[PATCH rtems-docs v3 6/6] start: Console output example updates
Ida Delphine idadelm at gmail.com
Sat Mar 20 18:54:59 UTC 2021
 user/start/app.rst       | 119 +++++++++++++++++++--------------------
 user/start/bsp-build.rst |  93 +++++++++++++++---------------
 user/start/bsp-test.rst  |  50 ++++++++--------
 user/start/sources.rst   |  12 ++--
 user/start/tools.rst     |  35 ++++++------
 5 files changed, 159 insertions(+), 150 deletions(-)
diff --git a/user/start/app.rst b/user/start/app.rst
index b04f8e1..2bb0a9e 100644
--- a/user/start/app.rst
+++ b/user/start/app.rst
@@ -148,47 +148,46 @@ The output will be something close to:
 .. code-block:: none
-     Setting top to                           : $BASE/app/hello
-     Setting out to                           : $BASE/app/hello/build
-     RTEMS Version                            : 5
-     Architectures                            : sparc-rtems5
-     Board Support Package (BSP)              : sparc-rtems5-erc32
-     Show commands                            : no
-     Long commands                            : no
-     Checking for program 'sparc-rtems5-gcc'  : $BASE/rtems/5/bin/sparc-rtems5-gcc
-     Checking for program 'sparc-rtems5-g++'  : $BASE/rtems/5/bin/sparc-rtems5-g++
-     Checking for program 'sparc-rtems5-ld'   : $BASE/rtems/5/bin/sparc-rtems5-ld
-     Checking for program 'sparc-rtems5-ar'   : $BASE/rtems/5/bin/sparc-rtems5-ar
-     Checking for program 'sparc-rtems5-nm'   : $BASE/rtems/5/bin/sparc-rtems5-nm
-     Checking for program 'sparc-rtems5-objdump' : $BASE/rtems/5/bin/sparc-rtems5-objdump
-     Checking for program 'sparc-rtems5-objcopy' : $BASE/rtems/5/bin/sparc-rtems5-objcopy
-     Checking for program 'sparc-rtems5-readelf' : $BASE/rtems/5/bin/sparc-rtems5-readelf
-     Checking for program 'sparc-rtems5-strip'   : $BASE/rtems/5/bin/sparc-rtems5-strip
-     Checking for program 'sparc-rtems5-ranlib'  : $BASE/rtems/5/bin/sparc-rtems5-ranlib
-     Checking for program 'rtems-ld'             : $BASE/rtems/5/bin/rtems-ld
-     Checking for program 'rtems-tld'            : $BASE/rtems/5/bin/rtems-tld
-     Checking for program 'rtems-syms'           : $BASE/rtems/5/bin/rtems-syms
-     Checking for program 'rtems-bin2c'          : $BASE/rtems/5/bin/rtems-bin2c
-     Checking for program 'tar'                  : /usr/bin/tar
-     Checking for program 'gcc, cc'              : $BASE/rtems/5/bin/sparc-rtems5-gcc
-     Checking for program 'ar'                   : $BASE/rtems/5/bin/sparc-rtems5-ar
-     Checking for program 'g++, c++'             : $BASE/rtems/5/bin/sparc-rtems5-g++
-     Checking for program 'gas, gcc'             : $BASE/rtems/5/bin/sparc-rtems5-gcc
-     Checking for c flags '-MMD'                 : yes
-     Checking for cxx flags '-MMD'               : yes
-     Compiler version (sparc-rtems5-gcc)         : 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
-     Checking for a valid RTEMS BSP installation : yes
-     Checking for RTEMS_DEBUG                    : no
-     Checking for RTEMS_MULTIPROCESSING          : no
-     Checking for RTEMS_NEWLIB                   : yes
-     Checking for RTEMS_POSIX_API                : yes
-     Checking for RTEMS_SMP                      : no
-     Checking for RTEMS_NETWORKING               : no
-     'configure' finished successfully (0.686s)
+     Setting top to                           : $BASE/app/hello
+     Setting out to                           : $BASE/app/hello/build
+     RTEMS Version                            : 6
+     Architectures                            : sparc-rtems6
+     Board Support Package (BSP)              : sparc-rtems6-erc32
