[PATCH 2/2] validation: Use support functions
Mon Mar 22 10:10:49 UTC 2021
 testsuites/validation/tc-barrier-create.c  |  31 ++-----
 testsuites/validation/tc-barrier-delete.c  |  55 ++----------
 testsuites/validation/tc-barrier-release.c |  74 ++++-----------
 testsuites/validation/tc-barrier-wait.c    | 100 ++++-----------------
 testsuites/validation/tc-signal-catch.c    |  30 ++-----
 testsuites/validation/tc-signal-send.c     |  82 ++++-------------
 6 files changed, 66 insertions(+), 306 deletions(-)
diff --git a/testsuites/validation/tc-barrier-create.c b/testsuites/validation/tc-barrier-create.c
index 2db0baea98..436030ef84 100644
--- a/testsuites/validation/tc-barrier-create.c
+++ b/testsuites/validation/tc-barrier-create.c
@@ -55,6 +55,8 @@
+#include "tc-support.h"
 #include <rtems/test.h>
@@ -208,11 +210,6 @@ static const char * const * const RtemsBarrierReqCreate_PreDesc[] = {
 typedef RtemsBarrierReqCreate_Context Context;
-typedef enum {
-  PRIO_NORMAL = 1,
-  PRIO_LOW
-} Priorities;
 static void Worker( rtems_task_argument arg )
   Context *ctx;
@@ -548,23 +545,10 @@ static void RtemsBarrierReqCreate_Post_IdVar_Check(
 static void RtemsBarrierReqCreate_Setup( RtemsBarrierReqCreate_Context *ctx )
-  rtems_status_code sc;
   memset( ctx, 0, sizeof( *ctx ) );
   ctx->id_value = INVALID_ID;
-  sc = rtems_task_create(
-    rtems_build_name( 'W', 'O', 'R', 'K' ),
-    PRIO_LOW,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_DEFAULT_MODES,
-    RTEMS_DEFAULT_ATTRIBUTES,
-    &ctx->worker_id
-  T_assert_rsc_success( sc );
-  sc = rtems_task_start( ctx->worker_id, Worker, (rtems_task_argument) ctx );
+  ctx->worker_id = CreateTask( "WORK", PRIO_LOW );
+  StartTask( ctx->worker_id, Worker, ctx );
 static void RtemsBarrierReqCreate_Setup_Wrap( void *arg )
@@ -580,12 +564,7 @@ static void RtemsBarrierReqCreate_Teardown(
-  if ( ctx->worker_id != 0 ) {
-    sc = rtems_task_delete( ctx->worker_id );
-    T_rsc_success( sc );
+  DeleteTask( ctx->worker_id );
 static void RtemsBarrierReqCreate_Teardown_Wrap( void *arg )
diff --git a/testsuites/validation/tc-barrier-delete.c b/testsuites/validation/tc-barrier-delete.c
index 5cfbee8c06..1655ff1b2f 100644
--- a/testsuites/validation/tc-barrier-delete.c
+++ b/testsuites/validation/tc-barrier-delete.c
@@ -55,6 +55,8 @@
@@ -135,12 +137,6 @@ static const char * const * const RtemsBarrierReqDelete_PreDesc[] = {
 typedef RtemsBarrierReqDelete_Context Context;
-typedef enum {
-  PRIO_HIGH = 1,
-  PRIO_NORMAL,
-  PRIO_LOW
-} Priorities;
   Context *ctx;
@@ -169,9 +165,7 @@ static void Worker( rtems_task_argument arg )
     ++ctx->wait_done;
-    prio = 0;
-    sc = rtems_task_set_priority( RTEMS_SELF, PRIO_LOW, &prio );
+    prio = SetSelfPriority( PRIO_LOW );
     T_eq_u32( prio, PRIO_HIGH );
@@ -295,28 +289,10 @@ static void RtemsBarrierReqDelete_Post_Flush_Check(
