rtems-test not running tests for leon3
Ryan Long
ryan.long at oarcorp.com
Tue Mar 23 15:32:08 UTC 2021
I’m on the master branch of rtems-tools, but the output is the same when I run it from the rtems-test included in tools/bin.
I got it to run with sparc-rtems6-sis, though.
Sent: Tuesday, March 23, 2021 9:22 AM
To: Ryan Long <ryan.long at oarcorp.com>
Cc: rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: rtems-test not running tests for leon3
Are you sure this is the master for RTEMS test?
The sis simulator has been out of gdb for a while. I would hope the tester configuration is gone. But apparently it isn't. You shouldn't use leon3. It needs to be removed.
Use leon3-sis or leon3-qemu
On Tue, Mar 23, 2021, 9:07 AM Ryan Long <ryan.long at oarcorp.com<mailto:ryan.long at oarcorp.com>> wrote:
Hi,
I’ve been trying to run the tests for leon3, but the only test that runs properly is the minimum test. All of the others produce output like so in the log file.
[334/597] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:329 W:0 | sparc/leon3: nsecs.exe
Result: invalid Time: 0:00:02.754956 nsecs.exe
=> gdb: /home/rlong/rtems-work/tools/bin/sparc-rtems6-gdb -i=mi --nx --quiet rtems/build/sparc/leon3/testsuites/samples/nsecs.exe
=> Reading symbols from rtems/build/sparc/leon3/testsuites/samples/nsecs.exe...
=> target sim -leon3
=> Undefined target command: "sim -leon3". Try "help target".
=> quit
Does anyone know how to run these?
And should I file a ticket for this and fix it in rtems-test?
Thanks,
Ryan
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/5e323078/attachment-0001.html>