+     Show commands                            : no
+     Long commands                            : no
+     Checking for program 'sparc-rtems6-gcc'  : $BASE/rtems/6/bin/sparc-rtems6-gcc
+     Checking for program 'sparc-rtems6-g++'  : $BASE/rtems/6/bin/sparc-rtems6-g++
+     Checking for program 'sparc-rtems6-ld'   : $BASE/rtems/6/bin/sparc-rtems6-ld
+     Checking for program 'sparc-rtems6-ar'   : $BASE/rtems/6/bin/sparc-rtems6-ar
+     Checking for program 'sparc-rtems6-nm'   : $BASE/rtems/6/bin/sparc-rtems6-nm
+     Checking for program 'sparc-rtems6-objdump' : $BASE/rtems/6/bin/sparc-rtems6-objdump
+     Checking for program 'sparc-rtems6-objcopy' : $BASE/rtems/6/bin/sparc-rtems6-objcopy
+     Checking for program 'sparc-rtems6-readelf' : $BASE/rtems/6/bin/sparc-rtems6-readelf
+     Checking for program 'sparc-rtems6-strip'   : $BASE/rtems/6/bin/sparc-rtems6-strip
+     Checking for program 'sparc-rtems6-ranlib'  : $BASE/rtems/6/bin/sparc-rtems6-ranlib
+     Checking for program 'rtems-ld'             : $BASE/rtems/6/bin/rtems-ld
+     Checking for program 'rtems-tld'            : $BASE/rtems/6/bin/rtems-tld
+     Checking for program 'rtems-syms'           : $BASE/rtems/6/bin/rtems-syms
+     Checking for program 'rtems-bin2c'          : $BASE/rtems/6/bin/rtems-bin2c
+     Checking for program 'tar'                  : /usr/bin/tar
+     Checking for program 'gcc, cc'              : $BASE/rtems/6/bin/sparc-rtems6-gcc
+     Checking for program 'ar'                   : $BASE/rtems/6/bin/sparc-rtems6-ar
+     Checking for program 'g++, c++'             : $BASE/rtems/6/bin/sparc-rtems6-g++
+     Checking for program 'gas, gcc'             : $BASE/rtems/6/bin/sparc-rtems6-gcc
+     Checking for c flags '-MMD'                 : yes
+     Checking for cxx flags '-MMD'               : yes
+     Compiler version (sparc-rtems6-gcc)         : 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
+     Checking for a valid RTEMS BSP installation : yes
+     Checking for RTEMS_DEBUG                    : no
+     Checking for RTEMS_MULTIPROCESSING          : no
+     Checking for RTEMS_NEWLIB                   : yes
+     Checking for RTEMS_POSIX_API                : no
+     Checking for RTEMS_SMP                      : no
+     Checking for RTEMS_NETWORKING               : no
+     'configure' finished successfully (1.142s)
 Build the application:
@@ -199,48 +198,48 @@ The output will be something close to:
-    Waf: Entering directory `$BASE/app/hello/build/sparc-rtems5-erc32'
+    Waf: Entering directory `$BASE/app/hello/build/sparc-rtems6-erc32'
     [1/3] Compiling init.c
     [2/3] Compiling hello.c
-    [3/3] Linking build/sparc-rtems5-erc32/hello.exe
-    Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems5-erc32'
-    'build-sparc-rtems5-erc32' finished successfully (0.183s)
+    [3/3] Linking build/sparc-rtems6-erc32/hello.exe
+    Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems6-erc32'
+    'build-sparc-rtems6-erc32' finished successfully (0.183s)
 Run the executable:
-    $HOME/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems6-erc32/hello.exe
+    $HOME/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems-erc32/hello.exe
-    RTEMS Testing - Run, 5.1.0
-     Command Line: $BASE/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
-     Host: FreeBSD hihi 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64
-     Python: 3.7.6 (default, Jan 30 2020, 01:18:54) [Clang 6.0.1 (tags/RELEASE_601/final 335540)]
-    Host: FreeBSD-12.1-RELEASE-p2-amd64-64bit-ELF (FreeBSD hihi 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64 amd64)
+    RTEMS Testing - Run, 6.0.not_released
