverageMap = (*it).second;
+ aCoverageMap = &findCoverageMap(itsSymbol);
return aCoverageMap;
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index 0647ff9..e19fa92 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -417,6 +417,21 @@ namespace Coverage {
processSymbol = false;
theInstructions.clear();
+ // Look for a '.' character and strip everything after it.
+ // There is a chance that the compiler splits function bodies to improve
+ // inlining. If there exists some inlinable function that contains a
+ // branch where one path is more expensive and less likely to be taken
+ // than the other, inlining only the branch instruction and the less
+ // expensive path results in smaller code size while preserving most of
+ // the performance improvement.
+ // When this happens, the compiler will generate a function with a
+ // ".part.n" suffix. For our purposes, this generated function part is
+ // equivalent to the original function and should be treated as such.
+ char *periodIndex = strstr(symbol, ".");
+ if (periodIndex != NULL) {
+ *periodIndex = 0;
// See if the new symbol is one that we care about.
if (SymbolsToAnalyze->isDesired( symbol )) {
currentSymbol = symbol;
diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
index 53bc8af..00062cc 100644
--- a/tester/covoar/SymbolTable.cc
+++ b/tester/covoar/SymbolTable.cc
@@ -46,12 +46,18 @@ namespace Coverage {
symbolData.startingAddress = start;
symbolData.length = length;
- if ( info[ symbol ].empty() == false ) {
- if ( info[ symbol ].front().length != length ) {
+ for (auto& symData : info[ symbol ]) {
+ // The starting address could differ since we strip any suffixes beginning
+ // with a '.'
+ if (symData.startingAddress != start) {
+ continue;
+ if (symData.length != length) {
std::ostringstream what;
what << "Different lengths for the symbol "
<< symbol
- << " (" << info[ symbol ].front().length
+ << " (" << symData.length
<< " and " << length
throw rld::error( what, "SymbolTable::addSymbol" );
2.27.0
