[PATCH rtems-docs v3 5/6] app: Update command to configure app
Ida Delphine
idadelm at gmail.com
Sat Mar 20 18:54:58 UTC 2021
user/start/app.rst | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/user/start/app.rst b/user/start/app.rst
index 8900f78..b04f8e1 100644
--- a/user/start/app.rst
+++ b/user/start/app.rst
@@ -8,7 +8,7 @@ Build Your Application
You tested a BSP in the previous section. We built the ``erc32`` BSP
-and it is installed under :file:`$HOME/quick-start/rtems/5`.
+and it is installed under :file:`$HOME/quick-start/rtems/6`.
We will now create a simple Hello World application with a Git
repository and using the `Waf <https://waf.io>`_ build system.
@@ -107,7 +107,7 @@ and copy the Waf script:
from __future__ import print_function
- rtems_version = "5"
+ rtems_version = "6"
try:
import rtems_waf.rtems as rtems
@@ -142,7 +142,7 @@ Configure the application using Waf's ``configure`` command:
.. code-block:: none
- ./waf configure --rtems=$HOME/quick-start/rtems/5 --rtems-bsp=sparc/erc32
+ ./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32
The output will be something close to:
@@ -210,7 +210,7 @@ Run the executable:
- $HOME/quick-start/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
+ $HOME/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems6-erc32/hello.exe
2.25.1