+    Command Line: $BASE/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems6-erc32/hello.exe
+    Host: Linux  5.8.0-44-generic #50~20.04.1-Ubuntu SMP Wed Feb 10 21:07:30 UTC 2021 x86_64
+    Python: 3.8.5 (default, Jan 27 2021, 15:41:15) [GCC 9.3.0]
+    Host: Linux-5.8.0-44-generic-x86_64-with-glibc2.29 (Linux 5.8.0-44-generic #50~20.04.1-Ubuntu SMP Wed Feb 10 21:07:30 UTC 2021 x86_64 x86_64)
-     SIS - SPARC/RISCV instruction simulator 2.21,  copyright Jiri Gaisler 2019
-     Bug-reports to jiri at gaisler.se
+    SIS - SPARC/RISCV instruction simulator 2.26,  copyright Jiri Gaisler 2020
+    Bug-reports to jiri at gaisler.se
-     ERC32 emulation enabled
+    ERC32 emulation enabled
-     Loaded build/sparc-rtems5-erc32/hello.exe, entry 0x02000000
+    Loaded build/sparc-rtems6-erc32/hello.exe, entry 0x02000000
     Hello World
     *** FATAL ***
     fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
     fatal code: 0 (0x00000000)
-    RTEMS version: 5.1.0
-    RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
+    RTEMS version: 6.0.0.586e06ec6222f1cd1f005aa8f4a34a8b33f5d862
+    RTEMS tools: 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
     executing thread ID: 0x08a010001
-    executing thread name: UI1
+    executing thread name: UI1
     cpu 0 in error mode (tt = 0x101)
-       107883  0200b6c0:  91d02000   ta  0x0
-    Run time     : 0:00:01.011474
+    158479  0200d500:  91d02000   ta  0x0
+    Run time     : 0:00:00.259136
 Commit the application to the repository:
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
index 335962b..6ffe9b0 100644
--- a/user/start/bsp-build.rst
+++ b/user/start/bsp-build.rst
@@ -154,30 +154,29 @@ by ``$BASE``.
-    Setting top to                           : $BASE/src/rtems
-    Setting out to                           : $BASE/src/rtems/build
-    Regenerate build specification cache (needs a couple of seconds)...
-    Configure board support package (BSP)    : sparc/erc32
-    Checking for program 'gzip'              : /usr/bin/gzip
-    Checking for program 'pax'               : /usr/bin/pax
-    Checking for program 'xz'                : /usr/bin/xz
-    'configure' finished successfully (11.069s)
+    Setting top to                           : $BASE/quick-start/src/rtems
+    Setting out to                           : $BASE/quick-start/src/rtems/build
+    Configure board support package (BSP)    : sparc/erc32
+    Checking for program 'sparc-rtems6-gcc'  : $BASE/quick-start/rtems/6/bin/sparc-rtems6-gcc
+    Checking for program 'sparc-rtems6-g++'  : $BASE/quick-start/rtems/6/bin/sparc-rtems6-g++
+    Checking for program 'sparc-rtems6-ar'   : $BASE/quick-start/rtems/6/bin/sparc-rtems6-ar
+    Checking for program 'sparc-rtems6-ld'   : $BASE/quick-start/rtems/6/bin/sparc-rtems6-ld
+    Checking for program 'ar'                : $BASE/quick-start/rtems/6/bin/sparc-rtems6-ar
+    Checking for program 'g++, c++'          : $BASE/quick-start/rtems/6/bin/sparc-rtems6-g++
+    Checking for program 'gas, gcc'          : $BASE/quick-start/rtems/6/bin/sparc-rtems6-gcc
+    Checking for program 'gcc, cc'           : $BASE/quick-start/rtems/6/bin/sparc-rtems6-gcc
+    Checking for asm flags '-MMD'            : yes
+    Checking for program 'rtems-bin2c'       : $BASE/quick-start/rtems/6/bin/rtems-bin2c
+    Checking for program 'gzip'              : /usr/bin/gzip
+    Checking for program 'rtems-ld'          : $BASE/quick-start/rtems/6/bin/rtems-ld
+    Checking for program 'rtems-syms'        : $BASE/quick-start/rtems/6/bin/rtems-syms
+    Checking for program 'xz'                : $BASE/anaconda3/bin/xz
+    'configure' finished successfully (0.414s)
 Building the BSP is the second step.
