[PATCH rtems-docs v3 1/6] prefixes: Update installation prefix
Mon Mar 22 17:41:18 UTC 2021
Hi Chris,
I wonder what is your opinion, should we bump these tutorials with
every version? And, is the find/replace of the commands the best way
to do this?
I feel like this topic comes up now and again. Maintaining these
examples is a little fragile.
@Ida: Thanks for the patches, now we'll need to determine if we want
to bump these examples like this, and whether we should consider a
better way to maintain this stuff in the future.
Gedare
On Sat, Mar 20, 2021 at 12:55 PM Ida Delphine <idadelm at gmail.com> wrote:
>  user/start/prefixes.rst | 8 ++++----
>  1 file changed, 4 insertions(+), 4 deletions(-)
> diff --git a/user/start/prefixes.rst b/user/start/prefixes.rst
> index 67255d0..826ce85 100644
> --- a/user/start/prefixes.rst
> +++ b/user/start/prefixes.rst
> @@ -40,7 +40,7 @@ applications and systems.
>  You build and install the tool suite with the :ref:`RTEMS Source Builder (RSB)
>  <RSB>`.  By default, the RSB will start the prefix path with a host operating
>  system specific path plus :file:`rtems`, and the RTEMS version, e.g.
> -:file:`/opt/rtems/5` on Linux, and :file:`/usr/local/rtems/5` on FreeBSD and
> +:file:`/opt/rtems/6` on Linux, and :file:`/usr/local/rtems/6` on FreeBSD and
>  macOS. Placing the RTEMS version number in the path lets you manage and
>  migrate RTEMS versions as they are released.
> @@ -50,10 +50,10 @@ make sure that your normal user has sufficient privileges to create files and
>  directories under the prefix.  For example, you can create a directory
>  :file:`/opt/rtems` and give it to a developer group with read, write, and
>  execute permissions.  Alternatively, you can choose a prefix in your home
> -directory, e.g. :file:`$HOME/rtems/5` or with a project-specific component
> -:file:`$HOME/project-x/rtems/5`.  For more ideas, see the :ref:`project
> +directory, e.g. :file:`$HOME/rtems/6` or with a project-specific component
> +:file:`$HOME/project-x/rtems/6`.  For more ideas, see the :ref:`project
>  sandboxing <ProjectSandboxing>` section.  In this quick start chapter, we will
> -choose :file:`$HOME/quick-start/rtems/5` for the RTEMS tool suite prefix.
> +choose :file:`$HOME/quick-start/rtems/6` for the RTEMS tool suite prefix.
>  .. warning::
> 2.25.1
> devel mailing list
> devel at rtems.org
