[PATCH] bsps/riscv: Add per cpu clock interrupt
Sat Mar 20 06:14:01 UTC 2021
seems fine to me, if it works, then push it
On Fri, Mar 19, 2021 at 5:30 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> - Fixes failure of test smpclock01
>  bsps/riscv/riscv/clock/clockdrv.c | 61 +++++++++++++++++++++++++------
>  1 file changed, 50 insertions(+), 11 deletions(-)
> diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
> index d085b6bd95..04abe24545 100644
> --- a/bsps/riscv/riscv/clock/clockdrv.c
> +++ b/bsps/riscv/riscv/clock/clockdrv.c
> @@ -41,6 +41,7 @@
>  #include <rtems/timecounter.h>
>  #include <rtems/score/cpuimpl.h>
>  #include <rtems/score/riscv-utility.h>
> +#include <rtems/score/smpimpl.h>
>  #include <libfdt.h>
> @@ -92,13 +93,18 @@ static void riscv_clock_at_tick(riscv_timecounter *tc)
>    volatile RISCV_CLINT_regs *clint;
>    uint64_t value;
> +  uint32_t cpu = 0;
> +#if defined(RTEMS_SMP)
> +  cpu = _CPU_SMP_Get_current_processor();
> +#endif
>    clint = tc->clint;
> -  value = clint->mtimecmp[0].val_64;
> +  value = clint->mtimecmp[cpu].val_64;
>    value += tc->interval;
> -  riscv_clock_write_mtimecmp(&clint->mtimecmp[0], value);
> +  riscv_clock_write_mtimecmp(&clint->mtimecmp[cpu], value);
>  static void riscv_clock_handler_install(void)
> @@ -148,6 +154,42 @@ static uint32_t riscv_clock_get_timebase_frequency(const void *fdt)
>    return fdt32_to_cpu(*val);
> +static void riscv_clock_clint_init(
> +  volatile RISCV_CLINT_regs *clint,
> +  uint64_t cmpval,
> +  uint32_t cpu
> +    &clint->mtimecmp[cpu],
> +       cmpval
> +  /* Enable mtimer interrupts */
> +  set_csr(mie, MIP_MTIP);
> +#if defined(RTEMS_SMP) && !defined(CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR)
> +static void riscv_clock_secondary_action(void *arg)
> +  volatile RISCV_CLINT_regs *clint = riscv_clint;
> +  uint64_t *cmpval = arg;
> +  uint32_t cpu = _CPU_SMP_Get_current_processor();
> +  riscv_clock_clint_init(clint, *cmpval, cpu);
> +#endif
> +static void riscv_clock_secondary_initialization(
> +  uint64_t cmpval
> +  _SMP_Othercast_action(riscv_clock_secondary_action, &cmpval);
> +#endif
>  static void riscv_clock_initialize(void)
>    const char *fdt;
> @@ -156,6 +198,7 @@ static void riscv_clock_initialize(void)
>    uint32_t tb_freq;
>    uint64_t us_per_tick;
>    uint32_t interval;
> +  uint64_t cmpval;
>    fdt = bsp_fdt_get();
>    tb_freq = riscv_clock_get_timebase_frequency(fdt);
> @@ -167,13 +210,11 @@ static void riscv_clock_initialize(void)
>    tc->clint = clint;
>    tc->interval = interval;
> -    &clint->mtimecmp[0],
> -    riscv_clock_read_mtime(&clint->mtime) + interval
> -  /* Enable mtimer interrupts */
> -  set_csr(mie, MIP_MTIP);
> +  cmpval = riscv_clock_read_mtime(&clint->mtime);
> +  cmpval += interval;
> +  riscv_clock_clint_init(clint, cmpval, 0);
> +  riscv_clock_secondary_initialization(clint, cmpval);
>    /* Initialize timecounter */
>    tc->base.tc_get_timecount = riscv_clock_get_timecount;
> @@ -213,6 +254,4 @@ RTEMS_SYSINIT_ITEM(
>  #define Clock_driver_support_install_isr(isr) \
>    riscv_clock_handler_install()
> -#define CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR
>  #include "../../../shared/dev/clock/clockimpl.h"
> 2.17.1
> devel mailing list
> devel at rtems.org