@@ -191,17 +190,17 @@ This command should output something like this (omitted lines are denoted by
-    Waf: Entering directory `$BASE/src/rtems/build'
-    Waf: Leaving directory `$BASE/src/rtems/build'
-    'build' finished successfully (0.546s)
-    Waf: Entering directory `$BASE/src/rtems/build/sparc/erc32'
-    [   1/3922] Compiling bsps/sparc/shared/start/start.S
-    [   2/3922] Compiling bsps/shared/dev/serial/mc68681_reg4.c
-    [   3/3922] Compiling bsps/shared/dev/rtc/icm7170.c
-    [4038/4038] Linking build/sparc/erc32/testsuites/tmtests/tmoverhd.exe
-    Waf: Leaving directory `$BASE/src/rtems/build/sparc/erc32'
-    'build_sparc/erc32' finished successfully (58.678s)
+    Waf: Entering directory `$BASE/quick-start/src/rtems/build'
+    Waf: Leaving directory `$BASE/quick-start/src/rtems/build'
+    'build' finished successfully (0.085s)
+    Waf: Entering directory `$BASE/quick-start/src/rtems/build/sparc/erc32'
+    [   1/4093] Compiling bsps/shared/dev/serial/mc68681_reg2.c
+    [   2/4093] Compiling bsps/shared/dev/rtc/mc146818a_ioreg.c
+    [   3/4093] Compiling bsps/shared/dev/flash/am29lv160.c
+    [4093/4093] Processing link: build/sparc/erc32/testsuites/libtests/dl01/dl01-tar.o build/sparc/erc32/testsuites/libtests/dl01/init.o build/sparc/erc32/testsuites/libtests/dl01/dl-load.o build/sparc/erc32/testsuites/libtests/dl01/dl01-sym.o -> build/sparc/erc32/testsuites/libtests/dl01.exe
+    Waf: Leaving directory `$BASE/quick-start/src/rtems/build/sparc/erc32'
+    'build_sparc/erc32' finished successfully (2m14.111s)
 The last step is to install the BSP.
@@ -216,16 +215,16 @@ by ``$BASE``.
