[PATCH] bsps/riscv: Add per cpu clock interrupt
Jan Sommer
jan.sommer at dlr.de
Fri Mar 19 11:30:20 UTC 2021
- Fixes failure of test smpclock01
bsps/riscv/riscv/clock/clockdrv.c | 61 +++++++++++++++++++++++++------
1 file changed, 50 insertions(+), 11 deletions(-)
diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
index d085b6bd95..04abe24545 100644
--- a/bsps/riscv/riscv/clock/clockdrv.c
+++ b/bsps/riscv/riscv/clock/clockdrv.c
@@ -41,6 +41,7 @@
#include <rtems/timecounter.h>
#include <rtems/score/cpuimpl.h>
#include <rtems/score/riscv-utility.h>
+#include <rtems/score/smpimpl.h>
#include <libfdt.h>
@@ -92,13 +93,18 @@ static void riscv_clock_at_tick(riscv_timecounter *tc)
volatile RISCV_CLINT_regs *clint;
uint64_t value;
+ uint32_t cpu = 0;
+#if defined(RTEMS_SMP)
+ cpu = _CPU_SMP_Get_current_processor();
+#endif
clint = tc->clint;
- value = clint->mtimecmp[0].val_64;
+ value = clint->mtimecmp[cpu].val_64;
value += tc->interval;
- riscv_clock_write_mtimecmp(&clint->mtimecmp[0], value);
+ riscv_clock_write_mtimecmp(&clint->mtimecmp[cpu], value);
static void riscv_clock_handler_install(void)
@@ -148,6 +154,42 @@ static uint32_t riscv_clock_get_timebase_frequency(const void *fdt)
return fdt32_to_cpu(*val);
+static void riscv_clock_clint_init(
+ volatile RISCV_CLINT_regs *clint,
+ uint64_t cmpval,
+ uint32_t cpu
+ &clint->mtimecmp[cpu],
+ cmpval
+ /* Enable mtimer interrupts */
+ set_csr(mie, MIP_MTIP);
+#if defined(RTEMS_SMP) && !defined(CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR)
+static void riscv_clock_secondary_action(void *arg)
+ volatile RISCV_CLINT_regs *clint = riscv_clint;
+ uint64_t *cmpval = arg;
+ uint32_t cpu = _CPU_SMP_Get_current_processor();
+ riscv_clock_clint_init(clint, *cmpval, cpu);
+#endif
+static void riscv_clock_secondary_initialization(
+ uint64_t cmpval
+ _SMP_Othercast_action(riscv_clock_secondary_action, &cmpval);
+#endif
static void riscv_clock_initialize(void)
const char *fdt;
@@ -156,6 +198,7 @@ static void riscv_clock_initialize(void)
uint32_t tb_freq;
uint64_t us_per_tick;
uint32_t interval;
+ uint64_t cmpval;
fdt = bsp_fdt_get();
tb_freq = riscv_clock_get_timebase_frequency(fdt);
@@ -167,13 +210,11 @@ static void riscv_clock_initialize(void)
tc->clint = clint;
tc->interval = interval;
- &clint->mtimecmp[0],
- riscv_clock_read_mtime(&clint->mtime) + interval
- /* Enable mtimer interrupts */
- set_csr(mie, MIP_MTIP);
+ cmpval = riscv_clock_read_mtime(&clint->mtime);
+ cmpval += interval;
+ riscv_clock_clint_init(clint, cmpval, 0);
+ riscv_clock_secondary_initialization(clint, cmpval);
/* Initialize timecounter */
tc->base.tc_get_timecount = riscv_clock_get_timecount;
@@ -213,6 +254,4 @@ RTEMS_SYSINIT_ITEM(
#define Clock_driver_support_install_isr(isr) \
riscv_clock_handler_install()
-#define CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR
#include "../../../shared/dev/clock/clockimpl.h"
2.17.1
