[PATCH v4] covoar: Handle periods in symbols from objdump
Alex White
alex.white at oarcorp.com
Fri Mar 26 21:21:04 UTC 2021
ping
> -----Original Message-----
> From: Alex White <alex.white at oarcorp.com>
> Sent: Friday, March 19, 2021 2:10 PM
> To: devel at rtems.org
> Cc: Alex White <alex.white at oarcorp.com>
> Subject: [PATCH v4] covoar: Handle periods in symbols from objdump
> Occasionally the compiler will generate symbols that look similar to symbols
> defined in RTEMS code except that they contain some suffix.
> These symbol suffixes are only found in the ELF symbol table; the symbols
> appear to be normal in the DWARF info. This appears to be happening on all
> architectures.
> For example, the function _Message_queue_Create from rtems appears as
> "_Message_queue_Create.part.0". Other suffixes include ".isra.0",
> ".constprop.0", and ".0".
> This looks to be related to compiler optimizations. Symbols with suffixes
> were being treated as unique. For our purposes, they should be mapped to
> the equivalent symbols in the DWARF info. This has been fixed.
> tester/covoar/ExecutableInfo.cc | 3 +--
> tester/covoar/ObjdumpProcessor.cc | 15 +++++++++++++++
> tester/covoar/SymbolTable.cc | 12 +++++++++---
> 3 files changed, 25 insertions(+), 5 deletions(-)
> diff --git a/tester/covoar/ExecutableInfo.cc
> b/tester/covoar/ExecutableInfo.cc index c996d75..1e14721 100644
> --- a/tester/covoar/ExecutableInfo.cc
> +++ b/tester/covoar/ExecutableInfo.cc
> @@ -118,8 +118,7 @@ namespace Coverage {
> // Obtain the coverage map containing the specified address.
> itsSymbol = theSymbolTable.getSymbol( address );
> if (itsSymbol != "") {
> - it = coverageMaps.find( itsSymbol );
> - aCoverageMap = (*it).second;
> + aCoverageMap = &findCoverageMap(itsSymbol);
> return aCoverageMap;
> diff --git a/tester/covoar/ObjdumpProcessor.cc
> b/tester/covoar/ObjdumpProcessor.cc
> index 0647ff9..e19fa92 100644
> --- a/tester/covoar/ObjdumpProcessor.cc
> +++ b/tester/covoar/ObjdumpProcessor.cc
> @@ -417,6 +417,21 @@ namespace Coverage {
> processSymbol = false;
> theInstructions.clear();
> + // Look for a '.' character and strip everything after it.
> + // There is a chance that the compiler splits function bodies to improve
> + // inlining. If there exists some inlinable function that contains a
> + // branch where one path is more expensive and less likely to be taken
> + // than the other, inlining only the branch instruction and the less
> + // expensive path results in smaller code size while preserving most of
> + // the performance improvement.
> + // When this happens, the compiler will generate a function with a
> + // ".part.n" suffix. For our purposes, this generated function part is
> + // equivalent to the original function and should be treated as such.
> + char *periodIndex = strstr(symbol, ".");
> + if (periodIndex != NULL) {
> + *periodIndex = 0;
> // See if the new symbol is one that we care about.
> if (SymbolsToAnalyze->isDesired( symbol )) {
> currentSymbol = symbol;
> diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
> index 53bc8af..00062cc 100644
> --- a/tester/covoar/SymbolTable.cc
> +++ b/tester/covoar/SymbolTable.cc
> @@ -46,12 +46,18 @@ namespace Coverage {
> symbolData.startingAddress = start;
> symbolData.length = length;
> - if ( info[ symbol ].empty() == false ) {
> - if ( info[ symbol ].front().length != length ) {
> + for (auto& symData : info[ symbol ]) {
> + // The starting address could differ since we strip any suffixes beginning
> + // with a '.'
> + if (symData.startingAddress != start) {
> + continue;
> + if (symData.length != length) {
> std::ostringstream what;
> what << "Different lengths for the symbol "
> << symbol
> - << " (" << info[ symbol ].front().length
> + << " (" << symData.length
> << " and " << length
> throw rld::error( what, "SymbolTable::addSymbol" );
> 2.27.0