 static void RtemsBarrierReqDelete_Setup( RtemsBarrierReqDelete_Context *ctx )
-  rtems_task_priority prio;
-  prio = 0;
-  sc = rtems_task_set_priority( RTEMS_SELF, PRIO_NORMAL, &prio );
-  T_eq_u32( prio, PRIO_HIGH );
-    PRIO_LOW,
-    &ctx->worker_id
+  SetSelfPriority( PRIO_NORMAL );
 static void RtemsBarrierReqDelete_Setup_Wrap( void *arg )
@@ -332,18 +308,8 @@ static void RtemsBarrierReqDelete_Teardown(
-  prio = 0;
-  sc = rtems_task_set_priority( RTEMS_SELF, PRIO_HIGH, &prio );
-  T_eq_u32( prio, PRIO_NORMAL );
+  RestoreRunnerPriority();
 static void RtemsBarrierReqDelete_Teardown_Wrap( void *arg )
@@ -357,12 +323,9 @@ static void RtemsBarrierReqDelete_Teardown_Wrap( void *arg )
 static void RtemsBarrierReqDelete_Prepare( RtemsBarrierReqDelete_Context *ctx )
-  prio = 0;
-  sc = rtems_task_set_priority( ctx->worker_id, PRIO_HIGH, &prio );
+  prio = SetPriority( ctx->worker_id, PRIO_HIGH );
   T_true( prio == PRIO_LOW || prio == PRIO_HIGH );
diff --git a/testsuites/validation/tc-barrier-release.c b/testsuites/validation/tc-barrier-release.c
index ee7a28026e..ca13ef8a6d 100644
--- a/testsuites/validation/tc-barrier-release.c
+++ b/testsuites/validation/tc-barrier-release.c
@@ -55,6 +55,8 @@
@@ -167,19 +169,6 @@ static const char * const * const RtemsBarrierReqRelease_PreDesc[] = {
 typedef RtemsBarrierReqRelease_Context Context;
-typedef enum {
-  PRIO_HIGH = 1,
-  PRIO_NORMAL
-} Priorities;
-static void SendEvents( rtems_id id, rtems_event_set events )
-  sc = rtems_event_send( id, events );
   Context *ctx;
@@ -187,19 +176,13 @@ static void Worker( rtems_task_argument arg )
   ctx = (Context *) arg;
   while ( true ) {
-    rtems_event_set   events;
-    events = 0;
-    sc = rtems_event_receive(
-      RTEMS_ALL_EVENTS,
-      RTEMS_EVENT_ANY | RTEMS_WAIT,
-      RTEMS_NO_TIMEOUT,
-      &events
+    rtems_event_set events;
+    events = ReceiveAnyEvents();
     if ( ( events & EVENT_WAIT ) != 0 ) {
+      rtems_status_code sc;
       sc = rtems_barrier_wait( ctx->id, RTEMS_NO_TIMEOUT );
@@ -372,32 +355,12 @@ static void RtemsBarrierReqRelease_Post_ReleasedVar_Check(
 static void RtemsBarrierReqRelease_Setup( RtemsBarrierReqRelease_Context *ctx )
-  prio = 0;
-    PRIO_HIGH,
-    &ctx->worker_id
-    ctx->worker_id,
-    Worker,
-    (rtems_task_argument) ctx
+  ctx->worker_id = CreateTask( "WORK", PRIO_HIGH );
   sc = rtems_barrier_create(
     NAME,
@@ -429,18 +392,9 @@ static void RtemsBarrierReqRelease_Teardown(
-  prio = 0;
   if ( ctx->manual_release_id != 0 ) {
     sc = rtems_barrier_delete( ctx->manual_release_id );
@@ -451,6 +405,8 @@ static void RtemsBarrierReqRelease_Teardown(
     sc = rtems_barrier_delete( ctx->auto_release_id );
 static void RtemsBarrierReqRelease_Teardown_Wrap( void *arg )
diff --git a/testsuites/validation/tc-barrier-wait.c b/testsuites/validation/tc-barrier-wait.c
