GSoC Project : Package Micro-python
Mon Mar 22 16:50:21 UTC 2021
On Mon, Mar 22, 2021 at 11:30 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Sat, Mar 20, 2021 at 12:33 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> > Hello Everyone,
> > I wanted to take Packaging Micro Python up as GSOC project this summer
> and the project will also include packaging LUA and picoC
> > The ticket for Micro Python  : https://devel.rtems.org/ticket/4349
> > What would be the complete Scope of the project?
> > And what would be a good starting point?
> Well, I guess Joel must have described the task, so I'll leave it to
> him to fill in some more details.
> Adding RSB packages may be not sufficient coding work for GSoC. It is
> important in the proposal to identify what would be the coding
> activities involved in this project. For example, we know from
> experience that Lua can just be built from some minor tailoring of its
> Makefile, so the package is very straightforward. However, the
> projects you mention are scripting environments, so maybe creating a
> framework in RTEMS for a "shell/intepreter" that can be built as an
> add-on by RSB would be a proper way to scope this effort.
I agree that Lua and Micropython should build easy but I had more
in mind.
The full project was language stacks for RTEMS with a better user
experience for Micropython, Lua, Tcl, etc although I am not sure what
etc would entail. I am not sure all three can be completed in the new
GSoC timeframe. All would follow the same pattern:
+ RSB package offering a reasonable default and access to configuration
+ Examples including at least bare embedded, use of custom commands,
and integrating with RTEMS shell commands Perhaps  interactive use with
command line history and editing integrated if we have that as a library
now.
+ Documentation specific to RTEMS and the examples
I imagined completely parallel kits for each embedded language we wanted
to support.
Does that help? Should he plan on Micropython and Lua?
--joel
> > Thanks
> > - Eshan
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210322/340b5312/attachment-0001.html>