-    'install' finished successfully (0.544s)
-    + install $BASE/rtems/5/sparc-rtems5/erc32/lib/start.o (from build/sparc/erc32/start.o)
-    + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/bspopts.h (from build/sparc/erc32/bsps/include/bspopts.h)
-    + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/zilog/z8036.h (from bsps/include/rtems/zilog/z8036.h)
+    'install' finished successfully (0.081s)
+    + install $BASE/quick-start/rtems/6/sparc-rtems6/erc32/lib/include/libchip/am29lv160.h (from bsps/include/libchip/am29lv160.h)
+    + install $BASE/quick-start/rtems/6/sparc-rtems6/erc32/lib/include/libchip/mc146818a.h (from bsps/include/libchip/mc146818a.h)
+    + install $BASE/quick-start/rtems/6/sparc-rtems6/erc32/lib/include/libchip/mc68681.h (from bsps/include/libchip/mc68681.h))
-    + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/score/watchdogimpl.h (from cpukit/include/rtems/score/watchdogimpl.h)
-    + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/score/watchdogticks.h (from cpukit/include/rtems/score/watchdogticks.h)
-    + install $BASE/rtems/5/sparc-rtems5/erc32/lib/include/rtems/score/wkspace.h (from cpukit/include/rtems/score/wkspace.h)
-    'install_sparc/erc32' finished successfully (2.985s)
+    + install $BASE/quick-start/rtems/6/sparc-rtems6/erc32/lib/include/rtems/score/watchdogticks.h (from cpukit/include/rtems/score/watchdogticks.h)
+    + install $BASE/quick-start/rtems/6/sparc-rtems6/erc32/lib/include/rtems/score/wkspace.h (from cpukit/include/rtems/score/wkspace.h)
+    + install $BASE/quick-start/rtems/6/sparc-rtems6/erc32/lib/include/rtems/score/wkspacedata.h (from cpukit/include/rtems/score/wkspacedata.h)
+    'install_sparc/erc32' finished successfully (1.834s))
diff --git a/user/start/bsp-test.rst b/user/start/bsp-test.rst
index 9243f5d..575f19e 100644
--- a/user/start/bsp-test.rst
+++ b/user/start/bsp-test.rst
@@ -31,36 +31,42 @@ by ``$BASE``.
     RTEMS Testing - Tester, 5.1.0
      Command Line: $BASE/rtems/5/bin/rtems-test --rtems-bsp=erc32-sis build/sparc/erc32
-     Python: 2.7.15 (default, Jan 10 2019, 01:14:47) [GCC 4.2.1 Compatible FreeBSD Clang 6.0.1 (tags/RELEASE_601/final 335540)]
-    Host: FreeBSD-12.0-RELEASE-p2-amd64-64bit-ELF (FreeBSD Build_FreeBSD12 12.0-RELEASE-p2 FreeBSD 12.0-RELEASE-p2 GENERIC amd64 amd64)
-    [  1/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32: dhrystone.exe
+    [  1/570] p:0   f:0   u:0   e:0   I:0   B:0   t:0   L:0   i:0   W:0   | sparc/erc32: dhrystone.exe
-    [589/589] p:574 f:0   u:5   e:0   I:0   B:3   t:0   i:0   W:0   | sparc/erc32: tmtimer01.exe
+    [570/570] p:554 f:2   u:6   e:1   I:0   B:3   t:0   L:0   i:0   W:0   | sparc/erc32: ts-validation-1.exe
-    Passed:        580
-    Failed:          0
-    User Input:      5
-    Expected Fail:   0
+    Passed:        558
+    Failed:          2
+    User Input:      6
+    Expected Fail:   1
     Indeterminate:   0
     Benchmark:       3
-    Timeout:         1
+    Timeout:         0
+    Test too long:   0
     Invalid:         0
     Wrong Version:   0
     Wrong Build:     0
     Wrong Tools:     0
-    Total:         589
+    Total:         570
+    Failures:
+    dl06.exe
+    minimum.exe
     User Input:
-     monitor.exe
-     termios.exe
-     top.exe
-     fileio.exe
-     capture.exe
+    dl10.exe
+    monitor.exe
+    termios.exe
+    top.exe
+    capture.exe
+    fileio.exe
+    Expected Fail:
+    psxfenv01.exe
     Benchmark:
-     whetstone.exe
-     linpack.exe
-     dhrystone.exe
-    Timeouts:
-     pppd.exe
-    Average test time: 0:00:00.437773
-    Testing time     : 0:04:17.848557
+    dhrystone.exe
+    linpack.exe
+    whetstone.exe
+    Average test time: 0:00:00.371256
+    Testing time     : 0:03:31.616055