index 2f7e41a28c..b67acabe13 100644
--- a/testsuites/validation/tc-barrier-wait.c
+++ b/testsuites/validation/tc-barrier-wait.c
@@ -55,6 +55,8 @@
@@ -170,20 +172,6 @@ static const char * const * const RtemsBarrierReqWait_PreDesc[] = {
 typedef RtemsBarrierReqWait_Context Context;
-typedef enum {
-  PRIO_HIGH = 1,
-  PRIO_NORMAL,
-  PRIO_LOW
-} Priorities;
   Context *ctx;
@@ -194,14 +182,7 @@ static void Worker( rtems_task_argument arg )
-    events = 0;
-      RTEMS_ALL_EVENTS,
-      RTEMS_NO_TIMEOUT,
-      &events
     if ( ( events & EVENT_CHECK_TIMER ) != 0 ) {
       T_eq_int(
@@ -238,9 +219,7 @@ static void Worker( rtems_task_argument arg )
         id = &ctx->auto_release_id;
-      prio = 0;
+      prio = SetSelfPriority( PRIO_HIGH );
       T_eq_u32( prio, PRIO_LOW );
       sc = rtems_barrier_delete( ctx->id );
@@ -249,8 +228,7 @@ static void Worker( rtems_task_argument arg )
       sc = rtems_barrier_create( NAME, attribute_set, maximum_waiters, id );
-      sc = rtems_task_set_priority( RTEMS_SELF, prio, &prio );
+      prio = SetSelfPriority( prio );
@@ -422,50 +400,15 @@ static void RtemsBarrierReqWait_Post_Status_Check(
 static void RtemsBarrierReqWait_Setup( RtemsBarrierReqWait_Context *ctx )
   ctx->main_id = rtems_task_self();
-  prio = 0;
-    PRIO_HIGH,
-    &ctx->high_worker_id
-    ctx->high_worker_id,
-    Worker,
-    PRIO_LOW,
-    &ctx->low_worker_id
-    ctx->low_worker_id,
-    Worker,
+  ctx->high_worker_id = CreateTask( "WRKH", PRIO_HIGH );
+  StartTask( ctx->high_worker_id, Worker, ctx );
+  ctx->low_worker_id = CreateTask( "WRKL", PRIO_LOW );
+  StartTask( ctx->low_worker_id, Worker, ctx );
     NAME,
@@ -495,23 +438,10 @@ static void RtemsBarrierReqWait_Setup_Wrap( void *arg )
 static void RtemsBarrierReqWait_Teardown( RtemsBarrierReqWait_Context *ctx )
-  prio = 0;
-  if ( ctx->high_worker_id != 0 ) {
-    sc = rtems_task_delete( ctx->high_worker_id );
-  if ( ctx->low_worker_id != 0 ) {
-    sc = rtems_task_delete( ctx->low_worker_id );
+  DeleteTask( ctx->high_worker_id );
+  DeleteTask( ctx->low_worker_id );
@@ -522,6 +452,8 @@ static void RtemsBarrierReqWait_Teardown( RtemsBarrierReqWait_Context *ctx )
 static void RtemsBarrierReqWait_Teardown_Wrap( void *arg )
diff --git a/testsuites/validation/tc-signal-catch.c b/testsuites/validation/tc-signal-catch.c
index 9025521aa9..be0ba2c7d3 100644
--- a/testsuites/validation/tc-signal-catch.c
+++ b/testsuites/validation/tc-signal-catch.c
@@ -56,6 +56,8 @@
 #include <rtems/score/smpbarrier.h>
@@ -666,15 +668,7 @@ static void RtemsSignalReqCatch_Setup( RtemsSignalReqCatch_Context *ctx )
     rtems_id          scheduler_id;
-      1,
-      &ctx->worker_id
+    ctx->worker_id = CreateTask( "WORK", 1 );
     sc = rtems_scheduler_ident_by_processor( 1, &scheduler_id );
