[PATCH 1/2] validation: Add test case support functions
Sebastian Huber
Mon Mar 22 10:10:48 UTC 2021
.../testsuites/validation/validation-0.yml | 1 +
.../testsuites/validation/validation-1.yml | 1 +
testsuites/validation/tc-support.c | 155 ++++++++++++++++++
testsuites/validation/tc-support.h | 97 +++++++++++
4 files changed, 254 insertions(+)
create mode 100644 testsuites/validation/tc-support.c
create mode 100644 testsuites/validation/tc-support.h
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 653e34824e..662b38cefb 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -19,6 +19,7 @@ source:
- testsuites/validation/tc-object.c
- testsuites/validation/tc-signal-catch.c
- testsuites/validation/tc-signal-send.c
+- testsuites/validation/tc-support.c
- testsuites/validation/tc-task-construct-errors.c
- testsuites/validation/tc-task-create-errors.c
- testsuites/validation/ts-validation-0.c
diff --git a/spec/build/testsuites/validation/validation-1.yml b/spec/build/testsuites/validation/validation-1.yml
index 8a98f8b382..fb622d0410 100644
--- a/spec/build/testsuites/validation/validation-1.yml
+++ b/spec/build/testsuites/validation/validation-1.yml
@@ -13,6 +13,7 @@ links: []
source:
- testsuites/validation/ts-validation-1.c
diff --git a/testsuites/validation/tc-support.c b/testsuites/validation/tc-support.c
new file mode 100644
index 0000000000..058628686c
--- /dev/null
+++ b/testsuites/validation/tc-support.c
@@ -0,0 +1,155 @@
+ * @file
+ * @ingroup RTEMSTestSuites
+ * @brief This source file contains the definition of DeleteTask(),
+ * DoCreateTask(), ReceiveAnyEvents(), RestoreRunnerASR(),
+ * RestoreRunnerMode(), RestoreRunnerPriority(), SendEvents(),
+ * SetMode(), SetSelfPriority(), SetPriority(), and StartTask().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "tc-support.h"
+#include <rtems/test.h>
+rtems_id DoCreateTask( rtems_name name, rtems_task_priority priority )
+ rtems_status_code sc;
+ rtems_id id;
+ sc = rtems_task_create(
+ name,
+ priority,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id
+ T_assert_rsc_success( sc );
+ return id;
+void StartTask( rtems_id id, rtems_task_entry entry, void *arg )
+ sc = rtems_task_start( id, entry, (rtems_task_argument) arg);
+void DeleteTask( rtems_id id )
+ if ( id != 0 ) {
+ sc = rtems_task_delete( id );
+ T_rsc_success( sc );
+rtems_event_set ReceiveAnyEvents( void )
+ rtems_event_set events;
+ events = 0;
+ sc = rtems_event_receive(
+ RTEMS_ALL_EVENTS,
+ RTEMS_EVENT_ANY | RTEMS_WAIT,
+ RTEMS_NO_TIMEOUT,
+ &events
+ return events;
+void SendEvents( rtems_id id, rtems_event_set events )
+ sc = rtems_event_send( id, events );
+rtems_mode SetMode( rtems_mode set, rtems_mode mask )
+ rtems_mode previous;
+ sc = rtems_task_mode( set, mask, &previous );
+ return previous;
+rtems_task_priority SetPriority( rtems_id id, rtems_task_priority priority )
+ rtems_task_priority previous;
+ sc = rtems_task_set_priority( id, priority, &previous );
+ return previous;
+rtems_task_priority SetSelfPriority( rtems_task_priority priority )
+ return SetPriority( RTEMS_SELF, priority );
+void RestoreRunnerASR( void )
+ sc = rtems_signal_catch( NULL, RTEMS_DEFAULT_MODES );
+void RestoreRunnerMode( void )
+ rtems_mode mode;
+ sc = rtems_task_mode( RTEMS_DEFAULT_MODES, RTEMS_ALL_MODE_MASKS, &mode );
+void RestoreRunnerPriority( void )
+ SetSelfPriority( PRIO_ULTRA_HIGH );
diff --git a/testsuites/validation/tc-support.h b/testsuites/validation/tc-support.h
index 0000000000..202bb0b478
--- /dev/null
+++ b/testsuites/validation/tc-support.h
@@ -0,0 +1,97 @@
+ * @file
+ * @brief This header file provides the support functions for the validation
+ * test cases.
+ * are met:
+#ifndef _TC_SUPPORT_H
+#define _TC_SUPPORT_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSTestSuites
+typedef enum {
+ PRIO_PSEUDO_ISR,
+ PRIO_ULTRA_HIGH,
+ PRIO_VERY_HIGH,
+ PRIO_HIGH,
+ PRIO_NORMAL,
+ PRIO_LOW,
+ PRIO_VERY_LOW,
+ PRIO_ULTRA_LOW
+} Priority;
+#define CreateTask( name, priority ) \
+ DoCreateTask( \
+ rtems_build_name( name[ 0 ], name[ 1 ], name[ 2 ], name[ 3 ] ), \
+ priority \
+rtems_id DoCreateTask( rtems_name name, rtems_task_priority priority );
+void StartTask( rtems_id id, rtems_task_entry entry, void *arg );
+void DeleteTask( rtems_id id );
+rtems_event_set ReceiveAnyEvents( void );
+void SendEvents( rtems_id id, rtems_event_set events );
+rtems_mode SetMode( rtems_mode set, rtems_mode mask );
+rtems_task_priority SetPriority( rtems_id id, rtems_task_priority priority );
+rtems_task_priority SetSelfPriority( rtems_task_priority priority );
+void RestoreRunnerASR( void );
+void RestoreRunnerMode( void );
+void RestoreRunnerPriority( void );
+#ifdef __cplusplus
+#endif
+#endif /* _TC_SUPPORT_H */
2.26.2