diff --git a/user/start/sources.rst b/user/start/sources.rst
index 669505d..6585e3d 100644
--- a/user/start/sources.rst
+++ b/user/start/sources.rst
@@ -121,13 +121,15 @@ This command should output something like this (omitted lines are denoted by
-    RTEMS Source Builder - Set Builder, 5.1.0
-    Build Set: 5/rtems-sparc
+    RTEMS Source Builder - Set Builder, 6 (5e449fb5c2cb)
+    Build Set: 6/rtems-sparc
+    Build Set: 6/rtems-autotools.bset
+    Build Set: 6/rtems-autotools-internal.bset
-    download: https://ftp.rtems.org/pub/rtems/releases/5/5.1.0/5.1.0/sources/gcc-7.5.0.tar.xz -> sources/gcc-7.5.0.tar.xz
+    download: https://git.rtems.org/rtems-tools/snapshot/rtems-tools-90342feb4dd63d188ce945adfb0a769...<see log> -> sources/rtems-tools-90342feb4dd63d188ce945adfb0a7694a42a65cd.tar.bz2
-    Build Sizes: usage: 0.000B total: 143.814MB (sources: 143.793MB, patches: 21.348KB, installed 0.000B)
-    Build Set: Time 0:05:52.617958
+    Build Sizes: usage: 0.000B total: 264.228MB (sources: 264.186MB, patches: 43.468KB, installed 0.000B)
+    Build Set: Time 0:06:34.357125
 If you encounter errors, check your internet connection, firewall settings,
 virus scanners and the availability of the download servers.
diff --git a/user/start/tools.rst b/user/start/tools.rst
index 6c5aa83..2706f71 100644
--- a/user/start/tools.rst
+++ b/user/start/tools.rst
@@ -33,22 +33,25 @@ built. The name you see may vary depending on the host you are using:
-    config: tools/rtems-binutils-2.34.cfg
-    package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
-    building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
-    sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB (installed: 29.966MB)
-    cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
-    reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
-    reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
-    config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
-    package: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
-    building: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
+    config: tools/rtems-binutils-2.36.cfg
+    package: sparc-rtems6-binutils-fbb9a7e-x86_64-linux-gnu-1
+    building: sparc-rtems6-binutils-fbb9a7e-x86_64-linux-gnu-1
+    sizes: sparc-rtems6-binutils-fbb9a7e-x86_64-linux-gnu-1: 716.015MB (installed: 163.538MB)
+    cleaning: sparc-rtems6-binutils-fbb9a7e-x86_64-linux-gnu-1
+    reporting: tools/rtems-binutils-2.36.cfg -> sparc-rtems6-binutils-fbb9a7e-x86_64-linux-gnu-1.txt
+    reporting: tools/rtems-binutils-2.36.cfg -> sparc-rtems6-binutils-fbb9a7e-x86_64-linux-gnu-1.xml
+    config: tools/rtems-gcc-10-newlib-head.cfg
+    package: sparc-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1
+    building: sparc-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1
-    Build Sizes: usage: 5.684GB total: 1.112GB (sources: 143.803MB, patches: 21.348KB, installed 995.188MB)
-    Build Set: Time 0:21:35.626294
+    Build Sizes: usage: 9.607GB total: 2.244GB (sources: 264.186MB, patches: 43.468KB, installed 1.986GB)
+    installing: 6/rtems-sparc -> $HOME/quick-start/rtems/6
+    clean staging: 6/rtems-sparc
+    Staging Size: 5.292MB
+    Build Set: Time 1:01:48.019157
 Once the build has successfully completed you can check if the cross C compiler
 works with the following command:
@@ -69,8 +72,8 @@ source code used.
-    sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
-    Copyright (C) 2017 Free Software Foundation, Inc.
+    sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
+    Copyright (C) 2020 Free Software Foundation, Inc.
     This is free software; see the source for copying conditions.  There is NO
     warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
2.25.1