@@ -682,12 +676,7 @@ static void RtemsSignalReqCatch_Setup( RtemsSignalReqCatch_Context *ctx )
     sc = rtems_task_set_scheduler( ctx->worker_id, scheduler_id, 1 );
-      ctx->worker_id,
-      Worker,
@@ -702,15 +691,8 @@ static void RtemsSignalReqCatch_Setup_Wrap( void *arg )
 static void RtemsSignalReqCatch_Teardown( RtemsSignalReqCatch_Context *ctx )
-  sc = rtems_signal_catch( NULL, RTEMS_DEFAULT_MODES );
+  RestoreRunnerASR();
 static void RtemsSignalReqCatch_Teardown_Wrap( void *arg )
diff --git a/testsuites/validation/tc-signal-send.c b/testsuites/validation/tc-signal-send.c
index 76ef5ead16..777143cf48 100644
--- a/testsuites/validation/tc-signal-send.c
+++ b/testsuites/validation/tc-signal-send.c
@@ -54,6 +54,8 @@
@@ -217,36 +219,6 @@ static const char * const * const RtemsSignalReqSend_PreDesc[] = {
 typedef RtemsSignalReqSend_Context Context;
-typedef enum {
-  PRIO_HIGH = 1,
-  PRIO_NORMAL
-} Priorities;
-static rtems_event_set Wait( void )
-  events = 0;
-    RTEMS_ALL_EVENTS,
-    RTEMS_NO_TIMEOUT,
-    &events
-  return events;
 static void WorkerDone( const Context *ctx )
 #if defined(RTEMS_SMP)
@@ -262,7 +234,7 @@ static void SendEventsToWorker( const Context *ctx, rtems_event_set events )
   if ( rtems_scheduler_get_processor_maximum() > 1 ) {
-    events = Wait();
     T_eq_u32( events, EVENT_WORKER_DONE );
 #endif
@@ -293,12 +265,12 @@ static void SignalHandler( rtems_signal_set signal_set )
       WorkerDone( ctx );
-      events = Wait();
       T_eq_u32( events, EVENT_SEND_DONE );
       WorkerDone( ctx );
-      events = Wait();
       T_eq_u32( events, EVENT_DO_ENABLE );
     } else {
       sc = rtems_signal_catch( ctx->handler, RTEMS_NO_ASR );
@@ -321,7 +293,7 @@ static void Worker( rtems_task_argument arg )
-    events = Wait();
     T_eq_u32( events, EVENT_START );
     if ( ctx->nested != 0 ) {
@@ -343,12 +315,12 @@ static void Worker( rtems_task_argument arg )
       WorkerDone( ctx );
-      events = Wait();
       WorkerDone( ctx );
-      events = Wait();
       sc = rtems_task_mode( mode, RTEMS_ASR_MASK, &mode );
@@ -357,7 +329,7 @@ static void Worker( rtems_task_argument arg )
       WorkerDone( ctx );
-    events = Wait();
     T_eq_u32( events, EVENT_END );
     WorkerDone( ctx );
@@ -659,26 +631,13 @@ static void RtemsSignalReqSend_Post_Recursive_Check(
 static void RtemsSignalReqSend_Setup( RtemsSignalReqSend_Context *ctx )
   ctx->runner_id = rtems_task_self();
-  prio = 0;
-    PRIO_HIGH,
-    &ctx->worker_id
@@ -692,8 +651,7 @@ static void RtemsSignalReqSend_Setup( RtemsSignalReqSend_Context *ctx )
   #endif
 static void RtemsSignalReqSend_Setup_Wrap( void *arg )
@@ -707,18 +665,8 @@ static void RtemsSignalReqSend_Setup_Wrap( void *arg )
 static void RtemsSignalReqSend_Teardown( RtemsSignalReqSend_Context *ctx )
-  prio = 0;
 static void RtemsSignalReqSend_Teardown_Wrap( void *arg )
2.26.2
